Having issues running Retro Arch through Hyperspin
dyspare
Hello,
I am having a problem thats causing me alot of grief. I can not find an answer anywhere.
I am Using Hyperspin as my front end, obviously, and trying to run a sega genesis game from retro arch. It shows a loading screen with a progress bar, then after it hits 100% is crashes to desktop and tells me that windows is searching for the problem. But never gives any answers. I got an error log file from rocketlauncher that says:
RetroArch [ERROR] :: gfx_ctx_init :: Failed to bind API (#0, version 0.0) on context driver "d3d".
But retro Arch is set to "gl"
Even if I set it to "D3d" it proceeds to a blank screen where i can here the sounds of the game but I can see only black?
Someone please have an answer for me
Are you able to load games directly through Retroarch outside of RL/HS? It sounds like you need to install DirectX and/or update your gpu drivers.
I can load retro arch outside of RL/HS.  I have the current gpu driver and i just re-downloaded directx  9c and installed again. it instantly said it was installed.  tried retro arch over and over. I keep getting the same error situation.
RetroArch: rarch_log_libretro: [libretro INFO] :: Frontend supports RGB565 - will use that instead of XRGB1555.
RetroArch: rarch_log_libretro: [libretro INFO] :: [genplus]: Defaulting system directory to J:\Temp files\Aladdin (E) [!].
RetroArch: rarch_log_libretro: [libretro INFO] :: Game Genie ROM should be located at: J:\Temp files\Aladdin (E) [!]\ggenie.bin
RetroArch: rarch_log_libretro: [libretro INFO] :: Action Replay (Pro) ROM should be located at: J:\Temp files\Aladdin (E) [!]\areplay.bin
RetroArch: rarch_log_libretro: [libretro INFO] :: Sonic & Knuckles (2 MB) ROM should be located at: J:\Temp files\Aladdin (E) [!]\sk.bin
RetroArch: rarch_log_libretro: [libretro INFO] :: Sonic & Knuckles UPMEM (256 KB) ROM should be located at: J:\Temp files\Aladdin (E) [!]\sk2chip.bin
RetroArch: rarch_log_libretro: [libretro INFO] :: Mega CD PAL BIOS should be located at: J:\Temp files\Aladdin (E) [!]\bios_CD_E.bin
RetroArch: rarch_log_libretro: [libretro INFO] :: Sega CD NTSC-U BIOS should be located at: J:\Temp files\Aladdin (E) [!]\bios_CD_U.bin
RetroArch: rarch_log_libretro: [libretro INFO] :: Mega CD NTSC-J BIOS should be located at: J:\Temp files\Aladdin (E) [!]\bios_CD_J.bin
RetroArch: rarch_log_libretro: [libretro INFO] :: Mega CD PAL BRAM is located at: J:\Temp files\Aladdin (E) [!]\scd_E.brm
RetroArch: rarch_log_libretro: [libretro INFO] :: Sega CD NTSC-U BRAM is located at: J:\Temp files\Aladdin (E) [!]\scd_U.brm
RetroArch: rarch_log_libretro: [libretro INFO] :: Mega CD NTSC-J BRAM is located at: J:\Temp files\Aladdin (E) [!]\scd_J.brm
RetroArch: rarch_log_libretro: [libretro INFO] :: Mega CD RAM CART is located at: J:\Temp files\Aladdin (E) [!]\cart.brm
RetroArch: rarch_log_libretro: [libretro INFO] :: INFORMATION - Loading 2097152 bytes ...
im just noticing that it is using a directory of \temp files\
that is not the correct directory for retro arch. unless this is just a normal retro arch or rocketlauncher functon
is this it?
19:18:01:994 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com)
19:18:01:996 | RL |   WARNING  | +0     | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance.
19:18:02:229 | RL |     DEBUG  | +234   | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32
19:18:02:230 | RL |     DEBUG  | +0     | Registry.Read - Registry Read finished, returning 0
19:18:02:233 | RL |      INFO  | +0     | Main - System Specs:
RocketLauncher Dir: J:\My Files\RocketLauncher
RocketLauncher is: 32-bit
OS: Microsoft Windows 7 Home Premium
SKU: Home Premium
Total Memory: 16316.50 MB
Free Memory: 9645.73 MB
Used Memory: 6670.770 MB
SystemType: 64-bit
Physical Processors: 1
Logical Processors: 8
GPU 1 Name: ATI Mobility Radeon HD 5850
GPU 1 RAM: -2048.00 MB
GPU 1 Driver Version: 8.741.1.5000
Sound 1 Device: Turtle Beach Z300 with Dolby Headphone
Sound 1 Status: Enabled
Sound 2 Device: ATI High Definition Audio Device
Sound 2 Status: Enabled
Sound 3 Device: Realtek High Definition Audio
Sound 3 Status: Enabled
System Locale: en-US
Formats Locale: en-US
Windows UI Language: en-US
Text Encoding: Windows-1252
OS Admin Status: No
RL Compatibility Flags:  HIGHDPIAWARE
Latest .Net Version: v4.0.30319
Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1080 work) [32bit] [60hz] [Landscape]
Monitor #2 (\\.\DISPLAY2): 1920x1080 (1920x1080 work) [32bit] [60hz] [Landscape]  (Primary)
Current AHK Desktop Width: 1920
Current AHK Desktop Height: 1080
Monitor #1 DPI: 125
Monitor #2 DPI: 125
ErrorMode: 0
AutoHotkey Path:
AHK Version: 1.1.13.00
Unicode: No
19:18:02:235 | RL |      INFO  | +0     | CheckFile - Checking if J:\My Files\RocketLauncher\RocketLauncher.exe exists
19:18:02:243 | RL |     DEBUG  | +16    | CheckFile - Attributes:
FileDescription          RocketLauncher
FileVersion              1.1.1.1
LegalCopyright           ©2016 RocketLauncher
ProductName              djvj's one swell guy!
ProductVersion           1.1.1.1
CompanyName              Your favorite Front End companion! Visit us @ www.rlauncher.com
File Size: 2179584 bytes
Created: 9/10/2016 - 4:01:19 PM
Modified: 9/10/2016 - 4:23:40 PM
19:18:02:245 | RL |      INFO  | +0     | Main - Raw CLI received: "-s Sega Genesis -r Aladdin (E) [!] -f J:\My Files\Hyperspin\HyperSpin.exe -p HyperSpin -c 1 -o 1"
19:18:02:253 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "J:\My Files\RocketLauncher\Module Extensions\RocketLauncher.dll"
19:18:02:260 | RL |      INFO  | +16    | File.CheckFile - Checking if "J:\My Files\RocketLauncher\Module Extensions\RocketLauncher.dll" exists
19:18:02:263 | RL |     TRACE  | +0     | File.Exist - This file exists: J:\My Files\RocketLauncher\Module Extensions\RocketLauncher.dll
19:18:02:265 | RL |     DEBUG  | +0     | File.CheckFile - Attributes:
FileDescription          RocketLauncher Utils
FileVersion              1.0.0.9
InternalName             RocketLauncher.dll
LegalCopyright           Copyright © RocketLauncher 2013-2016
OriginalFilename         RocketLauncher.dll
ProductName              RocketLauncher
ProductVersion           1.0.0.9
File Size: 68608 bytes
Created: 9/10/2016 - 4:01:28 PM
19:18:02:280 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Extension: J:\My Files\RocketLauncher\Module Extensions\Array.ahk
19:18:02:282 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 4781 bytes
Created: 9/10/2016 - 4:01:26 PM
Modified: 9/10/2016 - 4:23:42 PM
19:18:02:292 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Module Extensions\BinHexRW.ahk | v1.0.2
19:18:02:294 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5077 bytes
Modified: 9/10/2016 - 4:23:36 PM
19:18:02:297 | RL |      INFO  | +0     | CheckFile - Checking if J:\My Files\RocketLauncher\Module Extensions\BlockInput.exe exists
19:18:02:304 | RL |     DEBUG  | +0     | CheckFile - Attributes:
FileDescription
FileVersion              1.1.09.04
InternalName
OriginalFilename
ProductName
ProductVersion           1.1.09.04
File Size: 657920 bytes
Modified: 1/2/2014 - 11:27:34 PM
19:18:02:314 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Extension: J:\My Files\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop
19:18:02:317 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5323 bytes
Modified: 9/10/2016 - 4:23:45 PM
19:18:02:326 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: J:\My Files\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk
19:18:02:329 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5716 bytes
Modified: 4/29/2013 - 2:56:02 PM
19:18:02:342 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: J:\My Files\RocketLauncher\Module Extensions\gdip.ahk
19:18:02:344 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 88789 bytes
Modified: 1/13/2013 - 6:07:30 PM
19:18:02:354 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Module Extensions\gdip_alt.ahk | v1.0.3
19:18:02:356 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5891 bytes
Created: 9/10/2016 - 4:01:27 PM
Modified: 12/21/2015 - 12:08:03 AM
19:18:02:358 | RL |      INFO  | +0     | CheckFile - Checking if J:\My Files\RocketLauncher\Module Extensions\gsdll32.dll exists
19:18:02:366 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 13090816 bytes
Modified: 1/6/2015 - 10:20:42 PM
19:18:02:368 | RL |      INFO  | +16    | CheckFile - Checking if J:\My Files\RocketLauncher\Module Extensions\itextsharp.dll exists
19:18:02:376 | RL |     DEBUG  | +0     | CheckFile - Attributes:
FileDescription          iTextSharp
FileVersion              5.4.2.0
InternalName             itextsharp.dll
LegalCopyright           Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
OriginalFilename         itextsharp.dll
ProductName              iTextSharp
ProductVersion           5.4.2.0
CompanyName              1T3XT BVBA
File Size: 3743744 bytes
Modified: 6/14/2013 - 3:06:21 PM
19:18:02:396 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Module Extensions\Java.ahk | v1.0.0
19:18:02:399 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 7841 bytes
Modified: 12/24/2014 - 12:02:37 AM
19:18:02:409 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: J:\My Files\RocketLauncher\Module Extensions\JSON.ahk
19:18:02:420 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 9227 bytes
Modified: 9/10/2016 - 4:23:38 PM
19:18:02:431 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Module Extensions\Origin.ahk | v1.0.2
19:18:02:434 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 4904 bytes
Modified: 3/22/2015 - 3:51:41 PM
19:18:02:445 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: J:\My Files\RocketLauncher\Module Extensions\RegRW64.ahk
19:18:02:448 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 6915 bytes
Modified: 5/8/2014 - 4:06:39 AM
19:18:02:460 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: J:\My Files\RocketLauncher\Module Extensions\RIni.ahk | v1.7
19:18:02:463 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 67562 bytes
Modified: 9/10/2016 - 4:23:47 PM
19:18:02:465 | RL |      INFO  | +0     | CheckFile - Checking if J:\My Files\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
19:18:02:474 | RL |     DEBUG  | +0     | CheckFile - Attributes:
FileDescription          SevenZipSharp
FileVersion              0.64.5717.6837
InternalName             SevenZipSharp.dll
LegalCopyright           Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
OriginalFilename         SevenZipSharp.dll
ProductName              SevenZipSharp
ProductVersion           0.64.5717.6837
CompanyName              Markovtsev Vadim
File Size: 167424 bytes
Modified: 9/28/2015 - 10:35:11 PM
19:18:02:486 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Module Extensions\Steam.ahk | v1.0.3
19:18:02:489 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5504 bytes
19:18:02:499 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: J:\My Files\RocketLauncher\Module Extensions\VA.ahk
19:18:02:502 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 34688 bytes
Modified: 3/1/2013 - 10:05:47 PM
19:18:02:511 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Module Extensions\VA_Extension.ahk | v1.0.1
19:18:02:514 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3833 bytes
Modified: 1/13/2015 - 9:16:56 PM
19:18:02:524 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\7z.ahk | v1.1.0
19:18:02:526 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 31579 bytes
Created: 9/10/2016 - 4:01:23 PM
Modified: 9/10/2016 - 4:23:43 PM
19:18:02:540 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Bezel.ahk | v1.2.5
19:18:02:543 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 119247 bytes
19:18:02:555 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Fade.ahk | v1.1.9
19:18:02:557 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 39542 bytes
Created: 9/10/2016 - 4:01:24 PM
Modified: 9/10/2016 - 4:23:44 PM
19:18:02:566 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Fade Init.ahk | v1.0.3
19:18:02:570 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 1130 bytes
Modified: 9/10/2016 - 4:23:37 PM
19:18:02:582 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Fade Animations.ahk | v1.2.4
19:18:02:584 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 77966 bytes
19:18:02:595 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Keymapper.ahk | v1.1.5
19:18:02:597 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 33668 bytes
Modified: 9/10/2016 - 4:23:39 PM
19:18:02:606 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Keymapper Init.ahk | v1.0.6
19:18:02:609 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3956 bytes
19:18:02:619 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\MultiGame.ahk | v1.1.0
19:18:02:630 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 41541 bytes
19:18:02:640 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\MultiGame Init.ahk | v1.0.0
19:18:02:643 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 161 bytes
Modified: 4/14/2013 - 2:33:19 PM
19:18:02:665 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\MultiPlayer.ahk | v1.0.8
19:18:02:667 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 66776 bytes
Modified: 12/7/2015 - 6:37:45 AM
19:18:02:692 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Pause.ahk | v1.2.4
19:18:02:694 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 397144 bytes
Modified: 9/10/2016 - 4:23:49 PM
19:18:02:703 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Pause Init.ahk | v1.0.3
19:18:02:706 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 553 bytes
Modified: 8/23/2015 - 8:00:44 PM
19:18:02:725 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Password.ahk | v1.0.4
19:18:02:728 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 10121 bytes
Modified: 9/10/2016 - 4:23:51 PM
19:18:02:739 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk | v1.7.1
19:18:02:750 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 26345 bytes
Created: 9/10/2016 - 4:23:37 PM
19:18:02:760 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Log\Logger.ahk | v1.1.0
19:18:02:762 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3098 bytes
Created: 9/10/2016 - 4:23:43 PM
19:18:02:782 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk | v1.1.1
19:18:02:785 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 6725 bytes
19:18:02:796 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk | v1.0.0
19:18:02:799 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 1549 bytes
19:18:02:818 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk | v1.5.1
19:18:02:821 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 7797 bytes
Created: 9/10/2016 - 4:23:49 PM
19:18:02:840 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk | v1.0.0
19:18:02:842 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 2963 bytes
19:18:02:853 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\File\File.ahk | v1.6.0
19:18:02:856 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 9146 bytes
Created: 9/10/2016 - 4:23:52 PM
Modified: 9/10/2016 - 4:23:52 PM
19:18:02:876 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\File\Folder.ahk | v1.0.0
19:18:02:879 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 648 bytes
Created: 9/10/2016 - 4:23:42 PM
19:18:02:889 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk | v1.0.0
19:18:02:900 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 4412 bytes
19:18:02:911 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk | v1.1.1
19:18:02:913 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3741 bytes
19:18:02:935 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\File\Process.ahk | v1.5.0
19:18:02:937 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 9584 bytes
Created: 9/10/2016 - 4:23:39 PM
19:18:02:948 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk | v1.1.0
19:18:02:960 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 1220 bytes
Created: 9/10/2016 - 4:23:41 PM
Modified: 9/10/2016 - 4:23:41 PM
19:18:02:970 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk | v1.0.1
19:18:02:972 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5520 bytes
Created: 9/10/2016 - 4:23:46 PM
Modified: 9/10/2016 - 4:23:46 PM
19:18:02:990 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\UI\Control.ahk | v1.2.0
19:18:02:993 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 4561 bytes
Created: 9/10/2016 - 4:23:38 PM
19:18:02:004 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\UI\Window.ahk | v1.2.0
19:18:03:007 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 22846 bytes
19:18:03:026 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk | v1.0.0
19:18:03:028 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 1156 bytes
Created: 9/10/2016 - 4:23:51 PM
19:18:03:042 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk | v1.0.7
19:18:03:051 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 72261 bytes
Modified: 12/7/2015 - 6:37:59 AM
19:18:03:061 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Shader.ahk | v1.0.1
19:18:03:063 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3943 bytes
19:18:03:083 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Shader Init.ahk | v1.0.0
19:18:03:086 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 397 bytes
Created: 9/10/2016 - 4:23:50 PM
19:18:03:100 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Shared.ahk | v1.4.7
19:18:03:102 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 175721 bytes
Modified: 9/10/2016 - 4:23:50 PM
19:18:03:113 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Statistics.ahk | v1.0.4
19:18:03:116 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 26810 bytes
Modified: 1/10/2016 - 1:04:41 AM
19:18:03:125 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Statistics Init.ahk | v1.0.1
19:18:03:128 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 33 bytes
Modified: 12/24/2014 - 12:23:48 AM
19:18:03:139 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\Virtual Drive.ahk | v1.0.5
19:18:03:141 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 19148 bytes
19:18:03:152 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\XHotkey.ahk | v1.0.4
19:18:03:155 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 26540 bytes
Modified: 8/14/2015 - 1:14:18 AM
19:18:03:176 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: J:\My Files\RocketLauncher\Lib\XHotkey Init.ahk | v1.0.2
19:18:03:179 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 1063 bytes
Modified: 8/14/2015 - 1:14:25 AM
19:18:03:181 | RL |     DEBUG  | +0     | Main - Received this dbName with no path via CLI: "Aladdin (E) [!]"
19:18:03:183 | RL |     DEBUG  | +0     | Main - dbName: Aladdin (E) [!]
19:18:03:186 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
19:18:03:188 | RL |     TRACE  | +0     | Process.__New - Creating new process object for: "J:\My Files\Hyperspin\HyperSpin.exe"
19:18:03:190 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "J:\My Files\Hyperspin\HyperSpin.exe"
19:18:03:198 | RL |      INFO  | +16    | Main - RocketLauncher received "Sega Genesis" and "Aladdin (E) [!]"
