Xbox 360 joystick and spinning menus bug
freeky
Hi, I'm a new hyperspinner learning the ropes.
I ran into the spinning menus bug in hyperspin which is caused by enabling joysticks in hyperHQ. The problem is that I exclusively use joysticks for couch gaming and already have all of my emulators and pc games setup to use the wireless Xbox 360 controllers.
I have tried to use joytokey to setup a profile in rocketlauncher but it hasn't worked very well.
I've searched all over teh place and haven’t found a fix.
Is there a way to map my Xbox 360 control to emulate keyboard keys only in the Hyperspin menu? I want the Xbox control to go back to normal when I launch an emulator or game.
I have the same problem after updating the Windows 10 upgrade anniversary edition, without solution.
Try what agent47 posted. It should fix you right up. I'm using windows 10 and the startup script and it works great.
Check out my MAME Arcade classics themes
It has been fixed, thank you very much for the help.  :thumbsup:
thanks for pointing me in the right direction. I feel so dumb when I can't figure out a tutorial. I added the script in hyperhq and pointed the ini file to rocket launcher but nothing seems to happen.
You want to point it at the folder that has your HyperSpin.exe file.Then you want to make sure that Joysticks_Enabled is set to true in the script ini file. Make sure you also have the script exe file set in the startup tab in HyperHQ.
I restarted the computer the next day and no longer worked any way. I reinstalled the startup-script and configured (Joysticks_Enabled = true, set start button and the root of the Hyperspin folder) and does not work, it's weird because I left yesterday running ...
