Anumogabe Posted August 1, 2016 Posted August 1, 2016 I recently updated from Hyperspin 1.3 to 1.4 and changed from HyperLauncher to RocketLauncher. After following all the tutorials none of the games will load. Every time I tinker with it I get different errors, but the upshot seems to be with either the databases or the modules. I have pasted a copy of the log when I try to launch a MAME game: 12:57:46:288 | RL | INFO | +N/A | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com) 12:57:46:389 | RL | WARNING | +94 | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance. 12:57:49:658 | RL | DEBUG | +3265 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 12:57:49:758 | RL | DEBUG | +110 | Registry.Read - Registry Read finished, returning 0 12:57:49:828 | RL | INFO | +62 | Main - System Specs: RocketLauncher Dir: H:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 10 Home SKU: Windows 8 Total Memory: 16327.07 MB Free Memory: 11347.18 MB Used Memory: 4979.895 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: NVIDIA GeForce GTX 980 GPU 1 RAM: -1.00 MB GPU 1 Driver Version: 10.18.13.6881 Sound 1 Device: Realtek High Definition Audio Sound 1 Status: Enabled Sound 2 Device: NVIDIA High Definition Audio Sound 2 Status: Enabled Sound 3 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 3 Status: Enabled OS Language: English_United_Kingdom System Locale: en-GB Formats Locale: en-GB Windows UI Language: en-GB Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) [32bit] [60hz] [Landscape] (Primary) Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 Monitor #1 DPI: 100 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 12:57:49:928 | RL | INFO | +110 | CheckFile - Checking if H:\RocketLauncher\RocketLauncher.exe exists 12:57:50:269 | RL | INFO | +328 | Main - Raw CLI received: "-s MAME -r 1943 -f H:\Hyperspin\HyperSpin.exe -p HyperSpin -c 1 -o 1" 12:57:50:609 | RL | TRACE | +344 | File.__New - Creating new file object of: "H:\RocketLauncher\Module Extensions\RocketLauncher.dll" 12:57:50:684 | RL | INFO | +78 | File.CheckFile - Checking if "H:\RocketLauncher\Module Extensions\RocketLauncher.dll" exists 12:57:50:821 | RL | TRACE | +140 | File.Exist - This file exists: H:\RocketLauncher\Module Extensions\RocketLauncher.dll 12:57:50:901 | RL | INFO | +78 | CRC Check - CRC matches, this is an official unedited Extension: H:\RocketLauncher\Module Extensions\Array.ahk 12:57:51:049 | RL | INFO | +141 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Module Extensions\BinHexRW.ahk | v1.0.2 12:57:51:188 | RL | INFO | +141 | CheckFile - Checking if H:\RocketLauncher\Module Extensions\BlockInput.exe exists 12:57:51:285 | RL | INFO | +93 | CRC Check - CRC matches, this is an official unedited Extension: H:\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop 12:57:51:472 | RL | INFO | +188 | CRC Check - CRC matches, this is an official unedited Extension: H:\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk 12:57:51:630 | RL | INFO | +172 | CRC Check - CRC matches, this is an official unedited Extension: H:\RocketLauncher\Module Extensions\gdip.ahk 12:57:51:785 | RL | INFO | +140 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Module Extensions\gdip_alt.ahk | v1.0.3 12:57:51:788 | RL | INFO | +16 | CheckFile - Checking if H:\RocketLauncher\Module Extensions\gsdll32.dll exists 12:57:51:798 | RL | INFO | +0 | CheckFile - Checking if H:\RocketLauncher\Module Extensions\itextsharp.dll exists 12:57:51:821 | RL | INFO | +31 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Module Extensions\Java.ahk | v1.0.0 12:57:51:835 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Extension: H:\RocketLauncher\Module Extensions\JSON.ahk 12:57:51:850 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Module Extensions\Origin.ahk | v1.0.2 12:57:51:864 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: H:\RocketLauncher\Module Extensions\RegRW64.ahk 12:57:51:880 | RL | INFO | +31 | CRC Check - CRC matches, this is an official unedited Extension: H:\RocketLauncher\Module Extensions\RIni.ahk | v1.7 12:57:51:882 | RL | INFO | +0 | CheckFile - Checking if H:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists 12:57:51:907 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Module Extensions\Steam.ahk | v1.0.3 12:57:51:929 | RL | INFO | +32 | CRC Check - CRC matches, this is an official unedited Extension: H:\RocketLauncher\Module Extensions\VA.ahk 12:57:51:954 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Module Extensions\VA_Extension.ahk | v1.0.1 12:57:51:968 