19:18:03:213 | RL |      INFO  | +15    | Main - Did not find a "J:\My Files\RocketLauncher\Settings\Sega Genesis\Game Options.ini" file, skipping any game-specific options.
19:18:03:215 | RL |      INFO  | +0     | Main - Aladdin (E) [!] is using the default emulator: RetroArch
19:18:03:217 | RL |      INFO  | +0     | Main - Checking for a [RetroArch] section in J:\My Files\RocketLauncher\Settings\Sega Genesis\Emulators.ini
19:18:03:219 | RL |      INFO  | +0     | Main - Checking for a [RetroArch] section in J:\My Files\RocketLauncher\Settings\Global Emulators.ini
19:18:03:223 | RL |      INFO  | +0     | Main - Found [RetroArch] in J:\My Files\RocketLauncher\Settings\Global Emulators.ini
19:18:03:239 | RL |      INFO  | +16    | CheckFile - Checking if J:\My Files\RocketLauncher\Modules\RetroArch\RetroArch.ahk exists
19:18:03:248 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 52061 bytes
Created: 9/10/2016 - 4:01:29 PM
19:18:03:255 | RL |      INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
19:18:03:256 | RL |      INFO  | +0     | Main - Aladdin (E) [!] will use module: J:\My Files\RocketLauncher\Modules\RetroArch\RetroArch.ahk
19:18:03:322 | RL |   WARNING  | +78    | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "J:\My Files\RocketLauncher\Settings\Global RocketLauncher.ini"
19:18:03:325 | RL |   WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "J:\My Files\RocketLauncher\Settings\Sega Genesis\RocketLauncher.ini"
19:18:03:390 | RL |      INFO  | +63    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
19:18:03:417 | RL |      INFO  | +31    | CheckFile - Checking if J:\My Files\Hyperspin\Emulators\RetroArch\retroarch.exe exists
19:18:03:426 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 8339726 bytes
Created: 9/15/2016 - 9:23:16 PM
Modified: 1/20/2015 - 9:06:53 PM
19:18:03:427 | RL |      INFO  | +0     | Main - INI Keys read
19:18:03:443 | RL |      INFO  | +16    | CheckFile - Checking if J:\My Files\RocketLauncher\Module Extensions\7z.exe exists
19:18:03:451 | RL |     DEBUG  | +15    | CheckFile - Attributes:
FileDescription          7-Zip Console
FileVersion              15.06 beta
InternalName             7z
LegalCopyright           Copyright (c) 1999-2015 Igor Pavlov
OriginalFilename         7z.exe
ProductName              7-Zip
ProductVersion           15.06 beta
CompanyName              Igor Pavlov
File Size: 262144 bytes
19:18:03:452 | RL |      INFO  | +0     | CheckFile - Checking if J:\My Files\RocketLauncher\Module Extensions\7z.dll exists
19:18:03:460 | RL |     DEBUG  | +16    | CheckFile - Attributes:
FileDescription          7z Plugin
InternalName             7z
OriginalFilename         7z.dll
ProductName              7-Zip
File Size: 1012224 bytes
19:18:03:470 | RL |      INFO  | +0     | Main - "Aladdin (E) [!]" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
19:18:03:472 | RL |      INFO  | +0     | CheckPaths - Started
19:18:03:473 | RL |   WARNING  | +0     | CheckPaths - Please make sure your Database Name (Rom Name) does not contain the special characters [ or ] as these are used to denote sections in RocketLauncher's INI Files: Aladdin (E) [!]
19:18:03:476 | RL |      INFO  | +15    | CheckPaths - Looking for rom: J:\My Files\Hyperspin\Roms\Sega Genesis\Aladdin (E) [!].7z
19:18:03:479 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: J:\My Files\Hyperspin\Roms\Sega Genesis\Aladdin (E) [!]\Aladdin (E) [!].7z
19:18:03:480 | RL |      INFO  | +0     | CheckPaths - Rom not found
19:18:03:483 | RL |      INFO  | +0     | CheckPaths - Looking for rom: J:\My Files\Hyperspin\Roms\Sega Genesis\Aladdin (E) [!].rar
19:18:03:484 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: J:\My Files\Hyperspin\Roms\Sega Genesis\Aladdin (E) [!]\Aladdin (E) [!].rar
19:18:03:486 | RL |      INFO  | +0     | CheckPaths - Rom not found
19:18:03:488 | RL |      INFO  | +0     | CheckPaths - Looking for rom: J:\My Files\Hyperspin\Roms\Sega Genesis\Aladdin (E) [!].zip
19:18:03:490 | RL |      INFO  | +0     | CheckPaths - Found rom: J:\My Files\Hyperspin\Roms\Sega Genesis\Aladdin (E) [!].zip
19:18:03:492 | RL |     DEBUG  | +16    | CheckPaths - Current romName: Aladdin (E) [!]
19:18:03:494 | RL |     DEBUG  | +0     | CheckPaths - Current romPath: J:\My Files\Hyperspin\Roms\Sega Genesis
19:18:03:496 | RL |     DEBUG  | +0     | CheckPaths - Current romExtension: .zip
19:18:03:498 | RL |      INFO  | +0     | CheckPaths - Ended
19:18:03:502 | RL |      INFO  | +0     | BuildScript - User Variables:
; INJECTED VARIABLES
#NoTrayIcon
#InstallKeybdHook
MiscUtils.DetectHiddenWindows("On")
SetTitleMatchMode, 2
SendMode, Event
0 = 12
rlPath = J:\My Files\RocketLauncher
pluginPath = J:\My Files\RocketLauncher\Plugins
pluginName = HyperSpin
pluginExt = .plugin
contextOnExit = 1
rlMode =
rlTitle = RocketLauncher
rlVersion = 1.1.1.1
rlAuthor = djvj
rlURL = www.rlauncher.com
langFile = J:\My Files\RocketLauncher\Data\Language\Localization.ini
primMonitor = 2
frontendPID =
frontendPath = J:\My Files\Hyperspin
frontendExe = HyperSpin.exe
frontendExt = exe
frontendName = HyperSpin
frontendDrive = J
exitEmulatorKey = ~Esc
restoreFE = false
exitScriptKey = ~q & ~s
toggleCursorKey = ~e & ~t
emuFullPath = J:\My Files\Hyperspin\Emulators\RetroArch\retroarch.exe
emuPath = J:\My Files\Hyperspin\Emulators\RetroArch
emuName = RetroArch
emuExt = exe
baseRomPath =
romPath = J:\My Files\Hyperspin\Roms\Sega Genesis
romPathFromIni = J:\My Files\Hyperspin\Roms\Sega Genesis
romExtension = .zip
romExtensionOrig = .zip
romExtensions = 7z|rar|zip|sfc|gba|gb|a78|sv|gbc|rpk|gme|sc|cdt|ws|wsc|ngp|ngc|vms|ipf|n64|z64|sg|fds|caq|vb|vec|wav|cas|min|int|rom|tap|tzx|nes|col|nds|cpr|gg|pce|st2|sms|smc|lnx|md|32x|n64|a52|j64|cso|cue|iso|ccd|chd|bin
executable = retroarch.exe
systemDbName = Sega Genesis
systemName = Sega Genesis
dbPath =
dbName = Aladdin (E) [!]
dbExt =
romName = Aladdin (E) [!]
romMapPath =
romMappingEnabled = false
romMappingHideParent = false
romMappingMenuWidth = 400
romMappingMenuMargin = 65
romMappingTextMargin = 15
romMappingGameNameTextFont = Bebas Neue
romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
romMappingMenuFlagWidth = 55
altArchiveNameOnly =
altRomNameOnly =
altArchiveAndRomName =
altArchiveAndManyRomNames =
altRomNamesOnly =
romMapScenario =
skipchecks = false
romMatchExt = false
blockInputTime = 0
blockInputFile = J:\My Files\RocketLauncher\Module Extensions\BlockInput.exe
errorLevelReporting = false
lockLaunch = false
lockLaunchGame =
screenRotationAngle = 0
screenRotationAngleGame =
setResolution =
logFile =
logLabel := ["    INFO"," WARNING","   ERROR","   DEBUG","   TRACE"]
logLevel = 10
logShowDebugConsole = false
logShowCommandWindow = false
logCommandWindow = false
logIncludeModule = true
logIncludeDLLLogs = false
errorSounds = true
rlDebugConsoleStdout =
sysType = 64-bit
broadcastWindowTitle =
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
navSelectKey = Enter
navP2UpKey = Numpad8
navP2DownKey = Numpad2
navP2LeftKey = Numpad4
navP2RightKey = Numpad6
navP2SelectKey = NumpadEnter
originalWidth = 1920
originalHeight = 1080
vdEnabled = false
vdFullPath =
vdUseSCSI = true
vdDriveLetter =
vdDriveLetterScsi =
vdAddDrive = true
demulShooterPath =
servoStikEnabled = false
servoStikExitMode = false
ledblinkyEnabled = false
ledblinkySystemName =
ledblinkyFullPath =
ledblinkyProfilePath = J:\My Files\RocketLauncher\Profiles\LEDBlinky
ledblinkyRLProfile = J:\My Files\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
winIPACFullPath =
ultraMapEnabled = false
ultraMapFullPath =
emuIdleShutdown = 0
hideCursor = false
hideEmu = false
hideFE = false
suspendFE = false
fadeIn = true
fadeInDuration = 500
fadeInDelay = 5000
fadeInExitDelay = 0
fadeOutExitDelay = 0
fadeOut = true
fadeOutExtraScreen = false
fadeOutDuration = 500
fadeOutDelay = 4000
fadeLyrInterpolation = 7
fadeMuteEmulator = false
fadeUseBackgrounds = false
fadeClickThrough = false
fadeSounds = true
fade7zProgressMode = extraction
fadeWidthBaseRes = 1920
fadeHeightBaseRes = 1080
fadeLyr1Color = FF000000
fadeLyr2X = 0
fadeLyr2Y = 0
fadeLyr2W =
fadeLyr2H =
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3Pos = Center
fadeLyr3X = 450
fadeLyr3Y = 450
fadeLyr3W =
fadeLyr3H =
fadeLyr3Adjust = 1
fadeLyr3PicPad = 0
fadeLyr3Speed = 750
fadeLyr3Type = imageandbar
fadeLyr3Repeat = 1
fadeLyr3StaticX = 0
fadeLyr3StaticY = 870|1575
fadeLyr3StaticW =
fadeLyr3StaticH =
fadeLyr3StaticAdjust = 1
fadeLyr3StaticPicPad = 0
fadeLyr4Adjust = 1
fadeLyr4X = 1792|952
fadeLyr4Y = 891|1596
fadeLyr4W = 128
fadeLyr4H =
fadeLyr4Pos = No Alignment
fadeLyr4FPS = 50
fadeLyr4PicPad = 0
fadeTranspGifColor = FFFFFF
fadeBarWindow = Image
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowW = 900
fadeBarWindowH =
fadeBarWindowR = 30
fadeBarWindowM = 30
fadeBarWindowHatchStyle = 8
fadeBar = 7zOnly
fadeProgressDuration = 0
fadeBarBack = true
fadeBarBackColor = FF555555
fadeBarH = 30
fadeBarR = 10
fadeBarColor = DD00BFFF
fadeBarHatchStyle = 8
fadeBarPercentageText = true
fadeBarInfoText = true
fadeBarXOffset = 0
fadeBarYOffset = 150
fadeRomInfoSystemName = image
fadeRomInfoDeveloper = text with label
fadeRomInfoPublisher = text with label
fadeRomInfoGenre = disabled
fadeRomInfoRating = image
fadeRomInfoOrder = Description|SystemName|Year|Developer|Genre|Rating|Publisher
fadeRomInfoTextMargin = 7
fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular
fadeStatsInfoTextMargin = 7
fadeText1X = 0
fadeText1Y = 0
fadeText1 = Loading Game
fadeText2X = 0
fadeText2Y = 0
fadeText3 = Loading Game
fadeText4 = Loading Complete
fadeFont = Bebas Neue
fadeExtractionTime = disabled
fadeExtractionTimeTextX = 0
fadeExtractionTimeTextY = 0
fadeInterruptKey =
detectFadeErrorEnabled = true
fadeImgPath = J:\My Files\RocketLauncher\Media\Fade
RLDataPath = J:\My Files\RocketLauncher\Data
RLMediaPath = J:\My Files\RocketLauncher\Media
RLErrSoundPath = J:\My Files\RocketLauncher\Media\Sounds\Error
modulesPath = J:\My Files\RocketLauncher\Modules
moduleFullName = J:\My Files\RocketLauncher\Modules\RetroArch\RetroArch.ahk
moduleName = RetroArch
modulePath = J:\My Files\RocketLauncher\Modules\RetroArch
moduleExtension = ahk
moduleExtensionsPath = J:\My Files\RocketLauncher\Module Extensions
libPath = J:\My Files\RocketLauncher\Lib
sevenZEnabled = true
sevenZPath = J:\My Files\RocketLauncher\Module Extensions\7z.exe
sevenZDllPath = J:\My Files\RocketLauncher\Module Extensions\7z.dll
sevenZExtractPath = J:\Temp files
sevenZExtractPathOrig =
sevenZAttachSystemName = false
sevenZDelTemp = true
sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar
sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar
sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar
7zExtractPath = J:\Temp files
mgEnabled = false
mgKey = ~NumpadSub
mgBackgroundColor = FF000000
mgSidePadding = 0.2
mgWidthBaseRes = 1920
mgHeightBaseRes = 1080
mgYOffset = 500|800
mgFont = Arial
mgText2Offset = 100
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
mgSelectedEffect = rotate
mgUseGameArt = false
mgCandidate =
mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
mgOnLaunch = false
pauseEnabled = false
pauseKey = ~NumpadAdd
pauseBackToMenuBarKey = X
pauseZoomInKey = C
pauseZoomOutKey = V
pauseHiToTextPath = J:\My Files\RocketLauncher\Module Extensions\HiToText.exe
pauseSaveStateKeyCodes = {Shift down}{1 down}{1 up}{Shift up}{F3 down}{F3 up}|{Shift down}{2 down}{2 up}{Shift up}{F3 down}{F3 up}|{Shift down}{3 down}{3 up}{Shift up}{F3 down}{F3 up}|{Shift down}{4 down}{4 up}{Shift up}{F3 down}{F3 up}|{Shift down}{5 down}{5 up}{Shift up}{F3 down}{F3 up}|{Shift down}{6 down}{6 up}{Shift up}{F3 down}{F3 up}|{Shift down}{7 down}{7 up}{Shift up}{F3 down}{F3 up}|{Shift down}{8 down}{8 up}{Shift up}{F3 down}{F3 up}|{Shift down}{9 down}{9 up}{Shift up}{F3 down}{F3 up}|{Shift down}{10 down}{10 up}{Shift up}{F3 down}{F3 up}
pauseLoadStateKeyCodes = {Shift down}{1 down}{1 up}{Shift up}{F4 down}{F4 up}|{Shift down}{2 down}{2 up}{Shift up}{F4 down}{F4 up}|{Shift down}{3 down}{3 up}{Shift up}{F4 down}{F4 up}|{Shift down}{4 down}{4 up}{Shift up}{F4 down}{F4 up}|{Shift down}{5 down}{5 up}{Shift up}{F4 down}{F4 up}|{Shift down}{6 down}{6 up}{Shift up}{F4 down}{F4 up}|{Shift down}{7 down}{7 up}{Shift up}{F4 down}{F4 up}|{Shift down}{8 down}{8 up}{Shift up}{F4 down}{F4 up}|{Shift down}{9 down}{9 up}{Shift up}{F4 down}{F4 up}|{Shift down}{10 down}{10 up}{Shift up}{F4 down}{F4 up}
keyboardEncoder =
keyboardEncoderEnabled = false
keymapperEnabled = false
keymapperAHKMethod = false
keymapper = xpadder
xpadderFullPath = J:\My Files\Utilities\Xpadder\xpadder.exe
joyToKeyFullPath = J:\My Files\Utilities\JoyToKey\JoyToKey.exe
profilePath = J:\My Files\RocketLauncher\Profiles
keymapperProfilePath = J:\My Files\RocketLauncher\Profiles\xpadder
keymapperFrontEndProfileName = RocketLauncherUI
joyIDsEnabled = false
joyIDsPreferredControllersGlobal =
joyIDsPreferredControllersSystem = use_global
joyIDsPreferredControllersOnExit =
CustomJoyNamesEnabled = false
CustomJoyNames =
rotateMethod = false
FEProfile = J:\My Files\RocketLauncher\Profiles\xpadder\RocketLauncherUI
defaultProfile = J:\My Files\RocketLauncher\Profiles\xpadder\_Default
systemProfile = J:\My Files\RocketLauncher\Profiles\xpadder\Sega Genesis
xPadderSystemProfile = J:\My Files\RocketLauncher\Profiles\xpadder\Sega Genesis\_Default
emuProfile = J:\My Files\RocketLauncher\Profiles\xpadder\Sega Genesis\RetroArch
romProfile = J:\My Files\RocketLauncher\Profiles\xpadder\Sega Genesis\Aladdin (E) [!]
