Pizzadude Posted November 9, 2016 Posted November 9, 2016 Hi, I am new to hyperspin and have 2 questions in regards to the default configuration for installing Mame in Hyperspin.. I have the newest version of Hyperspin updated and Rocketlaunch. I see many using MAMEUIFX, can i use MameUI64 as my executable or do I have to use the NON windows Mame64 ? When I add the exe to Hyperspin it says I have to put a module ? mame ahk .166 shows up there.. It says that this module is used with the corresponding version of mame.. where do I find a 179 AHK module ? I did watch a very helpful video on how to do the install of the new Hyperspin and Rocketlauncher together but that's where it ends.. There are no video's or tutorials for setting up mame in the newest version of Hyperspin that I can find.. If there are and I am just not looking hard enough please feel free to point them out.. For my controls I am using a JPac.. All buttons work as they should when I run MAMEUI64.. When I enter hyperspin, the only thing that works is the PL1 joystick.. all others are something else.. Does Hyperspin read the control setup from MameUI or do I have to reconfigure them again in Hyperspin ?
thatman84 Posted November 9, 2016 Posted November 9, 2016 Try this vid Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Pizzadude Posted November 11, 2016 Author Posted November 11, 2016 So besides the video's not showing up for each game, only audio of the videos.. Now I'm getting another error when I try and load a game inside hyperspin.. "rom extension not found in INI" MameUI64 works flawless.. I have no clue what I am doing wrong....
Pizzadude Posted November 11, 2016 Author Posted November 11, 2016 4 minutes ago, agent47 said: The videos not playing could be a number of things like out of date gpu drivers, lack of codecs, etc. But if you're trying to use the MAME videos from antoPisa/Mame extras they will not work in HyperSpin, there's a specific set for HS vids on his site. All emumovies videos will work in HyperSpin. Post your HyperSpin log (the log.txt inside your HyperSpin folder) and post a RocketLauncher log set to Troubleshooting (open RLUI, set Logging Level to Troubleshooting on the RocketLauncher -> General Settings tab, run a game, and post the RocketLauncher.log file in your RocketLauncher folder). I have installed K-lite Mega pack codec, CCCP codec pack.... I have codec's coming out the ying yang lol
Pizzadude Posted November 11, 2016 Author Posted November 11, 2016 HYPERSPIN LOG 01:04:41 PM | HyperSpin Started 01:04:41 PM | Going FullScreen 01:04:41 PM | Checking for updates 01:04:41 PM | Update Check Complete 01:04:41 PM | Startup program unavailable 01:04:41 PM | Playing intro video 01:05:00 PM | Menu Mode is multi 01:05:00 PM | Loading Main Menu.xml 01:05:00 PM | Main Menu.xml successfully loaded 01:05:01 PM | Main Menu wheel loaded successfully 01:05:05 PM | Loading MAME.xml 01:05:06 PM | Main Menu.xml successfully loaded 01:05:06 PM | MAME wheel loaded successfully 01:05:32 PM | MAME wheel loaded successfully 01:06:02 PM | Launching Game 01:06:02 PM | Using HyperLaunch 01:06:02 PM | Getting Launcher path 01:06:02 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe 01:06:02 PM | Launcher located at E:\HyperSpin\HyperLaunch.exe 01:06:02 PM | Running Launcher 01:06:02 PM | Launcher Command Line is: E:\HyperSpin\HyperLaunch.exe "MAME" "1941" 01:06:05 PM | Launching Game 01:06:05 PM | Using HyperLaunch 01:06:05 PM | Getting Launcher path 01:06:05 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe 01:06:05 PM | Launcher located at E:\HyperSpin\HyperLaunch.exe 01:06:05 PM | Running Launcher 01:06:05 PM | Launcher Command Line is: E:\HyperSpin\HyperLaunch.exe "MAME" "1941u" 01:06:10 PM | Loading Main Menu.xml 01:06:10 PM | Main Menu.xml successfully loaded 01:06:10 PM | Main Menu wheel loaded successfully 01:06:12 PM | Exit program unavailable 01:06:12 PM | Quiting Hyperspin 01:06:12 PM | Bye! DEBUG 2016-11-10 11:03:08 [1] RocketLauncher.UI.Forms.PreferredJoysticksEditor RocketLauncher.UI.Forms.PreferredJoysticksEditor.updateJoystickCount(:0) – Connected Joystick with OEMName : J-PAC DEBUG 2016-11-10 11:04:17 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\RocketLauncherUI\Settings\nobezel.ini DEBUG 2016-11-10 11:04:45 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global Bezel.ini DEBUG 2016-11-10 11:04:45 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global RocketLauncher.ini DEBUG 2016-11-10 11:04:55 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global Bezel.ini DEBUG 2016-11-10 11:04:56 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global RocketLauncher.ini DEBUG 2016-11-10 11:04:56 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global RocketLauncher.ini DEBUG 2016-11-10 11:06:34 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global Emulators.ini DEBUG 2016-11-10 11:06:34 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\MAME\Emulators.ini DEBUG 2016-11-10 11:06:35 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Modules\MAME\MAME.ini DEBUG 2016-11-10 11:08:16 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\MAME\Emulators.ini