Demul not working on hyperspin
handsome1987
I have the demul emulator for my dreamcast games and i have it perfectly worked in rocketlauncher.
But in hyperspin when i choose a game nothing is happend.
When i quit hyperspin i see in my taskbar hyperlaunch. I have to exit it manually.
Does anyone know what i am doing wrong?
Thank u for the answer its working now!!
I had to change my hyperlaunch.exe into my rocketlauncher.exe so that hyperspin thinks that my hyperlaunch.exe is the launcher but its loaded rocketlauncher.exe.
Now its finally working!!
What? You just renamed your exe instead of changing the path like Agent said? That's not the right way to do it.
...or maybe I misunderstood you.
I copied my rocketlauncher.exe so i got a copy of that and i renamed it to hyperlaunch.exe and it worked perfect.Because in my settings its pointed to the map where rocketlauncher.exe and hyperlaunch.exe is but with the Original hyperlaunch it doesnt work. And i cant set it to rocketlauncher.exe there.
My guess is that will cause you a bunch of issues and problems down the road. And if it does I hate to think how hard it might possibly be to fix later, when it should be so simple to fix now by just installing it and setting it up right. Did you try changing the HyperSpin/Settings/Settings.ini like you should?
My settings are pointing to the rocktlaucher map but then it will use the hyperlaunch.exe and then its not working. Which line do you have by hyperlaunch-path?
I followed the tutorial on the youtube link and its working great now ty!!.
I only have 1 question i have future pinball and visual pinball on my hyperspin and rocketlauncher. When i launch a table and close it immediately rocketlauncher will not close.
If i start a table or wait a second of 5 and then close then rocketlauncher will exit.
So do you know if i can change something so when i close a table immediately also rocketlauncher will exit?
