m714w Posted November 30, 2016 Posted November 30, 2016 Hello, issue: I can launch all my Taito Type X games (.bat files) on it own and also can launch the game in RocketLuancher.exe. I cannot get any games to launch in Rocket Launcher UI 1.0.1.9. With fade off and Troubleshooting on, I can see a box opens fast and closes but nothing after. I do get the error: There was an error waiting for the window "BattleFantasia" Please check you have the correct version emulator installed for this module, followed any notes in the module, have the emulator working outside the frontend first. Also turn off Fade. History: with my Taito Type X, I had this set up and working a while back within RocketLancherUI /Hyperspin 1.4 but not sure when it stopped working. I did update the UI but not sure this is the cause. Below is the Log. If someone can help that would be great. 10:05:56:978 | RL | INFO | +N/A | Main - RocketLauncher v1.2.0.0 (www.rlauncher.com) 10:05:56:021 | RL | WARNING | +47 | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance. 10:05:57:144 | RL | DEBUG | +125 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 10:05:57:144 | RL | DEBUG | +0 | Registry.Read - Registry Read finished, returning 0 10:05:57:144 | RL | INFO | +0 | Main - System Specs: RocketLauncher Dir: D:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 7 Home Premium SKU: Home Premium Total Memory: 16335.37 MB Free Memory: 11755.11 MB Used Memory: 4580.266 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 2 GPU 1 Name: NVIDIA GeForce GTX 660 GPU 1 RAM: -2048.00 MB GPU 1 Driver Version: 9.18.13.2723 Sound 1 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 1 Status: Enabled Sound 2 Device: NVIDIA High Definition Audio Sound 2 Status: Enabled Sound 3 Device: Realtek High Definition Audio Sound 3 Status: Enabled OS Language: English_United_States System Locale: en-US Formats Locale: en-US Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x900 work) [16bit] [60hz] [Landscape] (Primary) Current AHK Desktop Width: 1440 Current AHK Desktop Height: 900 Monitor #1 DPI: 100 ErrorMode: 0 AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.13.00 Unicode: No 10:05:57:144 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\RocketLauncher.exe exists 10:05:57:145 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription RocketLauncher FileVersion 1.2.0.0 LegalCopyright ©2016 RocketLauncher ProductName djvj's one swell guy! ProductVersion 1.2.0.0 CompanyName Your favorite Front End companion! Visit us @ www.rlauncher.com File Size: 2184192 bytes Created: 12/17/2015 - 4:06:01 PM Modified: 11/27/2016 - 3:25:12 PM 10:05:57:145 | RL | INFO | +0 | Main - Raw CLI received: "-s Taito Type X -r Battle Fantasia -f D:\Arcade\HyperSpin.exe -p HyperSpin -c 1 -o 1" 10:05:57:146 | RL | TRACE | +0 | File.__New - Creating new file object of: "D:\RocketLauncher\Module Extensions\RocketLauncher.dll" 10:05:57:146 | RL | INFO | +0 | File.CheckFile - Checking if "D:\RocketLauncher\Module Extensions\RocketLauncher.dll" exists 10:05:57:147 | RL | TRACE | +0 | File.Exist - This file exists: D:\RocketLauncher\Module Extensions\RocketLauncher.dll 10:05:57:147 | RL | DEBUG | +0 | File.CheckFile - Attributes: FileDescription RocketLauncher Utils FileVersion 1.0.1.0 InternalName RocketLauncher.dll LegalCopyright Copyright © RocketLauncher 2013-2016 OriginalFilename RocketLauncher.dll ProductName RocketLauncher ProductVersion 1.0.1.0 File Size: 73216 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 11/27/2016 - 3:25:18 PM 10:05:57:151 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: D:\RocketLauncher\Module Extensions\Array.ahk 10:05:57:152 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4781 bytes Created: 12/17/2015 - 5:44:09 PM Modified: 4/21/2016 - 10:20:05 AM 10:05:57:153 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Module Extensions\BinHexRW.ahk 10:05:57:153 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5112 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 11/27/2016 - 3:25:41 PM 10:05:57:153 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\Module Extensions\BlockInput.exe exists 10:05:57:154 | RL | DEBUG | +16 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 1/2/2014 - 10:27:34 PM 10:05:57:155 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: D:\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop 10:05:57:156 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5323 bytes Created: 12/17/2015 - 5:44:21 PM Modified: 4/21/2016 - 10:20:17 AM 10:05:57:157 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: D:\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk 10:05:57:157 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5716 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 4/29/2013 - 1:56:02 PM 10:05:57:159 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: D:\RocketLauncher\Module Extensions\gdip.ahk 10:05:57:160 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 1/13/2013 - 5:07:30 PM 10:05:57:161 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Module Extensions\gdip_alt.ahk 10:05:57:162 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5955 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 11/27/2016 - 3:25:47 PM 10:05:57:162 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\Module Extensions\gsdll32.dll exists 10:05:57:162 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 13090816 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 1/6/2015 - 9:20:42 PM 10:05:57:163 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\Module Extensions\itextsharp.dll exists 10:05:57:164 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 6/14/2013 - 2:06:21 PM 10:05:57:165 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Module Extensions\Java.ahk 10:05:57:165 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 7859 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 11/27/2016 - 3:25:29 PM 10:05:57:166 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: D:\RocketLauncher\Module Extensions\JSON.ahk 10:05:57:167 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 9227 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 4/21/2016 - 10:20:04 AM 10:05:57:167 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Module Extensions\Origin.ahk 10:05:57:168 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4915 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 11/27/2016 - 3:25:16 PM 10:05:57:169 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: D:\RocketLauncher\Module Extensions\RegRW64.ahk 10:05:57:169 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 6915 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 5/8/2014 - 3:06:39 AM 10:05:57:171 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Extension: D:\RocketLauncher\Module Extensions\RIni.ahk | v1.7 10:05:57:171 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 67872 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 11/27/2016 - 3:25:44 PM 10:05:57:172 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists 