ci2own Posted September 20, 2016 Posted September 20, 2016 Hi! I started a new installation a few days ago and now i realized i have a wrong path in HS Settings to RocketLauncher. I changed it and now when try to load a game says can't find Database.xml in D:\RocketLauncher\Databases\.. Where can i change this? Thanks in advance!
ci2own Posted September 20, 2016 Author Posted September 20, 2016 You didn't properly connect HS and RL when setting it up. In RLUI on the General Settings -> RocketLauncher tab you need to set the Default Frontend Path to point to your HyperSpin exe and the Default Plugin to HyperSpin. You were right (as always)! That solved my first problem. Now my game/emulator loads but starts minimized. Running form RL does the same. I'm looking for some solution but can't find it. Do you know something about it? Thanks for your help!
ci2own Posted September 20, 2016 Author Posted September 20, 2016 Did you setup the emulator at all? Yes, my emulators works out of RL and HS. The thing is RL and HS launches the rom but it always keeps it minimized. It didn't happened to me before.
rastan Posted September 20, 2016 Posted September 20, 2016 Man, I thought I had it right but nope! So I was able to launch my emulators and roms from the new drive in RL (drive K:) but when I tried to launch them from Hyperspin they kept looking for the emulators in the old drive (C:). Mame of course worked with no problems.. no surprise there but my other emulators like ppsspp didn't work. Oh well... the plan in to move my HS and RL to the same drive with the roms but it's back to the drawing board. Just have to change my xpadder settings back.. but man now I know how those people feel that get a drive from somebody else... geezz.. this was my own HS setup and it was painful trying to figure out what was going wrong. I'm just gonna install a fresh setup and add each system one by one on the new drive instead of trying to transfer my current setup.
ci2own Posted September 20, 2016 Author Posted September 20, 2016 I know what is my problem, but don't know how to solve it. If i enable WinIPAC profiles, emulator keeps minimized and don't load profiles. If i disable WinIPAC, emulators start in full screen as it should. Don't know how to get it to load profiles and keep emu in full screen. Any help would be appreciated. Thanks in advance!
