drphilgood Posted September 25, 2016 Posted September 25, 2016 Hey everyone I am in the process of setting up my PS2 wheel. I have PCSX2.0 1.4.0 which runs fine stand alone. I noticed that when launching the games through RL or HS the emulator takes several mins to load the game. Approx 3-5 mins. Once it finally loads the game the controller pad doesn't work neither. If i open the emulator stand alone everything runs fine including the boot time and the controller. Anybody with suggestions? Thanks
Dabil Posted September 25, 2016 Posted September 25, 2016 Probably will need to see your rocketlauncher log. Sent from my SM-G920V using Tapatalk
drphilgood Posted September 25, 2016 Author Posted September 25, 2016 15:39:31:657 | RL | INFO | +N/A | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com) 15:39:31:832 | RL | INFO | +172 | Main - System Specs: RocketLauncher Dir: C:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 7 Professional SKU: Professional Total Memory: 6135.12 MB Free Memory: 2934.43 MB Used Memory: 3200.684 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 8 GPU 1 Name: AMD Radeon HD 5700 Series GPU 1 RAM: 1024.00 MB GPU 1 Driver Version: 15.200.1062.1004 Sound 1 Device: Realtek High Definition Audio Sound 1 Status: Enabled Sound 2 Device: AMD High Definition Audio Device Sound 2 Status: Enabled OS Language: English_United_States System Locale: en-US Formats Locale: en-US Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: HIGHDPIAWARE Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1024 work) [32bit] [60hz] [Landscape] (Primary) Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 Monitor #1 DPI: 150 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 15:39:31:832 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\RocketLauncher.exe exists 15:39:31:833 | RL | INFO | +0 | Main - Raw CLI received: "-s Sony Playstation 2 -r Dragon Quest VIII - Journey of the Cursed King (USA) -f C:\Hyperspin\HyperSpin.exe -p HyperSpin -c 1 -o 1" 15:39:31:833 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 15:39:31:833 | RL | INFO | +0 | Main - RocketLauncher received "Sony Playstation 2" and "Dragon Quest VIII - Journey of the Cursed King (USA)" 15:39:31:841 | RL | INFO | +15 | Main - Did not find a "C:\RocketLauncher\Settings\Sony Playstation 2\Game Options.ini" file, skipping any game-specific options. 15:39:31:841 | RL | INFO | +0 | Main - Dragon Quest VIII - Journey of the Cursed King (USA) is using the default emulator: PCSX2 15:39:31:841 | RL | INFO | +0 | Main - Checking for a [PCSX2] section in C:\RocketLauncher\Settings\Sony Playstation 2\Emulators.ini 15:39:31:841 | RL | INFO | +0 | Main - Checking for a [PCSX2] section in C:\RocketLauncher\Settings\Global Emulators.ini 15:39:31:842 | RL | INFO | +0 | Main - Found [PCSX2] in C:\RocketLauncher\Settings\Global Emulators.ini 15:39:31:842 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Modules\PCSX2\PCSX2.ahk exists 15:39:31:847 | RL | WARNING | +0 | Main - CRC Check - CRC does not match official module and will not be supported. Continue using at your own risk. 15:39:31:847 | RL | INFO | +0 | Main - Dragon Quest VIII - Journey of the Cursed King (USA) will use module: C:\RocketLauncher\Modules\PCSX2\PCSX2.ahk 15:39:31:851 | RL | WARNING | +16 | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "C:\RocketLauncher\Settings\Global RocketLauncher.ini" 15:39:31:851 | RL | WARNING | +0 | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "C:\RocketLauncher\Settings\Sony Playstation 2\RocketLauncher.ini" 15:39:31:880 | RL | INFO | +16 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 15:39:31:881 | RL | INFO | +0 | CheckFile - Checking if C:\PCSX2\pcsx2.exe exists 15:39:31:898 | RL | INFO | +31 | Main - INI Keys read 15:39:31:899 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.exe exists 15:39:31:900 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.dll exists 15:39:31:903 | RL | INFO | +0 | Main - "Dragon Quest VIII - Journey of the Cursed King (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 15:39:31:904 | RL | INFO | +0 | CheckPaths - Started 15:39:31:904 | RL | INFO | +0 | CheckPaths - Looking for rom: G:\Games\Sony Playstation 2\Dragon Quest VIII - Journey of the Cursed King (USA).7z 15:39:31:904 | RL | INFO | +0 | CheckPaths - Found rom: G:\Games\Sony Playstation 2\Dragon Quest VIII - Journey of the Cursed King (USA).7z 15:39:31:904 | RL | INFO | +0 | CheckPaths - Ended 15:39:31:904 | RL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook MiscUtils.DetectHiddenWindows("On") SetTitleMatchMode, 2 SendMode, Event 0 = 12 rlPath = C:\RocketLauncher pluginPath = C:\RocketLauncher\Plugins pluginName = HyperSpin pluginExt = .plugin contextOnExit = 1 rlMode = rlTitle = RocketLauncher rlVersion = 1.1.1.1 rlAuthor = djvj rlURL = www.rlauncher.com langFile = C:\RocketLauncher\Data\Language\Localization.ini primMonitor = 1 frontendPID = frontendPath = C:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = C exitEmulatorKey = ~Esc restoreFE = false exitScriptKey = Q toggleCursorKey = ~e & ~t emuFullPath = C:\PCSX2\pcsx2.exe emuPath = C:\PCSX2 emuName = PCSX2 emuExt = exe baseRomPath = G:\Sony Playstation 2 romPath = G:\Games\Sony Playstation 2 romPathFromIni = G:\Games\Sony Playstation 2|G:\Sony Playstation 2 romExtension = .7z romExtensionOrig = .7z romExtensions = 7z|zip|cue|iso|iso.bz2|bin.bz2 executable = pcsx2.exe systemDbName = Sony Playstation 2 systemName = Sony Playstation 2 dbPath = dbName = Dragon Quest VIII - Journey of the Cursed King (USA) dbExt = romName = Dragon Quest VIII - Journey of the Cursed King (USA) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingHideParent = false romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingGameNameTextFont = Bebas Neue romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = true blockInputTime = 0 blockInputFile = C:\RocketLauncher\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = setResolution = logFile = logLabel := [" INFO"," WARNING"," ERROR"," DEBUG"," TRACE"] logLevel = 3 logShowDebugConsole = false logShowCommandWindow = false logCommandWindow = false logIncludeModule = true logIncludeFileProperties = true logIncludeDLLLogs = false errorSounds = true rlDebugConsoleStdout = sysLang = English_United_States sysType = 64-bit broadcastWindowTitle = navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1920 originalHeight = 1080 vdEnabled = false vdFullPath = vdUseSCSI = true vdDriveLetter = vdDriveLetterScsi = vdAddDrive = true demulShooterPath = servoStikEnabled = false servoStikExitMode = false ledblinkyEnabled = false ledblinkySystemName = ledblinkyFullPath = ledblinkyProfilePath = C:\RocketLauncher\Profiles\LEDBlinky ledblinkyRLProfile = C:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher winIPACFullPath = ultraMapEnabled = false ultraMapFullPath = emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = false hideEmu = false hideFE = false suspendFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeClickThrough = false fadeSounds = true fade7zProgressMode = extraction fadeWidthBaseRes = 1920 fadeHeightBaseRes = 1080 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 450 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = 7zOnly fadeProgressDuration = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoDeveloper = text with label fadeRomInfoPublisher = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = C:\RocketLauncher\Media\Fade RLDataPath = C:\RocketLauncher\Data RLMediaPath = C:\RocketLauncher\Media RLErrSoundPath = C:\RocketLauncher\Media\Sounds\Error modulesPath = C:\RocketLauncher\Modules moduleFullName = C:\RocketLauncher\Modules\PCSX2\PCSX2.ahk moduleName = PCSX2 modulePath = C:\RocketLauncher\Modules\PCSX2 moduleExtension = ahk moduleExtensionsPath = C:\RocketLauncher\Module Extensions libPath = C:\RocketLauncher\Lib sevenZEnabled = true sevenZPath = C:\RocketLauncher\Module Extensions\7z.exe sevenZDllPath = C:\RocketLauncher\Module Extensions\7z.dll sevenZExtractPath = C:\TEMP GAMES HS sevenZExtractPathOrig = sevenZAttachSystemName = false sevenZDelTemp = true sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar 7zExtractPath = C:\TEMP GAMES HS mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1920 mgHeightBaseRes = 1080 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side mgOnLaunch = false pauseEnabled = true pauseKey = ~NumpadAdd pauseBackToMenuBarKey = X pauseZoomInKey = C pauseZoomOutKey = V pauseScreenshotKey = ~PrintScreen pauseHiToTextPath = C:\RocketLauncher\Module Extensions\HiToText.exe pauseSaveStateKeyCodes = {F1 down}{F1 up} pauseLoadStateKeyCodes = {F3 down}{F3 up} keyboardEncoder = keyboardEncoderEnabled = false keymapperEnabled = true keymapperAHKMethod = false keymapper = joytokey xpadderFullPath = C:\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = C:\RocketLauncher\Profiles\JoyToKey\JoyToKey.exe profilePath = C:\RocketLauncher\Profiles keymapperProfilePath = C:\RocketLauncher\Profiles\joytokey keymapperFrontEndProfileName = HyperSpin keymapperFrontEndProfile = joytokey keymapperRocketLauncherProfileEnabled = true joyIDsEnabled = true joyIDsPreferredControllersGlobal = joyIDsPreferredControllersSystem = use_global joyIDsPreferredControllersOnExit = CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = C:\RocketLauncher\Profiles\joytokey\HyperSpin defaultProfile = C:\RocketLauncher\Profiles\joytokey\_Default systemProfile = C:\RocketLauncher\Profiles\joytokey\Sony Playstation 2 xPadderSystemProfile = C:\RocketLauncher\Profiles\joytokey\Sony Playstation 2\_Default emuProfile = C:\RocketLauncher\Profiles\joytokey\Sony Playstation 2\PCSX2 romProfile = C:\RocketLauncher\Profiles\joytokey\Sony Playstation 2\Dragon Quest VIII - Journey of the Cursed King (USA) RocketLauncherProfile = C:\RocketLauncher\Profiles\joytokey\RocketLauncher blankProfile = C:\RocketLauncher\Profiles\joytokey\blank ahkFEProfile = C:\RocketLauncher\Profiles\AHK\HyperSpin ahkDefaultProfile = C:\RocketLauncher\Profiles\AHK\_Default ahkSystemProfile = C:\RocketLauncher\Profiles\AHK\Sony Playstation 2 ahkEmuProfile = C:\RocketLauncher\Profiles\AHK\Sony Playstation 2\PCSX2 ahkRomProfile = C:\RocketLauncher\Profiles\AHK\Sony Playstation 2\Dragon Quest VIII - Journey of the Cursed King (USA) ahkRocketLauncherProfile = C:\RocketLauncher\Profiles\AHK\RocketLauncher bezelEnabled = false bezelICEnabled = false shaderName = false shaderColor = shaderTransparency = statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe qResFullPath = C:\RocketLauncher\Module Extensions\QRes.exe mon1O = pacDrivedllFile = C:\RocketLauncher\Module Extensions\PacDrive32.dll userFadeAnimIniFile = C:\RocketLauncher\Lib\User Fade Animations.ini testFile = testDuration = initialErrorMode = 0 15:39:31:905 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 15:39:31:906 | RL | INFO | +0 | BuildScript - Loaded Keymapper Init.ahk scripts 15:39:31:906 | RL | INFO | +0 | BuildScript - Loaded Pause Init.ahk scripts 15:39:31:906 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 15:39:31:906 | RL | WARNING | +0 | BuildScript - "C:\RocketLauncher\Lib\User Functions Init.ahk" not found 15:39:31:906 | RL | INFO | +0 | BuildScript - Validating module 15:39:31:910 | RL | INFO | +0 | BuildScript - Validation complete 15:39:31:910 | RL | INFO | +0 | BuildScript - Module: MEmu = PCSX2 MEmuV = 1.5.0-dev-263 MURL = http://pcsx2.net/ MAuthor = djvj MVersion = 2.2.1 MCRC = 5E3D250C iCRC = 65DD0603 MID = 635038268913291718 MSystem = "Sony PlayStation 2" ;---------------------------------------------------------------------------- ; Notes: ; This module has many settings that can be controlled via RocketLauncherUI ; If you want to customize settings per game, add the game to the module's ini using RocketLauncherUI ; If you use Daemon Tools, make sure you have a SCSI virtual drive setup. Not a DT one. ; Tested Virtual Drive support with the cdvdGigaherz CDVD plugin. Make sure you set it to use your SCSI Virtual Drive letter. ; If the incorrect drive