10:05:57:173 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.5717.6837 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.5717.6837 CompanyName Markovtsev Vadim File Size: 167424 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 12/17/2015 - 5:44:22 PM 10:05:57:174 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Module Extensions\Steam.ahk 10:05:57:174 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5517 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 11/27/2016 - 3:25:13 PM 10:05:57:175 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: D:\RocketLauncher\Module Extensions\VA.ahk 10:05:57:176 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 3/1/2013 - 9:05:47 PM 10:05:57:177 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Module Extensions\VA_Extension.ahk 10:05:57:177 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3862 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 11/27/2016 - 3:25:19 PM 10:05:57:179 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\7z.ahk 10:05:57:179 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 33522 bytes Created: 12/17/2015 - 4:06:01 PM Modified: 11/27/2016 - 3:26:15 PM 10:05:57:181 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Bezel.ahk 10:05:57:182 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 120460 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:32 PM 10:05:57:183 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Fade.ahk 10:05:57:184 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 39552 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:28 PM 10:05:57:185 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Fade Init.ahk 10:05:57:185 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1140 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:47 PM 10:05:57:187 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Fade Animations.ahk 10:05:57:188 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 77961 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:46 PM 10:05:57:189 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Keymapper.ahk 10:05:57:189 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 33682 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:25 PM 10:05:57:190 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Keymapper Init.ahk 10:05:57:191 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3966 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:12 PM 10:05:57:192 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\MultiGame.ahk 10:05:57:193 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 41583 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:43 PM 10:05:57:194 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\MultiGame Init.ahk 10:05:57:194 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 169 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:15 PM 10:05:57:196 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\MultiPlayer.ahk 10:05:57:196 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 67277 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:14 PM 10:05:57:202 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Pause.ahk 10:05:57:202 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 400094 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:26:14 PM 10:05:57:203 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Pause Init.ahk 10:05:57:204 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 563 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:26:11 PM 10:05:57:205 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Password.ahk 10:05:57:205 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 10131 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:41 PM 10:05:57:207 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk 10:05:57:207 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 26445 bytes Created: 4/21/2016 - 10:20:17 AM Modified: 11/27/2016 - 3:25:48 PM 10:05:57:208 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Log\Logger.ahk 10:05:57:208 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3558 bytes Created: 4/21/2016 - 10:20:05 AM Modified: 11/27/2016 - 3:25:12 PM 10:05:57:209 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk 10:05:57:210 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 6617 bytes Created: 4/21/2016 - 10:20:11 AM Modified: 11/27/2016 - 3:25:18 PM 10:05:57:211 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk 10:05:57:211 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1547 bytes Created: 4/21/2016 - 10:20:00 AM Modified: 11/27/2016 - 3:26:12 PM 10:05:57:212 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk 10:05:57:213 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 7606 bytes Created: 4/21/2016 - 10:20:05 AM Modified: 11/27/2016 - 3:25:40 PM 10:05:57:214 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk 10:05:57:214 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 2948 bytes Created: 4/21/2016 - 10:20:05 AM Modified: 11/27/2016 - 3:25:27 PM 10:05:57:215 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\File\File.ahk 10:05:57:216 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 9032 bytes Created: 4/21/2016 - 10:19:56 AM Modified: 11/27/2016 - 3:25:41 PM 10:05:57:217 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\File\Folder.ahk 10:05:57:217 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 643 bytes Created: 4/26/2016 - 3:59:49 PM Modified: 11/27/2016 - 3:25:16 PM 10:05:57:218 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk 10:05:57:219 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4364 bytes Created: 4/21/2016 - 10:20:15 AM Modified: 11/27/2016 - 3:25:15 PM 10:05:57:219 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk 10:05:57:220 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3898 bytes Created: 5/21/2016 - 2:03:45 PM Modified: 11/27/2016 - 3:25:45 PM 10:05:57:221 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\File\Process.ahk 10:05:57:221 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 9513 bytes Created: 4/21/2016 - 10:20:00 AM Modified: 11/27/2016 - 3:25:13 PM 10:05:57:222 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk 10:05:57:223 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1231 bytes Created: 5/21/2016 - 2:03:09 PM Modified: 11/27/2016 - 3:25:28 PM 10:05:57:223 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\File\DemulShooter.ahk 10:05:57:224 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 682 bytes Created: 11/27/2016 - 3:25:30 PM Modified: 11/27/2016 - 3:25:31 PM 10:05:57:225 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk 10:05:57:225 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5426 bytes Created: 4/21/2016 - 10:19:59 AM Modified: 11/27/2016 - 3:25:26 PM 10:05:57:226 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\UI\Control.ahk 10:05:57:227 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4603 bytes Created: 4/21/2016 - 10:19:57 AM Modified: 11/27/2016 - 3:25:31 