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\7z.ahk | v1.1.0 12:57:52:063 | RL | INFO | +94 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Bezel.ahk | v1.2.5 12:57:52:090 | RL | INFO | +31 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Fade.ahk | v1.1.9 12:57:52:107 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Fade Init.ahk | v1.0.3 12:57:52:133 | RL | INFO | +31 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Fade Animations.ahk | v1.2.4 12:57:52:151 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Keymapper.ahk | v1.1.5 12:57:52:171 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Keymapper Init.ahk | v1.0.6 12:57:52:200 | RL | INFO | +31 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\MultiGame.ahk | v1.1.0 12:57:52:224 | RL | INFO | +32 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\MultiGame Init.ahk | v1.0.0 12:57:52:236 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\MultiPlayer.ahk | v1.0.8 12:57:52:346 | RL | INFO | +109 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Pause.ahk | v1.2.4 12:57:52:369 | RL | INFO | +31 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Pause Init.ahk | v1.0.3 12:57:52:391 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Password.ahk | v1.0.4 12:57:52:407 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk | v1.7.1 12:57:52:428 | RL | INFO | +32 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Log\Logger.ahk | v1.1.0 12:57:52:442 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk | v1.1.1 12:57:52:467 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk | v1.0.0 12:57:52:492 | RL | INFO | +31 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk | v1.5.1 12:57:52:516 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk | v1.0.0 12:57:52:529 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\File\File.ahk | v1.6.0 12:57:52:554 | RL | INFO | +32 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\File\Folder.ahk | v1.0.0 12:57:52:576 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk | v1.0.0 12:57:52:591 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk | v1.1.1 12:57:52:616 | RL | INFO | +31 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\File\Process.ahk | v1.5.0 12:57:52:639 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk | v1.1.0 12:57:52:654 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk | v1.0.1 12:57:52:678 | RL | INFO | +32 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\UI\Control.ahk | v1.2.0 12:57:52:703 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\UI\Window.ahk | v1.2.0 12:57:52:727 | RL | INFO | +32 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk | v1.0.0 12:57:52:742 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk | v1.0.7 12:57:52:767 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Shader.ahk | v1.0.1 12:57:52:790 | RL | INFO | +31 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Shader Init.ahk | v1.0.0 12:57:52:809 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Shared.ahk | v1.4.7 12:57:52:828 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Statistics.ahk | v1.0.4 12:57:52:849 | RL | INFO | +32 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Statistics Init.ahk | v1.0.1 12:57:52:860 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\Virtual Drive.ahk | v1.0.5 12:57:52:884 | RL | INFO | +31 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\XHotkey.ahk | v1.0.4 12:57:52:910 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: H:\RocketLauncher\Lib\XHotkey Init.ahk | v1.0.2 12:57:52:912 | RL | DEBUG | +16 | Main - Received this dbName with no path via CLI: "1943" 12:57:52:914 | RL | DEBUG | +0 | Main - dbName: 1943 12:57:52:916 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 12:57:52:918 | RL | TRACE | +0 | Process.__New - Creating new process object for: "H:\Hyperspin\HyperSpin.exe" 12:57:52:920 | RL | TRACE | +0 | File.__New - Creating new file object of: "H:\Hyperspin\HyperSpin.exe" 12:57:52:938 | RL | INFO | +16 | Main - RocketLauncher received "MAME" and "1943" 12:57:52:947 | RL | INFO | +15 | Main - Did not find a "H:\RocketLauncher\Settings\MAME\Game Options.ini" file, skipping any game-specific options. 12:57:52:949 | RL | INFO | +0 | Main - 1943 is using the default emulator: MAME 12:57:52:951 | RL | INFO | +0 | Main - Checking for a [MAME] section in H:\RocketLauncher\Settings\MAME\Emulators.ini 12:57:52:954 | RL | INFO | +0 | Main - Checking for a [MAME] section in H:\RocketLauncher\Settings\Global Emulators.ini 12:57:52:956 | RL | INFO | +0 | Main - Found [MAME] in H:\RocketLauncher\Settings\Global Emulators.ini 12:57:52:971 | RL | INFO | +16 | CheckFile - Checking if H:\Hyperspin\Modules\MAME\MAME.ahk exists 12:57:52:980 | RL | WARNING | +16 | Main - CRC Check - Module has no CRC defined on the header. 