Audit Problem
Ex1zTeNz
Hello everyone,
Im trying to set up Hyperspin with RetroArch but for some reason when I audit my roms they stay red, I used Don's HyperSpin Tools but even when all roms are renamed they cant be found in rocketlauncher.
My roms cant start in rocketlauncher, cant figure out why, Im using Simply Austin guides
Any pointers would be welcome
Cheers
Which roms/systems are you trying to audit? Have you setup the rom paths in RocketLauncher? What are some of the errors you get when you are trying to launch a rom from RL?
For now I try to set up Genesis and Nes roms, yes I set roms path, I choose Sega Genesis and in emulators tab I set roms path, but for some reason it stays red 0 from the 781 roms
When I try to start a rom in rocketlauncher I get a yellow sign that says cant find rom path :-/
If RL is saying it cannot find a rom path then that is where you problem is. Re-check and make sure you have the correct path(s) in RL. Posting a screenshot also might help in troubleshooting your problem.
Will this help?
18:58:13:734 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.2.0.0 (www.rlauncher.com)
18:58:13:770 | RL |   WARNING  | +31    | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance.
18:58:14:044 | RL |     DEBUG  | +281   | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32
18:58:14:047 | RL |     DEBUG  | +0     | Registry.Read - Registry Read finished, returning 0
18:58:14:050 | RL |      INFO  | +0     | Main - System Specs:
     RocketLauncher Dir: C:\Users\Hyperspin\Documents\RocketLauncher
     RocketLauncher is: 32-bit
     OS: Microsoft Windows 10 Pro
     SKU: Professional
     Total Memory: 16290.70 MB
     Free Memory: 10861.69 MB
     Used Memory: 5429.004 MB
     SystemType: 64-bit
     Physical Processors: 1
     Logical Processors: 8
     GPU 1 Name: NVIDIA GeForce GT 650M
     GPU 1 RAM: 1024.00 MB
     GPU 1 Driver Version: 21.21.13.7595
     Sound 1 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
     Sound 1 Status: Enabled
     Sound 2 Device: Cirrus Logic CS4206B (AB 40)
     Sound 2 Status: Enabled
     System Locale: fr-BE
     Formats Locale: fr-BE
     Windows UI Language: en-US
     Text Encoding: Windows-1252
     OS Admin Status: No
     RL Compatibility Flags:  HIGHDPIAWARE
     Latest .Net Version: v4.0.30319
     Monitor #1 (\\.\DISPLAY1): 2880x1800 (2880x1740 work) [32bit] [60hz] [Landscape]  (Primary)
     Current AHK Desktop Width: 2880
     Current AHK Desktop Height: 1800
     Monitor #1 DPI: 200
     ErrorMode: 0
     AutoHotkey Path:
     AHK Version: 1.1.13.00
     Unicode: No
18:58:14:053 | RL |      INFO  | +0     | CheckFile - Checking if C:\Users\Hyperspin\Documents\RocketLauncher\RocketLauncher.exe exists
18:58:14:069 | RL |      INFO  | +16    | Main - Raw CLI received: "-s Sega Genesis -r After Burner II (USA, Europe) -e RetroArch -f C:\Users\Hyperspin\Documents\HyperSpin\HyperSpin.exe -p HyperSpin -c 1 -o 1"
18:58:14:084 | RL |     TRACE  | +15    | File.__New - Creating new file object of: "C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\RocketLauncher.dll"
18:58:14:100 | RL |      INFO  | +16    | File.CheckFile - Checking if "C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\RocketLauncher.dll" exists
18:58:14:103 | RL |     TRACE  | +16    | File.Exist - This file exists: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\RocketLauncher.dll
18:58:14:125 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Extension: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\Array.ahk
18:58:14:145 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\BinHexRW.ahk
18:58:14:148 | RL |      INFO  | +0     | CheckFile - Checking if C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\BlockInput.exe exists
18:58:14:180 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Extension: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop
18:58:14:199 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Extension: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk
18:58:14:220 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\gdip.ahk
18:58:14:241 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\gdip_alt.ahk
18:58:14:245 | RL |      INFO  | +15    | CheckFile - Checking if C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\gsdll32.dll exists
18:58:14:261 | RL |      INFO  | +16    | CheckFile - Checking if C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\itextsharp.dll exists
18:58:14:293 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\Java.ahk
18:58:14:315 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\JSON.ahk
18:58:14:336 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\Origin.ahk