PM 10:05:57:228 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\UI\Window.ahk 10:05:57:228 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 24474 bytes Created: 4/21/2016 - 10:19:57 AM Modified: 11/27/2016 - 3:25:12 PM 10:05:57:229 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk 10:05:57:230 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1171 bytes Created: 4/21/2016 - 10:20:11 AM Modified: 11/27/2016 - 3:25:48 PM 10:05:57:231 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk 10:05:57:232 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 72279 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:40 PM 10:05:57:233 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Shader.ahk 10:05:57:233 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4183 bytes Created: 4/21/2016 - 10:19:58 AM Modified: 11/27/2016 - 3:25:13 PM 10:05:57:234 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Shader Init.ahk 10:05:57:234 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 412 bytes Created: 4/21/2016 - 10:20:03 AM Modified: 11/27/2016 - 3:25:56 PM 10:05:57:237 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Shared.ahk 10:05:57:237 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 174455 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:18 PM 10:05:57:239 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Statistics.ahk 10:05:57:239 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 27008 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:47 PM 10:05:57:240 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Statistics Init.ahk 10:05:57:240 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 43 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:29 PM 10:05:57:242 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\Virtual Drive.ahk 10:05:57:242 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 20294 bytes Created: 12/17/2015 - 4:06:01 PM Modified: 11/27/2016 - 3:25:32 PM 10:05:57:243 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\XHotkey.ahk 10:05:57:244 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 26615 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:25:42 PM 10:05:57:245 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Lib\XHotkey Init.ahk 10:05:57:245 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1073 bytes Created: 12/17/2015 - 4:05:59 PM Modified: 11/27/2016 - 3:26:03 PM 10:05:57:245 | RL | DEBUG | +0 | Main - Received this dbName with no path via CLI: "Battle Fantasia" 10:05:57:245 | RL | DEBUG | +0 | Main - dbName: Battle Fantasia 10:05:57:246 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 10:05:57:247 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: D:\RocketLauncher\Plugins\HyperSpin.plugin 10:05:57:247 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 9392 bytes Created: 12/17/2015 - 4:06:01 PM Modified: 11/27/2016 - 3:25:41 PM 10:05:57:247 | RL | TRACE | +0 | Process.__New - Creating new process object for: "D:\Arcade\HyperSpin.exe" 10:05:57:247 | RL | TRACE | +0 | File.__New - Creating new file object of: "D:\Arcade\HyperSpin.exe" 10:05:57:248 | RL | INFO | +15 | Main - RocketLauncher received "Taito Type X" and "Battle Fantasia" 10:05:57:253 | RL | INFO | +0 | Main - Did not find a "D:\RocketLauncher\Settings\Taito Type X\Game Options.ini" file, skipping any game-specific options. 10:05:57:254 | RL | INFO | +0 | Main - Battle Fantasia is using the default emulator: PCLauncher 10:05:57:254 | RL | INFO | +0 | Main - Checking for a [PCLauncher] section in D:\RocketLauncher\Settings\Taito Type X\Emulators.ini 10:05:57:254 | RL | INFO | +0 | Main - Checking for a [PCLauncher] section in D:\RocketLauncher\Settings\Global Emulators.ini 10:05:57:255 | RL | INFO | +0 | Main - Found [PCLauncher] in D:\RocketLauncher\Settings\Global Emulators.ini 10:05:57:256 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk exists 10:05:57:257 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 20197 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 11/27/2016 - 3:25:43 PM 10:05:57:257 | RL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 10:05:57:258 | RL | INFO | +0 | Main - Battle Fantasia will use module: D:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk 10:05:57:264 | RL | WARNING | +16 | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "D:\RocketLauncher\Settings\Global RocketLauncher.ini" 10:05:57:264 | RL | WARNING | +0 | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "D:\RocketLauncher\Settings\Taito Type X\RocketLauncher.ini" 10:05:57:285 | RL | INFO | +15 | Main - Using SkipChecks method "Rom and Emu" or emuName = "PCLauncher". 10:05:57:287 | RL | INFO | +0 | CheckFile - Checking if D:\Arcade\Emulators\PCLauncher\PCLauncher.exe exists 10:05:57:289 | RL | DEBUG | +0 | CheckFile - Attributes: FileVersion 1, 0, 48, 05 ProductVersion 1, 0, 48, 05 File Size: 207050 bytes Created: 11/23/2013 - 9:19:37 AM Modified: 10/26/2010 - 3:21:12 AM 10:05:57:290 | RL | INFO | +0 | Main - INI Keys read 10:05:57:290 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\Module Extensions\7z.exe exists 10:05:57:291 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 262144 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 12/17/2015 - 5:44:10 PM 10:05:57:292 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\Module Extensions\7z.dll exists 10:05:57:292 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription 7z Plugin FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.dll ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 1012224 bytes Created: 12/17/2015 - 4:06:00 PM Modified: 12/17/2015 - 5:44:21 PM 10:05:57:294 | RL | INFO | +0 | Main - "Battle Fantasia" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 10:05:57:294 | RL | WARNING | +N/A | Main - SkipChecks is enabled and set to: Rom Only 10:05:57:294 | RL | INFO | +0 | CheckPaths - Started 10:05:57:295 | RL | DEBUG | +16 | CheckPaths - Current romName: 10:05:57:295 | RL | DEBUG | +0 | CheckPaths - Current romPath: D:\Arcade\Taito Type X 10:05:57:295 | RL | DEBUG | +0 | CheckPaths - Current romExtension: 10:05:57:295 | RL | INFO | +0 | CheckPaths - Ended 10:05:57:296 | RL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook MiscUtils.DetectHiddenWindows("On") SetTitleMatchMode, 2 SendMode, Event Global RLLog Global RLObject 0 := "12" rlPath := "D:\RocketLauncher" pluginPath := "D:\RocketLauncher\Plugins" pluginName := "HyperSpin" pluginExt := ".plugin" contextOnExit := "1" rlMode := "" rlTitle := "RocketLauncher" rlVersion := "1.2.0.0" rlAuthor := "djvj" rlURL := "www.rlauncher.com" langFile := "D:\RocketLauncher\Data\Language\Localization.ini" primMonitor := "1" frontendPID := "" frontendPath := "D:\Arcade" frontendExe := "HyperSpin.exe" frontendExt := "exe" frontendName := "HyperSpin" frontendDrive := "D" exitEmulatorKey := "~Esc" restoreFE := "false" exitScriptKey := "~!" toggleCursorKey := "~e & ~t" emuFullPath := "D:\Arcade\Emulators\PCLauncher\PCLauncher.exe" emuPath := "D:\Arcade\Emulators\PCLauncher" emuName := "PCLauncher" emuExt := "exe" baseRomPath := "" romPath := "D:\Arcade\Taito Type X" romPathFromIni := "D:\Arcade\Taito Type X" romExtension := "" romExtensionOrig := "" romExtensions := "" executable := "PCLauncher.exe" systemDbName := "Taito Type X" systemName := "Taito Type X" dbPath := "" dbName := "Battle Fantasia" dbExt := "" romName := "" romMapPath := "" romMappingEnabled := "false" romMappingLaunchMenuEnabled := "false" romMappingFirstMatchingExt := "false" romMappingShowAllRomsInArchive := "true" romMappingNumberOfGamesByScreen := "7" romMappingHideParent := "false" romMappingMenuWidth := "400" romMappingMenuMargin := "65" romMappingTextFont := "Bebas Neue" romMappingTextOptions := "cFFFFFFFF r4 s60 Bold" romMappingDisabledTextColor := "ff888888" romMappingTextSizeDifference := "7" romMappingTextMargin := "15" romMappingTitleTextFont := "Bebas Neue" romMappingTitleTextOptions := "cFFFFFFFF r4 s90 Bold" romMappingTitle2TextFont := "Bebas Neue" romMappingTitle2TextOptions := "cFFFFFFFF r4 s22 Bold" romMappingGameInfoTextFont := "Bebas Neue" romMappingGameInfoTextOptions := "cFFFFFFFF r4 s22 Regular" romMappingGameNameTextFont := "Bebas Neue" romMappingGameNameTextOptions := "cFFFFFFFF r4 s40 Regular" romMappingBackgroundBrush := "aa000000" romMappingColumnBrush := "33000000" romMappingButtonBrush1 := "6f000000" romMappingButtonBrush2 := "33000000" romMappingBackgroundAlign := "Stretch and Lose Aspect" romMappingMenuFlagWidth := "55" romMappingMenuFlagSeparation := "7" romMappingDefaultMenuList := "FullList" romMappingSingleFilteredRomAutomaticLaunch := "false" altArchiveNameOnly := "" altRomNameOnly := "" altArchiveAndRomName := "" altArchiveAndManyRomNames := "" altRomNamesOnly := "" romMapScenario := "" skipchecks := "Rom Only" romMatchExt := "true" blockInputTime := "0" blockInputFile := "D:\RocketLauncher\Module Extensions\BlockInput.exe" errorLevelReporting := "false" lockLaunch := "false" lockLaunchGame := "" screenRotationAngle := "0" screenRotationAngleGame := "" setResolution := "" logFile := "" logLabel := [" INFO"," WARNING"," ERROR"," DEBUG"," TRACE"] logLevel := "10" logShowDebugConsole := "false" logShowCommandWindow := "false" logCommandWindow := "false" logIncludeModule := "true" logIncludeFileProperties := "true" logIncludeDLLLogs := "false" errorSounds := "true" rlDebugConsoleStdout := "" sysLang := "English_United_States" sysType := "64-bit" broadcastWindowTitle := "" navUpKey := "Up|W" navDownKey := "Down|S" navLeftKey := "Left|A" navRightKey := "Right|D" navSelectKey := "Enter|." navP2UpKey := "Numpad8" navP2DownKey := "Numpad2" navP2LeftKey := "Numpad4" navP2RightKey := "Numpad6" navP2SelectKey := "NumpadEnter" originalWidth := "1440" originalHeight := "900" vdEnabled := "true" vdFullPath := "C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe" vdUseSCSI := "true" vdDriveLetter := "0" vdDriveLetterScsi := "" vdAddDrive := "true" demulShooterPath := "" servoStikEnabled := "false" servoStikExitMode := "false" ledblinkyEnabled := "false" ledblinkySystemName := "" ledblinkyFullPath := "" ledblinkyProfilePath := "D:\RocketLauncher\Profiles\LEDBlinky" ledblinkyRLProfile := "D:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher" winIPACFullPath := "" ultraMapEnabled := "false" ultraMapFullPath := "" emuIdleShutdown := "0" launchPasswordHash := "UpUpDownDownLeftRightLeftRight" cursorSize := "" hideCursor := "false" hideEmu := "false" hideFE := "false" suspendFE := "false" fadeIn := "false" fadeInDuration := "500" fadeInTransitionAnimation := "DefaultAnimateFadeIn" fadeInDelay := "0" fadeInExitDelay := "0" fadeOutExitDelay := "0" fadeOut := "false" fadeOutExtraScreen := "false" fadeOutDuration := "500" fadeOutTransitionAnimation := "DefaultAnimateFadeOut" fadeOutDelay := "0" fadeLyrInterpolation := "7" fadeMuteEmulator := "false" fadeUseBackgrounds := "false" fadeClickThrough := "false" fadeSounds := "false" fade7zProgressMode := "extraction" fadeWidthBaseRes := "1920" fadeHeightBaseRes := "1080" fadeLyr1Color := "FF000000" fadeLyr1AlignImage := "Stretch and Lose Aspect" fadeLyr2Pos := "Stretch and Lose Aspect" fadeLyr2X := "0" fadeLyr2Y := "0" fadeLyr2W := "" fadeLyr2H := "" fadeLyr2Adjust := "1" fadeLyr2PicPad := "0" fadeLyr2Prefix := "Extra Layer 1 - Console" fadeLyr3Pos := "Center" fadeLyr3X := "450" fadeLyr3Y := "450" fadeLyr3W := "" fadeLyr3H := "" fadeLyr3Adjust := "1" fadeLyr3PicPad := "0" fadeLyr3Speed := "750" fadeLyr3Animation := "DefaultFadeAnimation" fadeLyr37zAnimation := "DefaultFadeAnimation" fadeLyr3Type := "imageandbar" fadeLyr3ImgFollow7zProgress := "true" fadeLyr3Repeat := "1" fadeLyr3BackImageTransparency := "30" fadeLyr3StaticPos := "No Alignment" fadeLyr3StaticX := "0" fadeLyr3StaticY := "870|1575" fadeLyr3StaticW := "" fadeLyr3StaticH := "" fadeLyr3StaticAdjust := "1" fadeLyr3StaticPicPad := "0" fadeLyr3StaticPrefix := "Info Bar" fadeLyr4Adjust := "1" fadeLyr4X := "1792|952" fadeLyr4Y := "891|1596" fadeLyr4W := "128" fadeLyr4H := "" fadeLyr4Pos := "No Alignment" fadeLyr4FPS := "50" fadeLyr4PicPad := "0" fadeTranspGifColor := "FFFFFF" fadeBarWindow := "Image" fadeBarWindowX := "" fadeBarWindowY := "" fadeBarWindowW := "900" fadeBarWindowH := "180" fadeBarWindowR := "30" fadeBarWindowM := "30" fadeBarWindowHatchStyle := "8" fadeBar := "true" fadeProgressDuration := "0" fadeBarBack := "true" fadeBarBackColor := "FF555555" fadeBarH := "30" fadeBarR := "10" fadeBarColor := "DD00BFFF" fadeBarHatchStyle := "8" fadeBarPercentageText := "true" fadeBarInfoText := "true" fadeBarXOffset := "0" fadeBarYOffset := "150" fadeRomInfoDescription := "filtered text" fadeRomInfoSystemName := "image" fadeRomInfoYear := "text with label" fadeRomInfoDeveloper := "text with label" fadeRomInfoPublisher := "text with label" fadeRomInfoGenre := "text" fadeRomInfoRating := "image" fadeRomInfoOrder := "Description|SystemName|Year|Manufacturer|Genre|Rating" fadeRomInfoTextPlacement := "User Defined" fadeRomInfoTextMargin := "7" fadeRomInfoText1Options := "w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular" fadeRomInfoText2Options := "w400 x8 y15 cFF555555 r4 s60 Bold" fadeRomInfoText3Options := "w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular" fadeRomInfoText4Options := "w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular" fadeRomInfoText5Options := "cFF555555 r4 s42 Bold" fadeRomInfoText6Options := "h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular" fadeRomInfoText7Options := "h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular" fadeStats_Number_of_Times_Played := "text with label" fadeStats_Last_Time_Played := "text with label" fadeStats_Average_Time_Played := "text with label" fadeStats_Total_Time_Played := "text with label" fadeStats_System_Total_Played_Time := "text with label" fadeStats_Total_Global_Played_Time := "text with label" fadeStatsInfoOrder := "Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time" fadeStatsInfoTextPlacement := "topRight" fadeStatsInfoTextMargin := "7" fadeStatsInfoText1Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText2Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText3Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText4Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText5Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText6Options := "cFFB4B4B4 r4 s22 Bold" fadeText1X := "0" fadeText1Y := "0" fadeText1Options := "cFFB4B4B4 r4 s30 Right Bold" fadeText1 := "Loading Game" fadeText2X := "0" fadeText2Y := "0" fadeText2Options := "cFFB4B4B4 r4 s30 Right Bold" fadeText2 := "Extraction Complete, Ready" fadeText3 := "Loading Game" fadeText4 := "Loading Complete" fadeFont := "Comic Sans MS" fadeSystemAndRomLayersOnly := "false" fadeExtractionTime := "disabled" fadeExtractionTimeTextX := "0" fadeExtractionTimeTextY := "0" fadeExtractionTimeTextOptions := "cFF555555 r4 s20 Bold" fadeInterruptKey := "@" detectFadeErrorEnabled := "true" fadeImgPath := "D:\RocketLauncher\Media\Fade" RLDataPath := "D:\RocketLauncher\Data" RLMediaPath := "D:\RocketLauncher\Media" RLErrSoundPath := "D:\RocketLauncher\Media\Sounds\Error" modulesPath := "D:\RocketLauncher\Modules" moduleFullName := "D:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk" moduleName := "PCLauncher" modulePath := "D:\RocketLauncher\Modules\PCLauncher" moduleExtension := "ahk" moduleExtensionsPath := "D:\RocketLauncher\Module Extensions" libPath := "D:\RocketLauncher\Lib" sevenZEnabled := "true" sevenZPath := "D:\RocketLauncher\Module Extensions\7z.exe" sevenZDllPath := "D:\RocketLauncher\Module Extensions\7z.dll" sevenZExtractPath := "C:\Temp" sevenZExtractPathOrig := "" sevenZAttachSystemName := "false" sevenZDelTemp := "true" sevenZFormats := ".zip|.rar|.7z|.lzh|.gzip|.tar" sevenZFormatsNoP := "zip|rar|7z|lzh|gzip|tar" sevenZFormatsRegEx := "\.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar" sevenZGamesToKeep := "" sevenZDeletePerSystem := "false" 7zExtractPath := "C:\Temp" mgEnabled := "false" mgKey := "~NumpadSub" mgBackgroundColor := "FF000000" mgSidePadding := "0.2" mgWidthBaseRes := "1920" mgHeightBaseRes := "1080" mgYOffset := "500|800" mgFont := "Arial" mgText1Options := "x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic" mgText1Text := "Please select a game" mgText2Options := "w96p cFFFFFFFF r4 s50 Center BoldItalic" mgText2Offset := "100" mgUseSound := "true" mgSoundfreq := "300" mgExitEffect := "none" mgSelectedEffect := "rotate" mgUseGameArt := "false" mgCandidate := "" mgValidTypes := "\(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side" mgOnLaunch := "false" pauseEnabled := "false" pauseKey := "~NumpadAdd" pauseBackToMenuBarKey := "X" pauseZoomInKey := "C" pauseZoomOutKey := "V" pauseScreenshotKey := "~PrintScreen" pauseHiToTextPath := "D:\RocketLauncher\Module Extensions\HiToText.exe" pauseSaveStateKeyCodes := "" pauseLoadStateKeyCodes := "" keyboardEncoder := "" keyboardEncoderEnabled := "false" keymapperEnabled := "false" keymapperAHKMethod := "Internal" keymapper := "" xpadderFullPath := "D:\Arcade\Tools\Xpadder\Xbox 360 Game Controller Player 1.xpaddercontroller" joyToKeyFullPath := "D:\RocketLauncher\Profiles\JoyToKey\JoyToKey_en\JoyToKey.exe" profilePath := "D:\RocketLauncher\Profiles" keymapperProfilePath := "D:\RocketLauncher\Profiles\" keymapperFrontEndProfileName := "RocketLauncherUI" keymapperFrontEndProfile := "joytokey" keymapperRocketLauncherProfileEnabled := "true" joyIDsEnabled := "false" joyIDsPreferredControllersGlobal := "Controller (XBOX 360 For Windows)" joyIDsPreferredControllersSystem := "use_global" joyIDsPreferredControllersOnExit := "Controller (XBOX 360 For Windows)" CustomJoyNamesEnabled := "false" CustomJoyNames := "" rotateMethod := "false" FEProfile := "D:\RocketLauncher\Profiles\\RocketLauncherUI" defaultProfile := "D:\RocketLauncher\Profiles\\_Default" systemProfile := "D:\RocketLauncher\Profiles\\Taito Type X" xPadderSystemProfile := "D:\RocketLauncher\Profiles\\Taito Type X\_Default" emuProfile := "D:\RocketLauncher\Profiles\\Taito Type X\PCLauncher" romProfile := "D:\RocketLauncher\Profiles\\Taito Type X\Battle Fantasia" RocketLauncherProfile := "D:\RocketLauncher\Profiles\\RocketLauncher" blankProfile := "D:\RocketLauncher\Profiles\\blank" ahkFEProfile := "D:\RocketLauncher\Profiles\AHK\RocketLauncherUI" ahkDefaultProfile := "D:\RocketLauncher\Profiles\AHK\_Default" ahkSystemProfile := "D:\RocketLauncher\Profiles\AHK\Taito Type X" ahkEmuProfile := "D:\RocketLauncher\Profiles\AHK\Taito Type X\PCLauncher" ahkRomProfile := "D:\RocketLauncher\Profiles\AHK\Taito Type X\Battle Fantasia" ahkRocketLauncherProfile := "D:\RocketLauncher\Profiles\AHK\RocketLauncher" bezelEnabled := "false" bezelICEnabled := "false" shaderName := "false" shaderColor := "" shaderTransparency := "" statisticsEnabled := "true" pressDuration := "-1" emuVolume := "1" dxwndIni := "D:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini" dxwndFullPath := "D:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe" qResFullPath := "D:\RocketLauncher\Module Extensions\QRes.exe" mon1O := "" pacDrivedllFile := "D:\RocketLauncher\Module Extensions\PacDrive32.dll" userFadeAnimIniFile := "D:\RocketLauncher\Lib\User Fade Animations.ini" testFile := "" testDuration := "" initialErrorMode := "0" 10:05:57:297 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 10:05:57:297 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 10:05:57:297 | RL | DEBUG | +0 | BuildScript - Module starts on line: 2 10:05:57:298 | RL | INFO | +0 | BuildScript - Validating module 10:05:57:300 | RL | INFO | +0 | BuildScript - Validation complete 10:05:57:300 | RL | INFO | +0 | BuildScript - Module: MEmu := "PCLauncher" MEmuV := "N/A" MURL := ["http://www.rlauncher.com/wiki/index.php?title=PCLauncher"] MAuthor := ["djvj"] MVersion := "2.2.7" MCRC := "5814E2E" iCRC := "28F444EF" MID := "635243126483565041" MSystem := ["American Laser Games","Arcade PC","Doujin Soft","Examu eX-BOARD","Fan Remakes","Games for Windows","Konami e-Amusement","Konami Bemani","Microsoft Windows","PCLauncher","PC Games","Singstar","Steam","Steam Big Picture","Taito Type X","Taito Type X2","Touhou","Touhou Project","Ultrastar","Ultrastar Deluxe","Windows Games"] ;---------------------------------------------------------------------------- ; Notes: ; Use the examples in the ini, in your Modules\PCLauncher\ folder, to add more applications. ; PCLauncher supports per-System inis. Copy your PCLauncher ini in the same folder and rename it to match the System's Name. Use this if you have games with the same name across multiple systems. ; Read the tooltips for each module setting in RocketLauncherUI for the definitions of each key and help using them. ; For information on how to use this module and what all the settings do, please see http://www.rlauncher.com/wiki/index.php?title=PCLauncher ;---------------------------------------------------------------------------- StartModule() moduleIni.CheckFile("Could not find """ . moduleIni.FileFullPath . """`n`nRocketLauncherUI will create this file when you configure your first game to be used with the " . MEmu . " module.") Application := moduleIni.Read(dbName, "Application",,,1) AppWaitExe := moduleIni.Read(dbName, "AppWaitExe",,,1) DiscImage := moduleIni.Read(dbName, "DiscImage",,,1) DXWndGame := moduleIni.Read(dbName, "DXWndGame",,,1) DXWndMaximizeWindow := moduleIni.Read(dbName, "DXWndMaximizeWindow",,,1) ExitMethod := moduleIni.Read(dbName, "ExitMethod",,,1) FadeTitle := moduleIni.Read(dbName, "FadeTitle",,,1) FadeTitleWaitTillActive := moduleIni.Read(dbName, "FadeTitleWaitTillActive","true",,1) FadeTitleTimeout := moduleIni.Read(dbName, "FadeTitleTimeout",,,1) FadeInExitSleep := moduleIni.Read(dbName, "FadeInExitSleep",,,1) HideConsole := moduleIni.Read(dbName, "HideConsole",,,1) OriginGame := moduleIni.Read(dbName, "OriginGame",,,1) Parameters := moduleIni.Read(dbName, "Parameters",,,1) PostLaunch := moduleIni.Read(dbName, "PostLaunch",,,1) PostLaunchParameters := moduleIni.Read(dbName, "PostLaunchParameters",,,1) PostLaunchSleep := moduleIni.Read(dbName, "PostLaunchSleep",,,1) PostExit := moduleIni.Read(dbName, "PostExit",,,1) PostExitParameters := moduleIni.Read(dbName, "PostExitParameters",,,1) PostExitSleep := moduleIni.Read(dbName, "PostExitSleep",,,1) PreLaunch := moduleIni.Read(dbName, "PreLaunch",,,1) PreLaunchParameters := moduleIni.Read(dbName, "PreLaunchParameters",,,1) PreLaunchMode := moduleIni.Read(dbName, "PreLaunchMode",,,1) PreLaunchSleep := moduleIni.Read(dbName, "PreLaunchSleep",,,1) SteamID := moduleIni.Read(dbName, "SteamID",,,1) WorkingFolder := moduleIni.Read(dbName, "WorkingFolder",,,1) bezelTopOffset := moduleIni.Read(dbName, "BezelTopOffset","0",,1) bezelBottomOffset := moduleIni.Read(dbName, "BezelBottomOffset","0",,1) bezelLeftOffset := moduleIni.Read(dbName, "BezelLeftOffset","0",,1) bezelRightOffset := moduleIni.Read(dbName, "BezelRightOffset","0",,1) BezelFixedResMode := moduleIni.Read(dbName, "BezelFixedResMode","false",,1) HideWindowTitleBar := moduleIni.Read(dbName, "HideWindowTitleBar","true",,1) HideWindowBorder := moduleIni.Read(dbName, "HideWindowBorder","true",,1) HideWindowMenuBar := moduleIni.Read(dbName, "HideWindowMenuBar","true",,1) HideDecoratorsAfterMove := moduleIni.Read(dbName, "HideDecoratorsAfterWindowMove","false",,1) HideWindowBorderFirst := moduleIni.Read(dbName, "HideWindowBorderFirst","false",,1) Fullscreen := moduleIni.Read(dbName, "Fullscreen",,,1) If (!Application && !SteamID) { ; This app cannot be launched if no info exists already in the ini and this is not a steam game ScriptError("You have not set up " . dbName . " in RocketLauncherUI yet, so PCLauncher does not know what exe, FadeTitle, and/or SteamID to watch for.") } ; Configuring bezel settings that would normally be set in BezelLabel If (HideWindowTitleBar = "false") disableHideTitleBar := true If (HideWindowBorder = "false") disableHideBorder := true If (HideWindowMenuBar = "false") disableHideToggleMenu := true If (HideDecoratorsAfterMove = "true") hideDecoratorsAfterWindowMove := true If (HideWindowBorderFirst = "true") hideBorderFirst := true If Fullscreen { ;Warn user if fullscreen is set, but no custom game user function file exists for this game gameUserFunc := new File(libPath . "\Lib\User Functions\" . systemName . "\" . dbName . ".ahk") If (!gameUserFunc.Exist()) { RLLog.Warning("PCLauncher - You have configured a fullscreen setting for this game, but no GameUserFunction file exists at '" . gameUserFunc.FileFullPath . "' therefore the fullscreen setting won't have any effect until you create such file and implement the proper SetFullscreen function") } } BezelGUI() FadeInStart() If (BezelFixedResMode = "true") BezelStart("fixResMode") Else BezelStart() If Application { primaryExe := new Emulator(Application) ; instantiate primary application executable object } If (AppWaitExe != "") { AppWaitExe := new Process(AppWaitExe) } If FadeTitle { FadeTitleObj := StringUtils.ParsePCTitle(FadeTitle) appPrimaryWindow := new Window(new WindowTitle(FadeTitleObj.Title,FadeTitleObj.Class)) ; instantiate primary application window object } ; If Application needs a cd/dvd image in the drive, mount it in DT first If DiscImage { RLLog.Info("PCLauncher - Application is a Disc Image, mounting it in DT") appIsImage := 1 DiscImage := new File(GetFullName(DiscImage)) ; convert a relative path defined in the PCLauncher ini to absolute DiscImage.CheckFile("Cannot find this DiscImage for " . dbName . ":`n" . DiscImage.FileFullPath) ; StringUtils.SplitPath(DiscImage,"",ImagePath,ImageExt,ImageName) If StringUtils.Contains(DiscImage.FileExt,"mds|mdx|b5t|b6t|bwt|ccd|cue|isz|nrg|cdi|iso|ape|flac") { VirtualDrive("get") ; get the vdDriveLetter ; VirtualDrive("mount",ImagePath . "\" . ImageName . "." . ImageExt) VirtualDrive("mount",DiscImage.FileFullPath) } Else ScriptError("You defined a DiscImage, but it is not a supported format for this module and/or DT:`nccd,cdi,cue,iso,isz,nrg") } ; Verify module's settings are set CheckSettings() If PreLaunch { RLLog.Info("PCLauncher - PreLaunch set by user, running: " . PreLaunch) PreLaunchParameters := If (!PreLaunchParameters or PreLaunchParameters="ERROR") ? "" : PreLaunchParameters If (preLaunchMode = "run") { errLevel := PreLaunchExe.Run(If PreLaunchIsURL ? "" : PreLaunchParameters,,,,,(If PreLaunchIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PreLaunch application. Please check it is a valid executable.") TimerUtils.Sleep(PreLaunchSleep) } Else { errLevel := PreLaunchExe.RunWait(If PreLaunchIsURL ? "" : PreLaunchParameters,,(If PreLaunchIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PreLaunch application. Please check it is a valid executable.") } } If (DXWndGame = "true") ; start dxwnd if needed DxwndRun() Fullscreen := If BezelEnabled() ? "false" : Fullscreen FullscreenParams := CustomFunction.SetFullscreenPreLaunch(Fullscreen) If (FullscreenParams) { RLLog.Debug("PCLauncher - Setting fullscreen parameters to : " . FullscreenParams) Parameters .= " " . FullscreenParams } If StringUtils.Contains(mode,"steam|steambp") ; steam launch Steam(SteamID, primaryExe.FileFullPath, Parameters) Else If (mode = "origin") ; origin launch Origin(primaryExe.FileName, primaryExe.FilePath, Parameters) Else { If (mode = "url") { RLLog.Info("PCLauncher - Launching URL.") errLevel := primaryExe.Run() } Else { ; standard launch RLLog.Info("PCLauncher - Launching a standard application.") If (HideConsole = "true" and primaryExe.FileExt = "bat") { RLLog.Info("PCLauncher - Hiding DOS console for bat file.") objShell := ComObjCreate("WScript.Shell") objShell.CurrentDirectory := If WorkingFolder ? WorkingFolder : primaryExe.FilePath errLevel := objShell.Run("""" . primaryExe.FileName . """ " . Parameters, 0, false) } Else errLevel := primaryExe.Run(Parameters,,,,,1,If WorkingFolder ? WorkingFolder : "") } If errLevel ScriptError("There was a problem launching your " . (If appIsImage ? "ImageExe" : "Application") . ". Please check it is a valid executable.") } If PostLaunch { RLLog.Info("PCLauncher - PostLaunch set by user, running: " . PostLaunch) PostLaunchExe := new