12:57:52:982 | RL | INFO | +0 | Main - 1943 will use module: H:\Hyperspin\Modules\MAME\MAME.ahk 12:57:52:020 | RL | WARNING | +46 | RIniReadCheck - Created missing RocketLauncher ini key: "DemulShooter_Path" in section: "DemulShooter" in "H:\RocketLauncher\Settings\RocketLauncher.ini" 12:57:53:214 | RL | WARNING | +188 | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "H:\RocketLauncher\Settings\Global RocketLauncher.ini" 12:57:53:218 | RL | WARNING | +0 | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "H:\RocketLauncher\Settings\MAME\RocketLauncher.ini" 12:57:53:421 | RL | INFO | +203 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 12:57:53:460 | RL | INFO | +47 | CheckFile - Checking if H:\Hyperspin\emulators\MAME\mame.exe exists 12:57:53:468 | RL | INFO | +0 | Main - INI Keys read 12:57:53:475 | RL | INFO | +16 | CheckFile - Checking if H:\RocketLauncher\Module Extensions\7z.exe exists 12:57:53:483 | RL | INFO | +0 | CheckFile - Checking if H:\RocketLauncher\Module Extensions\7z.dll exists 12:57:53:497 | RL | INFO | +15 | Main - "1943" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 12:57:53:499 | RL | INFO | +0 | CheckPaths - Started 12:57:53:501 | RL | INFO | +0 | CheckPaths - Looking for rom: H:\Hyperspin\emulators\MAME\roms\1943.7z 12:57:53:503 | RL | INFO | +0 | CheckPaths - Looking for rom by name in subfolder: H:\Hyperspin\emulators\MAME\roms\1943\1943.7z 12:57:53:505 | RL | INFO | +16 | CheckPaths - Rom not found 12:57:53:507 | RL | INFO | +0 | CheckPaths - Looking for rom: H:\Hyperspin\emulators\MAME\roms\1943.rar 12:57:53:518 | RL | INFO | +0 | CheckPaths - Looking for rom by name in subfolder: H:\Hyperspin\emulators\MAME\roms\1943\1943.rar 12:57:53:520 | RL | INFO | +0 | CheckPaths - Rom not found 12:57:53:522 | RL | INFO | +15 | CheckPaths - Looking for rom: H:\Hyperspin\emulators\MAME\roms\1943.zip 12:57:53:524 | RL | INFO | +0 | CheckPaths - Found rom: H:\Hyperspin\emulators\MAME\roms\1943.zip 12:57:53:526 | RL | DEBUG | +0 | CheckPaths - Current romName: 1943 12:57:53:528 | RL | DEBUG | +0 | CheckPaths - Current romPath: H:\Hyperspin\emulators\MAME\roms 12:57:53:530 | RL | DEBUG | +0 | CheckPaths - Current romExtension: .zip 12:57:53:532 | RL | INFO | +0 | CheckPaths - Ended 12:57:53:534 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 12:57:53:536 | RL | INFO | +16 | BuildScript - Loaded Statistics Init.ahk scripts 12:57:53:537 | RL | WARNING | +0 | BuildScript - "H:\RocketLauncher\Lib\User Functions Init.ahk" not found 12:57:53:539 | RL | DEBUG | +0 | BuildScript - Module starts on line: 2 12:57:53:542 | RL | INFO | +0 | BuildScript - Validating module 12:57:53:545 | RL | INFO | +0 | BuildScript - Validation complete 12:57:53:881 | RL | DEBUG | +344 | ScriptError - Playing error sound: error8.mp3 12:58:01:012 | RL | ERROR | +7125 | Your module does not contain a "StartModule()" line. Please download a module that has one. 12:58:01:015 | RL | INFO | +0 | ExitScript - Started 12:58:01:125 | RL | DEBUG | +109 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 12:58:01:128 | RL | DEBUG | +0 | Registry.Read - Registry Read finished, returning 0 12:58:01:131 | RL | TRACE | +16 | StringUtils.Contains - "false" does not contain "true|kill" 12:58:01:132 | RL | INFO | +0 | ExitScript - Restoring taskbar 12:58:01:134 | RL | TRACE | +0 | Window.__New - Created: "ahk_class Shell_TrayWnd" 12:58:01:137 | RL | TRACE | +0 | Window.__New - Created: "Start ahk_class Button" 12:58:01:139 | RL | TRACE | +0 | Window.Show - Unhiding window "ahk_class Shell_TrayWnd" 12:58:01:240 | RL | TRACE | +109 | Window.Show - Unhiding window "Start ahk_class Button" 12:58:01:253 | RL | INFO | +0 | SystemCursor - Restoring mouse cursor 12:58:01:266 | RL | INFO | +16 | ExitScript - Restored cursor I would be grateful for any assistance as everything was working fine under the old version. Cheers in advance.
JoyStickKilla Posted August 1, 2016 Posted August 1, 2016 Hmmm well it would help if you posted what your actual issue is/what errors you are getting and what part of the process you are getting them. But hunting through the log real quick I see maybe a bad RL install, at least that is what it looks like to me as it seems to be missing files.
xxoazarxx Posted August 4, 2016 Posted August 4, 2016 bonjour quelqu un pourai m aider s il vous plait