18:58:14:357 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Extension: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\RegRW64.ahk
18:58:14:380 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Extension: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\RIni.ahk | v1.7
18:58:14:384 | RL |      INFO  | +16    | CheckFile - Checking if C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
18:58:14:417 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\Steam.ahk
18:58:14:438 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\VA.ahk
18:58:14:458 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\VA_Extension.ahk
18:58:14:479 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\7z.ahk
18:58:14:502 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Bezel.ahk
18:58:14:524 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Fade.ahk
18:58:14:545 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Fade Init.ahk
18:58:14:566 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Fade Animations.ahk
18:58:14:588 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Keymapper.ahk
18:58:14:609 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Keymapper Init.ahk
18:58:14:630 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\MultiGame.ahk
18:58:14:650 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\MultiGame Init.ahk
18:58:14:672 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\MultiPlayer.ahk
18:58:14:698 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Pause.ahk
18:58:14:720 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Pause Init.ahk
18:58:14:741 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Password.ahk
18:58:14:762 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk
18:58:14:784 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Log\Logger.ahk
18:58:14:806 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk
18:58:14:828 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk
18:58:14:849 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk
18:58:14:869 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk
18:58:14:891 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\File\File.ahk
18:58:14:912 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\File\Folder.ahk
18:58:14:933 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk
18:58:14:960 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk
18:58:14:994 | RL |      INFO  | +47    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\File\Process.ahk
18:58:14:016 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk
18:58:15:045 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\File\DemulShooter.ahk
18:58:15:080 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk
18:58:15:104 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\UI\Control.ahk
18:58:15:126 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\UI\Window.ahk
18:58:15:149 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk
18:58:15:171 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk
18:58:15:191 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Shader.ahk
18:58:15:212 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Shader Init.ahk
18:58:15:236 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Shared.ahk
18:58:15:258 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Statistics.ahk
18:58:15:279 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Statistics Init.ahk
18:58:15:300 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\Virtual Drive.ahk
18:58:15:322 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\XHotkey.ahk
18:58:15:343 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Lib\XHotkey Init.ahk
18:58:15:348 | RL |     DEBUG  | +0     | Main - Received this dbName with no path via CLI: "After Burner II (USA, Europe)"
18:58:15:354 | RL |     DEBUG  | +16    | Main - dbName: After Burner II (USA, Europe)
18:58:15:370 | RL |      INFO  | +15    | Main - After Burner II (USA, Europe) is being forced via CLI to use the emulator: RetroArch
18:58:15:376 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
18:58:15:397 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\Users\Hyperspin\Documents\RocketLauncher\Plugins\HyperSpin.plugin
18:58:15:402 | RL |     TRACE  | +16    | Process.__New - Creating new process object for: "C:\Users\Hyperspin\Documents\HyperSpin\HyperSpin.exe"
18:58:15:407 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "C:\Users\Hyperspin\Documents\HyperSpin\HyperSpin.exe"
18:58:15:424 | RL |      INFO  | +15    | Main - RocketLauncher received "Sega Genesis" and "After Burner II (USA, Europe)"
18:58:15:435 | RL |      INFO  | +16    | Main - Did not find a "C:\Users\Hyperspin\Documents\RocketLauncher\Settings\Sega Genesis\Game Options.ini" file, skipping any game-specific options.