Process(PostLaunch) PostLaunchParameters := If (!PostLaunchParameters or PostLaunchParameters="ERROR") ? "" : PostLaunchParameters errLevel := PostLaunchExe.Run(If PostLaunchIsURL ? "" : PostLaunchParameters,,,,,(If PostLaunchIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PostLaunch application. Please check it is a valid executable.") TimerUtils.Sleep(PostLaunchSleep) } If FadeTitle { RLLog.Info("PCLauncher - FadeTitle set by user, waiting for """ . appPrimaryWindow.WinTitle.GetWindowTitle() . """") If (FadeTitleTimeout) appPrimaryWindow.Wait(FadeTitleTimeout) Else appPrimaryWindow.Wait() If (FadeTitleWaitTillActive = "true") appPrimaryWindow.WaitActive() } Else If AppWaitExe { RLLog.Info("PCLauncher - FadeTitle not set by user, but AppWaitExe is. Waiting for AppWaitExe: " . AppWaitExe.FileName) AppWaitExe.Process("Wait",15) If (AppWaitExe.PID = 0) ScriptError("PCLauncher - There was an error getting the Process ID of your AppWaitExe """ . AppWaitExe.FileName . """. Please try setting a FadeTitle instead.") } Else If SteamIDExe { RLLog.Info("PCLauncher - FadeTitle and AppWaitExe not set by user, but SteamIDExe was found. Waiting for SteamIDExe: " . SteamIDExe.FileFullPath) SteamIDExe.Process("Wait",15) ; wait 15 seconds for this process to launch If (SteamIDExe.PID = 0) ScriptError("PCLauncher - There was an error getting the Process ID from your SteamIDExe for """ . dbName . """. Please try setting a FadeTitle instead.") } Else If primaryExe.PID { RLLog.Info("PCLauncher - FadeTitle and AppWaitExe not set by user, but a PID for the primary application was found. Waiting for PID: " . primaryExe.PID) appPrimaryWindow.PID := primaryExe.PID ; store the PID of the primary exe into the window object appPrimaryWindow.Wait(,primaryExe.PID) ; only wait for the pid, not any other window element appPrimaryWindow.WaitActive(,primaryExe.PID) } Else RLLog.Error("PCLauncher - FadeTitle and AppWaitExe not set by user and no AppPID found from an Application, PCLauncher has nothing to wait for") If (DXWndGame = "true" and (DXWndMaximizeWindow = "aspect" or DXWndMaximizeWindow = "stretch")) appPrimaryWindow.Maximize(If (DXWndMaximizeWindow="aspect") ? "true" : "false") BezelDraw() TimerUtils.Sleep(FadeInExitSleep) ; PCLauncher setting for some stubborn games that keeps the fadeIn screen up a little longer FadeInExit() If AppWaitExe { If !FadeTitle { RLLog.Info("PCLauncher - Creating a window based on the AppWaitExe because FadeTitle was not set") appPrimaryWindow := new Window(new WindowTitle(,,,,AppWaitExe.PID)) ; instantiate AppWaitExe window object appPrimaryWindow.Wait() appPrimaryWindow.Get("ID") appPrimaryWindow.WinTitle.PID := "" ; remove PID from future window matches appPrimaryWindow.WinTitle.ID := appPrimaryWindow.ID ; inject hwnd ID so future matches use it instead } RLLog.Info("PCLauncher - Waiting for AppWaitExe """ . AppWaitExe.FileName . """ to close.") AppWaitExe.Process("WaitClose") } Else If FadeTitle { ; If fadeTitle is set and no appPID was created. RLLog.Info("PCLauncher - Waiting for FadeTitle """ . appPrimaryWindow.WinTitle.GetWindowTitle() . """ to close.") appPrimaryWindow.WaitClose() } Else If SteamIDExe { RLLog.Info("PCLauncher - Waiting for SteamIDExe """ . SteamIDExe.FileName . """ to close.") SteamIDExe.Process("WaitClose") } Else If primaryExe.PID { If !FadeTitle { RLLog.Info("PCLauncher - Creating a window based on the Primary Application """ . primaryExe.FileName . """ because FadeTitle nor AppWaitExe were set") appPrimaryWindow := new Window(new WindowTitle(,,,,primaryExe.PID)) ; instantiate primary application window object appPrimaryWindow.Wait() appPrimaryWindow.Get("ID") appPrimaryWindow.WinTitle.PID := "" ; remove PID from future window matches appPrimaryWindow.WinTitle.ID := appPrimaryWindow.ID ; inject hwnd ID so future matches use it instead } RLLog.Info("PCLauncher - Waiting for the Primary Application PID """ . primaryExe.PID . """ to close.") primaryExe.Process("WaitClose") } Else ScriptError("Could not find a proper AppWaitExe`, FadeTitle`, or AppPID (from the launched Application). Try setting either an AppWaitExe or FadeTitle so the module has something to look for.") If PostExit { RLLog.Info("PCLauncher - PostExit set by user, running: " . PostExit) PostExitExe := new Process(PostExit) PostExitParameters := If (!PostExitParameters or PostExitParameters="ERROR") ? "" : PostExitParameters errLevel := PostExitExe.Run(If PostExitIsURL ? "" : PostExitParameters,,,,,(If PostExitIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PostExit application. Please check it is a valid executable.") TimerUtils.Sleep(PostExitSleep) } ; If Application is a cd/dvd image, unmount it in DT If appIsImage VirtualDrive("unmount") ; Close steam if it was not open prior to launch, not really needed anymore because module knows how to launch if steam already running now ; If (primaryExe.PID = 0) ; Run, Steam.exe -shutdown, %SteamPath% ; close steam If (DXWndGame = "true") DxwndClose() BezelExit() FadeOutExit() ExitModule() CheckSettings() { Global Application,primaryExe Global PreLaunch,PreLaunchExe,PreLaunchIsURL Global PostLaunch,PostLaunchExe,PostLaunchIsURL Global PostExit,PostExitExe,PostExitIsURL Global moduleName,appIsImage,vdDriveLetter,SteamID,OriginGame,DXWndGame,mode,AppWaitExe,SteamIDExe,FadeTitle Global modulePath,fadeIn RLLog.Info("CheckSettings - Started") ; These checks allow you to run URL and Steam browser protocol commands. Without them ahk would error out that it can't find the file. This is different than setting a SteamID but either work If (SteamID) { mode := "steam" ; setting module to use steam mode RLLog.Info("PCLauncher - SteamID is set, setting mode to: """ . mode . """") } Else If (StringUtils.SubStr(Application,1,3) = "ste") { mode := "steambp" ; setting module to use Steam Browser Protocol mode RLLog.Info("PCLauncher - Application is a Steam Browser Protocol, setting mode to: """ . mode . """") } Else If (StringUtils.SubStr(Application,1,4) = "http") { mode := "url" ; setting module to use url mode RLLog.Info("PCLauncher - Application is a URL, setting mode to: """ . mode . """") } Else If OriginGame { mode := "origin" ; setting module to use Origin mode StringUtils.BackslashCheck(primaryExe.FileFullPath,"Application") RLLog.Info("PCLauncher - Origin mode enabled. Will log in to Origin if required.") } Else If Application { mode := "standard" ; for standard launching StringUtils.BackslashCheck(primaryExe.FileFullPath,"Application") RLLog.Info("PCLauncher - Setting mode to: """ . mode . """") } Else ; error if no modes are used ScriptError("Please set an Application, SteamID, Steam Browser Protocol, or URL in " moduleName . ".ini for """ . dbName . """") If (SteamID && Application) ; do not allow 2 launching methods as module cannot know which should be used ScriptError("You are trying to use Steam and an Application, you must choose one or the other.") If ((mode = "steam" || mode = "steambp") && !AppWaitExe && !FadeTitle) { ; && fadeIn = "true") { ; If AppWaitExe or FadeTitle are