Game Not Launching
patm95
Hi all.  I am setting up Hyperspin for the 2nd time on a new PC.  It's been over 5 years since last time so I have forgotten a lot and a lot has changed since then.  I am now trying to use Rocketlauncher.  I can not get Hyperspin to launch a game though.  It tests fine in Rocketlauncher.  However I have 2 systems setup in Hyperspin and neither one is working.  You select a game and press enter and nothing happens.  I'm guessing I am missing something simple?  Hyperlauncher is selected in HyperHQ.  I am under the impression we no longer muse HyperHQ for much when we are using Rocketlauncher?  Thank You.
Did you set the path to rocketlauncher in the settings.ini file?
I did, thanks for asking.  I was just double checking that today.
This is an observation that I just had and I am not sure if it means anything.  I can launch a game directly from Rocketlauncher by clicking the .exe file.  If I click on the Hyperlaunch.exe file on Hyperspin, it will launch RocketLauncher, but none of the games will launch that way.  That make any sense?
Ok. That is the video I used originally.  I think I figured out what was wrong. I had RocketLauncher configured to run as administrator.  I unchecked that box and now it runs fine.
Run as admin should never be needed for HS/RL stuff - as everything in the launch chain has to be run as admin or you will get the exact problem you've experienced.
