Loading Sega Genesis roms in HyperSpin
slimmo
Hi All,
firstly i'm a complete noob to this so if this is a silly question i do apologise for that.
so i have followed simply austin's guides in installing hyperspin and rocket launcher and have got MAME and N64 working but i have an issue with Sega Genesis.
after selecting the game i wish to play from within hyperspin i get about a 20 second delay and then a black screen with an error.
There was a error waiting for the window "". Please check you have the correct version emulator installed for this module. followed any notes in the module and have the emulator working outside your frontend first. also turn off fade to see if you are hiding your problem.
so games work from retroarch and from within rocketlauncher but not from hyperspin.
here is a copy of my hyperspin log incase that help someone with alot more talent than me.
09:34:51 PM |  HyperSpin Started
09:34:51 PM |  Going windowed mode
09:34:51 PM |  Checking for updates
09:34:51 PM |  Update Check Complete
09:34:51 PM |  Startup program unavailable
09:34:51 PM |  Playing intro video
09:34:53 PM |  Menu Mode is multi
09:34:53 PM |  Loading Main Menu.xml
09:34:53 PM |  Main Menu.xml successfully loaded
09:34:54 PM |  Main Menu wheel loaded successfully
09:34:55 PM |  Loading Sega Genesis.xml
09:34:55 PM |  Main Menu.xml successfully loaded
09:34:56 PM |  Sega Genesis wheel loaded successfully
09:35:06 PM |  Launching Game
09:35:06 PM |  Using HyperLaunch
09:35:06 PM |  Getting Launcher path
09:35:06 PM |  Launcher located at C:\RocketLauncher\RocketLauncher.exe
09:35:06 PM |  Running Launcher
09:35:06 PM |  Launcher Command Line is: C:\RocketLauncher\RocketLauncher.exe "Sega Genesis" "Aero the Acro-Bat 2"
09:35:53 PM |  Loading Main Menu.xml
09:35:53 PM |  Main Menu.xml successfully loaded
09:35:53 PM |  Main Menu wheel loaded successfully
09:35:55 PM |  Exit program unavailable
09:35:55 PM |  Quiting Hyperspin
09:35:55 PM |  Bye!
hoping someone can help me with this as i could use an early night after being up until 3am trying different things to try and get this workind.
many thanks
Slim
Can you run a Geneis rom directly from RocketlauncerUI?
your HS log can  only tell us if your HS exe is finding Rocketlauncher.
please try to load a game from RocketLauncherUI,  and let us know what happens.
more than likely you will get the same error, in witch case you need to post your Rocketlauncher log.
yes i can run roms from RocketLauncherUI fine.
however if i select modules and click the validate ini files for selected module i get this
ini file Retroarch.ini/ section %SystemName% is referencing an invalid group:videooptions
does that help at all
If I were you I would just go to the download section and download gigapig's pre-made hyperspin set-up. And then go to the forum post that explains what needs set-up. (Link for forum post is in the download description). You'll have 20-30 systems set-up and working quickly.
Sent from my SM-G920V using Tapatalk
Hi All
i have done a complete re-install just incase i have missed something along the way.
so now i have this error in rocketlaunch (maybe i should be posting on that forum too)
ScriptError - There was an error waiting for the window "". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
if i try and use gens it seems to boot gens only and never loads the game
and the same for fusion.
so i'm sure that it is something stupid that i'm overlooking but just really sure where to start.
Dabil whilst i'm sure your right with doing it the way you have said my problem is i wouldn't have learnt where to start looking when i get errors so would prefer to stick at it for a while longer and see who can come to my rescue!!.  lol
fuison and Gens haven't been updated in years
I would suggest you consolidate your Sega needs to Mednafen
Genesis, 32x, Master System, GG  and now Saturn!!!!!!
and if you decide to post your RL log,  I might be able to help,  but I can't guess what is wrong with the limited info you want to provide.
Hi Assassin
Thanks for the reply.
more than happy to post whatever is needed just not sure how to find them.
but i have found this and hope it's what your after.
03:22:04:620 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com)
03:22:04:624 | RL |   WARNING  | +0     | Main - You have "Logging_Show_Command_Window" enabled. This is only for showing errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
03:22:04:624 | RL |   WARNING  | +0     | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
03:22:04:624 | RL |   WARNING  | +0     | Main - You cannot use debug console and show/log a console for an emulator simultaneously. Turning off debug console to avoid errors launching.
03:22:04:722 | RL |      INFO  | +94    | Main - System Specs:
RocketLauncher Dir: C:\RocketLauncher
RocketLauncher is: 32-bit
OS: Microsoft Windows 7 Professional
SKU: Professional
Total Memory: 3454.49 MB
Free Memory: 1836.14 MB
Used Memory: 1618.355 MB
SystemType: 32-bit
Physical Processors: 1
Logical Processors: 2
GPU 1 Name: NVIDIA GeForce 6150SE nForce 430
GPU 1 RAM: 128.00 MB
GPU 1 Driver Version: 9.18.13.783
Sound 1 Device: High Definition Audio Device
Sound 1 Status: Enabled
System Locale: en-GB
Formats Locale: en-GB
Windows UI Language: en-US
Text Encoding: Windows-1252
OS Admin Status: Yes
RL Compatibility Flags:
Latest .Net Version: v4.0.30319
Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x860 work) [32bit] [60hz] [Landscape]  (Primary)
Current AHK Desktop Width: 1440
Current AHK Desktop Height: 900
Monitor #1 DPI: 100
ErrorMode: 0
AutoHotkey Path:
AHK Version: 1.1.13.00
Unicode: No
03:22:04:723 | RL |      INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\RocketLauncher.exe exists
03:22:04:724 | RL |      INFO  | +0     | Main - Raw CLI received: "-s Sega Genesis -r 3 Ninjas Kick Back (USA) -f C:\HyperSpin\HyperSpin.exe -p HyperSpin -c 1 -o 1"
03:22:04:724 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
03:22:04:725 | RL |      INFO  | +0     | Main - RocketLauncher received "Sega Genesis" and "3 Ninjas Kick Back (USA)"
03:22:04:737 | RL |      INFO  | +15    | Main - Did not find a "C:\RocketLauncher\Settings\Sega Genesis\Game Options.ini" file, skipping any game-specific options.
03:22:04:737 | RL |      INFO  | +0     | Main - 3 Ninjas Kick Back (USA) is using the default emulator: RetroArch
03:22:04:737 | RL |      INFO  | +0     | Main - Checking for a [RetroArch] section in C:\RocketLauncher\Settings\Sega Genesis\Emulators.ini
03:22:04:737 | RL |      INFO  | +0     | Main - Checking for a [RetroArch] section in C:\RocketLauncher\Settings\Global Emulators.ini
03:22:04:739 | RL |      INFO  | +0     | Main - Found [RetroArch] in C:\RocketLauncher\Settings\Global Emulators.ini
03:22:04:739 | RL |      INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Modules\RetroArch\RetroArch.ahk exists
03:22:04:749 | RL |      INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
03:22:04:749 | RL |      INFO  | +0     | Main - 3 Ninjas Kick Back (USA) will use module: C:\RocketLauncher\Modules\RetroArch\RetroArch.ahk
03:22:04:756 | RL |   WARNING  | +0     | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "C:\RocketLauncher\Settings\Global RocketLauncher.ini"
03:22:04:756 | RL |   WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "C:\RocketLauncher\Settings\Sega Genesis\RocketLauncher.ini"
03:22:04:801 | RL |      INFO  | +47    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
03:22:04:803 | RL |      INFO  | +0     | CheckFile - Checking if C:\HyperSpin\Emulators\RetroArch\retroarch.exe exists
03:22:04:804 | RL |      INFO  | +0     | Main - INI Keys read
03:22:04:805 | RL |      INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.exe exists
03:22:04:806 | RL |      INFO  | +15    | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.dll exists
03:22:04:807 | RL |      INFO  | +0     | CreateRomMapTable - Started
03:22:04:812 | RL |      INFO  | +0     | AltNameExistCheck - Found rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).bin
03:22:04:812 | RL |      INFO  | +0     | CreateRomMapTable - Ended, No mapping inis found.
