atrain9 Posted July 19, 2016 Posted July 19, 2016 Recently I obtained a smashing drive cab missing the crt monitor. I put a LCD tv in via vga input and hooked up everything and the smashing drive game plays fine. I decided to get a little adventageous and hooked up a pc running hyperspin so i could use the gas and brake peddles on the smashing drive hooked up via A-Pac USB (to pc)along with a xbox 360 wireless speed wheel (to pc microsoft wireless dongle)for steering wheel use. Everything works fine through mame. with that being said i can play smashing drive original game and switch over to pc on the hdmi input. My issue is with sega model emulators when i try and configure the gas and brake peddles.......my gas and brake peddels register as joy6. Sega model emulators only recognize or let you configure joy1...I think ??? I have a few usb gamepads (retro pads ) and light gun hooked up currently so Im thinking that could be issue ? Any help would be appreciated:)
32assassin Posted July 19, 2016 Posted July 19, 2016 you should consider using keymapper software such as joy2key or xpadder. this are the only systems in witch I had to create a single profile for each game given that some are gun games, some are racing games others are joystick games. rocketlauncher has a feature witch it lets you specify with controller you use for any given system. once you specified Joy6 as your default joystick (for this systems) you can load the game specificity keymaper profile for each game to Joy6.
