HyperSync help needed
BBBrennaNNN
I've only recently became a platinium member as well as a member for emumovies. Previously when I loaded HyperSync I login as a regular member for HyperBase but did not login for emumovies. I saved my login so each time I login/logout it auto logins into my Hyperbase account but not emumovies account. How do I fix this? thanks in advance!
Sorry I'm slightly confused. So before becoming a platinum member and a lifetime member of emumovies you were able to log into HyperSync but now you are a paid up member you can't?
If you have triple checked your log in details and your not using a password with special characters then you probably need to start a support ticket to the relevant forum.
Can you log on the ftp?
hmm ok let me rephrase. there is no problem login into hypersync! but there are 2 parts of that. 1 is my account from hyperspin. the other is emumovies tab. previously i login under hyperspin but not into my emumovies account. now when i login it only logins the hyperspin account and i cant go to the place to login my emumovies (the place where i type my userid/password). how do i get back to this page to type my userid/password?
thanks for the quick reply gigapig (btw i've been following your guide on installing PC games!)
You would click on the icon next to the arcade machine in HyperSync and then get your 2 accounts pop up. If you don't the take a look at the "application.ini" file found in C:\Users\name\AppData\Roaming\HyperSync, that file should have your accounts details.