03:22:04:814 | RL |      INFO  | +0     | Main - "3 Ninjas Kick Back (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
03:22:04:815 | RL |   WARNING  | +N/A   | Main - SkipChecks is enabled and set to: Rom Extension
03:22:04:815 | RL |      INFO  | +0     | CheckPaths - Started
03:22:04:815 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).7z
03:22:04:815 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).7z
03:22:04:815 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:815 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).zip
03:22:04:815 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).zip
03:22:04:815 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).sfc
03:22:04:815 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).sfc
03:22:04:815 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).ecm
03:22:04:815 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).ecm
03:22:04:816 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:816 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).gba
03:22:04:816 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).gba
03:22:04:816 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).a78
03:22:04:816 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).a78
03:22:04:816 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).sv
03:22:04:816 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).sv
03:22:04:816 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).gbc
03:22:04:817 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).gbc
03:22:04:817 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:817 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).rpk
03:22:04:817 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).rpk
03:22:04:817 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).gme
03:22:04:817 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).gme
03:22:04:817 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).sc
03:22:04:817 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).sc
03:22:04:817 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).cdt
03:22:04:818 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).cdt
03:22:04:818 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:818 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).ws
03:22:04:818 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).ws
03:22:04:818 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).wsc
03:22:04:818 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).wsc
03:22:04:818 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).ngp
03:22:04:818 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).ngp
03:22:04:818 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).ngc
03:22:04:819 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).ngc
03:22:04:819 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:819 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).vms
03:22:04:819 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).vms
03:22:04:819 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).ipf
03:22:04:819 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).ipf
03:22:04:819 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).n64
03:22:04:819 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).n64
03:22:04:819 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).z64
03:22:04:820 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).z64
03:22:04:820 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:820 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).sg
03:22:04:820 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).sg
03:22:04:820 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).fds
03:22:04:820 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).fds
03:22:04:820 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).caq
03:22:04:820 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).caq
03:22:04:821 | RL |      INFO  | +16    | CheckPaths - Rom not found
03:22:04:821 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).vb
03:22:04:821 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).vb
03:22:04:821 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:821 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).vec
03:22:04:821 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).vec
03:22:04:821 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).wav
03:22:04:821 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).wav
03:22:04:822 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).cas
03:22:04:822 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).cas
03:22:04:822 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:822 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).min
03:22:04:822 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).min
03:22:04:822 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).int
03:22:04:822 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).int
03:22:04:823 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).rom
03:22:04:823 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).rom
03:22:04:823 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:823 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).tap
03:22:04:823 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).tap
03:22:04:823 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).tzx
03:22:04:823 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).tzx
03:22:04:824 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:824 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).nes
03:22:04:824 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).nes
03:22:04:824 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).col
03:22:04:824 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).col
03:22:04:824 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).nds
03:22:04:824 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).nds
03:22:04:825 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).cpr
03:22:04:825 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).cpr
03:22:04:825 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:825 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).gg
03:22:04:825 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).gg
03:22:04:825 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).pce
03:22:04:825 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).pce
03:22:04:826 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).st2
03:22:04:826 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).st2
03:22:04:826 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:826 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).sms
03:22:04:826 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).sms
03:22:04:826 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).smc
03:22:04:826 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).smc
03:22:04:827 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).lnx
03:22:04:827 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).lnx
03:22:04:827 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:827 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).md
03:22:04:827 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).md
03:22:04:827 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).32x
03:22:04:827 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).32x
03:22:04:828 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:828 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).n64
03:22:04:828 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).n64
03:22:04:828 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).a52
03:22:04:828 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).a52
03:22:04:828 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).j64
03:22:04:829 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).j64
03:22:04:829 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:829 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).cso
03:22:04:829 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).cso
03:22:04:829 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).cue
03:22:04:829 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).cue
03:22:04:829 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).iso
03:22:04:830 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).iso
03:22:04:830 | RL |      INFO  | +0     | CheckPaths - Rom not found
03:22:04:830 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).ccd
03:22:04:830 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).ccd
03:22:04:830 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).chd
03:22:04:830 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA)\3 Ninjas Kick Back (USA).chd
03:22:04:831 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).bin
03:22:04:831 | RL |      INFO  | +0     | CheckPaths - Found rom: C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).bin
03:22:04:831 | RL |      INFO  | +0     | CheckPaths - Ended
03:22:04:832 | RL |      INFO  | +0     | BuildScript - User Variables:
; INJECTED VARIABLES
#NoTrayIcon
#InstallKeybdHook
MiscUtils.DetectHiddenWindows("On")
SetTitleMatchMode, 2
SendMode, Event
0 = 12
rlPath = C:\RocketLauncher
pluginPath = C:\RocketLauncher\Plugins
pluginName = HyperSpin
pluginExt = .plugin
contextOnExit = 1
rlMode =
rlTitle = RocketLauncher
rlVersion = 1.1.1.1
rlAuthor = djvj
rlURL = www.rlauncher.com
langFile = C:\RocketLauncher\Data\Language\Localization.ini
primMonitor = 1
frontendPID =
frontendPath = C:\HyperSpin
frontendExe = HyperSpin.exe
frontendExt = exe
frontendName = HyperSpin
frontendDrive = C
exitEmulatorKey = ~Esc
restoreFE = false
exitScriptKey = ~q & ~s
toggleCursorKey = ~e & ~t
emuFullPath = C:\HyperSpin\Emulators\RetroArch\retroarch.exe
emuPath = C:\HyperSpin\Emulators\RetroArch
emuName = RetroArch
emuExt = exe
baseRomPath =
romPath = C:\Users\Owner\Desktop
romPathFromIni = C:\Users\Owner\Desktop|C:\Users\Owner\Desktop\renamed files
romExtension = .bin
romExtensionOrig = .bin
romExtensions = 7z|zip|sfc|ecm|gba|gb|a78|sv|gbc|rpk|gme|sc|cdt|ws|wsc|ngp|ngc|vms|ipf|n64|z64|sg|fds|caq|vb|vec|wav|cas|min|int|rom|tap|tzx|nes|col|nds|cpr|gg|pce|st2|sms|smc|lnx|md|32x|n64|a52|j64|cso|cue|iso|ccd|chd|bin
executable = retroarch.exe
systemDbName = Sega Genesis
systemName = Sega Genesis
dbPath =
dbName = 3 Ninjas Kick Back (USA)
dbExt =
romName = 3 Ninjas Kick Back (USA)
romMapPath = C:\RocketLauncher\Settings\Sega Genesis\Rom Mapping
romMappingEnabled = true
romMappingFirstMatchingExt = true
romMappingHideParent = false
romMappingMenuWidth = 400
romMappingMenuMargin = 65
romMappingTextMargin = 15
romMappingGameNameTextFont = Bebas Neue
romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
romMappingMenuFlagWidth = 55
altArchiveNameOnly =
altRomNameOnly =
altArchiveAndRomName =
altArchiveAndManyRomNames =
altRomNamesOnly =
romMapScenario =
skipchecks = Rom Extension
romMatchExt = false
blockInputTime = 0
blockInputFile = C:\RocketLauncher\Module Extensions\BlockInput.exe
errorLevelReporting = false
lockLaunch = false
lockLaunchGame =
screenRotationAngle = 0
screenRotationAngleGame =
setResolution =
logFile =
logLabel := ["    INFO"," WARNING","   ERROR","   DEBUG","   TRACE"]
logLevel = 3
logShowDebugConsole = false
logShowCommandWindow = true
logCommandWindow = true
logIncludeModule = true
logIncludeDLLLogs = true
errorSounds = true
rlDebugConsoleStdout = 7
sysType = 32-bit
broadcastWindowTitle =
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
navSelectKey = Enter
navP2UpKey = Numpad8
navP2DownKey = Numpad2
navP2LeftKey = Numpad4
navP2RightKey = Numpad6
navP2SelectKey = NumpadEnter
originalWidth = 1440
originalHeight = 900
vdEnabled = false
vdFullPath =
vdUseSCSI = true
vdDriveLetter =
vdDriveLetterScsi =
vdAddDrive = true
demulShooterPath =
servoStikEnabled = false
servoStikExitMode = false
ledblinkyEnabled = false
ledblinkySystemName =
ledblinkyFullPath =
ledblinkyProfilePath = C:\RocketLauncher\Profiles\LEDBlinky
ledblinkyRLProfile = C:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
winIPACFullPath =
ultraMapEnabled = false
ultraMapFullPath =
emuIdleShutdown = 0
hideCursor = false
hideEmu = false
hideFE = false
suspendFE = false
fadeIn = false
fadeInDuration = 500
fadeInDelay = 0
fadeInExitDelay = 0
fadeOutExitDelay = 0
fadeOut = false
fadeOutExtraScreen = false
fadeOutDuration = 500
fadeOutDelay = 0
fadeLyrInterpolation = 7
fadeMuteEmulator = false
fadeUseBackgrounds = false
fadeClickThrough = false
fadeSounds = true
fade7zProgressMode = extraction
fadeWidthBaseRes = 1920
fadeHeightBaseRes = 1080
fadeLyr1Color = FF000000
fadeLyr2X = 0
fadeLyr2Y = 0
fadeLyr2W =
fadeLyr2H =
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3Pos = Center
fadeLyr3X = 450
fadeLyr3Y = 450
fadeLyr3W =
fadeLyr3H =
fadeLyr3Adjust = 1
fadeLyr3PicPad = 0
fadeLyr3Speed = 750
fadeLyr3Type = imageandbar
fadeLyr3Repeat = 1
fadeLyr3StaticX = 0
fadeLyr3StaticY = 870|1575
fadeLyr3StaticW =
fadeLyr3StaticH =
fadeLyr3StaticAdjust = 1
fadeLyr3StaticPicPad = 0
fadeLyr4Adjust = 1
fadeLyr4X = 1792|952
fadeLyr4Y = 891|1596
fadeLyr4W = 128
fadeLyr4H =
fadeLyr4Pos = No Alignment
fadeLyr4FPS = 50
fadeLyr4PicPad = 0
fadeTranspGifColor = FFFFFF
fadeBarWindow = Image
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowW = 900
fadeBarWindowH =
fadeBarWindowR = 30
fadeBarWindowM = 30
fadeBarWindowHatchStyle = 8
fadeBar = 7zOnly
fadeProgressDuration = 0
fadeBarBack = true
fadeBarBackColor = FF555555
fadeBarH = 30
fadeBarR = 10
fadeBarColor = DD00BFFF
fadeBarHatchStyle = 8
fadeBarPercentageText = true
fadeBarInfoText = true
fadeBarXOffset = 0
fadeBarYOffset = 150
fadeRomInfoSystemName = image
fadeRomInfoDeveloper = disabled
fadeRomInfoPublisher = disabled
fadeRomInfoGenre = disabled
fadeRomInfoRating = image
fadeRomInfoOrder = Description|SystemName|Year|Developer|Genre|Rating|Publisher
fadeRomInfoTextMargin = 7
fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular
fadeStatsInfoTextMargin = 7
fadeText1X = 0
