tscottn Posted July 13, 2016 Posted July 13, 2016 Hello all. So after a major HDD Loss of about 7TB of data on my main Hyperspin HDD I am now in the process of re downloading and setting up a new drive,( with a better backup system) I have started to set up a few systems and here is the problem I am running into right off the bat; I have mame setup in RL and Hyperspin setup as my FE. I have my xpadder profile setup for my controller in both the global and the mame tab in keymapper tab in the RLUI. If I start a game in mame directly from the mame / game tab in RLUI the mame xpadder profile loads just fine... However........ If I start hyperspin my Hyperspin xpadder profile loads as it should and I can navigate the main menu wheel but when I select my mame wheel and start a game, the mame xpadder profile will not load at all. xpadder just stays on the hyperspin FE profile. Its weird because playing directly from the RLUI will load the correct system profile, but not from Hyperspin itself. I believe I have all the settings correct and key mappers enabled and correct paths to profiles and xpadder setup in RLUI, Especially since RLUI will load the correct profile, just not Hyperspin. But Like i said, Hyperspin will load the FE profile but not the system, profile.. Any help would be greatly appreciated.. Thanks
32assassin Posted July 13, 2016 Posted July 13, 2016 you mighty want to check your MAME HyperHQ settings, you might have MAME loading directly (aka = not using Rocketlauncher). if this is the case your controller profile or anything RL related will not work.
tscottn Posted July 13, 2016 Author Posted July 13, 2016 Well it seemed that that was my issue, Thanks 32Assassin. !!!!!