RocketLauncherProfile = J:\My Files\RocketLauncher\Profiles\xpadder\RocketLauncher
blankProfile = J:\My Files\RocketLauncher\Profiles\xpadder\_Default\blank
ahkFEProfile = J:\My Files\RocketLauncher\Profiles\AHK\RocketLauncherUI
ahkDefaultProfile = J:\My Files\RocketLauncher\Profiles\AHK\_Default
ahkSystemProfile = J:\My Files\RocketLauncher\Profiles\AHK\Sega Genesis
ahkEmuProfile = J:\My Files\RocketLauncher\Profiles\AHK\Sega Genesis\RetroArch
ahkRomProfile = J:\My Files\RocketLauncher\Profiles\AHK\Sega Genesis\Aladdin (E) [!]
ahkRocketLauncherProfile = J:\My Files\RocketLauncher\Profiles\AHK\RocketLauncher
bezelEnabled = false
bezelICEnabled = false
shaderName = false
shaderColor =
shaderTransparency =
statisticsEnabled = true
pressDuration = -1
emuVolume = 1
dxwndIni = J:\My Files\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
dxwndFullPath = J:\My Files\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
qResFullPath = J:\My Files\RocketLauncher\Module Extensions\QRes.exe
mon1O =
pacDrivedllFile = J:\My Files\RocketLauncher\Module Extensions\PacDrive32.dll
userFadeAnimIniFile = J:\My Files\RocketLauncher\Lib\User Fade Animations.ini
testFile =
testDuration =
initialErrorMode = 0
19:18:03:507 | RL |      INFO  | +16    | BuildScript - Loaded XHotkey Init.ahk scripts
19:18:03:508 | RL |      INFO  | +0     | BuildScript - Loaded Fade Init.ahk scripts
19:18:03:511 | RL |      INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
19:18:03:513 | RL |   WARNING  | +0     | BuildScript - "J:\My Files\RocketLauncher\Lib\User Functions Init.ahk" not found
19:18:03:514 | RL |     DEBUG  | +0     | BuildScript - Module starts on line: 2
19:18:03:517 | RL |      INFO  | +0     | BuildScript - Validating module
19:18:03:527 | RL |      INFO  | +15    | BuildScript - Validation complete
19:18:03:529 | RL |      INFO  | +0     | BuildScript - Module:
MEmu = RetroArch
MEmuV =  v05-11-2015 Nightly
MURL = http://themaister.net/retroarch.html
MAuthor = djvj,zerojay
MVersion = 2.4.2
MCRC = A8D5F162
iCRC = F7B77133
MID = 635038268922229162
MSystem = "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","ScummVM","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Dreamcast","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Meganet","Sega Nomad","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sony PSP Minis","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
; Notes:
; If the emu doesn't load and you get no error, usually this means the LibRetro DLL is not working!
; Devs stated they will never add support for mounted images (like via DT)
; Fullscreen is controlled via the module setting in RocketLauncherUI
; This module uses the CLI version of RetroArch (retroarch.exe), not the GUI (retroarch-phoenix.exe).
; The emu may make a mouse cursor appear momentarily during launch, MouseMove and hide_cursor seem to have no effect
; Enable 7z support for archived roms
; Available CLI options: https://github.com/PyroFilmsFX/iOS/blob/master/docs/retroarch.1
; LibRetro DLLs:
; LibRetro DLLs come with the emu, but here is another source for them: http://forum.themaister.net/
; Whatever cores you decide to use, make sure they are extracted anywhere in your Emu_Path\cores folder. The module will find and load the default core unless you choose a custom one for each system.
; You can find supported cores that Retroarch supports simply by downloading them from the "retroarch-phoenix.exe" or by visiting here: https://github.com/libretro/libretro.github.com/wiki/Supported-cores
; Some good discussion on cores and filters: http://forum.themaister.net/viewtopic.php?id=270
; SRM files:
; srm are stored in a "srm" dir in the emu folder. Each system ran through retroarch gets its own folder inside srm
; Save states:
; Save states are stored in a "save" dir in the emu folder. Each system ran through retroarch gets its own folder inside save
; Config files:
; By default, the module looks for config files in a folder called config in the RetroArch folder. Example: C:\emus\RetroArch\config. You can change this folder to anything you like by changing the module's ConfigFolder setting in RocketLauncherUI.
; RetroArch's global config file is called "retroarch.cfg". RetroArch will use a system cfg file named to match your System Name (example: Nintendo Entertainment System.cfg).
; RetroArch will also load core config files named after the core name. Example: nestopia_libretro.cfg
; This allows different settings globally, for each system, and for each core. If you want all systems to use the same retroarch.cfg, do not have any system or core cfg files, only have the retroarch.cfg.
; If a core config exists, it takes precedence over the global config. And if a system config exists, it takes precedence over the core config.
; MultiGame:
; MultiGame support is currently only available for the Mednafen PSX core. Retroarch uses the same method as Mednafen to load multi-disc games. This method involves m3u playlists which are commonly used for music. The m3u files needed to load multi-disc games are generated for you by the module when you launch a multi-disc game and are saved to your corresponding rom directory. Due to m3u limitations, your multi-disc roms/images cannot be archived -- they must be unzipped. All single disc games can remain archived and you can still enable 7z under system settings. If you do not wish to use MultiGame support you can archive your roms/images and m3u generation will be skipped on launch.
; The m3u files generated by the module contain a list of paths to all roms/images in the multi-disc set. Retroarch automatically loads the first path in the m3u so the first path will always be the disc you are loading. For example, Final Fantasy VII has 3 discs and if you load Disc 2 first, the order of the paths in the m3u will be disc 2, disc 3, disc 1. If you load Disc 3 first, the order will be disc 3, disc 1, disc 2. The module anticipates this and will load the correct disk, selected from the Pause/MultiDisk menus. However if you choose to manually use Retroarch's UI or disk swap keys to change discs, you will need to keep this in mind.
; In order for RocketLauncher's MultiGame UI to swap discs, you must define Eject_Toggle_Key, Next_Disk_Key, and Previous_Disk_Key under global settings for the emulator in RocketLauncher. Because AHK and Retroarch use different naming conventions for some keyboard keys, it is best to use a letter, a number, or F1-F12.
; MAME:
; MAME BIOS roms should be placed in the system\mame folder
; System Specific Notes:
; Microsoft MSX/MSX2: Launch an MSX game and in the core options, set the console to be an MSX2 and it will play both just fine.
; Nintendo Famicom Disk System - Requires disksys.rom be placed in the folder you define as system_directory in the RetroArch's cfg.
; Sega CD - Requires "bios_CD_E.bin", "bios_CD_J.bin", "bios_CD_U.bin" all be placed in the folder you define as system_directory in the RetroArch's cfg.
; Super Nintendo Entertainment System - requires split all 10 dsp# & st### roms all be placed in the folder you define as system_directory in the RetroArch's cfg. Many games, like Super Mario Kart require these.
; NEC TurboGrafx-CD (using pce fast core) - Requires "syscard3.pce" be placed in the folder you define as system_directory in the RetroArch's cfg.
; NEC TurboGrafx-CD (using MAME core)
;   - You'll need to update a couple mame specific options in the Retroarch core options file to get it to boot from the cli. These should probably be updated automagically by the module. Turning softlists off, but might not need to.
;       mame_boot_from_cli = "enabled"
;       mame_softlists_enable = "disabled"
;       mame_softlists_auto_media = "disabled"
; - Requires hash folder from MAME/MESS/UME, either from the source or release package. Save this in the system_directory you've defined for RetroArch. Something like \RetroArch\system\mame\hash\
; - Requires the CD bios file(s) saved in the mame bios folder you've defined. Usually \RetroArch\system\mame\bios\
; For PC Engine-CD you'll need the file "[cd] cd-rom system (japan) (v2.1).pce" zipped as cdsys.zip and saved in a pce subfolder in your bios path, so \RetroArch\system\mame\bios\pce\cdsys.zip
; For PC Engine SuperGrafx-CD you'll need the file "[cd] super cd-rom system (japan) (v3.0).pce" zipped as scdsys.zip and saved in a pce subfolder in your bios path, so \RetroArch\system\mame\bios\pce\scdsys.zip
; For TurboGrafx-CD you'll need the file "[cd] turbografx cd system card (usa) (v2.0).pce" zipped as cdsys.zip and saved in a tg16 subfolder in your bios path, so \RetroArch\system\mame\bios\tg16\cdsys.zip
; For TurboDuo you'll need the file "[cd] turbografx cd super system card (usa) (v3.0).pce" zipped as scdsys.zip and saved in a tg16 subfolder in your bios path, so \RetroArch\system\mame\bios\tg16\scdsys.zip
; Nintendo Super Game Boy - Set the Module setting in RocketLauncherUI SuperGameBoy to true to enable a system or only a rom to use SGB mode. This is not needed if your systemName is set to the official name of "Nintendo Super Game Boy". Requires "sgb.boot.rom" and "Super Game Boy (World).sfc" to be placed in the folder you define as system_directory in the RetroArch's cfg. This is needed if you want to use Super game boy mode and color palettes. Also requires using the latest bsnes core. Not all games support SGB mode.
; MAME: The nag screen patch has been removed from the MAME core as of some point in March. We will be investigating our options for this. For MAME-based systems, make sure to set 7z use to false as MAME needs zip files.
; Sony PSP/PlayStation Minis: To avoid the dialog box complaining about ppge_atlas.zim, download it from https://github.com/libretro/libretro-ppsspp/blob/master/assets/ppge_atlas.zim and place it in your Retroarch/system/PPSSPP/ directory.
StartModule()
BezelGUI()
FadeInStart()
primaryExe := new Emulator(emuPath . "\" . executable) ; instantiate emulator executable object
emuPrimaryWindow := new Window(new WindowTitle("RetroArch","RetroArch")) ; instantiate primary emulator window object
emuConsoleWindow := new Window(new WindowTitle("","ConsoleWindowClass")) ; instantiate emulator console window object
; Here we define all supported systems for this module. This object controls how the module reacts to different systems. RetroArch can play a lot of systems, but needs to know what system you want to run, so this module has to adapt.
; 1 - Official System Name in RocketLauncher
; 2 - Short name used only for easy referencing within module
; 3 - Default core
; 4 - The system ID MAME core recognizes
RLLog.Debug("Module - Started building the " . MEmu . " object")
mTypeVar:="
( LTrim
AAE|LibRetro_AAE|mame_libretro
Acorn BBC Micro|LibRetro_BBCB|mess_libretro|bbcb
Amstrad CPC|LibRetro_CPC|mess_libretro|cpc464
Amstrad GX4000|LibRetro_GX4K|mess_libretro|gx4000
APF Imagination Machine|LibRetro_APF|mess_libretro|apfimag
Apple IIGS|LibRetro_AIIGS|mess_libretro|apple2gs
Applied Technology MicroBee|LibRetro_MBEE|mess_libretro|mbeeic
Atari 2600|LibRetro_2600|stella_libretro|a2600
Atari 5200|LibRetro_5200|mess_libretro|a5200
Atari 7800|LibRetro_7800|prosystem_libretro|a7800
Atari 8-Bit|LibRetro_ATARI8|mess_libretro|a800
Atari Classics|LibRetro_ACLS|mame_libretro
Atari Jaguar|LibRetro_JAG|virtualjaguar_libretro|jaguar
Atari Lynx|LibRetro_LYNX|handy_libretro|lynx
Atari ST|LibRetro_ST|hatari_libretro
Atari XEGS|LibRetro_XEGS|mess_libretro|xegs
Bally Astrocade|LibRetro_BAST|mess_libretro|astrocde
Bandai Gundam RX-78|LibRetro_BGRX|mess_libretro|rx78
Bandai Super Vision 8000|LibRetro_SV8K|mess_libretro|sv8000
Bandai Wonderswan|LibRetro_WSAN|mednafen_wswan_libretro|wswan
Bandai Wonderswan Color|LibRetro_WSANC|mednafen_wswan_libretro|wscolor
Canon X07|LibRetro_CX07|mess_libretro|x07
Capcom Classics|LibRetro_CAPC|mame_libretro
Capcom Play System|LibRetro_CPS1|fba_cores_cps1_libretro
Capcom Play System II|LibRetro_CPS2|fba_cores_cps2_libretro
Capcom Play System III|LibRetro_CPS3|mame_libretro
Casio PV-1000|LibRetro_CAS1K|mess_libretro|pv1000
Casio PV-2000|LibRetro_CAS2K|mess_libretro|pv2000
Cave|LibRetro_CAVE|mame_libretro
Coleco ADAM|LibRetro_ADAM|mess_libretro|adam
ColecoVision|LibRetro_COLEC|mess_libretro|coleco
Commodore Amiga|LibRetro_PUAE|puae_libretro
Commodore Max Machine|LibRetro_CMAX|mess_libretro|vic10
Creatronic Mega Duck|LibRetro_DUCK|mess_libretro|megaduck
Data East Classics|LibRetro_DATA|mame_libretro
Dragon Data Dragon|LibRetro_DRAG64|mess_libretro|dragon64
Elektronika BK|LibRetro_EBK|mess_libretro|bk0010
Elektronska Industrija Pecom 64|LibRetro_P64|mess_libretro|pecom64
Emerson Arcadia 2001|LibRetro_A2001|mess_libretro|arcadia
Entex Adventure Vision|LibRetro_AVISION|mess_libretro|advision
Epoch Game Pocket Computer|LibRetro_GPCKET|mess_libretro|gamepock
Epoch Super Cassette Vision|LibRetro_SCV|mess_libretro|scv
Exidy Sorcerer|LibRetro_SORCR|mess_libretro|sorcerer
Fairchild Channel F|LibRetro_CHANF|mess_libretro|channelf
Final Burn Alpha|LibRetro_FBA|fb_alpha_libretro
Funtech Super Acan|LibRetro_SACAN|mess_libretro|supracan
GamePark 32|LibRetro_GP32|mess_libretro|gp32
GCE Vectrex|LibRetro_VECTX|mess_libretro|vectrex
Hartung Game Master|LibRetro_GMASTR|mess_libretro|gmaster
Interton VC 4000|LibRetro_VC4K|mess_libretro|vc4000
Irem Classics|LibRetro_IREM|mame_libretro
JungleTac Sport Vii|LibRetro_SPORTV|mess_libretro|vii
Konami Classics|LibRetro_KONC|mame_libretro
Magnavox Odyssey 2|LibRetro_ODYS2|mess_libretro|odyssey2
MAME|LibRetro_MAME|mame_libretro|mame
Matra & Hachette Alice|LibRetro_ALICE|mess_libretro|alice32
Mattel Aquarius|LibRetro_AQUA|mess_libretro|aquarius
Mattel Intellivision|LibRetro_INTV|mess_libretro|intv
MGT Sam Coupe|LibRetro_SAMCP|mess_libretro|
Microsoft MS-DOS|LibRetro_MSDOS|dosbox_libretro
Microsoft MSX|LibRetro_MSX|bluemsx_libretro
Microsoft MSX2|LibRetro_MSX2|bluemsx_libretro
Microsoft Windows 3.x|LibRetro_WIN3X|dosbox_libretro
Midway Classics|LibRetro_MIDC|mame_libretro
Namco Classics|LibRetro_NAMC|mame_libretro
Namco System 22|LibRetro_NAM2|mame_libretro
NEC PC Engine|LibRetro_PCE|mednafen_pce_fast_libretro|pce,cart
NEC PC Engine-CD|LibRetro_PCECD|mednafen_pce_fast_libretro|pce,cdrom
NEC PC-FX|LibRetro_PCFX|mednafen_pcfx_libretro
NEC SuperGrafx|LibRetro_SGFX|mednafen_supergrafx_libretro|sgx,cart
NEC TurboGrafx-16|LibRetro_TG16|mednafen_pce_fast_libretro|tg16,cart
NEC TurboGrafx-CD|LibRetro_TGCD|mednafen_pce_fast_libretro|tg16,cdrom
Nintendo 64|LibRetro_N64|mupen64plus_libretro|n64
Nintendo 64DD|LibRetro_N64|mupen64plus_libretro
Nintendo Arcade Systems|LibRetro_NINARC|mame_libretro
Nintendo Classics|LibRetro_NINC|mame_libretro
Nintendo DS|LibRetro_DS|desmume_libretro
Nintendo Entertainment System|LibRetro_NES|nestopia_libretro|nes
Nintendo Famicom|LibRetro_NFAM|nestopia_libretro
Nintendo Famicom Disk System|LibRetro_NFDS|nestopia_libretro|famicom
Nintendo Game Boy|LibRetro_GB|gambatte_libretro|gameboy
Nintendo Game Boy Advance|LibRetro_GBA|vba_next_libretro|gba
Nintendo Game Boy Color|LibRetro_GBC|gambatte_libretro|gbcolor
Nintendo Game Boy Japan|LibRetro_GBJ|gambatte_libretro|gameboy
Nintendo Game & Watch|LibRetro_GW|gw_libretro
Nintendo Pokemon Mini|LibRetro_POKE|mess_libretro|pokemini
Nintendo Satellaview|LibRetro_NSFS|snes9x_libretro
Nintendo SuFami Turbo|LibRetro_NSFST|snes9x_libretro
Nintendo Super Famicom|LibRetro_NSF|bsnes_balanced_libretro
Nintendo Super Game Boy|LibRetro_SGB|bsnes_balanced_libretro
Nintendo Virtual Boy|LibRetro_NVB|mednafen_vb_libretro|vboy
Othello Multivision|LibRetro_OTHO|genesis_plus_gx_libretro
Panasonic 3DO|LibRetro_3DO|4do_libretro
Philips CD-i|LibRetro_CDI|mess_libretro|cdimono1
Philips Videopac|LibRetro_PVID|mess_libretro|videopac
RCA Studio II|LibRetro_STUD2|mess_libretro|studio2
SCUMMVM|LibRetro_SCUMM|scummvm_libretro
Sega 32X|LibRetro_32X|picodrive_libretro|32x
Sega CD|LibRetro_SCD|genesis_plus_gx_libretro|segacd
Sega Classics|LibRetro_SEGC|mame_libretro
Sega Dreamcast|LibRetro_DCAST|reicast_libretro
Sega Game Gear|LibRetro_GG|genesis_plus_gx_libretro|gamegear
Sega Genesis|LibRetro_GEN|genesis_plus_gx_libretro|genesis
Sega Mark III|Libretro_SM3|genesis_plus_gx_libretro
Sega Master System|LibRetro_SMS|genesis_plus_gx_libretro|sms
Sega Mega Drive|LibRetro_GEN|genesis_plus_gx_libretro|megadriv
Sega Mega Drive 32X|LibRetro_MD32X|picodrive_libretro
Sega Meganet|LibRetro_GEN|genesis_plus_gx_libretro|genesis
Sega Nomad|LibRetro_GEN|genesis_plus_gx_libretro|genesis
Sega Pico|LibRetro_PICO|picodrive_libretro
Sega Saturn|LibRetro_SAT|yabause_libretro|saturn
Sega Saturn Japan|LibRetro_SAT|yabause_libretro|saturnjp
Sega SC-3000|LibRetro_SC3K|mess_libretro|sc3000
Sega SG-1000|LibRetro_SG1K|genesis_plus_gx_libretro
Sega ST-V|LibRetro_STV|mame_libretro
Sega VMU|LibRetro_SVMU|mess_libretro|svmu
Sharp X1|LibRetro_SX1|mess_libretro|x1
Sinclair ZX Spectrum|LibRetro_SPECZX|mess_libretro|spectrum
SNK Classics|LibRetro_SNKC|mame_libretro
SNK Neo Geo|LibRetro_NEO|fb_alpha_libretro
SNK Neo Geo AES|LibRetro_NEOAES|mame_libretro|aes
SNK Neo Geo CD|LibRetro_NEOCD|mess_libretro|neocdz
SNK Neo Geo MVS|LibRetro_NEOMVS|mame_libretro
SNK Neo Geo Pocket|LibRetro_NGP|mednafen_ngp_libretro|ngp
SNK Neo Geo Pocket Color|LibRetro_NGPC|mednafen_ngp_libretro|ngpc
Sony PlayStation|LibRetro_PSX|mednafen_psx_libretro|psu
Sony PlayStation Minis|LibRetro_PSXMIN|ppsspp_libretro
Sony PocketStation|LibRetro_POCKS|mess_libretro|pockstat
Sony PSP|LibRetro_PSP|ppsspp_libretro
Sony PSP Minis|LibRetro_PSP|ppsspp_libretro
Sord M5|LibRetro_SORD|mess_libretro|m5
Spectravideo|LibRetro_SV328|mess_libretro|svi328n
Super Nintendo Entertainment System|LibRetro_SNES|bsnes_balanced_libretro|snes
Taito Classics|LibRetro_TAIC|mame_libretro
Tandy TRS-80 Color Computer|LibRetro_TRS80|mess_libretro|coco3
Technos|LibRetro_TECHN|mame_libretro
Texas Instruments TI 99-4A|LibRetro_TI99|mess_libretro|ti99_4a
Thomson MO5|LibRetro_MO5|mess_libretro|mo5
Thomson TO7|LibRetro_TO7|mess_libretro|to7
Tiger Game.com|LibRetro_TCOM|mess_libretro|gamecom
Tiki-100|LibRetro_TIKI|mess_libretro|kontiki
Tomy Tutor|LibRetro_TOMY|mess_libretro|tutor
VTech CreatiVision|LibRetro_VTECH|mess_libretro|crvision
Watara Supervision|LibRetro_SUPRV|mess_libretro|svision
Williams Classics|LibRetro_WILLS|mame_libretro
mType := Object()
Loop, Parse, mTypeVar, `n, `r
obj := {}
Loop, Parse, A_LoopField, |
If (A_Index = 1)
obj.System := A_LoopField
Else If (A_Index = 2)
obj.ID := A_LoopField
Else If (A_Index = 3)
obj.Core := A_LoopField
Else { ; 4
StringSplit, tmp, A_LoopField, `,
obj.MAMEID := tmp1
obj.MAMEMedia := tmp2
mType.Insert(obj["System"], obj)
RLLog.Debug("Module - Finished building the " . MEmu . " object")
; For easier use throughout the module
retroSystem := mType[systemName].System
retroID := mType[systemName].ID
retroCore := mType[systemName].Core
retroMAMEID := mType[systemName].MAMEID
retroMAMEMedia := mType[systemName].MAMEMedia
RLLog.Info("Module - Using these system variables:")
RLLog.Info("Module - retroSystem: " . retroSystem)
RLLog.Info("Module - retroID: " . retroID)
RLLog.Info("Module - retroCore: " . retroCore)
RLLog.Info("Module - retroMAMEID: " . retroMAMEID)
RLLog.Info("Module - retroMAMEMedia: " . retroMAMEMedia)
If !retroSystem
ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this " . MEmu . " module: " . moduleName)
If !retroCore
ScriptError("Your Core ID is: " . retroID . "`nCould not find a default core to use. Please update the module with a default core.")
