progets Posted October 4, 2016 Posted October 4, 2016 Does anyone have hiscore working in a current version of MAME64? If so, how do you get it working? I have done a lot of searching but most things are for the older non-LUA configuration and/or for MAMEUIFX. Any help or links would be great. Thanks.
phulshof Posted October 4, 2016 Posted October 4, 2016 I have it working under Linux using the LUA scripts. I'd have to check how to apply that to Windows, but I presume it would be very similar.
sevenseal Posted October 5, 2016 Posted October 5, 2016 it is enable through plugin which is provided with a fresh install of mame, two way to fo it, by navigating in general menu and enable in plugin tab, or go into the mame.ini file and place entry for desired plugin
progets Posted October 5, 2016 Author Posted October 5, 2016 Thanks guys. I have this working now. This was much easier than the older MAME versions. I was using a distributed MAME version that didn't have the "plugins" folder and I didn't realize that it was included in the official MAME download. I was using a "plugins" folder I found on the web and it wasn't from the same MAME version. I also thought that hiscore would be enabled in the "mame.ini" but that's no longer the case, now it's in the "plugins.ini" file (or via the UI).