18:58:15:440 | RL |      INFO  | +0     | Main - Checking for a [RetroArch] section in C:\Users\Hyperspin\Documents\RocketLauncher\Settings\Sega Genesis\Emulators.ini
18:58:15:446 | RL |      INFO  | +15    | Main - Checking for a [RetroArch] section in C:\Users\Hyperspin\Documents\RocketLauncher\Settings\Global Emulators.ini
18:58:15:452 | RL |      INFO  | +0     | Main - Found [RetroArch] in C:\Users\Hyperspin\Documents\RocketLauncher\Settings\Global Emulators.ini
18:58:15:484 | RL |      INFO  | +32    | CheckFile - Checking if C:\Users\Hyperspin\Documents\RocketLauncher\Modules\RetroArch\RetroArch.ahk exists
18:58:15:506 | RL |      INFO  | +15    | Main - CRC Check - CRC matches, this is an official unedited module.
18:58:15:510 | RL |      INFO  | +16    | Main - After Burner II (USA, Europe) will use module: C:\Users\Hyperspin\Documents\RocketLauncher\Modules\RetroArch\RetroArch.ahk
18:58:15:627 | RL |   WARNING  | +109   | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "C:\Users\Hyperspin\Documents\RocketLauncher\Settings\Global RocketLauncher.ini"
18:58:15:632 | RL |   WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "C:\Users\Hyperspin\Documents\RocketLauncher\Settings\Sega Genesis\RocketLauncher.ini"
18:58:15:676 | RL |      INFO  | +47    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
18:58:15:728 | RL |      INFO  | +63    | CheckFile - Checking if C:\Users\Hyperspin\Documents\HyperSpin\Emulators\RetroArch\retroarch.exe exists
18:58:15:747 | RL |      INFO  | +15    | Main - INI Keys read
18:58:15:766 | RL |      INFO  | +16    | CheckFile - Checking if C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\7z.exe exists
18:58:15:784 | RL |      INFO  | +16    | CheckFile - Checking if C:\Users\Hyperspin\Documents\RocketLauncher\Module Extensions\7z.dll exists
18:58:15:806 | RL |      INFO  | +31    | Main - "After Burner II (USA, Europe)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
18:58:15:811 | RL |      INFO  | +0     | CheckPaths - Started
18:58:15:815 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).7z
18:58:15:820 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).7z
18:58:15:825 | RL |      INFO  | +15    | CheckPaths - Rom not found
18:58:15:829 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).rar
18:58:15:833 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).rar
18:58:15:838 | RL |      INFO  | +16    | CheckPaths - Rom not found
18:58:15:842 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).zip
18:58:15:846 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).zip
18:58:15:850 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:15:854 | RL |      INFO  | +16    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).sfc
18:58:15:858 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).sfc
18:58:15:863 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:15:866 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).gba
18:58:15:870 | RL |      INFO  | +15    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).gba
18:58:15:875 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:15:879 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).gb
18:58:15:884 | RL |      INFO  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).gb
18:58:15:889 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:15:893 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).a78
18:58:15:897 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).a78
18:58:15:901 | RL |      INFO  | +16    | CheckPaths - Rom not found
18:58:15:905 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).sv
18:58:15:909 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).sv
18:58:15:913 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:15:917 | RL |      INFO  | +15    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).gbc
18:58:15:921 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).gbc
18:58:15:925 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:15:929 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).rpk
18:58:15:932 | RL |      INFO  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).rpk
18:58:15:936 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:15:940 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).gme
18:58:15:944 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).gme
18:58:15:948 | RL |      INFO  | +15    | CheckPaths - Rom not found
18:58:15:952 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).sc
18:58:15:956 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).sc
18:58:15:960 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:15:964 | RL |      INFO  | +16    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).cdt
18:58:15:968 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).cdt
18:58:15:972 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:15:976 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).ws
18:58:15:980 | RL |      INFO  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).ws
18:58:15:984 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:15:987 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).wsc
18:58:15:991 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).wsc
18:58:15:995 | RL |      INFO  | +15    | CheckPaths - Rom not found
18:58:15:999 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).ngp
18:58:15:003 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).ngp
18:58:16:007 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:011 | RL |      INFO  | +16    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).ngc
18:58:16:015 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).ngc