Fullscreen := moduleIni.Read("Settings", "Fullscreen","true","",1)
configFolder := moduleIni.Read("Settings", "ConfigFolder",emuPath . "\config","",1)
mameRomPath := moduleIni.Read("MAME", "BIOS_Roms_Folder","","",1)
mameHideNag := If moduleIni.Read("MAME", "Hide_Nag_Screen","false","",1) = "true" ? "enabled" : "disabled"
mameHideInfo := If moduleIni.Read("MAME", "Hide_Info_Screen","false","",1) = "true" ? "enabled" : "disabled"
mameHideWarn := If moduleIni.Read("MAME", "Hide_Warning_Screen","false","",1) = "true" ? "enabled" : "disabled"
hideConsole := moduleIni.Read("Settings", "HideConsole","true","",1)
ejectToggleKey := moduleIni.Read("Settings", "Eject_Toggle_Key","","",1)
nextDiskKey := moduleIni.Read("Settings", "Next_Disk_Key","","",1)
prevDiskKey := moduleIni.Read("Settings", "Previous_Disk_Key","","",1)
core := moduleIni.Read(romName . "|" . systemName, "LibRetro_Core",retroCore,"",1)
superGB := moduleIni.Read(romName . "|" . systemName, "SuperGameBoy","false","",1)
enableNetworkPlay := moduleIni.Read(romName . "|Network", "Enable_Network_Play","false","",1)
overlay := moduleIni.Read(romName . "|" . systemName, "Overlay","","",1)
videoShader := moduleIni.Read(romName . "|" . systemName, "VideoShader","","",1)
aspectRatioIndex := moduleIni.Read(romName . "|" . systemName, "AspectRatioIndex","","",1)
customViewportWidth := moduleIni.Read(romName . "|" . systemName, "CustomViewportWidth","","",1)
customViewportHeight := moduleIni.Read(romName . "|" . systemName, "CustomViewportHeight","","",1)
customViewportX := moduleIni.Read(romName . "|" . systemName, "CustomViewportX","","",1)
customViewportY := moduleIni.Read(romName . "|" . systemName, "CustomViewportY","","",1)
stretchToFillBezel := moduleIni.Read(romName . "|" . systemName, "StretchToFillBezel","false","",1)
rotation := moduleIni.Read(romName . "|" . systemName, "Rotation",0,"",1)
cropOverscan := moduleIni.Read(romName . "|" . systemName, "CropOverscan","","",1)
threadedVideo := moduleIni.Read(romName . "|" . systemName, "ThreadedVideo","","",1)
vSync := moduleIni.Read(romName . "|" . systemName, "VSync","","",1)
integerScale := moduleIni.Read(romName . "|" . systemName, "IntegerScale","","",1)
configurationPerCore := moduleIni.Read(romName . "|" . systemName, "ConfigurationPerCore","false","",1)
If (StringUtils.Contains(core, "^(mame|mess|ume)") && !retroMAMEID) {
retroMAMEID := "mame" ; set all systems that use a mame core to the default mame ID so any system name is supported
RLLog.Warning("Module - Setting MAMEID to default ""mame"" for """ . retroSystem . """")
configFolder := RLObject.getFullPathFromRelative(rlPath,configFolder)
mameRomPath := If mameRomPath ? RLObject.getFullPathFromRelative(rlPath,mameRomPath) : romPath
overlay := RLObject.getFullPathFromRelative(rlPath,overlay)
videoShader := RLObject.getFullPathFromRelative(rlPath,videoShader)
rotateBezel := false
configFolder := new Folder(configFolder)
If (retroID = "LibRetro_SGB" || superGB = "true") ; if system or rom is set to use Super Game Boy
{ superGB := "true" ; setting this just in case it's false and the system is Nintendo Super Game Boy
sgbRomPath := CheckFile(emuPath . "\system\Super Game Boy (World).sfc","Could not find the rom required for Super Game Boy support. Make sure the rom ""Super Game Boy (World).sfc"" is located in: " . emuPath . "\system")
CheckFile(emuPath . "\system\sgb.boot.rom","Could not find the bios required for Super Game Boy support. Make sure the bios ""sgb.boot.rom"" is located in: " . emuPath . "\system")
retroID := "LibRetro_SGB" ; switching to Super Game Boy mode
retroSystem := "Nintendo Super Game Boy"
; Find the dll for this system
libDll := CheckFile(emuPath . "\cores\" . core . ".dll", "Your " . retroID . " dll is set to " . core . " but could not locate this file:`n" . emuPath . "\cores\" . core . ".dll")
; Find the cfg file to use
If !configFolder.Exist()
ScriptError("You need to make sure ""ConfigFolder"" is pointing to your RetroArch config folder. By default it is looking here: """ . configFolder.FilePath . """")
globalRetroCfg := emuPath . "\retroarch.cfg"
systemRetroCfg := configFolder.FilePath . "\" . retroSystem . ".cfg"
coreRetroCfg := configFolder.FilePath . "\" . core . ".dll.cfg"
RLLog.Info("Module - Global cfg should be: " . globalRetroCfg)
RLLog.Info("Module - System cfg should be: " . systemRetroCfg)
RLLog.Info("Module - Core cfg should be: " . coreRetroCfg)
foundCfg := ""
systemRetroCfg := new File(systemRetroCfg)
coreRetroCfg := new File(coreRetroCfg)
globalRetroCfg := new File(globalRetroCfg)
If systemRetroCfg.Exist() { ; check for system cfg first
retroCFGFile := systemRetroCfg
foundCfg := 1
RLLog.Info("Module - Found a System cfg!")
} Else If coreRetroCfg.Exist() { ; 2nd option is a core config
retroCFGFile := coreRetroCfg
foundCfg := 1
RLLog.Info("Module - Found a Core cfg!")
} Else If globalRetroCfg.Exist() { ; 3rd is global cfg
retroCFGFile := globalRetroCfg
foundCfg := 1
RLLog.Info("Module - Found a Global cfg!")
If foundCfg {
RLLog.Info("Module - " . MEmu . " is using " . retroCFGFile.FileFullPath . " as its config file.")
retroCFG := LoadProperties(retroCFGFile.FileFullPath)
} Else
RLLog.Warning("Module - Could not find a cfg file to update settings. RetroArch will make one for you.")
If StringUtils.Contains(rotation,"1|3") ; use vertical bezel if RA rotation is set to 90 or 270 degrees
rotateBezel := true
If StringUtils.Contains(retroID, "LibRetro_NFDS|LibRetro_SCD|LibRetro_TGCD|LibRetro_PCECD|LibRetro_PCFX") { ; these systems require the retroarch settings to be read
retroSysDir := ReadProperty(retroCFG,"system_directory") ; read value
retroSysDir := ConvertRetroCFGKey(retroSysDir) ; remove dbl quotes
retroSysDirLeft := StringUtils.Left(retroSysDir, 2)
If (retroSysDirLeft = ":\") { ; if retroarch is set to use a default folder
retroSysDir := StringUtils.TrimLeft(retroSysDir, 1)
RLLog.Info("Module - RetroArch is using a relative system path: """ . retroSysDir . """")
retroSysDir := emuPath . retroSysDir
If !retroSysDir
ScriptError("RetroArch requires you to set your system_directory and place bios rom(s) in there for """ . retroSystem . """ to function. Please do this first by running ""retroarch-phoenix.exe"" manually.")
checkForSlash := StringUtils.Right(retroSysDir, 1)
If (checkForSlash = "\") ; check if a backslash is the last character. If it is, remove it, as this is non-standard method to define folders
retroSysDir := StringUtils.TrimRight(retroSysDir, 1)
If (StringUtils.Contains(core, "^(mame|mess|ume)")) || (StringUtils.Contains(retroID, "LibRetro_N64|LibRetro_NES|LibRetro_LYNX|LibRetro_PSX")) || (StringUtils.Contains(retroID, "LibRetro_NES") && (StringUtils.Contains(core, "nestopia_libretro"))) { ; these systems will use an ini to store game specific settings
RLLog.Info("Module - Reading / creating system ini for specific settings.")
If !StringUtils.Contains(core, "^(mame|mess|ume)") {
If !SystemModuleIni.Exist()
SystemModuleIni.Append ; create a new blank ini file if one does not exist
If (configurationPerCore = "true") {
coreOptionsCFGFile := new File(configFolder.FilePath . "\retroarch-core-options.cfg")
coreOptionsCFGFile.CheckFile("Could not find retroarch-core-options.cfg in retroarch directory: """ . configFolder.FilePath . """")
} Else {
coreOptionsCFGFile := new File(emuPath . "\retroarch-core-options.cfg")
coreOptionsCFGFile.CheckFile("Could not find retroarch-core-options.cfg in retroarch directory: """ . emuPath . """")
coreOptionsCFG := LoadProperties(coreOptionsCFGFile.FileFullPath)
If StringUtils.Contains(core, "^(mame|mess|ume)") { ; Set some MAME/MESS/UME core options.