is used, the emu will boot to the bios screen and emu will hang in your running processes on exit and require it to be force closed ; Module will set the CdvdSource to Plugin or Iso depending on if you have Virtual Drive enabled or not. ; If you have any problems closing the emulator, make sure noGUI module setting in RocketLauncherUI is set to default or false. ; Most stable bios is Japan v01.00(17/01/2000) ; ; Per-game memory cards ; This module supports per-game memory cards to prevent them from ever becoming full ; To use this feature, set the PerGameMemoryCards to true in RocketLauncherUI ; You need to create a default blank memory card in the path you have defined in pcsx's ini found in section [Folders], key MemoryCards. ; Make sure one of the current memory cards are blank, then copy it in that folder and rename it to "default.ps2". The module will copy this file to a romName.ps2 for each game launched. ; The module will only insert memory cards into Slot 1. So save your games there. ; ; Linuz cdvd plugin stores its settings in the registry @ HKEY_CURRENT_USER\Software\PS2Eplugin\CDVD\CDVDiso ; ; v1.4.0 setup guide: ; ; Run pcsx2 with the --help option to see current CLI parameters ; Known CLI options not currently supported by this module: ; --console forces the program log/console to be visible ; --portable enables portable mode operation (requires admin/root access) ; --elf=<str> executes an ELF image ; --forcewiz forces PCSX2 to start the First-time Wizard ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() primaryExe := new Emulator(emuPath . "\" . executable) ; instantiate emulator executable object emuPrimaryWindow := new Window(new WindowTitle("","wxWindowNR"),"","","PCSX2") ; instantiate primary emulator window object emuGUIWindow := new Window(new WindowTitle("PCSX2","wxWindowNR")) emuLoadingWindow := new Window(new WindowTitle("Speed","wxWindowNR"),"","PCSX2") emuBootingWindow := new Window(new WindowTitle("Booting","wxWindowNR")) Fullscreen := moduleIni.Read("Settings", "Fullscreen","true","",1) AspectRatio := moduleIni.Read(romName . "|Settings", "AspectRatio","4:3","",1) noGUI := moduleIni.Read("Settings", "noGUI","false","",1) ; disables display of the gui while running games perGameMemCards := moduleIni.Read("Settings", "PerGameMemoryCards","false","",1) hideConsole := moduleIni.Read("Settings", "HideConsole","true","",1) ; Hides console window from view if it shows up cfgPath := moduleIni.Read("Settings", "cfgpath", emuPath . "\Game Configs","",1) ; specifies the config folder; applies to pcsx2 + plugins autoCreateINIDir := moduleIni.Read("Settings", "AutoCreateINIDir","false","",1) ; Enables the module to auto-create of per game ini files and directories defaultINISPath := moduleIni.Read("Settings", "DefaultINISPath","","",1) ; Path to default INIS folder of PCSX2. fullboot := moduleIni.Read(romName . "|Settings", "fullboot","false","",1) ; disables the quick boot feature, forcing you to sit through the PS2 startup splash screens gs := moduleIni.Read(romName . "|Settings", "gs","","",1) ; override for the GS plugin pad := moduleIni.Read(romName . "|Settings", "pad","","",1) ; override for the PAD plugin spu2 := moduleIni.Read(romName . "|Settings", "spu2","","",1) ; override for the SPU2 plugin cdvd := moduleIni.Read(romName, "cdvd","","",1) ; override for the CDVD plugin usb := moduleIni.Read(romName . "|Settings", "usb","","",1) ; override for the USB plugin fw := moduleIni.Read(romName . "|Settings", "fw","","",1) ; override for the FW plugin dev9 := moduleIni.Read(romName . "|Settings", "dev9","","",1) ; override for the DEV9 plugin vdOveride := moduleIni.Read(romName, "VDOveride","","",1) nohacks := moduleIni.Read(romName, "nohacks","false","",1) ; disables all speedhacks gamefixes := moduleIni.Read(romName, "gamefixes","","",1) ; Enable specific gamefixes for this session. Use the specified comma or pipe-delimited list of gamefixes: VuAddSub,VuClipFlag,FpuCompare,FpuMul,FpuNeg,EETiming,SkipMpeg,OPHFlag,DMABusy,VIFFIFO,VI,FMVinSoftware ; GS plugin settings, primarily to fix upscaling issues in games. Game specific settings can be found here: http://www.neogaf.com/forum/showpost.php?p=27110555&postcount=2 userHacks_MSAA := If moduleIni.Read(romName, "MSAA",0,"",1) ; Applies hardware anti-aliasing userHacks_SkipDraw := moduleIni.Read(romName, "Skipdraw",0,"",1) ; Can remove ghost images userHacks_HalfPixelOffset := If moduleIni.Read(romName, "Half-pixel_Offset",0,"",1) ; Fixes blur or halo effects userHacks_WildHack := If moduleIni.Read(romName, "Wild_Arms_Offset",0,"",1) ; Fixes fonts in many games userHacks_unsafe_fbmask := If moduleIni.Read(romName, "Fast_Accurate_Blending",0,"",1) ; Accelerates blending operations, speeds up Xenosaga userHacks_AlphaStencil := If moduleIni.Read(romName, "Alpha_Stencil",0,"",1) ; May improve drawing shadows userHacks_align_sprite_X := If moduleIni.Read(romName, "Align_Sprite",0,"",1) ; Fixes issues with vertical lines in Ace Combat, Tekken, Soul Calibur userHacks_AlphaHack := If moduleIni.Read(romName, "Alpha",0,"",1) ; Improves drawing fog-like effects preload_frame_with_gs_data := If moduleIni.Read(romName, "Preload_Data_Frame",0,"",1) ; Fixes black screen issues in Armored Core: Last Raven userHacks_round_sprite_offset := moduleIni.Read(romName, "Round_Sprite",0,"",1) ; Fixes lines in sprites in Ar tonelico userHacks_SpriteHack := moduleIni.Read(romName, "Sprite",0,"",1) ; Fixes inner lines in sprites in Mana Khemia, Ar tonelico, Tales of Destiny userHacks_TCOffset := moduleIni.Read(romName, "TC_Offset",0,"",1) ; Fixes misaligned textures in Persona 3, Haunting Ground, Xenosaga ; Set the userHacks variable to 1 if any of the hacks are used. userHacks := If (userHacks_MSAA || userHacks_SkipDraw || userHacks_HalfPixelOffset || userHacks_WildHack || userHacks_unsafe_fbmask || userHacks_AlphaStencil || userHacks_align_sprite_X || userHacks_AlphaHack || preload_frame_with_gs_data || userHacks_round_sprite_offset || userHacks_SpriteHack || userHacks_TCOffset) ? 