dummel Posted September 3, 2016 Posted September 3, 2016 hello, I have a healthy system and began working on getting 'jessie' shaders working. interesting thing; if i enable the HLSL settings, they look great! but... the Games are on some kind of light speed setting! everything is zooming around! if i disable HLSL everything goes back to normal. i have looked for some obvious switch to bring me out of 'nuclear speed level 3' when using hlsl, but have yet to find it. has anyone out there come across this issue?
Suhrvivor Posted September 3, 2016 Posted September 3, 2016 Make sure throttle is set to 1 (on) in mame.ini
dummel Posted September 3, 2016 Author Posted September 3, 2016 thank you for the response - that setting is correct in my original file # CORE PERFORMANCE OPTIONS # autoframeskip 0 frameskip 0 seconds_to_run 0 throttle 1 syncrefresh 1 sleep 1 speed 1.0 refreshspeed 1
Suhrvivor Posted September 3, 2016 Posted September 3, 2016 My ini file doesn't have syncrefresh, Is that a recent feature? I use MAME 0.175 btw. (latest at the time of this post was 177).
DemonEyeX Posted September 7, 2016 Posted September 7, 2016 I had a similar problem with BGFX.It was VSync.Dunno if that helps, but I thought I would throw it out there.
dummel Posted September 8, 2016 Author Posted September 8, 2016 awesome! thank you! that was the issue