tmpCore := If StringUtils.Contains(core, "mame") ? "mame" : "mess"
WriteProperty(coreOptionsCFG, tmpCore . "_read_config", """enabled""", 1)
WriteProperty(coreOptionsCFG, tmpCore . "_boot_from_cli", """enabled""", 1) ; This needs to be enabled in order to run games with RLauncher
WriteProperty(coreOptionsCFG, tmpCore . "_hide_nagscreen", "" . mameHideNag . "", 1)
WriteProperty(coreOptionsCFG, tmpCore . "_hide_infoscreen", "" . mameHideInfo . "", 1)
WriteProperty(coreOptionsCFG, tmpCore . "_hide_warnings", "" . mameHideWarn . "", 1)
} Else If StringUtils.Contains(retroID, "LibRetro_N64") { ; Nintendo 64
mupenGfx := moduleIni.Read(romName . "|" . systemName, "Mupen_Gfx_Plugin", "auto","",1)
mupenRsp := moduleIni.Read(romName . "|" . systemName, "Mupen_RSP_Plugin", "auto","",1)
mupenCpu := moduleIni.Read(romName . "|" . systemName, "Mupen_CPU_Core", "dynamic_recompiler","",1)
mupenPak1 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_1", "memory","",1)
mupenPak2 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_2", "memory","",1)
mupenPak3 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_3", "memory","",1)
mupenPak4 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_4", "memory","",1)
mupenGfxAccur := moduleIni.Read(romName . "|" . systemName, "Mupen_Gfx_Accuracy", "high","",1)
mupenExpMem := moduleIni.Read(romName . "|" . systemName, "Mupen_Disable_Exp_Memory", "no","",1)
mupenTexturFilt := moduleIni.Read(romName . "|" . systemName, "Mupen_Texture_Filtering", "nearest","",1)
mupenViRefresh := moduleIni.Read(romName . "|" . systemName, "Mupen_VI_Refresh", "2200","",1)
mupenFramerate := moduleIni.Read(romName . "|" . systemName, "Mupen_Framerate", "fullspeed","",1)
mupenResolution := moduleIni.Read(romName . "|" . systemName, "Mupen_Resolution", "640x480","",1)
mupenPolyOffstFctr := moduleIni.Read(romName . "|" . systemName, "Mupen_Polygon_Offset_Factor", "-3.0","",1)
mupenPolyOffstUnts := moduleIni.Read(romName . "|" . systemName, "Mupen_Polygon_Offset_Units", "-3.0","",1)
mupenViOverlay := moduleIni.Read(romName . "|" . systemName, "Mupen_VI_Overlay", "disabled","",1)
mupenAnalogDzone := moduleIni.Read(romName . "|" . systemName, "Mupen_Analog_Deadzone", "15","",1)
WriteProperty(coreOptionsCFG, "mupen64-gfxplugin", mupenGfx, 1)
WriteProperty(coreOptionsCFG, "mupen64-rspplugin", mupenRsp, 1)
WriteProperty(coreOptionsCFG, "mupen64-cpucore", mupenCpu, 1)
WriteProperty(coreOptionsCFG, "mupen64-pak1", mupenPak1, 1)
WriteProperty(coreOptionsCFG, "mupen64-pak2", mupenPak2, 1)
WriteProperty(coreOptionsCFG, "mupen64-pak3", mupenPak3, 1)
WriteProperty(coreOptionsCFG, "mupen64-pak4", mupenPak4, 1)
WriteProperty(coreOptionsCFG, "mupen64-gfxplugin-accuracy", mupenGfxAccur, 1)
WriteProperty(coreOptionsCFG, "mupen64-disableexpmem", mupenExpMem, 1)
WriteProperty(coreOptionsCFG, "mupen64-filtering", mupenTexturFilt, 1)
WriteProperty(coreOptionsCFG, "mupen64-virefresh", mupenViRefresh, 1)
WriteProperty(coreOptionsCFG, "mupen64-framerate", mupenFramerate, 1)
WriteProperty(coreOptionsCFG, "mupen64-screensize", mupenResolution, 1)
WriteProperty(coreOptionsCFG, "mupen64-polyoffset-factor", mupenPolyOffstFctr, 1)
WriteProperty(coreOptionsCFG, "mupen64-polyoffset-units", mupenPolyOffstUnts, 1)
WriteProperty(coreOptionsCFG, "mupen64-angrylion-vioverlay", mupenViOverlay, 1)
WriteProperty(coreOptionsCFG, "mupen64-astick-deadzone", mupenAnalogDzone, 1)
} Else If StringUtils.Contains(retroID, "LibRetro_NES") { ; these systems will use an ini to store game specific settings
If StringUtils.Contains(core, "nestopia_libretro") { ; Nestopia
nestopiaBlargg := moduleIni.Read(romName . "|Nestopia", "Nestopia_Blargg_NTSC_Filter", "disabled","",1)
nestopiaPalette := moduleIni.Read(romName . "|Nestopia", "Nestopia_Palette", "canonical","",1)
nestopiaNoSprteLimit := moduleIni.Read(romName . "|Nestopia", "Nestopia_Remove_Sprites_Limit", "disabled","",1)
WriteProperty(coreOptionsCFG, "nestopia_blargg_ntsc_filter", nestopiaBlargg, 1)
WriteProperty(coreOptionsCFG, "nestopia_palette", nestopiaPalette, 1)
WriteProperty(coreOptionsCFG, "nestopia_nospritelimit", nestopiaNoSprteLimit, 1)
} Else If StringUtils.Contains(retroID, "LibRetro_LYNX") { ; Atari Lynx
If StringUtils.Contains(core, "handy_libretro") {   ; Handy
handyRotate := moduleIni.Read(romName . "|" . systemName, "Handy_Rotation", "None","",1)
If StringUtils.Contains(handyRotate, "240") or StringUtils.Contains(handyRotate, "90")
rotateBezel := true
WriteProperty(coreOptionsCFG, "handy_rot", handyRotate, 1)
} Else If StringUtils.Contains(retroID, "LibRetro_PSX") { ; Sony PlayStation
psxCdImageCache := moduleIni.Read(romName . "|" . systemName, "PSX_CD_Image_Cache", """enabled""","",1)
psxMemcardHandling := moduleIni.Read(romName . "|" . systemName, "PSX_Memcard_Handling", """libretro""","",1)
psxDualshockAnalogToggle := moduleIni.Read(romName . "|" . systemName, "PSX_Dualshock_Analog_Toggle", """enabled""","",1)
WriteProperty(coreOptionsCFG, "beetle_psx_cdimagecache", psxCdImageCache, 1)
WriteProperty(coreOptionsCFG, "beetle_psx_use_mednafen_memcard0_method", psxMemcardHandling, 1)
WriteProperty(coreOptionsCFG, "beetle_psx_analog_toggle", psxDualshockAnalogToggle, 1)
SaveProperties(coreOptionsCFGFile.FileFullPath, coreOptionsCFG)
hideEmuObj := Object(emuConsoleWindow,0,emuPrimaryWindow,1)
7z(romPath, romName, romExtension, sevenZExtractPath)
mgM3UFile := new File(romPath . "\" . romTable[1,4] . ".m3u")
mgRomExtensions := "cue|iso|ccd"
mgValidExtension := false
Loop, Parse, mgRomExtensions, |
If (romExtension = "." . A_LoopField)
mgValidExtension := true
If (StringUtils.Contains(retroID, "LibRetro_PSX") && romTable.MaxIndex() && mgValidExtension) { ; See if MultiGame table is populated
m3uRomIndex := Object()
mgType := romTable[1,6] . " "
mgMaxIndex := romTable.MaxIndex()
mgRomIndex := 0
If mgM3UFile.Exist()
mgM3UFile.Delete()
Loop % mgMaxIndex
If (romTable[A_Index, 3] = romName) {
tempType := romTable[A_Index, 5]
mgRomIndex := StringUtils.TrimLeft(tempType, StringUtils.StringLength(mgType))
RLLog.Info("Found rom index in rom set in romTable: " . mgRomIndex)
Break
If (mgRomIndex > 0) {
tempRomIndex := mgRomIndex
Loop % mgMaxIndex
mgTypeIndex := mgType . tempRomIndex
m3uRomIndex.Insert(tempRomIndex)
Loop % mgMaxIndex
If (romTable[A_Index, 5] = mgTypeIndex) {
tempRomPath := romTable[A_Index, 1]
mgM3UFile.Append(tempRomPath . "`n")
RLLog.Info("Module - Appending rom path to m3u: " . tempRomPath)
Break
If (tempRomIndex < mgMaxIndex)
tempRomIndex++
Else
tempRomIndex := 1
; MAME/MESS/UME core options
MAMEParam1 := ""
MAMEParam2 := ""
MAMEParam3 := ""
If StringUtils.Contains(core, "^(mame|mess|ume)") { ; if a MAME/MESS/UME core is used
If !retroMAMEID
ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for the MAME/MESS/UME LibRetro core")
Else
RLLog.Info("Module - MAME/MESS/UME mode using a known ident: " . retroMAMEID)
If !mameRomPath
ScriptError("Please set the RetroArch module setting ""BIOS_Roms_Folder"" to the folder that contains your MAME/MESS/UME BIOS roms to use with RetroArch.")
If (retroMAMEID = "mame") { ; want this for arcade mame only
RLLog.Info("Module - Retroarch MAME/MESS/UME Arcade mode enabled")
fullRomPath := " """ . romPath . "\" . romName . romExtension . """"
} Else {
RLLog.Info("Module - Retroarch MAME/MESS/UME Console/PC mode enabled")
MAMEParam1 := ""
MAMEParam2 := " -rompath \""" . mameRomPath . "\"""
; If we already have a media type, then use it.
If (StringUtils.Contains(retroMAMEID, "tg16|pce") && retroMAMEMedia = "cart") {
;MAMEParam3 := " -cart \" . """" . romPath . "\" . romName . romExtension . "\" . """"
MAMEParam3 := " -cart \""" . romPath . "\" . romName . romExtension . "\"""""
; TODO: This needs a better way to handle the cdrom bios files, in my opinion. As it is, there's no clean way to pick between the v2.00 or v3.00 bios.
;       Defaulting to the TurboDuo cdrom bios since it will play 2.00 or 3.00 games.
} Else If (StringUtils.Contains(retroMAMEID, "tg16|pce") && retroMAMEMedia = "cdrom") {
;MAMEParam3 := " -cart cdsys -cdrm \" . """" . romPath . "\" . romName . romExtension . "\" . """"
MAMEParam3 := " -cart scdsys -cdrm \""" . romPath . "\" . romName . romExtension . "\"""""
} Else {
; Build a key/value object containing the different MAMEParam3 choices
MAMEP3 := Object("alice32","cass1","gp32","memc","cpc464","cass","spectrum","cass","dragon64","cass","cdimono1","cdrom","bk0010","cass","neocd","cdrom","neocdz","cdrom","saturn","cdrm","saturnjp","cdrm","svi328n","cass","pecom64","cass","psu","cdrm","svmu","quik","gamecom","cart1","mbeeic","quik1")
MAMEParam3 := MAMEP3[retroMAMEID] ; search object for the retroMAMEID pair
MAMEParam3 := " -" . (If MAMEParam3 ? MAMEParam3 : "cart") . " \" . """" . romPath . "\" . romName . romExtension . "\" . """"
If (retroMAMEID = "mbeeic") ; Applied Technology MicroBee
{ microbeeModel := IniReadCheck(MAMESysINI, romName, "MicroBee_Model","mbeeic","",1)
If microbeeModel not in mbee,mbeeic,mbeepc,mbeepc85,mbee56
ScriptError("This is not a known MicroBee model value: " . microbeeModel)
Else If (microbeeModel != "mbeeic")
retroMAMEID := microbeeModel
If romExtension in .mwb,.com,.bee
mediaDeviceType := "quik1"
Else If romExtension in .wav,.tap
mediaDeviceType := "cass"
Else If romExtension in .rom
mediaDeviceType := "cart"
Else If romExtension in .dsk
mediaDeviceType := "flop1"
Else ; .bin format
mediaDeviceType := "quik2"
MAMEParam3 := " -" . mediaDeviceType . " \" . """" . romPath . "\" . romName . romExtension . "\" . """"
fullRomPath := MAMEParam1 . MAMEParam2 . MAMEParam3
} Else If (superGB = "true") {
RLLog.Info("Module - Retroarch Super Game Boy mode enabled")
fullRomPath := " """ . sgbRomPath . """ --subsystem sgb """ . romPath . "\" . romName . romExtension . """"
} Else {
RLLog.Info("Module - Retroarch standard mode enabled")
If (retroID = "LibRetro_NFDS") ; Nintendo Famicom Disk System
{ disksysRom := new File(retroSysDir . "\disksys.rom")
If !disksysRom.Exist()
ScriptError("RetroArch requires ""disksys.rom"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
} Else If (retroID = "LibRetro_SCD") ; Sega CD
{ If !StringUtils.Contains(romExtension, "\.bin|\.cue|\.iso")
ScriptError("RetroArch only supports Sega CD games in bin|cue|iso format. It does not support:`n" . romExtension)
biosCDEBin := new File(retroSysDir . "\bios_CD_E.bin")
biosCDUBin := new File(retroSysDir . "\bios_CD_U.bin")
biosCDJBin := new File(retroSysDir . "\bios_CD_J.bin")
If !biosCDEBin.Exist()
ScriptError("RetroArch requires ""bios_CD_E.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
If !biosCDUBin.Exist()
ScriptError("RetroArch requires ""bios_CD_U.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
If !biosCDJBin.Exist()
ScriptError("RetroArch requires ""bios_CD_J.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
} Else If StringUtils.Contains(retroID,"LibRetro_PCECD|LibRetro_TGCD") ; NEC PC Engine-CD and NEC TurboGrafx-CD
{ If !StringUtils.Contains(romExtension,"\.ccd|\.cue")
ScriptError("RetroArch only supports " . retroSystem . " games in ccd or cue format. It does not support:`n" . romExtension)
sysCard3Pce := new File(retroSysDir . "\syscard3.pce")
If !sysCard3Pce.Exist()
ScriptError("RetroArch requires ""syscard3.pce"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
} Else If (retroID = "LibRetro_PCFX")
pcfxBios := new File(retroSysDir . "\pcfx.bios")
If !pcfxBios.Exist()
ScriptError("RetroArch requires ""pcfx.bios"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
} Else If (retroID = "LibRetro_SCUMM")
scummFile := new File(romPath . "\" . romName . ".scummvm")
If !scummFile.Exist()
scummFile.Append("""" . romName . """")
networkSession := ""
If (enableNetworkPlay = "true") {
RLLog.Info("Module - Network Multi-Player is an available option for " . dbName)
netplayNickname := moduleIni.Read("Network", "NetPlay_Nickname","Player","",1)
getWANIP := moduleIni.Read("Network", "Get_WAN_IP","false","",1)
If (getWANIP = "true")
myPublicIP := GetPublicIP()
RLLog.Warning("Module - CAREFUL WHEN POSTING THIS LOG PUBLICLY AS IT CONTAINS YOUR IP ON THE NEXT LINE")
defaultServerIP := moduleIni.Read("Network", "Default_Server_IP", myPublicIP,"",1)
defaultServerPort := moduleIni.Read("Network", "Default_Server_Port","","",1)
lastIP := moduleIni.Read("Network", "Last_IP", defaultServerIP,"",1) ; does not need to be on the ISD
lastPort := moduleIni.Read("Network", "Last_Port", defaultServerPort,"",1) ; does not need to be on the ISD
mpMenuStatus := MultiPlayerMenu(lastIP,lastPort,networkType,"",0)
If (mpMenuStatus = -1) { ; if user exited menu early
RLLog.Warning("Module - Cancelled MultiPlayer Menu. Exiting module.")
ExitModule()
If networkSession {
RLLog.Info("Module - Using a Network for " . dbName)
moduleIni.Write(networkPort, "GlobalModuleIni", "Network", "Last_Port")
; msgbox lastIP: %lastIP%`nlastPort: %lastPort%`nnetworkIP: %networkIP%`nnetworkPort: %networkPort%
If (networkType = "client") {
moduleIni.Write(networkIP, "GlobalModuleIni", "Network", "Last_IP") ; Save last used IP and Port for quicker launching next time
netCommand := " -C " . networkIP . " --port " . networkPort . " --nick """ . netplayNickname . """" ; -C = connect as client
} Else { ; server
netCommand := " -H --port " . networkPort . " --nick """ . netplayNickname . """" ; -H = host as server
RLLog.Info("Module - Starting a network session using the IP """ . networkIP . """ and PORT """ . networkPort . """")
} Else
RLLog.Info("Module - User chose Single Player mode for this session")
BezelStart(,,(If rotateBezel ? 1:""))
If foundCfg {
If (stretchToFillBezel = "true" and bezelEnabled = "true" and bezelPath)
customViewportWidth := bezelScreenWidth
customViewportHeight := bezelScreenHeight
customViewportX := 0
customViewportY := 0
aspectRatioIndex := 22
RLLog.Info("Stretching viewport to fit bezel")
raCfgHasChanges := ""
WriteRetroProperty("input_overlay", overlay)
WriteRetroProperty("video_shader", videoShader)
WriteRetroProperty("aspect_ratio_index", aspectRatioIndex)
WriteRetroProperty("custom_viewport_width", customViewportWidth)
WriteRetroProperty("custom_viewport_height", customViewportHeight)
WriteRetroProperty("custom_viewport_x", customViewportX)
WriteRetroProperty("custom_viewport_y", customViewportY)
WriteRetroProperty("video_rotation", rotation)
WriteRetroProperty("video_crop_overscan", cropOverscan)
WriteRetroProperty("video_threaded", threadedVideo)
WriteRetroProperty("video_vsync", vSync)
WriteRetroProperty("video_scale_integer", integerScale)
WriteRetroProperty("input_disk_eject_toggle", ejectToggleKey)
WriteRetroProperty("input_disk_next", nextDiskKey)
WriteRetroProperty("input_disk_prev", prevDiskKey)
Loop, 8 ; Loop 8 times for 8 controllers
{ p%A_Index%ControllerType := moduleIni.Read(romName . "|" . systemName, "P" . A_Index . "_Controller_Type", 517,"",1)
WriteRetroProperty("input_libretro_device_p" . A_Index, p%A_Index%ControllerType)
If raCfgHasChanges {
RLLog.Info("Module - Saving changed settings to: """ . retroCFGFile.FileFullPath . """")
SaveProperties(retroCFGFile.FileFullPath, retroCFG)
fullscreen := If fullscreen = "true" ? " -f" : ""
srmPath := new Folder(emuPath . "\srm\" . retroSystem) ; path for this system's srm files
saveStatePath := new Folder(emuPath . "\save\" . retroSystem) ; path for this system's save state files
retroCFGFileCLI := If foundCfg ? " -c """ . retroCFGFile.FileFullPath . """" : ""
If !srmPath.Exist("folder")
srmPath.CreateDir() ; creating srm dir if it doesn't exist
If !saveStatePath.Exist("folder")
saveStatePath.CreateDir() ; creating save dir if it doesn't exist
HideAppStart(hideEmuObj,hideEmu)
If (StringUtils.Contains(core, "^(mame|mess|ume)") && (retroMAMEID != "mame")) {    ; if a MAME/MESS/UME core is used
primaryExe.Run(" """ . (retroMAMEID ? retroMAMEID : "") . fullRomPath . """ " . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
} Else If (retroID = "LibRetro_SCUMM") {
primaryExe.Run(" """ . scummFile . """" . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
} Else If (retroID = "LibRetro_SGB" || If superGB = "true") { ; For some reason, the order of our command line matters in this particular case.
primaryExe.Run(fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . fullRomPath . netCommand, "Hide")
} Else If mgM3UFile.Exist() {
primaryExe.Run(" """ . mgM3UFile.FileFullPath . """" . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
} Else {
primaryExe.Run(" " . fullRomPath . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
mpMenuStatus := ""
If networkSession {
canceledServerWait := false
multiplayerMenuExit := false
TimerUtils.SetTimer("NetworkConnectedCheck", 500)
If (networkType = "server") {
RLLog.Info("Module - Waiting for a client to connect to your server")
mpMenuStatus := MultiPlayerMenu(,,,,,,,,"You are the server. Please wait for your client to connect.")
} Else { ; client
RLLog.Info("Module - Trying to contact the server to establish a connection.")
mpMenuStatus := MultiPlayerMenu(,,,,,,,,"Attempting to connect to the server...")
If (mpMenuStatus = -1) { ; if user exited menu early before a client connected
RLLog.Warning("Module - Cancelled waiting for the " . If (networkType = "server") ? "client to connect" : "server to respond" . ". Exiting module.")
If primaryExe.Process("Exist")
primaryExe.Process("Close") ; must close process as the exe is waiting for a client to connect and no window was drawn yet
ExitModule()
} Else { ; blank response from MultiPlayerMenu, exited properly
RLLog.Info("Module - " . If (networkType = "server") ? "Client has connected" : "Connected to the server")
emuPrimaryWindow.Wait()
emuPrimaryWindow.WaitActive()
TimerUtils.SetTimer("NetworkConnectedCheck", "Off")
} Else { ; single player
If (hideConsole = "true")
emuConsoleWindow.Set("Transparent", "On") ; makes the console window transparent so you don't see it on exit
BezelDraw()
HideAppEnd(hideEmuObj,hideEmu)
FadeInExit()
primaryExe.Process("WaitClose")
7zCleanUp()
BezelExit()
FadeOutExit()
ExitModule()
; Writes new properties into the retroCFG if defined by user
WriteRetroProperty(key,value="") {
If (value != "") {
Global retroCFG,raCfgHasChanges
WriteProperty(retroCFG, key, value,1,1)
raCfgHasChanges := 1
; Used to convert between RetroArch keys and usable data
ConvertRetroCFGKey(txt,direction="read"){
Global emuPath,RLLog
If (direction = "read")
{ newtxt := StringUtils.TrimLeft(txt,1,0) ; removes the " from the left of the txt
newtxt := StringUtils.TrimRight(newtxt,1,0) ; removes the " from the right of the txt
relativeCheck := StringUtils.SubStr(newtxt,1,1,0)
If StringUtils.Contains(relativeCheck,":",0) { ; if the path contains a ":" then it is a relative path
RLLog.Debug("ConvertRetroCFGKey - " . newtxt . " is a relative path")
newtxt := StringUtils.TrimLeft(newtxt,1,0) ; removes the : from the left of the txt
newtxt := AbsoluteFromRelative(emuPath, "." . newtxt) ; convert relative to absolute
If StringUtils.Contains(newtxt,"/",0)
newtxt := StringUtils.Replace(newtxt,"/","\",1,"",0) ; replaces all forward slashes with backslashes
} Else If (direction = "write")
{ newtxt := """" . txt . """" ; wraps the txt with ""
If StringUtils.Contains(newtxt,"\\",0)
newtxt := StringUtils.Replace(newtxt,"\","/",1,"",0) ; replaces all backslashes with forward slashes
} Else
ScriptError("Not a valid use of ConvertRetroCFGKey. Only ""read"" or ""write"" are supported.")