DEBUG 2016-11-10 11:08:16 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global Emulators.ini DEBUG 2016-11-10 11:08:16 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\MAME\Emulators.ini DEBUG 2016-11-10 11:08:16 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\MAME\Games.ini DEBUG 2016-11-10 11:08:16 [1] RocketLauncher.UI.Controls.ModulePanel RocketLauncher.UI.Controls.ModulePanel.GenerateModuleList(:0) – Loading modules from E:\RocketLauncher\Modules DEBUG 2016-11-10 11:08:25 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Modules\MAME\MAME.ini DEBUG 2016-11-10 11:08:25 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Modules\MAME\MAME.ini DEBUG 2016-11-10 11:08:31 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\MAME\Emulators.ini DEBUG 2016-11-10 11:08:31 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global Emulators.ini DEBUG 2016-11-10 11:09:26 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global Emulators.ini DEBUG 2016-11-10 11:09:26 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global RocketLauncher.ini DEBUG 2016-11-10 11:09:30 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global Pause.ini DEBUG 2016-11-10 11:09:30 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global Bezel.ini DEBUG 2016-11-10 11:09:30 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File E:\RocketLauncher\Settings\Global Plugins.ini DEBUG 2016-11-10 11:09:34 [1] RocketLauncher.UI.Ini.RocketLauncherUIIni RocketLauncher.UI.Ini.RocketLauncherUIIni.updateWindowCoordinates(:0) – Updating window coordinates, From : 1368|732|602|0 To : 1368|732|-121|36
Pizzadude Posted November 11, 2016 Author Posted November 11, 2016 21 minutes ago, agent47 said: Are you using videos from EmuMovies or elsewhere? Like I said, some video formats will not play in HS no matter what. i am using a download of all the movies for 179 in the same MP4 format.. I bet that HS has a deal with emumovies to get people to pay to download more.. there is really no reason that other MP4 AVC movies wouln't work outside of HS forcibly not letting them.. people always talk about codec's and yet not a single person will tell you the exact codec that is needed... they all play in every player I have tried. VLC plays them just fine.. The only logical reason they would not play in HS would be, HS won't play video's that are not from Emumovies...
Pizzadude Posted November 11, 2016 Author Posted November 11, 2016 Just now, agent47 said: You don't have HS configured properly to use RocketLauncher so it's reverting to using HyperLaunch instead. Make sure that you're using HyperSpin 1.4 or newer and you have the Hyperlaunch_Path in the HyperSpin/Settings/Settings.ini pointing to your RocketLauncher.exe without any spelling mistakes. i followed the tutorial video step by step by step I have 1.4 HS and the newest rocketlauncher
Pizzadude Posted November 11, 2016 Author Posted November 11, 2016 28 minutes ago, agent47 said: You don't have HS configured properly to use RocketLauncher so it's reverting to using HyperLaunch instead. Make sure that you're using HyperSpin 1.4 or newer and you have the Hyperlaunch_Path in the HyperSpin/Settings/Settings.ini pointing to your RocketLauncher.exe without any spelling mistakes. i have went through HyperHQ, rocketlauncherUI and so on.. I have no idea where to put anymore links to rocketlaunch or hyperspin.. I was missing a : in the path this works but still no video's no matter how I encode them 01:54:13 PM | HyperSpin Started 01:54:13 PM | Going FullScreen 01:54:13 PM | Checking for updates 01:54:13 PM | Update Check Complete 01:54:13 PM | Startup program unavailable 01:54:13 PM | Playing intro video 01:54:32 PM | Menu Mode is multi 01:54:32 PM | Loading Main Menu.xml 01:54:32 PM | Main Menu.xml successfully loaded 01:54:33 PM | Main Menu wheel loaded successfully 01:54:38 PM | Loading MAME.xml 01:54:38 PM | Main Menu.xml successfully loaded 01:54:39 PM | MAME wheel loaded successfully 01:54:41 PM | Launching Game 01:54:41 PM | Using HyperLaunch 01:54:41 PM | Getting Launcher path 01:54:41 PM | Launcher located at E:\RocketLauncher\RocketLauncher.exe <-------- was missing the : on this line 01:54:41 PM | Running Launcher 01:54:41 PM | Launcher Command Line is: E:\RocketLauncher\RocketLauncher.exe "MAME" "1941u" 01:55:50 PM | Loading Main Menu.xml 01:55:50 PM | Main Menu.xml successfully loaded 01:55:51 PM | Main Menu wheel loaded successfully 01:55:52 PM | Exit program unavailable 01:55:52 PM | Quiting Hyperspin 01:55:52 PM | Bye!
Pizzadude Posted November 13, 2016 Author Posted November 13, 2016 I figured out the mp4 issue and can get non Emumovies mp4 video's to play in hyperspin.. Now that sparks another question..... On the wheel as you scroll through the games each title is supposed to have a icon or bmp for the name instead of just text name? Perfect example would be 88games.. That seems to have a icon that displays it differently.. Is there a mame icon pack or title pack that replaces just the text names for each game on the wheel ?? i hope i am explaining it properly...