1 : "" cfgPath := new Folder(GetFullName(cfgPath)) If !cfgPath.Exist() cfgPath.CreateDir() ; create the cfg folder if it does not exist ; PCSX2_ui.ini = default ini that contains memory card info and general settings portableIni := new File(emuPath . "\portable.ini") If portableIni.Exist() { ; portable install RLLog.Info("Module - PCSX2 is operating in a portable mode") pcsx2IniFolder := emuPath . "\inis_1.4.0" pcsx2_GS_IniFile := CheckFile(emuPath . "\inis_1.4.0\GSdx.ini", "Could not find the default GSdx.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.") } Else { ; default not portable install RLLog.Info("Module - PCSX2 is operating in a standard installation mode") pcsx2IniFolder := Registry.Read("HKCU", "Software\PCSX2", "SettingsFolder") } pcsx2Ini := new IniFile(pcsx2IniFolder . "\PCSX2_ui.ini") pcsx2Ini.CheckFile("Could not find the default PCSX2_ui.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.") pcsx2GSdxIni := new IniFile(pcsx2IniFolder . "\GSdx.ini") pcsx2GSdxIni.CheckFile("Could not find the default GSdx.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.") pcsx2IniFolder := new Folder(pcsx2IniFolder) ; Create INIs subfolder for the game if it does not exist and if AutoCreateINIDir is true perGameINIPath := new Folder(cfgPath.FileFullPath . "\" . romName) If (autoCreateINIDir = "true") { RLLog.Info("Module - PerGameIni - perGameINIPath = " . perGameINIPath.FileFullPath) If !perGameINIPath.Exist() { perGameINIPath.CreateDir() If (defaultINISPath != "") { defaultINISPath := new Folder(defaultINISPath) RLLog.Info("Module - PerGameIni - perGameINIPath does not exist. So we will create it at " . perGameINIPath.FileFullPath) RLLog.Info("Module - PerGameIni - Now copying the ini files from " . defaultINISPath.FileFullPath . " to " . perGameINIPath.FileFullPath) defaultINISPath.Copy(perGameINIPath.FileFullPath,0,"\*.ini") } Else { RLLog.Info("Module - PerGameIni - perGameINIPath does not exist. So we will create it at " . perGameINIPath.FileFullPath) RLLog.Info("Module - PerGameIni - Now copying the ini files from " . pcsx2IniFolder.FileFullPath . " to " . perGameINIPath.FileFullPath) pcsx2IniFolder.Copy(perGameINIPath.FileFullPath,0,"\*.ini") } } } BezelStart() Fullscreen := If Fullscreen = "true" ? " --fullscreen" : "" noGUI := If noGUI = "true" ? " --nogui" : "" If (noGUI != "") RLLog.Warning("Module - noGUI is set to true, THIS MAY PREVENT PCSX2 FROM CLOSING PROPERLY. If you have any issues, set it to false or default in RocketLauncherUI.") fullboot := If fullboot = "true" ? " --fullboot" : "" nohacks := If nohacks = "true" ? " --nohacks" : "" gamefixes := If gamefixes ? " --gamefixes=" . gamefixes : "" gs := If gs ? " --gs=""" . GetFullName(gs) . """" : "" pad := If pad ? " --pad=""" . GetFullName(pad) . """" : "" spu2 := If spu2 ? " --spu2=""" . GetFullName(spu2) . """" : "" usb := If usb ? " --usb=""" . GetFullName(usb) . """" : "" fw := If fw ? " --fw=""" . GetFullName(fw) . """" : "" dev9 := If dev9 ? " --dev9=""" . GetFullName(dev9) . """" : "" ; cfgRomPath := new File(cfgPath . "\" . romName) cfgPathCLI := If perGameINIPath.Exist() ? " --cfgpath=""" . perGameINIPath.FileFullPath . """" : "" ; Specify what main ini PCSX2 should use pcsx2GameIni := new File(perGameINIPath.FileFullPath . "\PCSX2_ui.ini") If (cfgPathCLI && pcsx2GameIni.Exist()) { ;We can't set both cfgpath and cfg CLI switches, so if only PCSX2_ui.ini file exists we use cfg otherwise we use cfgpath ;--cfg specifies a custom configuration file to use instead of PCSX2.ini (does not affect plugins) filecount := 0 Loop % perGameINIPath.FileFullPath . "\*.ini" filecount++ If (filecount = 1) { ;Only PCSX2_ui.ini found pcsx2IniFile := pcsx2GameIni RLLog.Info("Module - Found a game-specific PCSX2_ui.ini in the cfgPath. Telling PCSX2 to use this one instead: " . pcsx2IniFile.FileFullPath) cfg := " --cfg=""" . pcsx2IniFile.FileFullPath . """" cfgPathCLI := "" } } RLLog.Info("Module - " . (If cfgPathCLI != "" ? "Setting PCSX2's config path to """ . perGameINIPath.FileFullPath . """" : "Using PCSX2's default configuration folder: """ . pcsx2IniFolder.FileFullPath . """")) ; Update the aspect ratio if the user selected one. If AspectRatio { pcsx2Ini.Write(AspectRatio, "GSWindow", "AspectRatio") ; Write the aspect ratio value to the pcsx2Ini. } ; Update the GS plugin settings if hacks were selected. If userHacks { RLLog.Info("Module - UserHacks are being used. Updating GSdx.ini") pcsx2GSdxIni.Write(userHacks, "Settings", "UserHacks") pcsx2GSdxIni.Write(userHacks_MSAA, "Settings", "UserHacks_MSAA") pcsx2GSdxIni.Write(userHacks_SkipDraw, "Settings", "UserHacks_SkipDraw") pcsx2GSdxIni.Write(userHacks_HalfPixelOffset, "Settings", "UserHacks_HalfPixelOffset") pcsx2GSdxIni.Write(userHacks_WildHack, "Settings", "UserHacks_WildHack") pcsx2GSdxIni.Write(userHacks_unsafe_fbmask, "Settings", "UserHacks_unsafe_fbmask") pcsx2GSdxIni.Write(userHacks_AlphaStencil, "Settings", "UserHacks_AlphaStencil") pcsx2GSdxIni.Write(userHacks_align_sprite_X, "Settings", "UserHacks_align_sprite_X") pcsx2GSdxIni.Write(userHacks_AlphaHack, "Settings", "UserHacks_AlphaHack") pcsx2GSdxIni.Write(preload_frame_with_gs_data, "Settings", "preload_frame_with_gs_data") pcsx2GSdxIni.Write(userHacks_round_sprite_offset, "Settings", "UserHacks_round_sprite_offset") pcsx2GSdxIni.Write(userHacks_SpriteHack, "Settings", "UserHacks_SpriteHack") pcsx2GSdxIni.Write(userHacks_TCOffset, "Settings", "UserHacks_TCOffset") } Else { ; Make sure hacks are disabled. pcsx2GSdxIni.Write(UserHacks, "Settings", "UserHacks") } ; Memory Cards If (perGameMemCards = "true") { currentMemCard1 := pcsx2Ini.Read("MemoryCards", "Slot1_Filename") memCardPath := pcsx2Ini.Read("Folders", "MemoryCards") ; folder where memory cards are stored memCardPathLeft := StringUtils.SubStr(memCardPath,1,3) ; get left 3 characters memCardPathIsAbsolute := If (StringUtils.RegExMatch(memCardPathLeft, "[a-zA-Z]:\\") && (StringUtils.StringLength(memCardPath) >= 3)) ; this is 1 only when path