RLLog.Debug("ConvertRetroCFGKey - Converted " . txt . " to " . newtxt)
Return newtxt
MultiGame:
KeyUtils.SetKeyDelay(100)
emuPrimaryWindow.Activate()
KeyUtils.Send("{" . ejectToggleKey . " down}{" . ejectToggleKey . " up}") ; eject disc in Retroarch
If (!mgLastRomIndex) {
mgLastRomIndex := mgRomIndex
selectedRomIndex := 0
selectedRomIndex := StringUtils.TrimLeft(selectedRomNum, StringUtils.StringLength(mgType,0))
Loop % mgMaxIndex
If (m3uRomIndex[A_index] = mgLastRomIndex) {
tempLastRomIndex := A_index
RLLog.Debug("Module - Last index: " . tempLastRomIndex)
If (m3uRomIndex[A_index] = selectedRomIndex) {
tempSelectedRomIndex := A_index
RLLog.Debug("Module - Selected index: " . tempSelectedRomIndex)
mgNewIndex := tempLastRomIndex - tempSelectedRomIndex
If (mgNewIndex < 0) {
mgNewIndex := mgNewIndex * -1
Loop % mgNewIndex
RLLog.Debug("Module - Sending the next disk key: " . nextDiskKey)
KeyUtils.Send("{" . nextDiskKey . " down}{" . nextDiskKey . " up}")
} Else If (mgNewIndex > 0) {
Loop % mgNewIndex
RLLog.Debug("Module - Sending the previous disk key: " . mgNewIndex)
KeyUtils.Send("{" . prevDiskKey . " down}{" . prevDiskKey . " up}")
KeyUtils.Send("{" . ejectToggleKey . " down}{" . ejectToggleKey . " up}") ; close disc in Retroarch
mgLastRomIndex := selectedRomIndex
Return
NetworkConnectedCheck:
If clientConnected
multiplayerMenuExit := true
Else If emuPrimaryWindow.Exist() {
RLLog.Info("Module - RetroArch session started, closing the MultiPlayer menu")
Return
CloseProcess:
FadeOutStart()
emuPrimaryWindow.Close()
Return
19:18:03:571 | RL |      INFO  | +47    | BuildScript - Loaded Multi-Player scripts
19:18:03:576 | RL |      INFO  | +0     | BuildScript - Loaded Statistics.ahk script
19:18:03:579 | RL |   WARNING  | +0     | BuildScript - "J:\My Files\RocketLauncher\Lib\User Functions.ahk" not found
19:18:03:582 | RL |      INFO  | +0     | BuildScript - Finished injecting functions into module
19:18:03:590 | RL |      INFO  | +16    | Main - Module is built
19:18:03:592 | RL |      INFO  | +0     | CheckFile - Checking if J:\My Files\RocketLauncher\AutoHotkey.dll exists
19:18:03:601 | RL |     DEBUG  | +15    | CheckFile - Attributes:
FileDescription          AutoHotkey_H ANSI 32-bit
FileVersion              1.1.13.00
InternalName             AutoHotkey_H
LegalCopyright           Copyright (C) 2003-2013
OriginalFilename         AutoHotkey.exe
ProductName              AutoHotkey_H
ProductVersion           1.1.13.00
File Size: 802304 bytes
Created: 9/10/2016 - 4:01:18 PM
Modified: 9/10/2016 - 4:23:47 PM
19:18:03:604 | RL |      INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
19:18:03:606 | RL |      INFO  | +0     | Main - Running module
19:18:03:965 | MD |      INFO  | +N/A   | Module initialized
19:18:03:967 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
19:18:03:970 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
19:18:03:972 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 1 check
19:18:03:974 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 2 check
19:18:03:995 | MD |     TRACE  | +31    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
19:18:03:997 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
19:18:03:001 | MD |     DEBUG  | +0     | fadeInTransitionAnimation: DefaultAnimateFadeIn
19:18:04:003 | MD |     DEBUG  | +0     | fadeOutTransitionAnimation: DefaultAnimateFadeOut
19:18:04:004 | MD |     DEBUG  | +0     | fadeLyr3Animation: DefaultFadeAnimation
19:18:04:027 | MD |     DEBUG  | +31    | fadeLyr37zAnimation: DefaultFadeAnimation
19:18:04:029 | MD |      INFO  | +0     | StartModule - Started
19:18:04:030 | MD |      INFO  | +0     | StartModule - MEmu: RetroArch
MEmuV: v05-11-2015 Nightly
MURL: http://themaister.net/retroarch.html
MAuthor: djvj,zerojay
MVersion: 2.4.2
MCRC: A8D5F162
iCRC: F7B77133
MID:
MSystem: "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","ScummVM","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Dreamcast","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Meganet","Sega Nomad","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sony PSP Minis","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
19:18:04:033 | MD |      INFO  | +0     | StartModule - You have a supported System Name for this module: "Sega Genesis"
19:18:04:036 | MD |      INFO  | +0     | PluginInit - Started
19:18:04:057 | MD |     DEBUG  | +32    | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Publisher|Year|Genre|Rating
19:18:04:059 | MD |      INFO  | +0     | CheckFile - Checking if J:\My Files\Hyperspin\Databases\Sega Genesis\Sega Genesis.xml exists
19:18:04:061 | MD |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 416655 bytes
Created: 9/10/2016 - 3:55:51 PM
Modified: 9/15/2016 - 9:39:46 PM
19:18:04:065 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
19:18:04:067 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
19:18:04:089 | MD |     DEBUG  | +31    | BuildDatabaseTable - Searching database for: Name
19:18:04:090 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Name" with a value: "Aladdin (E) [!]"
19:18:04:123 | MD |     DEBUG  | +31    | BuildDatabaseTable - Searching database for: Cloneof
19:18:04:124 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Cloneof
19:18:04:126 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Publisher
19:18:04:129 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Publisher
19:18:04:151 | MD |     DEBUG  | +31    | BuildDatabaseTable - Searching database for: Year
19:18:04:153 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Year
19:18:04:154 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Genre
19:18:04:156 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Genre
19:18:04:158 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Rating
19:18:04:160 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Rating
19:18:04:161 | MD |     TRACE  | +0     | PluginInit - GameInfo:
GameInfo Label: Name | GameInfo Value: Aladdin (E) [!]
19:18:04:181 | MD |     DEBUG  | +31    | BuildDatabaseTable - Ended
19:18:04:184 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
19:18:04:186 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Game Logo: J:\My Files\Hyperspin\Media\Sega Genesis\Images\Wheel\Aladdin (E) [!].png
19:18:04:188 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a System Logo: J:\My Files\Hyperspin\Media\Main Menu\Images\Wheel\Sega Genesis.png
19:18:04:190 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
Asset Label: System Logo | Asset Path1:  J:\My Files\Hyperspin\Media\Main Menu\Images\Wheel\Sega Genesis.png | Asset Extension1:  png | Asset Type1:  system
19:18:04:192 | MD |      INFO  | +0     | BuildAssetsTable - Ended
19:18:04:209 | MD |      INFO  | +32    | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
19:18:04:210 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Artwork1: J:\My Files\Hyperspin\Media\Sega Genesis\Images\Artwork1\Aladdin (E) [!].png
19:18:04:222 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Box Art: J:\My Files\Hyperspin\Media\Sega Genesis\Images\Artwork2\Aladdin (E) [!].png
19:18:04:223 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Cartridge: J:\My Files\Hyperspin\Media\Sega Genesis\Images\Artwork3\Aladdin (E) [!].png
19:18:04:245 | MD |     DEBUG  | +31    | BuildAssetsTable - Searching for a Flyers: J:\My Files\Hyperspin\Media\Sega Genesis\Images\Artwork4\Aladdin (E) [!].png
19:18:04:246 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Letters: J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters
19:18:04:341 | MD |     DEBUG  | +93    | BuildAssetsTable - Searching for a Other: J:\My Files\Hyperspin\Media\Sega Genesis\Images\Other
19:18:04:373 | MD |     DEBUG  | +32    | BuildAssetsTable - Media assets found:
Asset Label: Letters | Asset Path1:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
Asset Label: Letters | Asset Path2:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
Asset Label: Letters | Asset Path3:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
Asset Label: Letters | Asset Path4:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
Asset Label: Letters | Asset Path5:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
Asset Label: Letters | Asset Path6:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
Asset Label: Letters | Asset Path7:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
Asset Label: Letters | Asset Path8:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
Asset Label: Letters | Asset Path9:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
Asset Label: Letters | Asset Path10:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
Asset Label: Letters | Asset Path11:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
Asset Label: Letters | Asset Path12:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
Asset Label: Letters | Asset Path13:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
Asset Label: Letters | Asset Path14:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
Asset Label: Letters | Asset Path15:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
Asset Label: Letters | Asset Path16:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
Asset Label: Letters | Asset Path17:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
Asset Label: Letters | Asset Path18:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
Asset Label: Letters | Asset Path19:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
Asset Label: Letters | Asset Path20:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
Asset Label: Letters | Asset Path21:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
Asset Label: Letters | Asset Path22:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
Asset Label: Letters | Asset Path23:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
Asset Label: Letters | Asset Path24:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
Asset Label: Letters | Asset Path25:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
Asset Label: Letters | Asset Path26:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
Asset Label: Letters | Asset Path27:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
Asset Label: Letters | Asset Path28:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
Asset Label: Letters | Asset Path29:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
Asset Label: Letters | Asset Path30:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
Asset Label: Letters | Asset Path31:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
Asset Label: Letters | Asset Path32:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
Asset Label: Letters | Asset Path33:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
Asset Label: Letters | Asset Path34:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
Asset Label: Letters | Asset Path35:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
Asset Label: Letters | Asset Path36:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
Asset Label: Letters | Asset Path37:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
Asset Label: Letters | Asset Path38:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
Asset Label: Letters | Asset Path39:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
Asset Label: Other | Asset Path1:  J:\My Files\Hyperspin\Media\Sega Genesis\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
19:18:04:375 | MD |      INFO  | +0     | BuildAssetsTable - Ended
19:18:04:378 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Game Video|System Video
19:18:04:396 | MD |     DEBUG  | +31    | BuildAssetsTable - Searching for a Game Video: J:\My Files\Hyperspin\Media\Sega Genesis\Video\Aladdin (E) [!].*
19:18:04:398 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a System Video: J:\My Files\Hyperspin\Media\Main Menu\Video\Sega Genesis.*
19:18:04:400 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
Asset Label: System Video | Asset Path1:  J:\My Files\Hyperspin\Media\Main Menu\Video\Sega Genesis.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
19:18:04:401 | MD |      INFO  | +0     | BuildAssetsTable - Ended
19:18:04:403 | MD |      INFO  | +0     | PluginInit - Ended
19:18:04:405 | MD |     DEBUG  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: Aladdin (E) [!]
19:18:04:407 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
19:18:04:409 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,
19:18:04:411 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 1 check
19:18:04:432 | MD |     TRACE  | +31    | XHotkeyTableCreation - Post loop 2 check
19:18:04:434 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
19:18:04:435 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
19:18:04:438 | MD |     TRACE  | +0     | Process.__New - Creating new process object for: "J:\My Files\Hyperspin\HyperSpin.exe"
19:18:04:440 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "J:\My Files\Hyperspin\HyperSpin.exe"
19:18:04:467 | MD |     TRACE  | +31    | File.__New - Creating new file object of: "J:\My Files\RocketLauncher\Modules\RetroArch\Sega Genesis\Aladdin (E) [!].ini"
19:18:04:490 | MD |     TRACE  | +31    | File.__New - Creating new file object of: "J:\My Files\RocketLauncher\Modules\RetroArch\Sega Genesis.ini"
19:18:04:499 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "J:\My Files\RocketLauncher\Modules\RetroArch\RetroArch.ini"
19:18:04:522 | MD |     TRACE  | +32    | File.Exist - This file exists: J:\My Files\RocketLauncher\Modules\RetroArch\RetroArch.ini
19:18:04:525 | MD |     DEBUG  | +0     | RIniFile.__New - "Module" at index 1, adding "GlobalModuleIni" from: "J:\My Files\RocketLauncher\Modules\RetroArch\RetroArch.ini"
19:18:04:530 | MD |      INFO  | +0     | StartModule - Ended
19:18:04:532 | MD |     DEBUG  | +0     | FadeInStart - Started
19:18:04:552 | MD |     TRACE  | +31    | XHotkeyTableCreation - Started
19:18:04:553 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~e&~t,
19:18:04:555 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 10 check
19:18:04:557 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
19:18:04:559 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 11 check
19:18:04:561 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
19:18:04:563 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 12 check
19:18:04:565 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
19:18:04:566 | MD |     DEBUG  | +0     | FadeInStart - No keys were set to interrupt fade so ability to interrupt fade is disabled
19:18:04:588 | MD |     TRACE  | +31    | FadeInStart - Fade screen scale factor: X=1.000000, Y= 1.000000
19:18:04:589 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\Aladdin (E) [!]\Layer 1*.*
19:18:04:592 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Horizontal\Layer 1*.*
19:18:04:594 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 1*.*
19:18:04:596 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 1*.png
19:18:04:617 | MD |     DEBUG  | +31    | GetFadeDirPicFile - Found Fade "Layer 1": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 1.png
19:18:04:618 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 1*.gif
19:18:04:621 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 1*.tif
19:18:04:623 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 1*.bmp
19:18:04:625 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 1*.jpg
19:18:04:627 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 1.png
19:18:04:629 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\Aladdin (E) [!]\Extra Layer 1 - Console*.*
19:18:04:646 | MD |     DEBUG  | +31    | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Horizontal\Extra Layer 1 - Console*.*
19:18:04:654 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Extra Layer 1 - Console*.*
19:18:04:657 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: J:\My Files\RocketLauncher\Media\Fade\_Default\Horizontal\Extra Layer 1 - Console*.*
19:18:04:659 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: J:\My Files\RocketLauncher\Media\Fade\_Default\Extra Layer 1 - Console*.*
19:18:04:884 | MD |      INFO  | +234   | DefaultAnimateFadeIn - Started, direction is: in
19:18:04:886 | MD |      INFO  | +0     | DefaultAnimateFadeIn - Drawing First FadeIn Image.
