Mame slider wont save
floodie
Hi - as per the title... If I boot hyperspin, then Mame, then say Kung fu master. It is very bright so I press the weird Tilde key (next to the "1) and it opens up a slider/scroll bar at the bottom overlayed on top of the game.. I can arrow up and down through various options which all effect the image in someway (is this hlsl?). Anyway, if I get it right then exit - when I restart its back to the way it was.. All settings lost...
however, all key changes etc save fine.
Any thoughts?
thank you
David
That's the way it's always been I'm afraid, mame has never saved the slider settings.
You have to write your changes down and then add them to your ini file/s
I HAVE TO DO WHAT!!! WRITE THEM DOWN!!.... how dare thee..
:) ah ok not a problem, I thought it was something I was doing wrong... that's for confirming, I mustve done it around 10 times doubting I was doing it each time!..
HLSL isn't too bad, id like to try GLSL though, any idea how I "switch" to that?. and where the settings are for it?... the .ini seems to only have HLSL settings
I personally prefer glsl and also have been messing with bgfx. If you use the Geom shader with bgfx, I'm sure I read the slider settings would stick.
Anyway glsl is much simpler, you set it and leave it, no messing with settings.
Try this.
Ah I started watching that in bed last night but fell asleep! remember the starfield desktop... Nice one ill give it a look after work later when I'm more awake.
Glad I was able to make you nod off. :)