fadeText1Y = 0
fadeText1 = Loading Game
fadeText2X = 0
fadeText2Y = 0
fadeText3 = Loading Game
fadeText4 = Loading Complete
fadeFont = Bebas Neue
fadeExtractionTime = disabled
fadeExtractionTimeTextX = 0
fadeExtractionTimeTextY = 0
fadeInterruptKey =
detectFadeErrorEnabled = true
fadeImgPath = C:\RocketLauncher\Media\Fade
RLDataPath = C:\RocketLauncher\Data
RLMediaPath = C:\RocketLauncher\Media
RLErrSoundPath = C:\RocketLauncher\Media\Sounds\Error
modulesPath = C:\RocketLauncher\Modules
moduleFullName = C:\RocketLauncher\Modules\RetroArch\RetroArch.ahk
moduleName = RetroArch
modulePath = C:\RocketLauncher\Modules\RetroArch
moduleExtension = ahk
moduleExtensionsPath = C:\RocketLauncher\Module Extensions
libPath = C:\RocketLauncher\Lib
sevenZEnabled = true
sevenZPath = C:\RocketLauncher\Module Extensions\7z.exe
sevenZDllPath = C:\RocketLauncher\Module Extensions\7z.dll
sevenZExtractPath = C:\Temp Game HyperSpin
sevenZExtractPathOrig =
sevenZAttachSystemName = false
sevenZDelTemp = true
sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar
sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar
sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar
7zExtractPath = C:\Temp Game HyperSpin
mgEnabled = false
mgKey = ~NumpadSub
mgBackgroundColor = FF000000
mgSidePadding = 0.2
mgWidthBaseRes = 1920
mgHeightBaseRes = 1080
mgYOffset = 500|800
mgFont = Arial
mgText2Offset = 100
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
mgSelectedEffect = rotate
mgUseGameArt = false
mgCandidate =
mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
mgOnLaunch = false
pauseEnabled = false
pauseKey = ~NumpadAdd
pauseBackToMenuBarKey = X
pauseZoomInKey = C
pauseZoomOutKey = V
pauseHiToTextPath = C:\RocketLauncher\Module Extensions\HiToText.exe
pauseSaveStateKeyCodes = {Shift down}{1 down}{1 up}{Shift up}{F3 down}{F3 up}|{Shift down}{2 down}{2 up}{Shift up}{F3 down}{F3 up}|{Shift down}{3 down}{3 up}{Shift up}{F3 down}{F3 up}|{Shift down}{4 down}{4 up}{Shift up}{F3 down}{F3 up}|{Shift down}{5 down}{5 up}{Shift up}{F3 down}{F3 up}|{Shift down}{6 down}{6 up}{Shift up}{F3 down}{F3 up}|{Shift down}{7 down}{7 up}{Shift up}{F3 down}{F3 up}|{Shift down}{8 down}{8 up}{Shift up}{F3 down}{F3 up}|{Shift down}{9 down}{9 up}{Shift up}{F3 down}{F3 up}|{Shift down}{10 down}{10 up}{Shift up}{F3 down}{F3 up}
pauseLoadStateKeyCodes = {Shift down}{1 down}{1 up}{Shift up}{F4 down}{F4 up}|{Shift down}{2 down}{2 up}{Shift up}{F4 down}{F4 up}|{Shift down}{3 down}{3 up}{Shift up}{F4 down}{F4 up}|{Shift down}{4 down}{4 up}{Shift up}{F4 down}{F4 up}|{Shift down}{5 down}{5 up}{Shift up}{F4 down}{F4 up}|{Shift down}{6 down}{6 up}{Shift up}{F4 down}{F4 up}|{Shift down}{7 down}{7 up}{Shift up}{F4 down}{F4 up}|{Shift down}{8 down}{8 up}{Shift up}{F4 down}{F4 up}|{Shift down}{9 down}{9 up}{Shift up}{F4 down}{F4 up}|{Shift down}{10 down}{10 up}{Shift up}{F4 down}{F4 up}
keyboardEncoder =
keyboardEncoderEnabled = false
keymapperEnabled = false
keymapperAHKMethod = false
keymapper = xpadder
xpadderFullPath = C:\Utilities\Xpadder\xpadder.exe
joyToKeyFullPath = C:\HyperSpin\Utilities\JoyToKey_en\JoyToKey.exe
profilePath = C:\RocketLauncher\Profiles
keymapperProfilePath = C:\RocketLauncher\Profiles\xpadder
keymapperFrontEndProfileName = RocketLauncherUI
joyIDsEnabled = false
joyIDsPreferredControllersGlobal =
joyIDsPreferredControllersSystem = use_global
joyIDsPreferredControllersOnExit =
CustomJoyNamesEnabled = false
CustomJoyNames =
rotateMethod = false
FEProfile = C:\RocketLauncher\Profiles\xpadder\RocketLauncherUI
defaultProfile = C:\RocketLauncher\Profiles\xpadder\_Default
systemProfile = C:\RocketLauncher\Profiles\xpadder\Sega Genesis
xPadderSystemProfile = C:\RocketLauncher\Profiles\xpadder\Sega Genesis\_Default
emuProfile = C:\RocketLauncher\Profiles\xpadder\Sega Genesis\RetroArch
romProfile = C:\RocketLauncher\Profiles\xpadder\Sega Genesis\3 Ninjas Kick Back (USA)
RocketLauncherProfile = C:\RocketLauncher\Profiles\xpadder\RocketLauncher
blankProfile = C:\RocketLauncher\Profiles\xpadder\_Default\blank
ahkFEProfile = C:\RocketLauncher\Profiles\AHK\RocketLauncherUI
ahkDefaultProfile = C:\RocketLauncher\Profiles\AHK\_Default
ahkSystemProfile = C:\RocketLauncher\Profiles\AHK\Sega Genesis
ahkEmuProfile = C:\RocketLauncher\Profiles\AHK\Sega Genesis\RetroArch
ahkRomProfile = C:\RocketLauncher\Profiles\AHK\Sega Genesis\3 Ninjas Kick Back (USA)
ahkRocketLauncherProfile = C:\RocketLauncher\Profiles\AHK\RocketLauncher
bezelEnabled = false
bezelICEnabled = false
shaderName = false
shaderColor =
shaderTransparency =
statisticsEnabled = true
pressDuration = -1
emuVolume = 1
dxwndIni = C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
dxwndFullPath = C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
qResFullPath = C:\RocketLauncher\Module Extensions\QRes.exe
mon1O =
pacDrivedllFile = C:\RocketLauncher\Module Extensions\PacDrive32.dll
userFadeAnimIniFile = C:\RocketLauncher\Lib\User Fade Animations.ini
testFile =
testDuration =
initialErrorMode = 0
03:22:04:834 | RL |      INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
03:22:04:834 | RL |      INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
03:22:04:834 | RL |   WARNING  | +0     | BuildScript - "C:\RocketLauncher\Lib\User Functions Init.ahk" not found
03:22:04:834 | RL |      INFO  | +0     | BuildScript - Validating module
03:22:04:842 | RL |      INFO  | +15    | BuildScript - Validation complete
03:22:04:842 | RL |      INFO  | +0     | BuildScript - Module:
MEmu = RetroArch
MEmuV =  v05-11-2015 Nightly
MURL = http://themaister.net/retroarch.html
MAuthor = djvj,zerojay
MVersion = 2.4.2
MCRC = A8D5F162
iCRC = F7B77133
MID = 635038268922229162
MSystem = "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","ScummVM","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Dreamcast","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Meganet","Sega Nomad","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sony PSP Minis","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
; Notes:
; If the emu doesn't load and you get no error, usually this means the LibRetro DLL is not working!
; Devs stated they will never add support for mounted images (like via DT)
; Fullscreen is controlled via the module setting in RocketLauncherUI
; This module uses the CLI version of RetroArch (retroarch.exe), not the GUI (retroarch-phoenix.exe).
; The emu may make a mouse cursor appear momentarily during launch, MouseMove and hide_cursor seem to have no effect
; Enable 7z support for archived roms
; Available CLI options: https://github.com/PyroFilmsFX/iOS/blob/master/docs/retroarch.1
; LibRetro DLLs:
; LibRetro DLLs come with the emu, but here is another source for them: http://forum.themaister.net/
; Whatever cores you decide to use, make sure they are extracted anywhere in your Emu_Path\cores folder. The module will find and load the default core unless you choose a custom one for each system.
; You can find supported cores that Retroarch supports simply by downloading them from the "retroarch-phoenix.exe" or by visiting here: https://github.com/libretro/libretro.github.com/wiki/Supported-cores
; Some good discussion on cores and filters: http://forum.themaister.net/viewtopic.php?id=270
; SRM files:
; srm are stored in a "srm" dir in the emu folder. Each system ran through retroarch gets its own folder inside srm
; Save states:
; Save states are stored in a "save" dir in the emu folder. Each system ran through retroarch gets its own folder inside save
; Config files:
; By default, the module looks for config files in a folder called config in the RetroArch folder. Example: C:\emus\RetroArch\config. You can change this folder to anything you like by changing the module's ConfigFolder setting in RocketLauncherUI.
; RetroArch's global config file is called "retroarch.cfg". RetroArch will use a system cfg file named to match your System Name (example: Nintendo Entertainment System.cfg).
; RetroArch will also load core config files named after the core name. Example: nestopia_libretro.cfg
; This allows different settings globally, for each system, and for each core. If you want all systems to use the same retroarch.cfg, do not have any system or core cfg files, only have the retroarch.cfg.
; If a core config exists, it takes precedence over the global config. And if a system config exists, it takes precedence over the core config.
; MultiGame:
; MultiGame support is currently only available for the Mednafen PSX core. Retroarch uses the same method as Mednafen to load multi-disc games. This method involves m3u playlists which are commonly used for music. The m3u files needed to load multi-disc games are generated for you by the module when you launch a multi-disc game and are saved to your corresponding rom directory. Due to m3u limitations, your multi-disc roms/images cannot be archived -- they must be unzipped. All single disc games can remain archived and you can still enable 7z under system settings. If you do not wish to use MultiGame support you can archive your roms/images and m3u generation will be skipped on launch.
; The m3u files generated by the module contain a list of paths to all roms/images in the multi-disc set. Retroarch automatically loads the first path in the m3u so the first path will always be the disc you are loading. For example, Final Fantasy VII has 3 discs and if you load Disc 2 first, the order of the paths in the m3u will be disc 2, disc 3, disc 1. If you load Disc 3 first, the order will be disc 3, disc 1, disc 2. The module anticipates this and will load the correct disk, selected from the Pause/MultiDisk menus. However if you choose to manually use Retroarch's UI or disk swap keys to change discs, you will need to keep this in mind.
; In order for RocketLauncher's MultiGame UI to swap discs, you must define Eject_Toggle_Key, Next_Disk_Key, and Previous_Disk_Key under global settings for the emulator in RocketLauncher. Because AHK and Retroarch use different naming conventions for some keyboard keys, it is best to use a letter, a number, or F1-F12.
; MAME:
; MAME BIOS roms should be placed in the system\mame folder
; System Specific Notes:
; Microsoft MSX/MSX2: Launch an MSX game and in the core options, set the console to be an MSX2 and it will play both just fine.
; Nintendo Famicom Disk System - Requires disksys.rom be placed in the folder you define as system_directory in the RetroArch's cfg.
; Sega CD - Requires "bios_CD_E.bin", "bios_CD_J.bin", "bios_CD_U.bin" all be placed in the folder you define as system_directory in the RetroArch's cfg.
; Super Nintendo Entertainment System - requires split all 10 dsp# & st### roms all be placed in the folder you define as system_directory in the RetroArch's cfg. Many games, like Super Mario Kart require these.
; NEC TurboGrafx-CD (using pce fast core) - Requires "syscard3.pce" be placed in the folder you define as system_directory in the RetroArch's cfg.
; NEC TurboGrafx-CD (using MAME core)
;   - You'll need to update a couple mame specific options in the Retroarch core options file to get it to boot from the cli. These should probably be updated automagically by the module. Turning softlists off, but might not need to.
;       mame_boot_from_cli = "enabled"
;       mame_softlists_enable = "disabled"
;       mame_softlists_auto_media = "disabled"
; - Requires hash folder from MAME/MESS/UME, either from the source or release package. Save this in the system_directory you've defined for RetroArch. Something like \RetroArch\system\mame\hash\
; - Requires the CD bios file(s) saved in the mame bios folder you've defined. Usually \RetroArch\system\mame\bios\
; For PC Engine-CD you'll need the file "[cd] cd-rom system (japan) (v2.1).pce" zipped as cdsys.zip and saved in a pce subfolder in your bios path, so \RetroArch\system\mame\bios\pce\cdsys.zip
; For PC Engine SuperGrafx-CD you'll need the file "[cd] super cd-rom system (japan) (v3.0).pce" zipped as scdsys.zip and saved in a pce subfolder in your bios path, so \RetroArch\system\mame\bios\pce\scdsys.zip
; For TurboGrafx-CD you'll need the file "[cd] turbografx cd system card (usa) (v2.0).pce" zipped as cdsys.zip and saved in a tg16 subfolder in your bios path, so \RetroArch\system\mame\bios\tg16\cdsys.zip
; For TurboDuo you'll need the file "[cd] turbografx cd super system card (usa) (v3.0).pce" zipped as scdsys.zip and saved in a tg16 subfolder in your bios path, so \RetroArch\system\mame\bios\tg16\scdsys.zip
; Nintendo Super Game Boy - Set the Module setting in RocketLauncherUI SuperGameBoy to true to enable a system or only a rom to use SGB mode. This is not needed if your systemName is set to the official name of "Nintendo Super Game Boy". Requires "sgb.boot.rom" and "Super Game Boy (World).sfc" to be placed in the folder you define as system_directory in the RetroArch's cfg. This is needed if you want to use Super game boy mode and color palettes. Also requires using the latest bsnes core. Not all games support SGB mode.
; MAME: The nag screen patch has been removed from the MAME core as of some point in March. We will be investigating our options for this. For MAME-based systems, make sure to set 7z use to false as MAME needs zip files.
; Sony PSP/PlayStation Minis: To avoid the dialog box complaining about ppge_atlas.zim, download it from https://github.com/libretro/libretro-ppsspp/blob/master/assets/ppge_atlas.zim and place it in your Retroarch/system/PPSSPP/ directory.
StartModule()
BezelGUI()
FadeInStart()
primaryExe := new Emulator(emuPath . "\" . executable) ; instantiate emulator executable object
emuPrimaryWindow := new Window(new WindowTitle("RetroArch","RetroArch")) ; instantiate primary emulator window object
emuConsoleWindow := new Window(new WindowTitle("","ConsoleWindowClass")) ; instantiate emulator console window object
; Here we define all supported systems for this module. This object controls how the module reacts to different systems. RetroArch can play a lot of systems, but needs to know what system you want to run, so this module has to adapt.