19:18:05:384 | MD |      INFO  | +500   | DefaultAnimateFadeIn - Ended
19:18:05:446 | MD |     DEBUG  | +62    | FadeInStart - Ended
19:18:05:448 | MD |      INFO  | +0     | DxwndUpdateIniPath - DxwndIni set to J:\My Files\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
19:18:05:450 | MD |     DEBUG  | +0     | CoverFE - Started
19:18:05:455 | MD |     DEBUG  | +0     | CoverFE - Ended
19:18:05:478 | MD |     TRACE  | +31    | Emulator.__New - Creating new emulator object for: "J:\My Files\Hyperspin\Emulators\RetroArch\retroarch.exe"
19:18:05:479 | MD |     TRACE  | +0     | Process.__New - Creating new process object for: "J:\My Files\Hyperspin\Emulators\RetroArch\retroarch.exe"
19:18:05:482 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "J:\My Files\Hyperspin\Emulators\RetroArch\retroarch.exe"
19:18:05:504 | MD |     TRACE  | +31    | Window.__New - Created: "RetroArch ahk_class RetroArch"
19:18:05:506 | MD |     TRACE  | +0     | Window.__New - Created: "ahk_class ConsoleWindowClass"
19:18:05:508 | MD |     DEBUG  | +0     | Module - Started building the RetroArch object
19:18:05:513 | MD |     DEBUG  | +0     | Module - Finished building the RetroArch object
19:18:05:515 | MD |      INFO  | +0     | Module - Using these system variables:
19:18:05:535 | MD |      INFO  | +32    | Module - retroSystem: Sega Genesis
19:18:05:537 | MD |      INFO  | +0     | Module - retroID: LibRetro_GEN
19:18:05:538 | MD |      INFO  | +0     | Module - retroCore: genesis_plus_gx_libretro
19:18:05:540 | MD |      INFO  | +0     | Module - retroMAMEID: genesis
19:18:05:542 | MD |      INFO  | +0     | Module - retroMAMEMedia: cdrom
19:18:05:544 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - Fullscreen: Key does not exist
19:18:05:546 | MD |      INFO  | +0     | RIniFile.Read - Module - Fullscreen: true (DEFAULT)
19:18:05:548 | MD |      INFO  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - ConfigFolder: ..\Hyperspin\Emulators\RetroArch\config
19:18:05:570 | MD |     TRACE  | +31    | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - BIOS_Roms_Folder: Section does not exist
19:18:05:576 | MD |      INFO  | +0     | RIniFile.Read - Module - BIOS_Roms_Folder: (NO VALUE)
19:18:05:579 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Hide_Nag_Screen: Section does not exist
19:18:05:581 | MD |      INFO  | +0     | RIniFile.Read - Module - Hide_Nag_Screen: false (DEFAULT)
19:18:05:600 | MD |     TRACE  | +31    | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Hide_Info_Screen: Section does not exist
19:18:05:602 | MD |      INFO  | +0     | RIniFile.Read - Module - Hide_Info_Screen: false (DEFAULT)
19:18:05:605 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Hide_Warning_Screen: Section does not exist
19:18:05:607 | MD |      INFO  | +0     | RIniFile.Read - Module - Hide_Warning_Screen: false (DEFAULT)
19:18:05:609 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - HideConsole: Key does not exist
19:18:05:611 | MD |      INFO  | +0     | RIniFile.Read - Module - HideConsole: true (DEFAULT)
19:18:05:633 | MD |     TRACE  | +31    | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - Eject_Toggle_Key: Key does not exist
19:18:05:635 | MD |      INFO  | +0     | RIniFile.Read - Module - Eject_Toggle_Key: (NO VALUE)
19:18:05:637 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - Next_Disk_Key: Key does not exist
19:18:05:639 | MD |      INFO  | +0     | RIniFile.Read - Module - Next_Disk_Key: (NO VALUE)
19:18:05:641 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - Previous_Disk_Key: Key does not exist
19:18:05:643 | MD |      INFO  | +0     | RIniFile.Read - Module - Previous_Disk_Key: (NO VALUE)
19:18:05:661 | MD |     TRACE  | +31    | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - LibRetro_Core: Section does not exist
19:18:05:663 | MD |      INFO  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - LibRetro_Core: genesis_plus_gx_libretro
19:18:05:665 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - SuperGameBoy: Section does not exist
19:18:05:667 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - SuperGameBoy: Key does not exist
19:18:05:669 | MD |      INFO  | +0     | RIniFile.Read - Module - SuperGameBoy: false (DEFAULT)
19:18:05:670 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - Enable_Network_Play: Section does not exist
19:18:05:672 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Network] - Enable_Network_Play: Section does not exist
19:18:05:674 | MD |      INFO  | +0     | RIniFile.Read - Module - Enable_Network_Play: false (DEFAULT)
19:18:05:696 | MD |     TRACE  | +32    | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - Overlay: Section does not exist
19:18:05:698 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - Overlay: Key does not exist
19:18:05:727 | MD |      INFO  | +31    | RIniFile.Read - Module - Overlay: (NO VALUE)
19:18:05:729 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - VideoShader: Section does not exist
19:18:05:731 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - VideoShader: Key does not exist
19:18:05:733 | MD |      INFO  | +0     | RIniFile.Read - Module - VideoShader: (NO VALUE)
19:18:05:735 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - AspectRatioIndex: Section does not exist
19:18:05:754 | MD |     TRACE  | +31    | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - AspectRatioIndex: Key does not exist
19:18:05:756 | MD |      INFO  | +0     | RIniFile.Read - Module - AspectRatioIndex: (NO VALUE)
19:18:05:758 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - CustomViewportWidth: Section does not exist
19:18:05:760 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - CustomViewportWidth: Key does not exist
19:18:05:762 | MD |      INFO  | +0     | RIniFile.Read - Module - CustomViewportWidth: (NO VALUE)
19:18:05:764 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - CustomViewportHeight: Section does not exist
19:18:05:766 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - CustomViewportHeight: Key does not exist
19:18:05:768 | MD |      INFO  | +0     | RIniFile.Read - Module - CustomViewportHeight: (NO VALUE)
19:18:05:790 | MD |     TRACE  | +31    | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - CustomViewportX: Section does not exist
19:18:05:792 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - CustomViewportX: Key does not exist
19:18:05:795 | MD |      INFO  | +0     | RIniFile.Read - Module - CustomViewportX: (NO VALUE)
19:18:05:796 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - CustomViewportY: Section does not exist
19:18:05:799 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - CustomViewportY: Key does not exist
19:18:05:816 | MD |      INFO  | +31    | RIniFile.Read - Module - CustomViewportY: (NO VALUE)
19:18:05:818 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - StretchToFillBezel: Section does not exist
19:18:05:819 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - StretchToFillBezel: Key does not exist
19:18:05:822 | MD |      INFO  | +0     | RIniFile.Read - Module - StretchToFillBezel: false (DEFAULT)
19:18:05:823 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - Rotation: Section does not exist
19:18:05:825 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - Rotation: Key does not exist
19:18:05:828 | MD |      INFO  | +0     | RIniFile.Read - Module - Rotation: 0 (DEFAULT)
19:18:05:829 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - CropOverscan: Section does not exist
19:18:05:851 | MD |     TRACE  | +32    | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - CropOverscan: Key does not exist
19:18:05:852 | MD |      INFO  | +0     | RIniFile.Read - Module - CropOverscan: (NO VALUE)
19:18:05:855 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - ThreadedVideo: Section does not exist
19:18:05:856 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - ThreadedVideo: Key does not exist
19:18:05:858 | MD |      INFO  | +0     | RIniFile.Read - Module - ThreadedVideo: (NO VALUE)
19:18:05:860 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - VSync: Section does not exist
19:18:05:881 | MD |     TRACE  | +31    | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - VSync: Key does not exist
19:18:05:883 | MD |      INFO  | +0     | RIniFile.Read - Module - VSync: (NO VALUE)
19:18:05:885 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - IntegerScale: Section does not exist
19:18:05:887 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - IntegerScale: Key does not exist
19:18:05:889 | MD |      INFO  | +0     | RIniFile.Read - Module - IntegerScale: (NO VALUE)
19:18:05:892 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Aladdin (E) [!]] - ConfigurationPerCore: Section does not exist
19:18:05:909 | MD |     TRACE  | +31    | RIniFile.Read - Module {GlobalModuleIni} - [Sega Genesis] - ConfigurationPerCore: Key does not exist
19:18:05:910 | MD |      INFO  | +0     | RIniFile.Read - Module - ConfigurationPerCore: false (DEFAULT)
19:18:05:913 | MD |     TRACE  | +0     | StringUtils.Contains - "genesis_plus_gx_libretro" does not contain "^(mame|mess|ume)"
19:18:05:922 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "J:\My Files\Hyperspin\Emulators\RetroArch\config"
19:18:05:947 | MD |     TRACE  | +31    | Folder.__New - Created new folder object of: "J:\My Files\Hyperspin\Emulators\RetroArch\config"
19:18:05:948 | MD |      INFO  | +0     | CheckFile - Checking if J:\My Files\Hyperspin\Emulators\RetroArch\cores\genesis_plus_gx_libretro.dll exists
19:18:05:951 | MD |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3010010 bytes
Created: 9/15/2016 - 9:23:26 PM
Modified: 1/23/2015 - 1:08:47 AM
19:18:05:953 | MD |     TRACE  | +0     | File.Exist - This file exists: J:\My Files\Hyperspin\Emulators\RetroArch\config
19:18:05:955 | MD |      INFO  | +0     | Module - Global cfg should be: J:\My Files\Hyperspin\Emulators\RetroArch\retroarch.cfg
19:18:05:977 | MD |      INFO  | +31    | Module - System cfg should be: J:\My Files\Hyperspin\Emulators\RetroArch\config\Sega Genesis.cfg
19:18:05:978 | MD |      INFO  | +0     | Module - Core cfg should be: J:\My Files\Hyperspin\Emulators\RetroArch\config\genesis_plus_gx_libretro.dll.cfg
19:18:05:980 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "J:\My Files\Hyperspin\Emulators\RetroArch\config\Sega Genesis.cfg"
19:18:05:007 | MD |     TRACE  | +32    | File.__New - Creating new file object of: "J:\My Files\Hyperspin\Emulators\RetroArch\config\genesis_plus_gx_libretro.dll.cfg"
19:18:06:014 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "J:\My Files\Hyperspin\Emulators\RetroArch\retroarch.cfg"
19:18:06:035 | MD |     TRACE  | +31    | File.Exist - This file exists: J:\My Files\Hyperspin\Emulators\RetroArch\config\Sega Genesis.cfg
19:18:06:037 | MD |      INFO  | +0     | Module - Found a System cfg!
19:18:06:039 | MD |      INFO  | +0     | Module - RetroArch is using J:\My Files\Hyperspin\Emulators\RetroArch\config\Sega Genesis.cfg as its config file.
19:18:06:041 | MD |      INFO  | +0     | LoadProperties - Started and loading this cfg into memory: J:\My Files\Hyperspin\Emulators\RetroArch\config\Sega Genesis.cfg
19:18:06:045 | MD |      INFO  | +0     | LoadProperties - Ended
19:18:06:047 | MD |     TRACE  | +0     | StringUtils.Contains - "0" does not contain "1|3"
19:18:06:049 | MD |     TRACE  | +0     | StringUtils.Contains - "LibRetro_GEN" does not contain "LibRetro_NFDS|LibRetro_SCD|LibRetro_TGCD|LibRetro_PCECD|LibRetro_PCFX"
19:18:06:071 | MD |     TRACE  | +31    | StringUtils.Contains - "genesis_plus_gx_libretro" does not contain "^(mame|mess|ume)"
19:18:06:073 | MD |     TRACE  | +0     | StringUtils.Contains - "LibRetro_GEN" does not contain "LibRetro_N64|LibRetro_NES|LibRetro_LYNX|LibRetro_PSX"
19:18:06:075 | MD |     TRACE  | +0     | StringUtils.Contains - "LibRetro_GEN" does not contain "LibRetro_NES"
19:18:06:077 | MD |      INFO  | +0     | 7z - Started, received J:\My Files\Hyperspin\Roms\Sega Genesis\Aladdin (E) [!].zip. If rom is an archive, it will extract to J:\Temp files
19:18:06:079 | MD |     DEBUG  | +0     | 7z - Using Standard method to extract this rom
19:18:06:101 | MD |     DEBUG  | +31    | 7z - ".zip" found in .zip|.rar|.7z|.lzh|.gzip|.tar
19:18:06:103 | MD |      INFO  | +0     | CheckFile - Checking if J:\My Files\Hyperspin\Roms\Sega Genesis\Aladdin (E) [!].zip exists
19:18:06:106 | MD |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 1187232 bytes
Created: 12/3/2015 - 2:32:16 PM
Modified: 12/1/2009 - 5:32:40 PM
19:18:06:221 | MD |      INFO  | +125   | 7z - Archive name matches rom name; DLL found rom inside archive using "findFileInZip": "Aladdin (E) [!].bin"
19:18:06:253 | MD |     DEBUG  | +31    | 7z - Invoked COM Object, ROM extracted size: 2097152 bytes
19:18:06:255 | MD |     DEBUG  | +0     | 7z - Checking if this archive has already been extracted in J:\Temp files\Aladdin (E) [!]
19:18:06:257 | MD |     DEBUG  | +0     | 7z - File does not already exist in J:\Temp files\Aladdin (E) [!], proceeding to extract it.
19:18:06:259 | MD |     DEBUG  | +0     | 7z - Calculated a difference of  bytes, so this file will be extracted
19:18:06:261 | MD |     DEBUG  | +0     | 7z - File found in archive
19:18:06:263 | MD |     DEBUG  | +0     | 7z - Extracted path of rom will be 49 in length and within the 255 character limit.
19:18:06:265 | MD |      INFO  | +0     | 7z - The sevenZExtractPath has 3576752 MB of free space which is enough to extract this game: 2 MB
19:18:06:288 | MD |     DEBUG  | +31    | 7z - FadeIn is true, starting timer to update Layer 3 animation with 7z.exe statistics
19:18:06:290 | MD |      INFO  | +0     | DefaultFadeAnimation - Started
19:18:06:292 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\Aladdin (E) [!]\Info Bar*.*
19:18:06:294 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Horizontal\Info Bar*.*
19:18:06:296 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Info Bar*.*
19:18:06:298 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: J:\My Files\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.*
19:18:06:320 | MD |     DEBUG  | +32    | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: J:\My Files\RocketLauncher\Media\Fade\_Default\Info Bar*.*
19:18:06:322 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Info Bar*.png
19:18:06:325 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "Info Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Info Bar.png
19:18:06:327 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Info Bar*.gif
19:18:06:329 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Info Bar*.tif
19:18:06:351 | MD |     DEBUG  | +31    | GetFadeDirPicFile - Looking for Fade "Info Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp
19:18:06:354 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg
19:18:06:356 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use J:\My Files\RocketLauncher\Media\Fade\_Default\Info Bar.png
19:18:06:382 | MD |     DEBUG  | +31    | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\Aladdin (E) [!]\Layer 3*.*
19:18:06:384 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Horizontal\Layer 3*.*
19:18:06:386 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 3*.*
19:18:06:388 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 3*.png
19:18:06:390 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "Layer 3": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 3.png
19:18:06:413 | MD |     DEBUG  | +31    | GetFadeDirPicFile - Looking for Fade "Layer 3": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 3*.gif
19:18:06:415 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 3*.tif
19:18:06:418 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 3*.bmp
19:18:06:420 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 3*.jpg
19:18:06:422 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Layer 3.png
19:18:06:443 | MD |     DEBUG  | +31    | GetFadeDirPicFile - Checking if any Fade "Progress Bar" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\Aladdin (E) [!]\Progress Bar*.*
19:18:06:444 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Progress Bar" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Horizontal\Progress Bar*.*
19:18:06:446 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Progress Bar" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Progress Bar*.*
19:18:06:448 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Progress Bar" media exists in: J:\My Files\RocketLauncher\Media\Fade\_Default\Horizontal\Progress Bar*.*
19:18:06:450 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Progress Bar" media exists in: J:\My Files\RocketLauncher\Media\Fade\_Default\Progress Bar*.*
19:18:06:452 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Progress Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Progress Bar*.png
19:18:06:454 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "Progress Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Progress Bar.png
19:18:06:474 | MD |     DEBUG  | +32    | GetFadeDirPicFile - Looking for Fade "Progress Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Progress Bar*.gif
19:18:06:476 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Progress Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Progress Bar*.tif
19:18:06:479 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Progress Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Progress Bar*.bmp
19:18:06:480 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Progress Bar": J:\My Files\RocketLauncher\Media\Fade\_Default\Progress Bar*.jpg
19:18:06:483 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use J:\My Files\RocketLauncher\Media\Fade\_Default\Progress Bar.png
19:18:06:507 | MD |      INFO  | +31    | BuildAssetsTable - Started - Building Table for: Genre Logo|Rating Logo|Developer Logo|Publisher Logo|Year Logo
19:18:06:509 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Genre Logo:
19:18:06:511 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Rating Logo:
19:18:06:513 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Developer Logo:
19:18:06:516 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Publisher Logo:
19:18:06:534 | MD |     DEBUG  | +31    | BuildAssetsTable - Searching for a Year Logo:
19:18:06:537 | MD |      INFO  | +0     | BuildAssetsTable - Ended
19:18:06:539 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: System Logo|Game Logo|Game Logo
19:18:06:541 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a System Logo: J:\My Files\RocketLauncher\Media\Logos\Sega Genesis\_Default\
19:18:06:544 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Game Logo: J:\My Files\RocketLauncher\Media\Logos\Sega Genesis\Aladdin (E) [!]\
19:18:06:546 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Game Logo:
19:18:06:548 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
Asset Label: System Logo | Asset Path1:  J:\My Files\RocketLauncher\Media\Logos\Sega Genesis\_Default\Sega Genesis.png | Asset Extension1:  png | Asset Type1:  system
19:18:06:570 | MD |      INFO  | +31    | BuildAssetsTable - Ended
19:18:06:635 | MD |     DEBUG  | +63    | GetFadeDirPicFile - Checking if any Fade "7z extracting" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\Aladdin (E) [!]\7z extracting*.*
19:18:06:637 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "7z extracting" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Horizontal\7z extracting*.*
19:18:06:639 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "7z extracting" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\7z extracting*.*
19:18:06:641 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "7z extracting" media exists in: J:\My Files\RocketLauncher\Media\Fade\_Default\Horizontal\7z extracting*.*
19:18:06:665 | MD |     DEBUG  | +31    | GetFadeDirPicFile - Checking if any Fade "7z extracting" media exists in: J:\My Files\RocketLauncher\Media\Fade\_Default\7z extracting*.*
19:18:06:667 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "7z extracting": J:\My Files\RocketLauncher\Media\Fade\_Default\7z extracting*.mp3
19:18:06:669 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "7z extracting": J:\My Files\RocketLauncher\Media\Fade\_Default\7z extracting.mp3
19:18:06:671 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use J:\My Files\RocketLauncher\Media\Fade\_Default\7z extracting.mp3
19:18:06:673 | MD |      INFO  | +0     | DefaultFadeAnimation - Playing J:\My Files\RocketLauncher\Media\Fade\_Default\7z extracting.mp3
19:18:06:880 | MD |     DEBUG  | +218   | FadeInDelay - Started
19:18:06:940 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage
19:18:06:970 | MD |     DEBUG  | +31    | DefaultFadeAnimationLoop - Starting sevenZTimeout Timer
19:18:07:057 | MD |      INFO  | +78    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:126 | MD |      INFO  | +78    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:188 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:256 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:316 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:378 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:438 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:494 | MD |     DEBUG  | +47    | SevenZTimeout - 7z.exe is no longer running
19:18:07:509 | MD |      INFO  | +15    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:563 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:625 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:687 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:757 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:821 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:883 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:07:962 | MD |      INFO  | +78    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:023 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:081 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:143 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:203 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:270 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:330 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:390 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:452 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:517 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:577 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:642 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:701 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:764 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:834 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:898 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:08:960 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:016 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:082 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:154 | MD |      INFO  | +78    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:222 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:284 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:342 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:411 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:467 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:533 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:591 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:653 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:715 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:787 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:849 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:911 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:09:967 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:10:027 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:10:099 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:10:159 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:10:241 | MD |      INFO  | +78    | DefaultFadeAnimationLoop - percentage0.000000
19:18:10:295 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage0.000000
19:18:10:365 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage0.000000
19:18:10:437 | MD |      INFO  | +78    | DefaultFadeAnimationLoop - percentage0.000000
19:18:10:468 | MD |     DEBUG  | +31    | FadeInDelay - Ended
19:18:10:470 | MD |      INFO  | +0     | DefaultFadeAnimation - Ended
19:18:10:472 | MD |     DEBUG  | +0     | 7z - Logging is debug or higher, dumping 7z Extraction info to log
19:18:10:474 | MD |      INFO  | +0     | 7z - Starting 7z extraction of J:\My Files\Hyperspin\Roms\Sega Genesis\Aladdin (E) [!].zip  to J:\Temp files\Aladdin (E) [!]
