acpowell Posted August 26, 2016 Posted August 26, 2016 Good day all, I currently have mame running in hyperspin and was trying to get daphne added. I can run the games with daphne loader just fine (short of dragons layer having no sound with the latest daphne) but when I try to open the game in rocketlauncher I get command errors and when I launch it in Hyperspin I get an error saying it cannot for the module for daphne. I have exhausted my fingers searching for a way to fix it but nothing works. on a side note, is it possible to add the daphne games to my mame wheel so I don't have 2 wheels?
acpowell Posted August 28, 2016 Author Posted August 28, 2016 I figured it out. Long story short, I moved my folder that had RL/MAME in it, and forgot to change the part in hyperspin that told it where RL was. So on the Daphne being added to the mame wheel part. What ini do I edit and where would I tell it to use an alternate emu?
pinsanity Posted August 29, 2016 Posted August 29, 2016 You have to add each game name for daphne manually to the MAME xml database. Then load up rocketlauncherUI and do a system audit for MAME. The daphne games will be missing and show up as red so you need to add the daphne roms path under the Emulators tab for the MAME system. Then select the games tab for MAME and choose alternate emulators. Each Daphne game needs to be added (using the green plus sign) and setup one at a time using the pop up box and saved individually. e.g. ace Daphne Daphne lair Daphne Daphne etc.
32assassin Posted August 29, 2016 Posted August 29, 2016 you should also add the txt extension to your MAME Global emulator, so that MAME game scan (in RLUI) can find your Daphne games. After you add the rom path to your Dahpne frame files.
acpowell Posted August 30, 2016 Author Posted August 30, 2016 okay, I think I will be tackling that this weekend. I have it working in a separate wheel for now.