looks like this "C:\" memCardPath := If memCardPathIsAbsolute ? memCardPath : emuPath . "\" . memCardPath ; if only a folder name is defined for the memory card path, tack on the emuPath to find the memory cards, otherwise leave the full path as is defaultMemCard := new File(memCardPath . "\default.ps2") ; defining default blank memory card for slot 1 RLLog.Info("Module - Default memory card for Slot 1 should be: " . defaultMemCard.FileFullPath) romMemCard1 := new File(memCardPath . "\" . romName . ".ps2") ; defining name for rom's memory card for slot 1 RLLog.Info("Module - Rom memory card for Slot 1 should be: " . romMemCard1.FileFullPath) RLLog.Info("Module - Current memory card inserted in PCSX2's ini in Slot 1 is: " . currentMemCard1.FileFullPath) If (currentMemCard1 != romName . ".ps2") { ; if current memory card in slot 1 does not match this romName, switch to one that does if exist or load a default one If !romMemCard1.Exist() ; first check if romName.ps2 memory card exists If !defaultMemCard.Exist() RLLog.Error("Module - A default memory card for Slot 1 was not found in """ . memCardPath . """. Please create an empty memory card called ""default.ps2"" in this folder for per-game memory card support.") Else { defaultMemCard.Copy(romMemCard1.FileFullPath) ; create a new blank memory card for this game RLLog.Info("Module - Creating a new blank memory card for this game in Slot 1: " . romMemCard1.FileFullPath) } pcsx2Ini.Write(romName . ".ps2", "MemoryCards", "Slot1_Filename") ; update the ini to use this rom's card RLLog.Info("Module - Switched memory card in Slot 1 to: " . romMemCard1.FileFullPath) } } hideEmuObj := Object(emuBootingWindow,0,emuGUIWindow,0,emuPrimaryWindow,1) 7z(romPath, romName, romExtension, SevenZExtractPath) pcsx2Ini := LoadProperties(pcsx2IniFile.FileFullPath) ; load the config into memory dvdSource := ReadProperty(pcsx2Ini,"CdvdSource") ; read value If (vdEnabled != "true" && romExtension = ".cue") { RLLog.Warning("Module - Virtual Drive is disabled but you supplied a .cue as your rom which is not supported by PCSX2") pcsx2GameBin := new File(romPath . "\" . romName . ".bin") pcsx2GameIso := new File(romPath . "\" . romName . ".iso") If pcsx2GameBin.Exist() { romExtension := ".bin" RLLog.Warning("Module - Found a .bin file with the same name as your cue, using it instead. Please change the order of your rom extensions if you want bins to be found first.") } Else If pcsx2GameIso.Exist() { romExtension := ".iso" RLLog.Warning("Module - Found a .iso file with the same name as your cue, using it instead. Please change the order of your rom extensions if you want isos to be found first.") } } ; Mount the CD using a Virtual Drive If vdOveride ; this allows per-game Virtual Drive support because some games boot to black when Virtual Drive is enabled vdEnabled := vdOveride If (vdEnabled = "true" && StringUtils.Contains(romExtension,"\.mds|\.mdx|\.b5t|\.b6t|\.bwt|\.ccd|\.cue|\.isz|\.nrg|\.cdi|\.iso|\.ape|\.flac")) { ; if Virtual Drive is enabled and using an image type Virtual Drive can load If !cdvd { vdCDVDPlugin := moduleIni.Read("Settings", "VD_CDVD_Plugin","","",1) If vdCDVDPlugin cdvd := vdCDVDPlugin } cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : "" If (dvdSource != "Plugin") { RLLog.Info("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can read from Virtual Drive.") WriteProperty(pcsx2Ini,"CdvdSource","Plugin") ; write a new value to the pcsx2IniFile SaveProperties(pcsx2IniFile.FileFullPath,pcsx2Ini) ; save pcsx2IniFile to disk } pcsx2cdvdIni := new IniFile(pcsx2IniFolder . "\cdvdGigaherz.ini") dvdDrive := pcsx2cdvdIni.Read("Config", "Source") ; cdvd drive If StringUtils.InStr(dvdDrive,"@") { If (vdDriveLetter != "") pcsx2cdvdIni.Write(vdDriveLetter, "Config", "Source") Else ScriptError("You are using a Virtual Drive but have not selected the drive you want to use in PCSX2 CDVD Plugin settings. Select your drive first, either in RLUI Virtual Drive Third Party Settings or within the PCSX2's plugin settings, then try launching again.") } Else If (dvdDrive != vdDriveLetter) { RLLog.Warning("Module - PCSX2 is set to use drive """ . dvdDrive . """ but RocketLauncher is set to use """ . vdDriveLetter . """. Ignore this warning if this is expected.") } VirtualDrive("mount",romPath . "\" . romName . romExtension) HideAppStart(hideEmuObj,hideEmu) errLvl := primaryExe.Run(" --usecd" . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, "UseErrorLevel") usedVD := 1 ; tell the rest of the script to use VD methods } Else If StringUtils.Contains(romExtension,"\.iso|\.mdf|\.nrg|\.bin|\.img|\.gz|\.cso|\.dump") ; the only formats PCSX2 supports loading directly { If !cdvd { imageCDVDPlugin := moduleIni.Read("Settings", "Image_CDVD_Plugin","","",1) If imageCDVDPlugin cdvd := imageCDVDPlugin } cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : "" If (dvdSource != "Iso") { RLLog.Info("Module - CdvdSource was not set to ""Iso"", changing it so PCSX2 can launch this " . romExtension . " image directly") WriteProperty(pcsx2Ini,"CdvdSource","Iso") ; write a new value to the pcsx2IniFile SaveProperties(pcsx2IniFile.FileFullPath,pcsx2Ini) ; save pcsx2IniFile to disk } HideAppStart(hideEmuObj,hideEmu) errLvl := primaryExe.Run(" """ . romPath . "\" . romName . romExtension . """ " . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, "UseErrorLevel") } Else If StringUtils.Contains(romExtension,"\.bz2") ; special case format that requires plugin mode and pcsx2 loads it directly { If !cdvd { linuzCDVDPlugin := moduleIni.Read("Settings", "Linuz_CDVD_Plugin","","",1) If linuzCDVDPlugin cdvd := linuzCDVDPlugin } cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : "" If (dvdSource != "plugin") { RLLog.Info("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can launch this " . romExtension . " image directly") WriteProperty(pcsx2Ini,"CdvdSource","Plugin") ; write a new value to the pcsx2IniFile SaveProperties(pcsx2IniFile.FileFullPath,pcsx2Ini) ; save pcsx2IniFile to disk } oldHex := Registry.Read("HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", "IsoFile") ; read last used bz2 image newHex := StringUtils.StringToHex(romPath . "\" . romName . romExtension) ; convert new bz2 image path to hex i := 512 - StringUtils.StringLength(newHex) ; get total amount of 0's to add to end of hex to make it 512 bytes Loop % i newHex := newHex . "0" ; add required bytes to end If (oldHex != newHex) { RLLog.Info("Module - Writing new bz2 path to registry") Registry.Write("REG_BINARY", "HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", "IsoFile", newHex) ; write new bz2 path to registry } HideAppStart(hideEmuObj,hideEmu) errLvl := primaryExe.Run(" """ . romPath . "\" . romName . romExtension . """ " . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, "UseErrorLevel") } Else ScriptError("You are trying to run a rom type of """ . romExtension . """ but PCSX2 only supports loading iso|mdf|nrg|bin|img|gz directly. Please turn on Virtual Drive and/or 7z support or put ""cue"" last in your rom extensions for " . MEmu . " instead.") If errLvl ScriptError("Error launching emulator, closing script.") emuPrimaryWindow.Wait() emuPrimaryWindow.WaitActive() BezelDraw() ; If (hideConsole = "true") { ; should not be needed anymore ; TimerUtils.SetTimerF("HidePCSX2Console", 10) ; SetTimerF("HidePCSX2Console", 10) ; emuBootingWindow.Set("Transparent",0) ; ,"Booting ahk_class wxWindowNR","","fps:","fps:") ; hiding the console window ; emuGUIWindow.Set("Transparent",0) ;,"PCSX2 ahk_class wxWindowNR","","fps:","fps:") ; hiding the GUI window with the menubar ; } SetTitleMatchMode 2 ; Wrong window might be detected in the next loop if we only use the class name for WinGetTitle so we will add fps to it Loop { ; Looping until pcsx2 is done loading game Sleep, 200 loopWinTitle := emuLoadingWindow.GetTitle(0) ; Excluding the title of the GUI window so we can read the title of the game window instead StringUtils.RegExMatch(loopWinTitle,"(?<=\()(.*?)(?=\))",winText) ;,1,0) ; Only get value between parenthesis If (winText > 0) { ; If FPS shows any value, break out RLLog.Debug("Module - Game is now running, waiting for exit") Break } If A_Index > 150 ; After 30 seconds, error out ScriptError("There was an error detecting when PCSX2 finished loading your game. Please report this so the module can be fixed.") ; Old method here in case devs change something back ; StringSplit, winTextSplit, winTitle, |, %A_Space% ; If (winTextSplit10 != "") ; 10th position in the array is empty until game actually starts ; Break ; tipText:= ; Loop % winTextSplit0 ; tipText .= "`nposition " . A_Index . ": " . winTextSplit%A_Index% ; ToolTip, % "Loop: " . A_Index . "`ntitle: " . winTitle . "`ntext: " . winText . tipText,0,0 } HideAppEnd(hideEmuObj,hideEmu) FadeInExit() primaryExe.Process("WaitClose") If usedVD VirtualDrive("unmount") 7zCleanUp() BezelExit() FadeOutExit() ExitModule() MultiGame: ; msgbox % "selectedRom = " . selectedRom . "`nselected game = " . currentButton . "`nmgRomPath = " . mgRomPath . "`nmgRomExt = " . mgRomExt . "`nmgRomName = " . mgRomName ; Unmount the CD from Virtual Drive If usedVD VirtualDrive("unmount") Sleep, 500 ; Required to prevent your Virtual Drive from bugging ; Mount the CD using Virtual Drive If usedVD VirtualDrive("mount",selectedRom) Return ; HidePCSX2Console: ; hideConsoleTimer++ ; If emuBootingWindow.Exist() ; { RLLog.Info("Module - HidePCSX2Console - Console window found, hiding it out of view.") ; emuBootingWindow.Set("Transparent",0) ; ,"Booting ahk_class wxWindowNR","","fps:","fps:") ; hiding the console window ; emuGUIWindow.Set("Transparent",0) ; ,"PCSX2 ahk_class wxWindowNR","","fps:","fps:") ; hiding the GUI window with the menubar ; SetTimer("HidePCSX2Console", "Off") ; } Else If (hideConsoleTimer >= 200) ; SetTimer("HidePCSX2Console", "Off") ; Return ; HidePCSX2Console() { ; Static hideConsoleTimer ; hideConsoleTimer++ ; If emuBootingWindow.Exist() ; { RLLog.Info("Module - HidePCSX2Console - Console window found, hiding it out of view.") ; emuBootingWindow.Set("Transparent",0) ; ,"Booting ahk_class wxWindowNR","","fps:","fps:") ; hiding the console window ; emuGUIWindow.Set("Transparent",0) ; ,"PCSX2 ahk_class wxWindowNR","","fps:","fps:") ; hiding the GUI window with the menubar ; TimerUtils.SetTimerF("HidePCSX2Console", "Off") ; } Else If (hideConsoleTimer >= 200) ; TimerUtils.SetTimerF("HidePCSX2Console", "Off") ; } CloseProcess: FadeOutStart() If (fullscreen = "true") { ; emuPrimaryWindow.CreateControl("wxWindowNR1") ; instantiate new control for wxWindowNR1 ; emuPrimaryWindow.GetControl("wxWindowNR1").Send("Esc") ; Send ESC to the main window when fullscreen is true to close the emu emuPrimaryWindow.Close() } Else { emuGUIWindow.MenuSelectItem("System","Pause") emuGUIWindow.Close() } Return 15:39:31:929 | RL | INFO | +31 | BuildScript - Loaded Pause scripts 15:39:31:931 | RL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 15:39:31:933 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 15:39:31:933 | RL | WARNING | +0 | BuildScript - "C:\RocketLauncher\Lib\User Functions.ahk" not found 15:39:31:933 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 15:39:31:935 | RL | INFO | +0 | Main - Module is built 15:39:31:935 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\AutoHotkey.dll exists 15:39:31:940 | RL | INFO | +0 | Main - Running module 15:39:32:172 | MD | INFO | +N/A | Module initialized 15:39:32:173 | MD | INFO | +0 | LoadPreferredControllers - Started 15:39:32:173 | MD | INFO | +0 | GetJoystickArray - Started 15:39:32:200 | MD | INFO | +31 | GetJoystickGUID - Started 15:39:32:200 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118001444553540000 15:39:32:202 | MD | INFO | +0 | GetJoystickGUID - Started 15:39:32:202 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118002444553540000 15:39:32:203 | MD | INFO | +0 | GetJoystickGUID - Started 15:39:32:204 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118003444553540000 15:39:32:205 | MD | INFO | +0 | GetJoystickGUID - Started 15:39:32:205 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118004444553540000 15:39:32:205 | MD | INFO | +0 | GetJoystickArray - Ended 15:39:32:205 | MD | INFO | +0 | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List 15:39:32:205 | MD | INFO | +0 | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers 15:39:32:205 | MD | INFO | +0 | ChangeJoystickID - Started 15:39:32:206 | MD | INFO | +0 | ChangeJoystickID - Ended 15:39:32:206 | MD | INFO | +0 | ChangeJoystickID - Started 15:39:32:206 | MD | INFO | +0 | ChangeJoystickID - Ended 15:39:32:206 | MD | INFO | +0 | ChangeJoystickID - Started 15:39:32:206 | MD | INFO | +0 | ChangeJoystickID - Ended 15:39:32:206 | MD | INFO | +0 | ChangeJoystickID - Started 15:39:32:206 | MD | INFO | +0 | ChangeJoystickID - Ended 15:39:32:206 | MD | INFO | +0 | LoadPreferredControllers - Ended 15:39:32:206 | MD | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Profiles\JoyToKey\JoyToKey.exe exists 15:39:32:207 | MD | INFO | +0 | Keymapper - Loading joytokey 15:39:32:207 | MD | INFO | +0 | RunKeymapper - Started, using method "load" 15:39:32:207 | MD | INFO | +0 | GetJoystickArray - Started 15:39:32:233 | MD | INFO | +31 | GetJoystickGUID - Started 15:39:32:233 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118001444553540000 15:39:32:235 | MD | INFO | +0 | GetJoystickGUID - Started 15:39:32:236 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118002444553540000 15:39:32:238 | MD | INFO | +0 | GetJoystickGUID - Started 15:39:32:238 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118003444553540000 15:39:32:257 | MD | INFO | +32 | GetJoystickGUID - Started 15:39:32:257 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118004444553540000 15:39:32:257 | MD | INFO | +0 | GetJoystickArray - Ended 15:39:32:257 | MD | WARNING | +0 | GetProfile - Keymapper support is enabled for "joytokey", but could not find a "Dragon Quest VIII - Journey of the Cursed King (USA)", "PCSX2", "Sony Playstation 2", default, a "" player 1 profile or a blank profile in "C:\RocketLauncher\Profiles\joytokey" for controller "" 15:39:32:257 | MD | INFO | +0 | RunJoyToKey - Started 15:39:32:268 | MD | INFO | +0 | WinClose - Closing: JoyToKey ahk_class TMainForm 15:39:32:499 | MD | INFO | +234 | Process - WaitClose JoyToKey.exe 2 15:39:32:500 | MD | INFO | +0 | RunJoyToKey - Ended 15:39:32:500 | MD | INFO | +0 | RunKeymapper - Ended 15:39:32:500 | MD | INFO | +0 | StartModule - Started 15:39:32:501 | MD | INFO | +0 | StartModule - MEmu: PCSX2 MEmuV: 1.5.0-dev-263 MURL: http://pcsx2.net/ MAuthor: djvj MVersion: 2.2.1 MCRC: 5E3D250C iCRC: 65DD0603 MID: MSystem: "Sony PlayStation 2" 15:39:32:501 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Sony Playstation 2" 15:39:32:501 | MD | INFO | +0 | PluginInit - Started 15:39:32:501 | MD | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Databases\Sony Playstation 2\Sony Playstation 2.xml exists 15:39:32:505 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 15:39:32:526 | MD | INFO | +31 | BuildAssetsTable - Ended 15:39:32:526 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 15:39:32:559 | MD | INFO | +31 | BuildAssetsTable - Ended 15:39:32:559 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 15:39:32:560 | MD | INFO | +0 | BuildAssetsTable - Ended 15:39:32:560 | MD | INFO | +0 | PluginInit - Ended 15:39:32:563 | MD | INFO | +0 | StartModule - Ended 15:39:32:563 | MD | INFO | +0 | RIniFile.Read - Module - Fullscreen: true (DEFAULT) 15:39:32:563 | MD | INFO | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - AspectRatio: Stretch 15:39:32:563 | MD | INFO | +0 | RIniFile.Read - Module - noGUI: false (DEFAULT) 15:39:32:564 | MD | INFO | +0 | RIniFile.Read - Module - PerGameMemoryCards: false (DEFAULT) 15:39:32:564 | MD | INFO | +0 | RIniFile.Read - Module - HideConsole: true (DEFAULT) 15:39:32:564 | MD | INFO | +0 | RIniFile.Read - Module - cfgpath: C:\PCSX2\Game Configs (DEFAULT) 15:39:32:564 | MD | INFO | +0 | RIniFile.Read - Module - AutoCreateINIDir: false (DEFAULT) 15:39:32:564 | MD | INFO | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - DefaultINISPath: ..\Users\Beta\Documents\PCSX2\inis_1.4.0 15:39:32:564 | MD | INFO | +0 | RIniFile.Read - Module - fullboot: false (DEFAULT) 15:39:32:564 | MD | INFO | +0 | RIniFile.Read - Module - gs: (NO VALUE) 15:39:32:565 | MD | INFO | +0 | RIniFile.Read - Module - pad: (NO VALUE) 15:39:32:565 | MD | INFO | +0 | RIniFile.Read - Module - spu2: (NO VALUE) 15:39:32:565 | MD | INFO | +0 | RIniFile.Read - Module - cdvd: (NO VALUE) 15:39:32:565 | MD | INFO | +0 | RIniFile.Read - Module - usb: (NO VALUE) 15:39:32:565 | MD | INFO | +0 | RIniFile.Read - Module - fw: (NO VALUE) 15:39:32:565 | MD | INFO | +0 | RIniFile.Read - Module - dev9: (NO VALUE) 15:39:32:566 | MD | INFO | +0 | RIniFile.Read - Module - VDOveride: (NO VALUE) 15:39:32:566 | MD | INFO | +0 | RIniFile.Read - Module - nohacks: false (DEFAULT) 15:39:32:566 | MD | INFO | +0 | RIniFile.Read - Module - gamefixes: (NO VALUE) 15:39:32:566 | MD | INFO | +0 | RIniFile.Read - Module - MSAA: 0 (DEFAULT) 15:39:32:566 | MD | INFO | +0 | RIniFile.Read - Module - Skipdraw: 0 (DEFAULT) 15:39:32:566 | MD | INFO | +0 | RIniFile.Read - Module - Half-pixel_Offset: 0 (DEFAULT) 15:39:32:566 | MD | INFO | +0 | RIniFile.Read - Module - Wild_Arms_Offset: 0 (DEFAULT) 15:39:32:566 | MD | INFO | +0 | RIniFile.Read - Module - Fast_Accurate_Blending: 0 (DEFAULT) 15:39:32:566 | MD | INFO | +0 | RIniFile.Read - Module - Alpha_Stencil: 0 (DEFAULT) 15:39:32:567 | MD | INFO | +0 | RIniFile.Read - Module - Align_Sprite: 0 (DEFAULT) 15:39:32:567 | MD | INFO | +0 | RIniFile.Read - Module - Alpha: 0 (DEFAULT) 15:39:32:567 | MD | INFO | +0 | RIniFile.Read - Module - Preload_Data_Frame: 0 (DEFAULT) 15:39:32:567 | MD | INFO | +0 | RIniFile.Read - Module - Round_Sprite: 0 (DEFAULT) 15:39:32:567 | MD | INFO | +0 | RIniFile.Read - Module - Sprite: 0 (DEFAULT) 15:39:32:567 | MD | INFO | +0 | RIniFile.Read - Module - TC_Offset: 