; 1 - Official System Name in RocketLauncher
; 2 - Short name used only for easy referencing within module
; 3 - Default core
; 4 - The system ID MAME core recognizes
RLLog.Debug("Module - Started building the " . MEmu . " object")
mTypeVar:="
( LTrim
AAE|LibRetro_AAE|mame_libretro
Acorn BBC Micro|LibRetro_BBCB|mess_libretro|bbcb
Amstrad CPC|LibRetro_CPC|mess_libretro|cpc464
Amstrad GX4000|LibRetro_GX4K|mess_libretro|gx4000
APF Imagination Machine|LibRetro_APF|mess_libretro|apfimag
Apple IIGS|LibRetro_AIIGS|mess_libretro|apple2gs
Applied Technology MicroBee|LibRetro_MBEE|mess_libretro|mbeeic
Atari 2600|LibRetro_2600|stella_libretro|a2600
Atari 5200|LibRetro_5200|mess_libretro|a5200
Atari 7800|LibRetro_7800|prosystem_libretro|a7800
Atari 8-Bit|LibRetro_ATARI8|mess_libretro|a800
Atari Classics|LibRetro_ACLS|mame_libretro
Atari Jaguar|LibRetro_JAG|virtualjaguar_libretro|jaguar
Atari Lynx|LibRetro_LYNX|handy_libretro|lynx
Atari ST|LibRetro_ST|hatari_libretro
Atari XEGS|LibRetro_XEGS|mess_libretro|xegs
Bally Astrocade|LibRetro_BAST|mess_libretro|astrocde
Bandai Gundam RX-78|LibRetro_BGRX|mess_libretro|rx78
Bandai Super Vision 8000|LibRetro_SV8K|mess_libretro|sv8000
Bandai Wonderswan|LibRetro_WSAN|mednafen_wswan_libretro|wswan
Bandai Wonderswan Color|LibRetro_WSANC|mednafen_wswan_libretro|wscolor
Canon X07|LibRetro_CX07|mess_libretro|x07
Capcom Classics|LibRetro_CAPC|mame_libretro
Capcom Play System|LibRetro_CPS1|fba_cores_cps1_libretro
Capcom Play System II|LibRetro_CPS2|fba_cores_cps2_libretro
Capcom Play System III|LibRetro_CPS3|mame_libretro
Casio PV-1000|LibRetro_CAS1K|mess_libretro|pv1000
Casio PV-2000|LibRetro_CAS2K|mess_libretro|pv2000
Cave|LibRetro_CAVE|mame_libretro
Coleco ADAM|LibRetro_ADAM|mess_libretro|adam
ColecoVision|LibRetro_COLEC|mess_libretro|coleco
Commodore Amiga|LibRetro_PUAE|puae_libretro
Commodore Max Machine|LibRetro_CMAX|mess_libretro|vic10
Creatronic Mega Duck|LibRetro_DUCK|mess_libretro|megaduck
Data East Classics|LibRetro_DATA|mame_libretro
Dragon Data Dragon|LibRetro_DRAG64|mess_libretro|dragon64
Elektronika BK|LibRetro_EBK|mess_libretro|bk0010
Elektronska Industrija Pecom 64|LibRetro_P64|mess_libretro|pecom64
Emerson Arcadia 2001|LibRetro_A2001|mess_libretro|arcadia
Entex Adventure Vision|LibRetro_AVISION|mess_libretro|advision
Epoch Game Pocket Computer|LibRetro_GPCKET|mess_libretro|gamepock
Epoch Super Cassette Vision|LibRetro_SCV|mess_libretro|scv
Exidy Sorcerer|LibRetro_SORCR|mess_libretro|sorcerer
Fairchild Channel F|LibRetro_CHANF|mess_libretro|channelf
Final Burn Alpha|LibRetro_FBA|fb_alpha_libretro
Funtech Super Acan|LibRetro_SACAN|mess_libretro|supracan
GamePark 32|LibRetro_GP32|mess_libretro|gp32
GCE Vectrex|LibRetro_VECTX|mess_libretro|vectrex
Hartung Game Master|LibRetro_GMASTR|mess_libretro|gmaster
Interton VC 4000|LibRetro_VC4K|mess_libretro|vc4000
Irem Classics|LibRetro_IREM|mame_libretro
JungleTac Sport Vii|LibRetro_SPORTV|mess_libretro|vii
Konami Classics|LibRetro_KONC|mame_libretro
Magnavox Odyssey 2|LibRetro_ODYS2|mess_libretro|odyssey2
MAME|LibRetro_MAME|mame_libretro|mame
Matra & Hachette Alice|LibRetro_ALICE|mess_libretro|alice32
Mattel Aquarius|LibRetro_AQUA|mess_libretro|aquarius
Mattel Intellivision|LibRetro_INTV|mess_libretro|intv
MGT Sam Coupe|LibRetro_SAMCP|mess_libretro|
Microsoft MS-DOS|LibRetro_MSDOS|dosbox_libretro
Microsoft MSX|LibRetro_MSX|bluemsx_libretro
Microsoft MSX2|LibRetro_MSX2|bluemsx_libretro
Microsoft Windows 3.x|LibRetro_WIN3X|dosbox_libretro
Midway Classics|LibRetro_MIDC|mame_libretro
Namco Classics|LibRetro_NAMC|mame_libretro
Namco System 22|LibRetro_NAM2|mame_libretro
NEC PC Engine|LibRetro_PCE|mednafen_pce_fast_libretro|pce,cart
NEC PC Engine-CD|LibRetro_PCECD|mednafen_pce_fast_libretro|pce,cdrom
NEC PC-FX|LibRetro_PCFX|mednafen_pcfx_libretro
NEC SuperGrafx|LibRetro_SGFX|mednafen_supergrafx_libretro|sgx,cart
NEC TurboGrafx-16|LibRetro_TG16|mednafen_pce_fast_libretro|tg16,cart
NEC TurboGrafx-CD|LibRetro_TGCD|mednafen_pce_fast_libretro|tg16,cdrom
Nintendo 64|LibRetro_N64|mupen64plus_libretro|n64
Nintendo 64DD|LibRetro_N64|mupen64plus_libretro
Nintendo Arcade Systems|LibRetro_NINARC|mame_libretro
Nintendo Classics|LibRetro_NINC|mame_libretro
Nintendo DS|LibRetro_DS|desmume_libretro
Nintendo Entertainment System|LibRetro_NES|nestopia_libretro|nes
Nintendo Famicom|LibRetro_NFAM|nestopia_libretro
Nintendo Famicom Disk System|LibRetro_NFDS|nestopia_libretro|famicom
Nintendo Game Boy|LibRetro_GB|gambatte_libretro|gameboy
Nintendo Game Boy Advance|LibRetro_GBA|vba_next_libretro|gba
Nintendo Game Boy Color|LibRetro_GBC|gambatte_libretro|gbcolor
Nintendo Game Boy Japan|LibRetro_GBJ|gambatte_libretro|gameboy
Nintendo Game & Watch|LibRetro_GW|gw_libretro
Nintendo Pokemon Mini|LibRetro_POKE|mess_libretro|pokemini
Nintendo Satellaview|LibRetro_NSFS|snes9x_libretro
Nintendo SuFami Turbo|LibRetro_NSFST|snes9x_libretro
Nintendo Super Famicom|LibRetro_NSF|bsnes_balanced_libretro
Nintendo Super Game Boy|LibRetro_SGB|bsnes_balanced_libretro
Nintendo Virtual Boy|LibRetro_NVB|mednafen_vb_libretro|vboy
Othello Multivision|LibRetro_OTHO|genesis_plus_gx_libretro
Panasonic 3DO|LibRetro_3DO|4do_libretro
Philips CD-i|LibRetro_CDI|mess_libretro|cdimono1
Philips Videopac|LibRetro_PVID|mess_libretro|videopac
RCA Studio II|LibRetro_STUD2|mess_libretro|studio2
SCUMMVM|LibRetro_SCUMM|scummvm_libretro
Sega 32X|LibRetro_32X|picodrive_libretro|32x
Sega CD|LibRetro_SCD|genesis_plus_gx_libretro|segacd
Sega Classics|LibRetro_SEGC|mame_libretro
Sega Dreamcast|LibRetro_DCAST|reicast_libretro
Sega Game Gear|LibRetro_GG|genesis_plus_gx_libretro|gamegear
Sega Genesis|LibRetro_GEN|genesis_plus_gx_libretro|genesis
Sega Mark III|Libretro_SM3|genesis_plus_gx_libretro
Sega Master System|LibRetro_SMS|genesis_plus_gx_libretro|sms
Sega Mega Drive|LibRetro_GEN|genesis_plus_gx_libretro|megadriv
Sega Mega Drive 32X|LibRetro_MD32X|picodrive_libretro
Sega Meganet|LibRetro_GEN|genesis_plus_gx_libretro|genesis
Sega Nomad|LibRetro_GEN|genesis_plus_gx_libretro|genesis
Sega Pico|LibRetro_PICO|picodrive_libretro
Sega Saturn|LibRetro_SAT|yabause_libretro|saturn
Sega Saturn Japan|LibRetro_SAT|yabause_libretro|saturnjp
Sega SC-3000|LibRetro_SC3K|mess_libretro|sc3000
Sega SG-1000|LibRetro_SG1K|genesis_plus_gx_libretro
Sega ST-V|LibRetro_STV|mame_libretro
Sega VMU|LibRetro_SVMU|mess_libretro|svmu
Sharp X1|LibRetro_SX1|mess_libretro|x1
Sinclair ZX Spectrum|LibRetro_SPECZX|mess_libretro|spectrum
SNK Classics|LibRetro_SNKC|mame_libretro
SNK Neo Geo|LibRetro_NEO|fb_alpha_libretro
SNK Neo Geo AES|LibRetro_NEOAES|mame_libretro|aes
SNK Neo Geo CD|LibRetro_NEOCD|mess_libretro|neocdz
SNK Neo Geo MVS|LibRetro_NEOMVS|mame_libretro
SNK Neo Geo Pocket|LibRetro_NGP|mednafen_ngp_libretro|ngp
SNK Neo Geo Pocket Color|LibRetro_NGPC|mednafen_ngp_libretro|ngpc
Sony PlayStation|LibRetro_PSX|mednafen_psx_libretro|psu
Sony PlayStation Minis|LibRetro_PSXMIN|ppsspp_libretro
Sony PocketStation|LibRetro_POCKS|mess_libretro|pockstat
Sony PSP|LibRetro_PSP|ppsspp_libretro
Sony PSP Minis|LibRetro_PSP|ppsspp_libretro
Sord M5|LibRetro_SORD|mess_libretro|m5
Spectravideo|LibRetro_SV328|mess_libretro|svi328n
Super Nintendo Entertainment System|LibRetro_SNES|bsnes_balanced_libretro|snes
Taito Classics|LibRetro_TAIC|mame_libretro
Tandy TRS-80 Color Computer|LibRetro_TRS80|mess_libretro|coco3
Technos|LibRetro_TECHN|mame_libretro
Texas Instruments TI 99-4A|LibRetro_TI99|mess_libretro|ti99_4a
Thomson MO5|LibRetro_MO5|mess_libretro|mo5
Thomson TO7|LibRetro_TO7|mess_libretro|to7
Tiger Game.com|LibRetro_TCOM|mess_libretro|gamecom
Tiki-100|LibRetro_TIKI|mess_libretro|kontiki
Tomy Tutor|LibRetro_TOMY|mess_libretro|tutor
VTech CreatiVision|LibRetro_VTECH|mess_libretro|crvision
Watara Supervision|LibRetro_SUPRV|mess_libretro|svision
Williams Classics|LibRetro_WILLS|mame_libretro
mType := Object()
Loop, Parse, mTypeVar, `n, `r
obj := {}
Loop, Parse, A_LoopField, |
If (A_Index = 1)
obj.System := A_LoopField
Else If (A_Index = 2)
obj.ID := A_LoopField
Else If (A_Index = 3)
obj.Core := A_LoopField
Else { ; 4
StringSplit, tmp, A_LoopField, `,
obj.MAMEID := tmp1
obj.MAMEMedia := tmp2
mType.Insert(obj["System"], obj)
RLLog.Debug("Module - Finished building the " . MEmu . " object")
; For easier use throughout the module
retroSystem := mType[systemName].System
retroID := mType[systemName].ID
retroCore := mType[systemName].Core
retroMAMEID := mType[systemName].MAMEID
retroMAMEMedia := mType[systemName].MAMEMedia
RLLog.Info("Module - Using these system variables:")
RLLog.Info("Module - retroSystem: " . retroSystem)
RLLog.Info("Module - retroID: " . retroID)
RLLog.Info("Module - retroCore: " . retroCore)
RLLog.Info("Module - retroMAMEID: " . retroMAMEID)
RLLog.Info("Module - retroMAMEMedia: " . retroMAMEMedia)
If !retroSystem
ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this " . MEmu . " module: " . moduleName)
If !retroCore
ScriptError("Your Core ID is: " . retroID . "`nCould not find a default core to use. Please update the module with a default core.")