18:58:16:019 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:022 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).vms
18:58:16:026 | RL |      INFO  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).vms
18:58:16:030 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:034 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).ipf
18:58:16:038 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).ipf
18:58:16:042 | RL |      INFO  | +15    | CheckPaths - Rom not found
18:58:16:046 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).n64
18:58:16:049 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).n64
18:58:16:053 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:057 | RL |      INFO  | +16    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).z64
18:58:16:061 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).z64
18:58:16:065 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:068 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).sg
18:58:16:072 | RL |      INFO  | +15    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).sg
18:58:16:076 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:080 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).fds
18:58:16:085 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).fds
18:58:16:089 | RL |      INFO  | +16    | CheckPaths - Rom not found
18:58:16:093 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).caq
18:58:16:097 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).caq
18:58:16:101 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:105 | RL |      INFO  | +16    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).vb
18:58:16:109 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).vb
18:58:16:113 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:116 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).vec
18:58:16:120 | RL |      INFO  | +15    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).vec
18:58:16:124 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:128 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).wav
18:58:16:132 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).wav
18:58:16:136 | RL |      INFO  | +16    | CheckPaths - Rom not found
18:58:16:139 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).cas
18:58:16:143 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).cas
18:58:16:147 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:151 | RL |      INFO  | +16    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).min
18:58:16:155 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).min
18:58:16:159 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:163 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).int
18:58:16:167 | RL |      INFO  | +15    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).int
18:58:16:170 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:174 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).rom
18:58:16:178 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).rom
18:58:16:182 | RL |      INFO  | +16    | CheckPaths - Rom not found
18:58:16:186 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).tap
18:58:16:189 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).tap
18:58:16:193 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:197 | RL |      INFO  | +15    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).tzx
18:58:16:201 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).tzx
18:58:16:204 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:208 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).nes
18:58:16:212 | RL |      INFO  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).nes
18:58:16:217 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:221 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).col
18:58:16:225 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).col
18:58:16:229 | RL |      INFO  | +16    | CheckPaths - Rom not found
18:58:16:233 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).nds
18:58:16:237 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).nds
18:58:16:241 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:244 | RL |      INFO  | +15    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).cpr
18:58:16:248 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).cpr
18:58:16:252 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:256 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).gg
18:58:16:260 | RL |      INFO  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).gg
18:58:16:264 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:268 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).pce
18:58:16:272 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).pce
18:58:16:276 | RL |      INFO  | +16    | CheckPaths - Rom not found
18:58:16:280 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).st2
18:58:16:284 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).st2
18:58:16:287 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:291 | RL |      INFO  | +15    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).sms
18:58:16:295 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).sms
18:58:16:299 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).smc
18:58:16:307 | RL |      INFO  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).smc
18:58:16:311 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:315 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).lnx
18:58:16:319 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).lnx
18:58:16:323 | RL |      INFO  | +15    | CheckPaths - Rom not found
18:58:16:327 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).md