0 (DEFAULT) 15:39:32:586 | MD | INFO | +31 | Module - PCSX2 is operating in a standard installation mode 15:39:32:586 | MD | INFO | +0 | File.CheckFile - Checking if "C:\Users\Beta\Documents\PCSX2\inis_1.4.0\PCSX2_ui.ini" exists 15:39:32:588 | MD | INFO | +0 | File.CheckFile - Checking if "C:\Users\Beta\Documents\PCSX2\inis_1.4.0\GSdx.ini" exists 15:39:32:589 | MD | INFO | +0 | Module - Using PCSX2's default configuration folder: "C:\Users\Beta\Documents\PCSX2\inis_1.4.0" 15:39:32:589 | MD | INFO | +0 | IniFile.Write - SECTION: [GSWindow] - KEY: AspectRatio - VALUE: Stretch - FILE: C:\Users\Beta\Documents\PCSX2\inis_1.4.0\PCSX2_ui.ini 15:39:32:589 | MD | INFO | +0 | IniFile.Write - SECTION: [Settings] - KEY: UserHacks - VALUE: - FILE: C:\Users\Beta\Documents\PCSX2\inis_1.4.0\GSdx.ini 15:39:32:589 | MD | INFO | +0 | 7z - Started, received G:\Games\Sony Playstation 2\Dragon Quest VIII - Journey of the Cursed King (USA).7z. If rom is an archive, it will extract to C:\TEMP GAMES HS 15:39:32:590 | MD | INFO | +0 | CheckFile - Checking if G:\Games\Sony Playstation 2\Dragon Quest VIII - Journey of the Cursed King (USA).7z exists 15:39:32:787 | MD | INFO | +203 | 7z - Archive name matches rom name; DLL found rom inside archive using "findFileInZip": "Dragon Quest VIII - Journey of the Cursed King (USA).iso" 15:39:32:789 | MD | INFO | +0 | 7z - The sevenZExtractPath has 11114 MB of free space which is enough to extract this game: 4180 MB 15:39:32:789 | MD | INFO | +0 | 7z - Starting 7z extraction of G:\Games\Sony Playstation 2\Dragon Quest VIII - Journey of the Cursed King (USA).7z to C:\TEMP GAMES HS\Dragon Quest VIII - Journey of the Cursed King (USA) 15:42:42:593 | MD | INFO | +189806 | 7z - Finished 7z extraction which took 310 seconds 15:42:42:593 | MD | WARNING | +0 | 7z - romPath changed from "G:\Games\Sony Playstation 2" to "C:\TEMP GAMES HS\Dragon Quest VIII - Journey of the Cursed King (USA)" 15:42:42:593 | MD | WARNING | +0 | 7z - romName changed from "Dragon Quest VIII - Journey of the Cursed King (USA)" to "Dragon Quest VIII - Journey of the Cursed King (USA)" 15:42:42:593 | MD | WARNING | +0 | 7z - romExtension changed from ".7z" to ".iso" 15:42:42:593 | MD | INFO | +0 | 7z - Ended 15:42:42:593 | MD | INFO | +0 | LoadProperties - Started and loading this cfg into memory: 15:42:42:593 | MD | INFO | +0 | LoadProperties - Ended 15:42:42:593 | MD | INFO | +0 | RIniFile.Read - Module - Image_CDVD_Plugin: (NO VALUE) 15:42:42:593 | MD | INFO | +0 | Module - CdvdSource was not set to "Iso", changing it so PCSX2 can launch this .iso image directly 15:42:42:593 | MD | INFO | +0 | SaveProperties - Started and saving this cfg to disk: 15:42:42:593 | MD | INFO | +0 | SaveProperties - Ended 15:42:42:594 | MD | INFO | +0 | Process.Run - Running: C:\PCSX2\pcsx2.exe "C:\TEMP GAMES HS\Dragon Quest VIII - Journey of the Cursed King (USA)\Dragon Quest VIII - Journey of the Cursed King (USA).iso" --fullscreen 15:42:42:675 | MD | INFO | +78 | Window.Wait - Waiting for window "ahk_class wxWindowNR" 15:42:42:906 | MD | INFO | +234 | Window.WaitActive - Waiting for "ahk_class wxWindowNR" 15:42:45:167 | MD | INFO | +2262 | Process.Process - "WaitClose" "pcsx2.exe" 15:43:30:065 | MD | INFO | +44897 | CloseProcess - Started, user requested to end launched application 15:43:30:926 | MD | INFO | +858 | CloseProcess - Ended 15:43:31:476 | MD | INFO | +546 | 7zCleanUp - Started 15:43:31:616 | MD | INFO | +141 | 7zCleanUp - Deleted C:\TEMP GAMES HS\Dragon Quest VIII - Journey of the Cursed King (USA) 15:43:31:616 | MD | INFO | +0 | 7zCleanUp - Ended 15:43:31:616 | MD | INFO | +0 | ExitModule - Started 15:43:31:616 | MD | INFO | +0 | Starting Updating Statistics: 15:43:31:746 | MD | INFO | +125 | Game section statistics updated. 15:43:31:746 | MD | INFO | +0 | RunKeymapper - Started, using method "unload" 15:43:31:746 | MD | INFO | +0 | GetJoystickArray - Started 15:43:31:766 | MD | INFO | +31 | GetJoystickGUID - Started 15:43:31:766 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118001444553540000 15:43:31:766 | MD | INFO | +0 | GetJoystickGUID - Started 15:43:31:776 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118002444553540000 15:43:31:776 | MD | INFO | +0 | GetJoystickGUID - Started 15:43:31:776 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118003444553540000 15:43:31:776 | MD | INFO | +0 | GetJoystickGUID - Started 15:43:31:776 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 002263C20480E6118004444553540000 15:43:31:776 | MD | INFO | +0 | GetJoystickArray - Ended 15:43:31:776 | MD | INFO | +0 | RunJoyToKey - Started 15:43:31:776 | MD | INFO | +0 | WinClose - Closing: JoyToKey ahk_class TMainForm 15:43:31:876 | MD | INFO | +109 | Process - WaitClose JoyToKey.exe 2 15:43:31:876 | MD | INFO | +0 | RunJoyToKey - Ended 15:43:31:876 | MD | INFO | +0 | RunKeymapper - Ended 15:43:31:876 | MD | INFO | +0 | ExitModule - Ended End of Module Logs 15:43:31:986 | RL | INFO | +240054 | Main - Module ended, exiting RocketLauncher normally 15:43:31:986 | RL | INFO | +0 | ExitScript - Started 15:43:31:986 | RL | INFO | +0 | ExitScript - Restoring taskbar 15:43:32:211 | RL | INFO | +219 | SystemCursor - Restoring mouse cursor 15:43:32:221 | RL | INFO | +15 | ExitScript - Restored cursor
drphilgood Posted September 25, 2016 Author Posted September 25, 2016 Thanks. I realized after looking at the log it was extracting the .7z version of the game. I have the .ISO in the same directory but I guess it was defaulting to the .7z file. Is it recommended to leave the .7z archives and just temp the files every time or should i use .gz format? Does it do the same for .gz format? meaning the load times? Thanks.
badboo Posted September 28, 2016 Posted September 28, 2016 On the long run, you end up needing more space. I prefer leaving the roms on .7z. This happened to me and now my 5tb HDD is full. If I didn't have the majority of the PS2 collection on .7z, I would have had to get another hdd by this time. The 7z made a big difference.