Fullscreen := moduleIni.Read("Settings", "Fullscreen","true","",1)
configFolder := moduleIni.Read("Settings", "ConfigFolder",emuPath . "\config","",1)
mameRomPath := moduleIni.Read("MAME", "BIOS_Roms_Folder","","",1)
mameHideNag := If moduleIni.Read("MAME", "Hide_Nag_Screen","false","",1) = "true" ? "enabled" : "disabled"
mameHideInfo := If moduleIni.Read("MAME", "Hide_Info_Screen","false","",1) = "true" ? "enabled" : "disabled"
mameHideWarn := If moduleIni.Read("MAME", "Hide_Warning_Screen","false","",1) = "true" ? "enabled" : "disabled"
hideConsole := moduleIni.Read("Settings", "HideConsole","true","",1)
ejectToggleKey := moduleIni.Read("Settings", "Eject_Toggle_Key","","",1)
nextDiskKey := moduleIni.Read("Settings", "Next_Disk_Key","","",1)
prevDiskKey := moduleIni.Read("Settings", "Previous_Disk_Key","","",1)
core := moduleIni.Read(romName . "|" . systemName, "LibRetro_Core",retroCore,"",1)
superGB := moduleIni.Read(romName . "|" . systemName, "SuperGameBoy","false","",1)
enableNetworkPlay := moduleIni.Read(romName . "|Network", "Enable_Network_Play","false","",1)
overlay := moduleIni.Read(romName . "|" . systemName, "Overlay","","",1)
videoShader := moduleIni.Read(romName . "|" . systemName, "VideoShader","","",1)
aspectRatioIndex := moduleIni.Read(romName . "|" . systemName, "AspectRatioIndex","","",1)
customViewportWidth := moduleIni.Read(romName . "|" . systemName, "CustomViewportWidth","","",1)
customViewportHeight := moduleIni.Read(romName . "|" . systemName, "CustomViewportHeight","","",1)
customViewportX := moduleIni.Read(romName . "|" . systemName, "CustomViewportX","","",1)
customViewportY := moduleIni.Read(romName . "|" . systemName, "CustomViewportY","","",1)
stretchToFillBezel := moduleIni.Read(romName . "|" . systemName, "StretchToFillBezel","false","",1)
rotation := moduleIni.Read(romName . "|" . systemName, "Rotation",0,"",1)
cropOverscan := moduleIni.Read(romName . "|" . systemName, "CropOverscan","","",1)
threadedVideo := moduleIni.Read(romName . "|" . systemName, "ThreadedVideo","","",1)
vSync := moduleIni.Read(romName . "|" . systemName, "VSync","","",1)
integerScale := moduleIni.Read(romName . "|" . systemName, "IntegerScale","","",1)
configurationPerCore := moduleIni.Read(romName . "|" . systemName, "ConfigurationPerCore","false","",1)
If (StringUtils.Contains(core, "^(mame|mess|ume)") && !retroMAMEID) {
retroMAMEID := "mame" ; set all systems that use a mame core to the default mame ID so any system name is supported
RLLog.Warning("Module - Setting MAMEID to default ""mame"" for """ . retroSystem . """")
configFolder := RLObject.getFullPathFromRelative(rlPath,configFolder)
mameRomPath := If mameRomPath ? RLObject.getFullPathFromRelative(rlPath,mameRomPath) : romPath
overlay := RLObject.getFullPathFromRelative(rlPath,overlay)
videoShader := RLObject.getFullPathFromRelative(rlPath,videoShader)
rotateBezel := false
configFolder := new Folder(configFolder)
If (retroID = "LibRetro_SGB" || superGB = "true") ; if system or rom is set to use Super Game Boy
{ superGB := "true" ; setting this just in case it's false and the system is Nintendo Super Game Boy
sgbRomPath := CheckFile(emuPath . "\system\Super Game Boy (World).sfc","Could not find the rom required for Super Game Boy support. Make sure the rom ""Super Game Boy (World).sfc"" is located in: " . emuPath . "\system")
CheckFile(emuPath . "\system\sgb.boot.rom","Could not find the bios required for Super Game Boy support. Make sure the bios ""sgb.boot.rom"" is located in: " . emuPath . "\system")
retroID := "LibRetro_SGB" ; switching to Super Game Boy mode
retroSystem := "Nintendo Super Game Boy"
; Find the dll for this system
libDll := CheckFile(emuPath . "\cores\" . core . ".dll", "Your " . retroID . " dll is set to " . core . " but could not locate this file:`n" . emuPath . "\cores\" . core . ".dll")
; Find the cfg file to use
If !configFolder.Exist()
ScriptError("You need to make sure ""ConfigFolder"" is pointing to your RetroArch config folder. By default it is looking here: """ . configFolder.FilePath . """")
globalRetroCfg := emuPath . "\retroarch.cfg"
systemRetroCfg := configFolder.FilePath . "\" . retroSystem . ".cfg"
coreRetroCfg := configFolder.FilePath . "\" . core . ".dll.cfg"
RLLog.Info("Module - Global cfg should be: " . globalRetroCfg)
RLLog.Info("Module - System cfg should be: " . systemRetroCfg)
RLLog.Info("Module - Core cfg should be: " . coreRetroCfg)
foundCfg := ""
systemRetroCfg := new File(systemRetroCfg)
coreRetroCfg := new File(coreRetroCfg)
globalRetroCfg := new File(globalRetroCfg)
If systemRetroCfg.Exist() { ; check for system cfg first
retroCFGFile := systemRetroCfg
foundCfg := 1
RLLog.Info("Module - Found a System cfg!")
} Else If coreRetroCfg.Exist() { ; 2nd option is a core config
retroCFGFile := coreRetroCfg
foundCfg := 1
RLLog.Info("Module - Found a Core cfg!")
} Else If globalRetroCfg.Exist() { ; 3rd is global cfg
retroCFGFile := globalRetroCfg
foundCfg := 1
RLLog.Info("Module - Found a Global cfg!")
If foundCfg {
RLLog.Info("Module - " . MEmu . " is using " . retroCFGFile.FileFullPath . " as its config file.")
retroCFG := LoadProperties(retroCFGFile.FileFullPath)
} Else
RLLog.Warning("Module - Could not find a cfg file to update settings. RetroArch will make one for you.")
If StringUtils.Contains(rotation,"1|3") ; use vertical bezel if RA rotation is set to 90 or 270 degrees
rotateBezel := true
If StringUtils.Contains(retroID, "LibRetro_NFDS|LibRetro_SCD|LibRetro_TGCD|LibRetro_PCECD|LibRetro_PCFX") { ; these systems require the retroarch settings to be read
retroSysDir := ReadProperty(retroCFG,"system_directory") ; read value
retroSysDir := ConvertRetroCFGKey(retroSysDir) ; remove dbl quotes
retroSysDirLeft := StringUtils.Left(retroSysDir, 2)
If (retroSysDirLeft = ":\") { ; if retroarch is set to use a default folder
retroSysDir := StringUtils.TrimLeft(retroSysDir, 1)
RLLog.Info("Module - RetroArch is using a relative system path: """ . retroSysDir . """")
retroSysDir := emuPath . retroSysDir
If !retroSysDir
ScriptError("RetroArch requires you to set your system_directory and place bios rom(s) in there for """ . retroSystem . """ to function. Please do this first by running ""retroarch-phoenix.exe"" manually.")
checkForSlash := StringUtils.Right(retroSysDir, 1)
If (checkForSlash = "\") ; check if a backslash is the last character. If it is, remove it, as this is non-standard method to define folders
retroSysDir := StringUtils.TrimRight(retroSysDir, 1)
If (StringUtils.Contains(core, "^(mame|mess|ume)")) || (StringUtils.Contains(retroID, "LibRetro_N64|LibRetro_NES|LibRetro_LYNX|LibRetro_PSX")) || (StringUtils.Contains(retroID, "LibRetro_NES") && (StringUtils.Contains(core, "nestopia_libretro"))) { ; these systems will use an ini to store game specific settings
RLLog.Info("Module - Reading / creating system ini for specific settings.")
