WinAEU vs FS-AEU
Styphelus
Which is the recommended emulator for the Amiga?
I was able to get both running but can't really tell the difference. I've been reading that FS-AEU may be more compatible and more accurate but not sure how it works under Rocketluanher. My roms are in lha format and work fine from within the emulator but when I try suing rocketlauncher it says it doesn't support .lha files. I'm also not sure about save states.
Should I just stick to WinAEU?
  • 3 weeks later...
I would love to hear about this as well. I just learned about this other one and I have had nothing but headaches trying to setup the controls and etc in WinUAE. It's the ONLY aspect of the Amiga and CD32 sections of my build that are unfinished.
I'm not sure what file format my amiga games are in but I could give it a try and see what happens.
If .lha files work in the emulator then I am sure you just need to add that extension to the list of acceptable roms. To do that open rlui, click on emulators, find the emulator in question, double click it to open the dialogue, add |lha at the end of list of extensions.
Sent from my SM-G920V using Tapatalk
I'm having awful trouble with WIN UAE (cpu over 100%) that I can't solve.
Did you follow any particular thread/link setting up FS-UAE that you could share?
