phantasy Posted September 24, 2016 Posted September 24, 2016 Following some of Simply Austin's youtube videos (thanks again!!), I set things up pretty well with MESS. I updated my MAME after years to 177 and now that MESS is built in, I wish to just use the combo emulator and Retroarch as must as possible. For all RocketLauncher systems matched to MESS, do I change the emulator to MAME or do I just map the MESS exe file in global settings to the same exe as my MAME is mapped as? Alternatively, RetroArch has a mame core, so is retroarch best to map to if you have your 'system' folder within Retroarch's directory full of the appropriate bios, files, etc? Thanks!!
Guest Posted September 24, 2016 Posted September 24, 2016 Following some of Simply Austin's youtube videos (thanks again!!), I set things up pretty well with MESS. I updated my MAME after years to 177 and now that MESS is built in, I wish to just use the combo emulator and Retroarch as must as possible. For all RocketLauncher systems matched to MESS, do I change the emulator to MAME or do I just map the MESS exe file in global settings to the same exe as my MAME is mapped as? Alternatively, RetroArch has a mame core, so is retroarch best to map to if you have your 'system' folder within Retroarch's directory full of the appropriate bios, files, etc? Thanks!! Change the emulator for your MESS systems to now use MAME. Also, using the MAME core in RA is a terrible experience. Just use MAME directly. Sent from my iPhone using Tapatalk