If !StringUtils.Contains(core, "^(mame|mess|ume)") {
If !SystemModuleIni.Exist()
SystemModuleIni.Append ; create a new blank ini file if one does not exist
If (configurationPerCore = "true") {
coreOptionsCFGFile := new File(configFolder.FilePath . "\retroarch-core-options.cfg")
coreOptionsCFGFile.CheckFile("Could not find retroarch-core-options.cfg in retroarch directory: """ . configFolder.FilePath . """")
} Else {
coreOptionsCFGFile := new File(emuPath . "\retroarch-core-options.cfg")
coreOptionsCFGFile.CheckFile("Could not find retroarch-core-options.cfg in retroarch directory: """ . emuPath . """")
coreOptionsCFG := LoadProperties(coreOptionsCFGFile.FileFullPath)
If StringUtils.Contains(core, "^(mame|mess|ume)") { ; Set some MAME/MESS/UME core options.
tmpCore := If StringUtils.Contains(core, "mame") ? "mame" : "mess"
WriteProperty(coreOptionsCFG, tmpCore . "_read_config", """enabled""", 1)
WriteProperty(coreOptionsCFG, tmpCore . "_boot_from_cli", """enabled""", 1) ; This needs to be enabled in order to run games with RLauncher
WriteProperty(coreOptionsCFG, tmpCore . "_hide_nagscreen", "" . mameHideNag . "", 1)
WriteProperty(coreOptionsCFG, tmpCore . "_hide_infoscreen", "" . mameHideInfo . "", 1)
WriteProperty(coreOptionsCFG, tmpCore . "_hide_warnings", "" . mameHideWarn . "", 1)
} Else If StringUtils.Contains(retroID, "LibRetro_N64") { ; Nintendo 64
mupenGfx := moduleIni.Read(romName . "|" . systemName, "Mupen_Gfx_Plugin", "auto","",1)
mupenRsp := moduleIni.Read(romName . "|" . systemName, "Mupen_RSP_Plugin", "auto","",1)
mupenCpu := moduleIni.Read(romName . "|" . systemName, "Mupen_CPU_Core", "dynamic_recompiler","",1)
mupenPak1 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_1", "memory","",1)
mupenPak2 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_2", "memory","",1)
mupenPak3 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_3", "memory","",1)
mupenPak4 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_4", "memory","",1)
mupenGfxAccur := moduleIni.Read(romName . "|" . systemName, "Mupen_Gfx_Accuracy", "high","",1)
mupenExpMem := moduleIni.Read(romName . "|" . systemName, "Mupen_Disable_Exp_Memory", "no","",1)
mupenTexturFilt := moduleIni.Read(romName . "|" . systemName, "Mupen_Texture_Filtering", "nearest","",1)
mupenViRefresh := moduleIni.Read(romName . "|" . systemName, "Mupen_VI_Refresh", "2200","",1)
mupenFramerate := moduleIni.Read(romName . "|" . systemName, "Mupen_Framerate", "fullspeed","",1)
mupenResolution := moduleIni.Read(romName . "|" . systemName, "Mupen_Resolution", "640x480","",1)
mupenPolyOffstFctr := moduleIni.Read(romName . "|" . systemName, "Mupen_Polygon_Offset_Factor", "-3.0","",1)
mupenPolyOffstUnts := moduleIni.Read(romName . "|" . systemName, "Mupen_Polygon_Offset_Units", "-3.0","",1)
mupenViOverlay := moduleIni.Read(romName . "|" . systemName, "Mupen_VI_Overlay", "disabled","",1)
mupenAnalogDzone := moduleIni.Read(romName . "|" . systemName, "Mupen_Analog_Deadzone", "15","",1)
WriteProperty(coreOptionsCFG, "mupen64-gfxplugin", mupenGfx, 1)
WriteProperty(coreOptionsCFG, "mupen64-rspplugin", mupenRsp, 1)
WriteProperty(coreOptionsCFG, "mupen64-cpucore", mupenCpu, 1)
WriteProperty(coreOptionsCFG, "mupen64-pak1", mupenPak1, 1)
WriteProperty(coreOptionsCFG, "mupen64-pak2", mupenPak2, 1)
WriteProperty(coreOptionsCFG, "mupen64-pak3", mupenPak3, 1)
WriteProperty(coreOptionsCFG, "mupen64-pak4", mupenPak4, 1)
WriteProperty(coreOptionsCFG, "mupen64-gfxplugin-accuracy", mupenGfxAccur, 1)
WriteProperty(coreOptionsCFG, "mupen64-disableexpmem", mupenExpMem, 1)
WriteProperty(coreOptionsCFG, "mupen64-filtering", mupenTexturFilt, 1)
WriteProperty(coreOptionsCFG, "mupen64-virefresh", mupenViRefresh, 1)
WriteProperty(coreOptionsCFG, "mupen64-framerate", mupenFramerate, 1)
WriteProperty(coreOptionsCFG, "mupen64-screensize", mupenResolution, 1)
WriteProperty(coreOptionsCFG, "mupen64-polyoffset-factor", mupenPolyOffstFctr, 1)
WriteProperty(coreOptionsCFG, "mupen64-polyoffset-units", mupenPolyOffstUnts, 1)
WriteProperty(coreOptionsCFG, "mupen64-angrylion-vioverlay", mupenViOverlay, 1)
WriteProperty(coreOptionsCFG, "mupen64-astick-deadzone", mupenAnalogDzone, 1)
} Else If StringUtils.Contains(retroID, "LibRetro_NES") { ; these systems will use an ini to store game specific settings
If StringUtils.Contains(core, "nestopia_libretro") { ; Nestopia
nestopiaBlargg := moduleIni.Read(romName . "|Nestopia", "Nestopia_Blargg_NTSC_Filter", "disabled","",1)
nestopiaPalette := moduleIni.Read(romName . "|Nestopia", "Nestopia_Palette", "canonical","",1)
nestopiaNoSprteLimit := moduleIni.Read(romName . "|Nestopia", "Nestopia_Remove_Sprites_Limit", "disabled","",1)
WriteProperty(coreOptionsCFG, "nestopia_blargg_ntsc_filter", nestopiaBlargg, 1)
WriteProperty(coreOptionsCFG, "nestopia_palette", nestopiaPalette, 1)
WriteProperty(coreOptionsCFG, "nestopia_nospritelimit", nestopiaNoSprteLimit, 1)
} Else If StringUtils.Contains(retroID, "LibRetro_LYNX") { ; Atari Lynx
If StringUtils.Contains(core, "handy_libretro") {   ; Handy
handyRotate := moduleIni.Read(romName . "|" . systemName, "Handy_Rotation", "None","",1)
If StringUtils.Contains(handyRotate, "240") or StringUtils.Contains(handyRotate, "90")
rotateBezel := true
WriteProperty(coreOptionsCFG, "handy_rot", handyRotate, 1)
} Else If StringUtils.Contains(retroID, "LibRetro_PSX") { ; Sony PlayStation
psxCdImageCache := moduleIni.Read(romName . "|" . systemName, "PSX_CD_Image_Cache", """enabled""","",1)
psxMemcardHandling := moduleIni.Read(romName . "|" . systemName, "PSX_Memcard_Handling", """libretro""","",1)
psxDualshockAnalogToggle := moduleIni.Read(romName . "|" . systemName, "PSX_Dualshock_Analog_Toggle", """enabled""","",1)
WriteProperty(coreOptionsCFG, "beetle_psx_cdimagecache", psxCdImageCache, 1)
WriteProperty(coreOptionsCFG, "beetle_psx_use_mednafen_memcard0_method", psxMemcardHandling, 1)
WriteProperty(coreOptionsCFG, "beetle_psx_analog_toggle", psxDualshockAnalogToggle, 1)
SaveProperties(coreOptionsCFGFile.FileFullPath, coreOptionsCFG)
hideEmuObj := Object(emuConsoleWindow,0,emuPrimaryWindow,1)
7z(romPath, romName, romExtension, sevenZExtractPath)
mgM3UFile := new File(romPath . "\" . romTable[1,4] . ".m3u")
mgRomExtensions := "cue|iso|ccd"
mgValidExtension := false
Loop, Parse, mgRomExtensions, |
If (romExtension = "." . A_LoopField)
mgValidExtension := true
If (StringUtils.Contains(retroID, "LibRetro_PSX") && romTable.MaxIndex() && mgValidExtension) { ; See if MultiGame table is populated
m3uRomIndex := Object()
mgType := romTable[1,6] . " "
mgMaxIndex := romTable.MaxIndex()
mgRomIndex := 0
If mgM3UFile.Exist()
mgM3UFile.Delete()
Loop % mgMaxIndex
If (romTable[A_Index, 3] = romName) {
tempType := romTable[A_Index, 5]
mgRomIndex := StringUtils.TrimLeft(tempType, StringUtils.StringLength(mgType))
RLLog.Info("Found rom index in rom set in romTable: " . mgRomIndex)
Break
If (mgRomIndex > 0) {
tempRomIndex := mgRomIndex
Loop % mgMaxIndex
mgTypeIndex := mgType . tempRomIndex
m3uRomIndex.Insert(tempRomIndex)
Loop % mgMaxIndex
If (romTable[A_Index, 5] = mgTypeIndex) {
tempRomPath := romTable[A_Index, 1]
mgM3UFile.Append(tempRomPath . "`n")
RLLog.Info("Module - Appending rom path to m3u: " . tempRomPath)
Break
If (tempRomIndex < mgMaxIndex)
tempRomIndex++
Else
tempRomIndex := 1
; MAME/MESS/UME core options
MAMEParam1 := ""
MAMEParam2 := ""
MAMEParam3 := ""
If StringUtils.Contains(core, "^(mame|mess|ume)") { ; if a MAME/MESS/UME core is used
If !retroMAMEID
ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for the MAME/MESS/UME LibRetro core")
Else
RLLog.Info("Module - MAME/MESS/UME mode using a known ident: " . retroMAMEID)
If !mameRomPath
ScriptError("Please set the RetroArch module setting ""BIOS_Roms_Folder"" to the folder that contains your MAME/MESS/UME BIOS roms to use with RetroArch.")
If (retroMAMEID = "mame") { ; want this for arcade mame only
RLLog.Info("Module - Retroarch MAME/MESS/UME Arcade mode enabled")
fullRomPath := " """ . romPath . "\" . romName . romExtension . """"
} Else {
RLLog.Info("Module - Retroarch MAME/MESS/UME Console/PC mode enabled")
MAMEParam1 := ""
MAMEParam2 := " -rompath \""" . mameRomPath . "\"""
; If we already have a media type, then use it.
If (StringUtils.Contains(retroMAMEID, "tg16|pce") && retroMAMEMedia = "cart") {
;MAMEParam3 := " -cart \" . """" . romPath . "\" . romName . romExtension . "\" . """"
MAMEParam3 := " -cart \""" . romPath . "\" . romName . romExtension . "\"""""
; TODO: This needs a better way to handle the cdrom bios files, in my opinion. As it is, there's no clean way to pick between the v2.00 or v3.00 bios.
;       Defaulting to the TurboDuo cdrom bios since it will play 2.00 or 3.00 games.