19:18:10:511 | MD |      INFO  | +47    | DefaultFadeAnimationLoop - percentage0.000000
19:18:10:546 | MD |      INFO  | +31    | Process - Wait 7z.exe 2
19:18:10:576 | MD |     DEBUG  | +31    | 7z - Starting SevenZTimeout Timer
19:18:10:612 | MD |     DEBUG  | +32    | Extracting file: Aladdin (E) [!].bin | Percentage Extracted:  80%
19:18:10:830 | MD |     DEBUG  | +218   | SevenZTimeout - 7z.exe is no longer running
19:18:10:837 | MD |     DEBUG  | +0     | Extracting file: Aladdin (E) [!].bin | Percentage Extracted: 100%
19:18:10:860 | MD |     DEBUG  | +31    | 7z - 7z.exe returned a percentage >= 100, assuming extraction is complete
19:18:10:868 | MD |      INFO  | +0     | DefaultFadeAnimationLoop - percentage0.000000
19:18:10:916 | MD |     DEBUG  | +63    | DefaultFadeAnimationLoop - Progress bar reached 100%
19:18:10:922 | MD |      INFO  | +0     | DefaultFadeAnimationLoop - percentage100
19:18:10:969 | MD |     DEBUG  | +46    | GetFadeDirPicFile - Checking if any Fade "7z complete" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\Aladdin (E) [!]\7z complete*.*
19:18:10:972 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "7z complete" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\Horizontal\7z complete*.*
19:18:10:974 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "7z complete" media exists in: J:\My Files\RocketLauncher\Media\Fade\Sega Genesis\_Default\7z complete*.*
19:18:10:977 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "7z complete" media exists in: J:\My Files\RocketLauncher\Media\Fade\_Default\Horizontal\7z complete*.*
19:18:10:994 | MD |     DEBUG  | +32    | GetFadeDirPicFile - Checking if any Fade "7z complete" media exists in: J:\My Files\RocketLauncher\Media\Fade\_Default\7z complete*.*
19:18:10:996 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "7z complete": J:\My Files\RocketLauncher\Media\Fade\_Default\7z complete*.mp3
19:18:10:999 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "7z complete": J:\My Files\RocketLauncher\Media\Fade\_Default\7z complete.mp3
19:18:10:001 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use J:\My Files\RocketLauncher\Media\Fade\_Default\7z complete.mp3
19:18:11:003 | MD |      INFO  | +0     | DefaultFadeAnimationLoop - Playing 7z fade complete sound: J:\My Files\RocketLauncher\Media\Fade\_Default\7z complete.mp3
19:18:11:103 | MD |     DEBUG  | +93    | DefaultFadeAnimationLoop - 7z already finished or user interrupted fade, so animation loop is finished.
19:18:11:120 | MD |     DEBUG  | +31    | DefaultFadeAnimationLoop - Fade Layer 3 is drawn and Extraction bar is at 100% so animation loop is finished.
19:18:11:123 | MD |      INFO  | +0     | DefaultFadeAnimationLoop - percentage100
19:18:11:126 | MD |     DEBUG  | +0     | DefaultFadeAnimationLoop - AnimationLoop has finished
19:18:11:128 | MD |     DEBUG  | +0     | DefaultFadeAnimationLoop - Ended
19:18:11:162 | MD |     DEBUG  | +32    | DefaultFadeAnimationLoop - 7z already finished or user interrupted fade, so animation loop is finished.
19:18:11:164 | MD |     DEBUG  | +0     | DefaultFadeAnimationLoop - Fade Layer 3 is drawn and Extraction bar is at 100% so animation loop is finished.
19:18:11:186 | MD |      INFO  | +31    | 7z - Finished 7z extraction which took 1 seconds
19:18:11:188 | MD |     DEBUG  | +0     | 7z - Found file in J:\Temp files\Aladdin (E) [!]\Aladdin (E) [!].bin
19:18:11:191 | MD |   WARNING  | +0     | 7z - romPath changed from "J:\My Files\Hyperspin\Roms\Sega Genesis" to "J:\Temp files\Aladdin (E) [!]"
19:18:11:193 | MD |   WARNING  | +0     | 7z - romName changed from "Aladdin (E) [!]" to "Aladdin (E) [!]"
19:18:11:196 | MD |   WARNING  | +0     | 7z - romExtension changed from ".zip" to ".bin"
19:18:11:218 | MD |      INFO  | +31    | 7z - Ended
19:18:11:219 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "J:\Temp files\Aladdin (E) [!]\.m3u"
19:18:11:227 | MD |     TRACE  | +0     | StringUtils.Contains - "LibRetro_GEN" does not contain "LibRetro_PSX"
19:18:11:253 | MD |     TRACE  | +31    | StringUtils.Contains - "genesis_plus_gx_libretro" does not contain "^(mame|mess|ume)"
19:18:11:255 | MD |      INFO  | +0     | Module - Retroarch standard mode enabled
19:18:11:257 | MD |     TRACE  | +0     | StringUtils.Contains - "LibRetro_GEN" does not contain "LibRetro_PCECD|LibRetro_TGCD"
19:18:11:295 | MD |     DEBUG  | +47    | WriteProperty - Writing - video_rotation: 0
19:18:11:329 | MD |     TRACE  | +31    | StringUtils.Contains - "LibRetro_GEN" does not contain "LibRetro_PSX"
19:18:11:357 | MD |      INFO  | +31    | Module - Saving changed settings to: "J:\My Files\Hyperspin\Emulators\RetroArch\config\Sega Genesis.cfg"
19:18:11:359 | MD |      INFO  | +0     | SaveProperties - Started and saving this cfg to disk: J:\My Files\Hyperspin\Emulators\RetroArch\config\Sega Genesis.cfg
19:18:11:419 | MD |      INFO  | +63    | SaveProperties - Ended
19:18:11:421 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "J:\My Files\Hyperspin\Emulators\RetroArch\srm\Sega Genesis"
19:18:11:429 | MD |     TRACE  | +0     | Folder.__New - Created new folder object of: "J:\My Files\Hyperspin\Emulators\RetroArch\srm\Sega Genesis"
19:18:11:451 | MD |     TRACE  | +31    | File.__New - Creating new file object of: "J:\My Files\Hyperspin\Emulators\RetroArch\save\Sega Genesis"
19:18:11:461 | MD |     TRACE  | +0     | Folder.__New - Created new folder object of: "J:\My Files\Hyperspin\Emulators\RetroArch\save\Sega Genesis"
19:18:11:479 | MD |     TRACE  | +31    | File.Exist - This folder exists: J:\My Files\Hyperspin\Emulators\RetroArch\srm\Sega Genesis
19:18:11:481 | MD |     TRACE  | +0     | File.Exist - This folder exists: J:\My Files\Hyperspin\Emulators\RetroArch\save\Sega Genesis
19:18:11:483 | MD |     TRACE  | +0     | StringUtils.Contains - "genesis_plus_gx_libretro" does not contain "^(mame|mess|ume)"
19:18:11:486 | MD |     TRACE  | +0     | CustomFunction.PreLaunch - Starting
19:18:11:487 | MD |     TRACE  | +0     | CustomFunction.PreLaunch - Ending
19:18:11:489 | MD |      INFO  | +0     | Process.Run - Running: J:\My Files\Hyperspin\Emulators\RetroArch\retroarch.exe  "J:\Temp files\Aladdin (E) [!]\Aladdin (E) [!].bin" -f -c "J:\My Files\Hyperspin\Emulators\RetroArch\config\Sega Genesis.cfg" -L "J:\My Files\Hyperspin\Emulators\RetroArch\cores\genesis_plus_gx_libretro.dll" -s "J:\My Files\Hyperspin\Emulators\RetroArch\srm\Sega Genesis\Aladdin (E) [!].srm" -S "J:\My Files\Hyperspin\Emulators\RetroArch\save\Sega Genesis\Aladdin (E) [!].state"
19:18:11:537 | MD |     DEBUG  | +47    | Process.Run - "retroarch.exe  "J:\Temp files\Aladdin (E) [!]\Aladdin (E) [!].bin" -f -c "J:\My Files\Hyperspin\Emulators\RetroArch\config\Sega Genesis.cfg" -L "J:\My Files\Hyperspin\Emulators\RetroArch\cores\genesis_plus_gx_libretro.dll" -s "J:\My Files\Hyperspin\Emulators\RetroArch\srm\Sega Genesis\Aladdin (E) [!].srm" -S "J:\My Files\Hyperspin\Emulators\RetroArch\save\Sega Genesis\Aladdin (E) [!].state"" Process ID: 324
19:18:11:561 | MD |     TRACE  | +31    | CustomFunction.PostLaunch - Starting
19:18:11:603 | MD |     TRACE  | +47    | CustomFunction.PostLaunch - Ending
19:18:11:605 | MD |     TRACE  | +0     | Window.__New - Created: "ahk_id 32445058"
19:18:11:608 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "Off"
19:18:11:611 | MD |     TRACE  | +0     | Window.GetPos - Retrieved x:0 y:0 w: 2400 h: 1350 from "ahk_id 32445058"
19:18:11:613 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "On"
19:18:11:616 | MD |     DEBUG  | +0     | MiscUtils.GetActiveWindowStatus - Title: CoverFE | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 2400 | Height: 1350 | Window HWND: 0x1ef1282 | Process ID: 12444 | Process Path: J:\My Files\RocketLauncher\RocketLauncher.exe
19:18:11:651 | MD |      INFO  | +47    | Window.Wait - Waiting for window "RetroArch ahk_class RetroArch"
19:18:11:877 | MD |     TRACE  | +218   | Window.__New - Created: "ahk_id 32445058"
19:18:11:879 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "Off"
19:18:11:882 | MD |     TRACE  | +0     | Window.GetPos - Retrieved x:0 y:0 w: 2400 h: 1350 from "ahk_id 32445058"
19:18:11:919 | MD |     TRACE  | +47    | MiscUtils.DetectHiddenWindows - Mode changed to "On"
19:18:11:921 | MD |     DEBUG  | +0     | MiscUtils.GetActiveWindowStatus - Title: CoverFE | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 2400 | Height: 1350 | Window HWND: 0x1ef1282 | Process ID: 12444 | Process Path: J:\My Files\RocketLauncher\RocketLauncher.exe
19:18:11:923 | MD |     TRACE  | +0     | Window.__New - Created: "ahk_id 32445058"
19:18:11:926 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "Off"
19:18:11:953 | MD |     TRACE  | +31    | Window.GetPos - Retrieved x:0 y:0 w: 2400 h: 1350 from "ahk_id 32445058"
19:18:11:955 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "On"
19:18:11:957 | MD |     DEBUG  | +0     | MiscUtils.GetActiveWindowStatus - Title: CoverFE | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 2400 | Height: 1350 | Window HWND: 0x1ef1282 | Process ID: 12444 | Process Path: J:\My Files\RocketLauncher\RocketLauncher.exe
19:18:11:960 | MD |      INFO  | +0     | Window.WaitActive - Waiting for "RetroArch ahk_class RetroArch"
19:18:12:338 | MD |     TRACE  | +390   | Window.__New - Created: "ahk_id 792666"
19:18:12:340 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "Off"
19:18:12:343 | MD |     TRACE  | +0     | Window.GetPos - Retrieved x:0 y:0 w: 1920 h: 1080 from "ahk_id 792666"
19:18:12:345 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "On"
19:18:12:347 | MD |     DEBUG  | +0     | MiscUtils.GetActiveWindowStatus - Title: RetroArch | Class: RetroArch | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0xc185a | Process ID: 324 | Process Path: J:\My Files\Hyperspin\Emulators\RetroArch\retroarch.exe
19:18:12:381 | MD |     TRACE  | +31    | Window.Set - Setting Transparent to On for window "ahk_class ConsoleWindowClass"
19:18:12:421 | MD |     DEBUG  | +47    | FadeInExit - Started
19:18:12:424 | MD |      INFO  | +0     | DefaultAnimateFadeIn - Started, direction is: out
19:18:12:959 | MD |      INFO  | +531   | DefaultAnimateFadeIn - Ended
19:18:13:077 | MD |     TRACE  | +125   | XHotkeyTableCreation - Started
19:18:13:079 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~e&~t,
19:18:13:082 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 10 check
19:18:13:084 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
19:18:13:115 | MD |     TRACE  | +31    | XHotkeyTableCreation - Post loop 11 check
19:18:13:146 | MD |     TRACE  | +31    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
19:18:13:166 | MD |     TRACE  | +31    | XHotkeyTableCreation - Post loop 12 check
19:18:13:169 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
19:18:13:171 | MD |     DEBUG  | +0     | FadeInExit - Ended, waiting for user to close launched application
19:18:13:173 | MD |     TRACE  | +0     | CustomFunction.PostLoad - Starting
19:18:13:175 | MD |     TRACE  | +0     | CustomFunction.PostLoad - Ending
19:18:13:178 | MD |      INFO  | +0     | Process.Process - "WaitClose" "retroarch.exe"
19:18:13:206 | MD |     TRACE  | +31    | Process.GetProcessID
19:18:32:980 | MD |     DEBUG  | +19781 | Process.Process - "retroarch.exe" returned 0 and is now closed. Continuing thread.
19:18:32:984 | MD |      INFO  | +0     | 7zCleanUp - Started
19:18:32:028 | MD |      INFO  | +47    | 7zCleanUp - Deleted J:\Temp files\Aladdin (E) [!]
19:18:33:031 | MD |      INFO  | +0     | 7zCleanUp - Ended
19:18:33:033 | MD |     DEBUG  | +0     | FadeOutExit - Started
19:18:33:035 | MD |      INFO  | +0     | DefaultAnimateFadeOut - Started, direction is: out
19:18:33:589 | MD |      INFO  | +562   | DefaultAnimateFadeOut - Ended
19:18:33:591 | MD |     DEBUG  | +0     | FadeOutExit - Ended
19:18:33:593 | MD |      INFO  | +0     | ExitModule - Started
19:18:33:596 | MD |      INFO  | +0     | Starting Updating Statistics:
19:18:33:598 | MD |     TRACE  | +0     | Total Elapsed Time in Pause in seconds: 0
19:18:33:621 | MD |     TRACE  | +31    | gameSectionStartTime:3024347484
19:18:33:630 | MD |     TRACE  | +0     | ElapsedTime:20
19:18:33:651 | MD |     TRACE  | +31    | Statistics cleared game name: Aladdin
19:18:33:811 | MD |     TRACE  | +156   | Loaded game statistics from ini files:
Number_of_Times_Played: 0
Last_Time_Played: 0
Average_Time_Played: 0
Total_Time_Played: 0
System_Total_Played_Time: 341
Total_Global_Played_Time: 7367
19:18:33:814 | MD |     TRACE  | +0     | Updated Statistics: Number_of_Times_Played: 1
Last_Time_Played: Saturday September 17, 2016 07:18:13 PM
Average_Time_Played: 20
Total_Time_Played: 20
System_Total_Played_Time: 361
Total_Global_Played_Time: 7387
19:18:33:942 | MD |      INFO  | +125   | Game section statistics updated.
19:18:33:965 | MD |     TRACE  | +31    | CustomFunction.PostExit - Starting
19:18:33:968 | MD |     TRACE  | +0     | CustomFunction.PostExit - Ending
19:18:33:970 | MD |      INFO  | +0     | ExitModule - Ended
End of Module Logs
19:18:34:089 | RL |      INFO  | +30483 | Main - Module ended, exiting RocketLauncher normally
19:18:34:092 | RL |      INFO  | +0     | ExitScript - Started
19:18:34:116 | RL |     DEBUG  | +31    | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32
19:18:34:119 | RL |     DEBUG  | +0     | Registry.Read - Registry Read finished, returning 0
19:18:34:122 | RL |     TRACE  | +0     | StringUtils.Contains - "false" does not contain "true|kill"
19:18:34:124 | RL |      INFO  | +0     | ExitScript - Restoring taskbar
19:18:34:127 | RL |     TRACE  | +0     | Window.__New - Created: "ahk_class Shell_TrayWnd"
19:18:34:129 | RL |     TRACE  | +0     | Window.__New - Created: "Start ahk_class Button"
19:18:34:132 | RL |     TRACE  | +16    | Window.Show - Unhiding window "ahk_class Shell_TrayWnd"
19:18:34:239 | RL |     TRACE  | +109   | Window.Show - Unhiding window "Start ahk_class Button"
19:18:34:356 | RL |      INFO  | +109   | SystemCursor - Restoring mouse cursor
19:18:34:362 | RL |      INFO  | +0     | ExitScript - Restored cursor
oh ok, can you suggest something other then retroarch then? I only got that because a tutorial i was watching told me to. I had been using things like fusion for sega and nestopia etc.
A lot of RA lovers here but I myself do not use RetroArch. Just continue to use individual emulators for each system. The only real advantage RA has is the shaders... which I care nothing about.
Sent from my B3-A20 using Tapatalk