18:58:16:332 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).md
18:58:16:336 | RL |      INFO  | +16    | CheckPaths - Rom not found
18:58:16:340 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).32x
18:58:16:344 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).32x
18:58:16:349 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:353 | RL |      INFO  | +16    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).n64
18:58:16:357 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).n64
18:58:16:362 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:366 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).a52
18:58:16:370 | RL |      INFO  | +15    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).a52
18:58:16:374 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:379 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).j64
18:58:16:383 | RL |      INFO  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).j64
18:58:16:388 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:392 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).cso
18:58:16:396 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).cso
18:58:16:400 | RL |      INFO  | +16    | CheckPaths - Rom not found
18:58:16:404 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).cue
18:58:16:409 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).cue
18:58:16:413 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:417 | RL |      INFO  | +15    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).iso
18:58:16:422 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).iso
18:58:16:426 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:430 | RL |      INFO  | +16    | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).ccd
18:58:16:434 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).ccd
18:58:16:439 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:443 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).chd
18:58:16:447 | RL |      INFO  | +15    | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).chd
18:58:16:452 | RL |      INFO  | +0     | CheckPaths - Rom not found
18:58:16:456 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe).bin
18:58:16:460 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\Hyperspin\Desktop\Genesis\After Burner II (USA, Europe)\After Burner II (USA, Europe).bin
18:58:16:465 | RL |      INFO  | +16    | CheckPaths - Rom not found
18:58:16:469 | RL |     DEBUG  | +0     | CheckPaths - Current romName:
18:58:16:473 | RL |     DEBUG  | +0     | CheckPaths - Current romPath:
18:58:16:477 | RL |     DEBUG  | +16    | CheckPaths - Current romExtension:
18:58:16:835 | RL |     DEBUG  | +343   | ScriptError - Playing error sound: error1.mp3
18:58:23:093 | RL |     ERROR  | +6266  | Cannot find Rom
In any Rom_Paths provided:
"C:\Users\Hyperspin\Desktop\Genesis"
With any provided Rom_Extension:
"7z|rar|zip|sfc|gba|gb|a78|sv|gbc|rpk|gme|sc|cdt|ws|wsc|ngp|ngc|vms|ipf|n64|z64|sg|fds|caq|vb|vec|wav|cas|min|int|rom|tap|tzx|nes|col|nds|cpr|gg|pce|st2|sms|smc|lnx|md|32x|n64|a52|j64|cso|cue|iso|ccd|chd|bin"
18:58:23:099 | RL |      INFO  | +0     | ExitScript - Started
18:58:23:110 | RL |     DEBUG  | +16    | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32
18:58:23:115 | RL |     DEBUG  | +0     | Registry.Read - Registry Read finished, returning 0
18:58:23:119 | RL |     TRACE  | +15    | StringUtils.Contains - "false" does not contain "true|kill"
18:58:23:123 | RL |      INFO  | +0     | ExitScript - Restoring taskbar
18:58:23:128 | RL |     TRACE  | +0     | Window.__New - Created: "ahk_class Shell_TrayWnd"
18:58:23:132 | RL |     TRACE  | +0     | Window.__New - Created: "Start ahk_class Button"
18:58:23:136 | RL |     TRACE  | +16    | Window.Show - Unhiding window "ahk_class Shell_TrayWnd"
18:58:23:244 | RL |     TRACE  | +109   | Window.Show - Unhiding window "Start ahk_class Button"
18:58:23:281 | RL |      INFO  | +32    | SystemCursor - Restoring mouse cursor
18:58:23:321 | RL |      INFO  | +46    | ExitScript - Restored cursor
18:58:23:327 | RL |      INFO  | +0     | ExitScript - Ended
Like I said before, make sure your paths are correct. RL cannot find any roms on the path you specified so clearly there is something wrong there.
"C:\Users\Hyperspin\Desktop\Genesis" seems like a weird place to put your roms tho, maybe you did so for testing purposes but I advice you to put your roms somewhere else than on your desktop.
Yes the folder of my roms is located on my desktop for testing purpose only, Ill move them to my hyperspin folder.
Yes there is a After Burner II (USA, Europe) it seems that I have other games labeld like this, not all but some. The games extensions are .GEN
This folder is the renamed one  with Don's Hyperspin Tools, the source of these roms where compressed in 7zip, but it extracted by it self after being renamed.
.gen isn't part of the extension list for your emulator. Adding that or compressing your roms will help.
If you put the roms to their desired location make sure you also update the path in RL.
Thanks for the fast reply and the help guys, what extention does retroarch accept for genesis games? got some 32X games  are these the same extention like genesis?
These are the extensions listed for Retroarch, but you can add GEN to that list too if you want, another solution is to compress your roms.
No, filename and extension shouldn't really matter if you have compressed roms. Make sure you have the option 7z enabled under the settings --> main settings tab for that particular system.
You guys where a great help, it works now, I added the gen extention into RetroArch as well and now it works like a charm.
Thanks for your time and help :-)