} Else If (StringUtils.Contains(retroMAMEID, "tg16|pce") && retroMAMEMedia = "cdrom") {
;MAMEParam3 := " -cart cdsys -cdrm \" . """" . romPath . "\" . romName . romExtension . "\" . """"
MAMEParam3 := " -cart scdsys -cdrm \""" . romPath . "\" . romName . romExtension . "\"""""
} Else {
; Build a key/value object containing the different MAMEParam3 choices
MAMEP3 := Object("alice32","cass1","gp32","memc","cpc464","cass","spectrum","cass","dragon64","cass","cdimono1","cdrom","bk0010","cass","neocd","cdrom","neocdz","cdrom","saturn","cdrm","saturnjp","cdrm","svi328n","cass","pecom64","cass","psu","cdrm","svmu","quik","gamecom","cart1","mbeeic","quik1")
MAMEParam3 := MAMEP3[retroMAMEID] ; search object for the retroMAMEID pair
MAMEParam3 := " -" . (If MAMEParam3 ? MAMEParam3 : "cart") . " \" . """" . romPath . "\" . romName . romExtension . "\" . """"
If (retroMAMEID = "mbeeic") ; Applied Technology MicroBee
{ microbeeModel := IniReadCheck(MAMESysINI, romName, "MicroBee_Model","mbeeic","",1)
If microbeeModel not in mbee,mbeeic,mbeepc,mbeepc85,mbee56
ScriptError("This is not a known MicroBee model value: " . microbeeModel)
Else If (microbeeModel != "mbeeic")
retroMAMEID := microbeeModel
If romExtension in .mwb,.com,.bee
mediaDeviceType := "quik1"
Else If romExtension in .wav,.tap
mediaDeviceType := "cass"
Else If romExtension in .rom
mediaDeviceType := "cart"
Else If romExtension in .dsk
mediaDeviceType := "flop1"
Else ; .bin format
mediaDeviceType := "quik2"
MAMEParam3 := " -" . mediaDeviceType . " \" . """" . romPath . "\" . romName . romExtension . "\" . """"
fullRomPath := MAMEParam1 . MAMEParam2 . MAMEParam3
} Else If (superGB = "true") {
RLLog.Info("Module - Retroarch Super Game Boy mode enabled")
fullRomPath := " """ . sgbRomPath . """ --subsystem sgb """ . romPath . "\" . romName . romExtension . """"
} Else {
RLLog.Info("Module - Retroarch standard mode enabled")
If (retroID = "LibRetro_NFDS") ; Nintendo Famicom Disk System
{ disksysRom := new File(retroSysDir . "\disksys.rom")
If !disksysRom.Exist()
ScriptError("RetroArch requires ""disksys.rom"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
} Else If (retroID = "LibRetro_SCD") ; Sega CD
{ If !StringUtils.Contains(romExtension, "\.bin|\.cue|\.iso")
ScriptError("RetroArch only supports Sega CD games in bin|cue|iso format. It does not support:`n" . romExtension)
biosCDEBin := new File(retroSysDir . "\bios_CD_E.bin")
biosCDUBin := new File(retroSysDir . "\bios_CD_U.bin")
biosCDJBin := new File(retroSysDir . "\bios_CD_J.bin")
If !biosCDEBin.Exist()
ScriptError("RetroArch requires ""bios_CD_E.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
If !biosCDUBin.Exist()
ScriptError("RetroArch requires ""bios_CD_U.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
If !biosCDJBin.Exist()
ScriptError("RetroArch requires ""bios_CD_J.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
} Else If StringUtils.Contains(retroID,"LibRetro_PCECD|LibRetro_TGCD") ; NEC PC Engine-CD and NEC TurboGrafx-CD
{ If !StringUtils.Contains(romExtension,"\.ccd|\.cue")
ScriptError("RetroArch only supports " . retroSystem . " games in ccd or cue format. It does not support:`n" . romExtension)
sysCard3Pce := new File(retroSysDir . "\syscard3.pce")
If !sysCard3Pce.Exist()
ScriptError("RetroArch requires ""syscard3.pce"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
} Else If (retroID = "LibRetro_PCFX")
pcfxBios := new File(retroSysDir . "\pcfx.bios")
If !pcfxBios.Exist()
ScriptError("RetroArch requires ""pcfx.bios"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
} Else If (retroID = "LibRetro_SCUMM")
scummFile := new File(romPath . "\" . romName . ".scummvm")
If !scummFile.Exist()
scummFile.Append("""" . romName . """")
networkSession := ""
If (enableNetworkPlay = "true") {
RLLog.Info("Module - Network Multi-Player is an available option for " . dbName)
netplayNickname := moduleIni.Read("Network", "NetPlay_Nickname","Player","",1)
getWANIP := moduleIni.Read("Network", "Get_WAN_IP","false","",1)
If (getWANIP = "true")
myPublicIP := GetPublicIP()
RLLog.Warning("Module - CAREFUL WHEN POSTING THIS LOG PUBLICLY AS IT CONTAINS YOUR IP ON THE NEXT LINE")
defaultServerIP := moduleIni.Read("Network", "Default_Server_IP", myPublicIP,"",1)
defaultServerPort := moduleIni.Read("Network", "Default_Server_Port","","",1)
lastIP := moduleIni.Read("Network", "Last_IP", defaultServerIP,"",1) ; does not need to be on the ISD
lastPort := moduleIni.Read("Network", "Last_Port", defaultServerPort,"",1) ; does not need to be on the ISD
mpMenuStatus := MultiPlayerMenu(lastIP,lastPort,networkType,"",0)
If (mpMenuStatus = -1) { ; if user exited menu early
RLLog.Warning("Module - Cancelled MultiPlayer Menu. Exiting module.")
ExitModule()
If networkSession {
RLLog.Info("Module - Using a Network for " . dbName)
moduleIni.Write(networkPort, "GlobalModuleIni", "Network", "Last_Port")
; msgbox lastIP: %lastIP%`nlastPort: %lastPort%`nnetworkIP: %networkIP%`nnetworkPort: %networkPort%
If (networkType = "client") {
moduleIni.Write(networkIP, "GlobalModuleIni", "Network", "Last_IP") ; Save last used IP and Port for quicker launching next time
netCommand := " -C " . networkIP . " --port " . networkPort . " --nick """ . netplayNickname . """" ; -C = connect as client
} Else { ; server
netCommand := " -H --port " . networkPort . " --nick """ . netplayNickname . """" ; -H = host as server
RLLog.Info("Module - Starting a network session using the IP """ . networkIP . """ and PORT """ . networkPort . """")
} Else
RLLog.Info("Module - User chose Single Player mode for this session")
BezelStart(,,(If rotateBezel ? 1:""))
If foundCfg {
If (stretchToFillBezel = "true" and bezelEnabled = "true" and bezelPath)
customViewportWidth := bezelScreenWidth
customViewportHeight := bezelScreenHeight
customViewportX := 0
customViewportY := 0
aspectRatioIndex := 22
RLLog.Info("Stretching viewport to fit bezel")
raCfgHasChanges := ""
WriteRetroProperty("input_overlay", overlay)
WriteRetroProperty("video_shader", videoShader)
WriteRetroProperty("aspect_ratio_index", aspectRatioIndex)
WriteRetroProperty("custom_viewport_width", customViewportWidth)
WriteRetroProperty("custom_viewport_height", customViewportHeight)
WriteRetroProperty("custom_viewport_x", customViewportX)
WriteRetroProperty("custom_viewport_y", customViewportY)
WriteRetroProperty("video_rotation", rotation)
WriteRetroProperty("video_crop_overscan", cropOverscan)
WriteRetroProperty("video_threaded", threadedVideo)
WriteRetroProperty("video_vsync", vSync)
WriteRetroProperty("video_scale_integer", integerScale)
WriteRetroProperty("input_disk_eject_toggle", ejectToggleKey)
WriteRetroProperty("input_disk_next", nextDiskKey)
WriteRetroProperty("input_disk_prev", prevDiskKey)
Loop, 8 ; Loop 8 times for 8 controllers
{ p%A_Index%ControllerType := moduleIni.Read(romName . "|" . systemName, "P" . A_Index . "_Controller_Type", 517,"",1)
WriteRetroProperty("input_libretro_device_p" . A_Index, p%A_Index%ControllerType)
If raCfgHasChanges {
RLLog.Info("Module - Saving changed settings to: """ . retroCFGFile.FileFullPath . """")
SaveProperties(retroCFGFile.FileFullPath, retroCFG)
fullscreen := If fullscreen = "true" ? " -f" : ""
srmPath := new Folder(emuPath . "\srm\" . retroSystem) ; path for this system's srm files
saveStatePath := new Folder(emuPath . "\save\" . retroSystem) ; path for this system's save state files
retroCFGFileCLI := If foundCfg ? " -c """ . retroCFGFile.FileFullPath . """" : ""
If !srmPath.Exist("folder")
srmPath.CreateDir() ; creating srm dir if it doesn't exist
If !saveStatePath.Exist("folder")
saveStatePath.CreateDir() ; creating save dir if it doesn't exist
HideAppStart(hideEmuObj,hideEmu)
If (StringUtils.Contains(core, "^(mame|mess|ume)") && (retroMAMEID != "mame")) {    ; if a MAME/MESS/UME core is used
primaryExe.Run(" """ . (retroMAMEID ? retroMAMEID : "") . fullRomPath . """ " . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
} Else If (retroID = "LibRetro_SCUMM") {
primaryExe.Run(" """ . scummFile . """" . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
} Else If (retroID = "LibRetro_SGB" || If superGB = "true") { ; For some reason, the order of our command line matters in this particular case.
primaryExe.Run(fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . fullRomPath . netCommand, "Hide")
} Else If mgM3UFile.Exist() {
primaryExe.Run(" """ . mgM3UFile.FileFullPath . """" . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
} Else {
primaryExe.Run(" " . fullRomPath . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
mpMenuStatus := ""
If networkSession {
canceledServerWait := false
multiplayerMenuExit := false
TimerUtils.SetTimer("NetworkConnectedCheck", 500)
If (networkType = "server") {
RLLog.Info("Module - Waiting for a client to connect to your server")
mpMenuStatus := MultiPlayerMenu(,,,,,,,,"You are the server. Please wait for your client to connect.")
} Else { ; client
RLLog.Info("Module - Trying to contact the server to establish a connection.")
mpMenuStatus := MultiPlayerMenu(,,,,,,,,"Attempting to connect to the server...")
If (mpMenuStatus = -1) { ; if user exited menu early before a client connected
RLLog.Warning("Module - Cancelled waiting for the " . If (networkType = "server") ? "client to connect" : "server to respond" . ". Exiting module.")
If primaryExe.Process("Exist")
primaryExe.Process("Close") ; must close process as the exe is waiting for a client to connect and no window was drawn yet
ExitModule()
} Else { ; blank response from MultiPlayerMenu, exited properly
RLLog.Info("Module - " . If (networkType = "server") ? "Client has connected" : "Connected to the server")
emuPrimaryWindow.Wait()
emuPrimaryWindow.WaitActive()
TimerUtils.SetTimer("NetworkConnectedCheck", "Off")
} Else { ; single player
If (hideConsole = "true")
emuConsoleWindow.Set("Transparent", "On") ; makes the console window transparent so you don't see it on exit
BezelDraw()
HideAppEnd(hideEmuObj,hideEmu)
FadeInExit()
primaryExe.Process("WaitClose")
7zCleanUp()
BezelExit()
FadeOutExit()
ExitModule()
; Writes new properties into the retroCFG if defined by user
WriteRetroProperty(key,value="") {
If (value != "") {
Global retroCFG,raCfgHasChanges
WriteProperty(retroCFG, key, value,1,1)
raCfgHasChanges := 1
; Used to convert between RetroArch keys and usable data
ConvertRetroCFGKey(txt,direction="read"){
Global emuPath,RLLog
If (direction = "read")
{ newtxt := StringUtils.TrimLeft(txt,1,0) ; removes the " from the left of the txt
newtxt := StringUtils.TrimRight(newtxt,1,0) ; removes the " from the right of the txt
relativeCheck := StringUtils.SubStr(newtxt,1,1,0)
If StringUtils.Contains(relativeCheck,":",0) { ; if the path contains a ":" then it is a relative path
RLLog.Debug("ConvertRetroCFGKey - " . newtxt . " is a relative path")
newtxt := StringUtils.TrimLeft(newtxt,1,0) ; removes the : from the left of the txt
newtxt := AbsoluteFromRelative(emuPath, "." . newtxt) ; convert relative to absolute
If StringUtils.Contains(newtxt,"/",0)
newtxt := StringUtils.Replace(newtxt,"/","\",1,"",0) ; replaces all forward slashes with backslashes
} Else If (direction = "write")
{ newtxt := """" . txt . """" ; wraps the txt with ""
If StringUtils.Contains(newtxt,"\\",0)
newtxt := StringUtils.Replace(newtxt,"\","/",1,"",0) ; replaces all backslashes with forward slashes
} Else
ScriptError("Not a valid use of ConvertRetroCFGKey. Only ""read"" or ""write"" are supported.")
RLLog.Debug("ConvertRetroCFGKey - Converted " . txt . " to " . newtxt)
Return newtxt
MultiGame:
KeyUtils.SetKeyDelay(100)
emuPrimaryWindow.Activate()
KeyUtils.Send("{" . ejectToggleKey . " down}{" . ejectToggleKey . " up}") ; eject disc in Retroarch
If (!mgLastRomIndex) {
mgLastRomIndex := mgRomIndex
selectedRomIndex := 0
selectedRomIndex := StringUtils.TrimLeft(selectedRomNum, StringUtils.StringLength(mgType,0))
Loop % mgMaxIndex
If (m3uRomIndex[A_index] = mgLastRomIndex) {
tempLastRomIndex := A_index
RLLog.Debug("Module - Last index: " . tempLastRomIndex)
If (m3uRomIndex[A_index] = selectedRomIndex) {
tempSelectedRomIndex := A_index
RLLog.Debug("Module - Selected index: " . tempSelectedRomIndex)
mgNewIndex := tempLastRomIndex - tempSelectedRomIndex
If (mgNewIndex < 0) {
mgNewIndex := mgNewIndex * -1
Loop % mgNewIndex
RLLog.Debug("Module - Sending the next disk key: " . nextDiskKey)
KeyUtils.Send("{" . nextDiskKey . " down}{" . nextDiskKey . " up}")
} Else If (mgNewIndex > 0) {
Loop % mgNewIndex
RLLog.Debug("Module - Sending the previous disk key: " . mgNewIndex)
KeyUtils.Send("{" . prevDiskKey . " down}{" . prevDiskKey . " up}")
KeyUtils.Send("{" . ejectToggleKey . " down}{" . ejectToggleKey . " up}") ; close disc in Retroarch
mgLastRomIndex := selectedRomIndex
Return
NetworkConnectedCheck:
If clientConnected
multiplayerMenuExit := true
Else If emuPrimaryWindow.Exist() {
RLLog.Info("Module - RetroArch session started, closing the MultiPlayer menu")
Return
CloseProcess:
FadeOutStart()
emuPrimaryWindow.Close()
Return
03:22:04:872 | RL |      INFO  | +32    | BuildScript - Loaded Multi-Player scripts
03:22:04:876 | RL |      INFO  | +0     | BuildScript - Loaded Statistics.ahk script
03:22:04:877 | RL |   WARNING  | +0     | BuildScript - "C:\RocketLauncher\Lib\User Functions.ahk" not found
03:22:04:877 | RL |      INFO  | +0     | BuildScript - Finished injecting functions into module
03:22:04:879 | RL |      INFO  | +0     | Main - Module is built
03:22:04:879 | RL |      INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\AutoHotkey.dll exists
03:22:04:881 | RL |      INFO  | +0     | Main - Running module
03:22:05:091 | MD |      INFO  | +N/A   | Module initialized
03:22:05:093 | MD |      INFO  | +0     | StartModule - Started
03:22:05:093 | MD |      INFO  | +0     | StartModule - MEmu: RetroArch
MEmuV: v05-11-2015 Nightly
MURL: http://themaister.net/retroarch.html
MAuthor: djvj,zerojay
MVersion: 2.4.2
MCRC: A8D5F162
iCRC: F7B77133
MID:
MSystem: "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","ScummVM","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Dreamcast","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Meganet","Sega Nomad","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sony PSP Minis","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
03:22:05:093 | MD |      INFO  | +0     | StartModule - You have a supported System Name for this module: "Sega Genesis"
03:22:05:095 | MD |      INFO  | +0     | PluginInit - Started
03:22:05:095 | MD |      INFO  | +0     | CheckFile - Checking if C:\HyperSpin\Databases\Sega Genesis\Sega Genesis.xml exists
03:22:05:098 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
03:22:05:098 | MD |      INFO  | +0     | BuildAssetsTable - Ended
03:22:05:098 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
03:22:05:163 | MD |      INFO  | +62    | BuildAssetsTable - Ended
03:22:05:163 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Game Video|System Video
03:22:05:184 | MD |      INFO  | +32    | BuildAssetsTable - Ended
03:22:05:184 | MD |      INFO  | +0     | PluginInit - Ended
03:22:05:186 | MD |      INFO  | +0     | StartModule - Ended
03:22:05:189 | MD |      INFO  | +0     | Module - Using these system variables:
03:22:05:189 | MD |      INFO  | +0     | Module - retroSystem: Sega Genesis
03:22:05:189 | MD |      INFO  | +0     | Module - retroID: LibRetro_GEN
03:22:05:189 | MD |      INFO  | +0     | Module - retroCore: genesis_plus_gx_libretro
03:22:05:189 | MD |      INFO  | +0     | Module - retroMAMEID: genesis
03:22:05:189 | MD |      INFO  | +0     | Module - retroMAMEMedia: cdrom
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - Fullscreen: true (DEFAULT)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - ConfigFolder: C:\HyperSpin\Emulators\RetroArch\config (DEFAULT)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - BIOS_Roms_Folder: (NO VALUE)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - Hide_Nag_Screen: false (DEFAULT)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - Hide_Info_Screen: false (DEFAULT)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - Hide_Warning_Screen: false (DEFAULT)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - HideConsole: true (DEFAULT)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - Eject_Toggle_Key: (NO VALUE)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - Next_Disk_Key: (NO VALUE)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - Previous_Disk_Key: (NO VALUE)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - LibRetro_Core: genesis_plus_gx_libretro (DEFAULT)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - SuperGameBoy: false (DEFAULT)
03:22:05:189 | MD |      INFO  | +0     | RIniFile.Read - Module - Enable_Network_Play: false (DEFAULT)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - Overlay: (NO VALUE)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - VideoShader: (NO VALUE)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - AspectRatioIndex: (NO VALUE)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - CustomViewportWidth: (NO VALUE)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - CustomViewportHeight: (NO VALUE)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - CustomViewportX: (NO VALUE)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - CustomViewportY: (NO VALUE)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - StretchToFillBezel: false (DEFAULT)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - Rotation: 0 (DEFAULT)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - CropOverscan: (NO VALUE)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - ThreadedVideo: (NO VALUE)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - VSync: (NO VALUE)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - IntegerScale: (NO VALUE)
03:22:05:190 | MD |      INFO  | +0     | RIniFile.Read - Module - ConfigurationPerCore: false (DEFAULT)
03:22:05:191 | MD |      INFO  | +0     | CheckFile - Checking if C:\HyperSpin\Emulators\RetroArch\cores\genesis_plus_gx_libretro.dll exists
03:22:05:191 | MD |      INFO  | +0     | Module - Global cfg should be: C:\HyperSpin\Emulators\RetroArch\retroarch.cfg
03:22:05:192 | MD |      INFO  | +0     | Module - System cfg should be: C:\HyperSpin\Emulators\RetroArch\config\Sega Genesis.cfg
03:22:05:192 | MD |      INFO  | +0     | Module - Core cfg should be: C:\HyperSpin\Emulators\RetroArch\config\genesis_plus_gx_libretro.dll.cfg
03:22:05:192 | MD |      INFO  | +0     | Module - Found a Global cfg!
03:22:05:192 | MD |      INFO  | +0     | Module - RetroArch is using C:\HyperSpin\Emulators\RetroArch\retroarch.cfg as its config file.
03:22:05:192 | MD |      INFO  | +0     | LoadProperties - Started and loading this cfg into memory: C:\HyperSpin\Emulators\RetroArch\retroarch.cfg
03:22:05:195 | MD |      INFO  | +0     | LoadProperties - Ended
03:22:05:195 | MD |      INFO  | +0     | 7z - Started, received C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).bin. If rom is an archive, it will extract to C:\Temp Game HyperSpin
03:22:05:195 | MD |      INFO  | +0     | 7z - This file is not an archive and does not need to be extracted.
03:22:05:195 | MD |      INFO  | +0     | 7z - Skipping main processing.
03:22:05:195 | MD |      INFO  | +0     | 7z - This rom type does not need 7z: ".bin"
03:22:05:195 | MD |   WARNING  | +0     | 7z - romPath changed from "C:\Users\Owner\Desktop" to "C:\Users\Owner\Desktop"
03:22:05:195 | MD |   WARNING  | +0     | 7z - romName changed from "3 Ninjas Kick Back (USA)" to "3 Ninjas Kick Back (USA)"
03:22:05:195 | MD |   WARNING  | +0     | 7z - romExtension changed from ".bin" to ".bin"
03:22:05:195 | MD |      INFO  | +0     | 7z - Ended
03:22:05:216 | MD |      INFO  | +31    | Module - Retroarch standard mode enabled
03:22:05:217 | MD |      INFO  | +0     | Module - Saving changed settings to: "C:\HyperSpin\Emulators\RetroArch\retroarch.cfg"
03:22:05:217 | MD |      INFO  | +0     | SaveProperties - Started and saving this cfg to disk: C:\HyperSpin\Emulators\RetroArch\retroarch.cfg
03:22:05:221 | MD |      INFO  | +0     | SaveProperties - Ended
03:22:05:222 | MD |      INFO  | +0     | Process.Run - Running: C:\HyperSpin\Emulators\RetroArch\retroarch.exe  "C:\Users\Owner\Desktop\3 Ninjas Kick Back (USA).bin" -f -c "C:\HyperSpin\Emulators\RetroArch\retroarch.cfg" -L "C:\HyperSpin\Emulators\RetroArch\cores\genesis_plus_gx_libretro.dll" -s "C:\HyperSpin\Emulators\RetroArch\srm\Sega Genesis\3 Ninjas Kick Back (USA).srm" -S "C:\HyperSpin\Emulators\RetroArch\save\Sega Genesis\3 Ninjas Kick Back (USA).state"
03:22:05:245 | MD |   WARNING  | +31    | Process.Run - Showing Command Window to troubleshoot launching. ProcessID: 3288
03:22:05:245 | MD |      INFO  | +0     | Window.Wait - Waiting for window ""
03:22:41:118 | MD |     ERROR  | +35865 | ScriptError - There was an error waiting for the window "". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
03:22:41:118 | MD |      INFO  | +0     | ExitModule - Started
03:22:41:118 | MD |      INFO  | +0     | Starting Updating Statistics:
03:22:41:339 | MD |      INFO  | +218   | Game section statistics updated.
03:22:41:340 | MD |      INFO  | +0     | ExitModule - Ended
End of Module Logs
03:22:41:409 | RL |      INFO  | +36535 | Main - Module ended, exiting RocketLauncher normally
03:22:41:409 | RL |      INFO  | +0     | ExitScript - Started
03:22:41:425 | RL |      INFO  | +16    | ExitScript - Restoring taskbar
03:22:41:676 | RL |      INFO  | +249   | SystemCursor - Restoring mouse cursor
03:22:41:696 | RL |      INFO  | +16    | ExitScript - Restored cursor
would like to point out i moved 1 rom outside the normal rom folder and extracted it and the set the rom path to my desktop which is where the rom is now located.
hope that makes sence
thanks again.
hi
can anyone shed any light on this or have a stumbled across some sort of bug that nobody has had before?
also having a problem with daemon tools mount switch syntax error and unmount switch systax error
regards