defined, that will take precedence over the automatic method using the SteamIDs.ini SteamIDFile := new IniFile(modulePath . "\SteamIDs.ini") SteamIDFile.CheckFile() If !SteamID ; if this game does not have a SteamID defined StringUtils.SplitPath(Application,SteamID) ; try to grab the ID from the Application name SteamIDExe := SteamIDFile.ReadCheck(SteamID, "exe",,,1) If !SteamIDExe ; if it was still not found, error out ScriptError("You are using launching a Steam game but no way for the module to know what window to wait for after launching. Please set a AppWaitExe, FadeTitle, or make sure your SteamID and the correct exe is defined in the SteamIDs.ini",10) Else { RLLog.Info("PCLauncher - Found an exe in the SteamIDs.ini for this game: """ . SteamIDExe . """") SteamIDExe := new Process(SteamIDExe) } } Else If (mode = "url" && !AppWaitExe && !FadeTitle) ScriptError("You are using launching a URL but no way for the module to know what to window to wait for after launching. Please set a AppWaitExe or FadeTitle to your default application that gets launched when opening URLs.",10) If (appIsImage && !primaryExe.FilePath) ; if user only defined an exe for Application with no path, assume it will be found on the root dir of the image when mounted primaryExe.FilePath := vdDriveLetter . ":\" If (!primaryExe.FileName && mode = "standard" && (mode != "steam" || mode != "steambp")) ScriptError("Missing filename on the end of your Application in " . moduleName . ".ini:`n" . primaryExe.FileFullPath) If (!primaryExe.FileExt && mode = "standard" && (mode != "steam" || mode != "steambp")) ScriptError("Missing extension on your Application in " . moduleName . ".ini:`n" . primaryExe.FileFullPath) PreLaunchExe := AltAppCheck(PreLaunch,"PreLaunch",PreLaunchIsURL) PostLaunchExe := AltAppCheck(PostLaunch,"PostLaunch",PostLaunchIsURL) PostExitExe := AltAppCheck(PostExit,"PostExit",PostExitIsURL) If (mode = "standard") primaryExe.CheckFile("Cannot find this Application:`n" . primaryExe.FileFullPath) ; keeping this last so more descriptive errors will trigger first RLLog.Info("CheckSettings - Ended") } AltAppCheck(file,id,ByRef urlID) { If file { obj := new Process(file) urlID := If (StringUtils.SubStr(file,1,4)="http" || StringUtils.SubStr(file,1,3)="ste") ? 1:"" If urlID RLLog.Info("PCLauncher - " . id . " is a URL or Steam Browser Protocol: " . file) Else { StringUtils.BackslashCheck(obj.FileFullPath,id) obj.CheckFile("Cannot find this " . id . " application:`n" . obj.FileFullPath) } Return obj } } HaltEmu: CustomFunction.HaltGame() Return RestoreEmu: CustomFunction.RestoreGame() Return CloseProcess: If (ExitMethod != "InGame") { FadeOutStart() If (ExitMethod = "Process Close AppWaitExe" && AppWaitExe) { RLLog.Info("CloseProcess - ExitMethod is ""Process Close AppWaitExe""") AppWaitExe.Process("Close") } Else If (ExitMethod = "WinClose AppWaitExe" && AppWaitExe) { RLLog.Info("CloseProcess - ExitMethod is ""WinClose AppWaitExe""") AppWaitExe.Process("Exist") AppWaitWindow := new Window(new WindowTitle(,,,,AppWaitExe.PID)) AppWaitWindow.Close() } Else If (ExitMethod = "Process Close Application") { RLLog.Info("CloseProcess - ExitMethod is ""Process Close Application""") primaryExe.Process("Close") } Else If (ExitMethod = "WinClose Application" && FadeTitle) { RLLog.Info("CloseProcess - ExitMethod is ""WinClose Close Application""") appPrimaryWindow.Close() } Else If (ExitMethod = "Send Alt+F4") { RLLog.Info("CloseProcess - ExitMethod is ""Send Alt+F4""") KeyUtils.Send("!{F4}") } Else { RLLog.Info("CloseProcess - Default ExitMethod`, using ""WinClose""") appPrimaryWindow.Close() } } Return 10:05:57:300 | RL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 10:05:57:301 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 10:05:57:301 | RL | WARNING | +0 | BuildScript - "D:\RocketLauncher\Lib\User Functions\Global.ahk" not found 10:05:57:302 | RL | WARNING | +0 | BuildScript - "D:\RocketLauncher\Lib\User Functions\Taito Type X.ahk" not found 10:05:57:302 | RL | WARNING | +0 | BuildScript - "D:\RocketLauncher\Lib\User Functions\Emulators\PCLauncher.ahk" not found 10:05:57:302 | RL | WARNING | +0 | BuildScript - "D:\RocketLauncher\Lib\User Functions\Taito Type X\Emulators\PCLauncher.ahk" not found 10:05:57:302 | RL | WARNING | +0 | BuildScript - "D:\RocketLauncher\Lib\User Functions\Taito Type X\Battle Fantasia.ahk" not found 10:05:57:302 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 10:05:57:303 | RL | INFO | +0 | Main - Module is built 10:05:57:303 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\AutoHotkey.dll exists 10:05:57:305 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.13.00 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2003-2013 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.13.00 File Size: 802304 bytes Created: 1/17/2016 - 4:20:35 PM Modified: 11/27/2016 - 3:25:50 PM 10:05:57:305 | RL | INFO | +0 | Main - Loading Internal AHK Keymapping 10:05:57:306 | RL | INFO | +0 | GetAHKProfile - Started 10:05:57:306 | RL | DEBUG | +0 | GetAHKProfile - Searching for: D:\RocketLauncher\Profiles\AHK\Taito Type X\Battle Fantasia.ahk 10:05:57:306 | RL | DEBUG | +0 | GetAHKProfile - Searching for: D:\RocketLauncher\Profiles\AHK\Taito Type X\PCLauncher.ahk 10:05:57:306 | RL | DEBUG | +0 | GetAHKProfile - Searching for: D:\RocketLauncher\Profiles\AHK\Taito Type X.ahk 10:05:57:307 | RL | DEBUG | +0 | GetAHKProfile - Searching for: D:\RocketLauncher\Profiles\AHK\_Default.ahk 10:05:57:307 | RL | WARNING | +0 | GetAHKProfile - Keymapper support is enabled for AHK, but could not find a Battle Fantasia, PCLauncher, Taito Type X, or a default profile in 10:05:57:307 | RL | INFO | +0 | GetAHKProfile - Ended 10:05:57:307 | RL | INFO | +0 | Main - Attaching AHK remaps to module using: 10:05:57:308 | RL | INFO | +0 | Main - Finished building Internal AHK remaps 10:05:57:308 | RL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 10:05:57:308 | RL | INFO | +0 | Main - Running module 10:05:57:429 | MD | INFO | +N/A | Module initialized 10:05:57:430 | MD | DEBUG | +0 | XHotkeyTableCreation - Started 10:05:57:430 | MD | DEBUG | +0 | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups 10:05:57:430 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 1 check 10:05:57:430 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 2 check 10:05:57:430 | MD | DEBUG | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 10:05:57:430 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 10:05:57:432 | MD | TRACE | +0 | CustomFunction.Init - Starting 10:05:57:432 | MD | TRACE | +0 | CustomFunction.Init - Ending 10:05:57:432 | MD | INFO | +0 | StartModule - Started 10:05:57:432 | MD | INFO | +0 | StartModule - MEmu: PCLauncher MEmuV: N/A MURL: MAuthor: MVersion: 2.2.7 MCRC: 5814E2E iCRC: 28F444EF MID: MSystem: 10:05:57:432 | MD | WARNING | +0 | StartModule - You have an unsupported System Name for this module: "Taito Type X". Only the following System Names are suppported: "" 10:05:57:433 | MD | INFO | +0 | PluginInit - Started 10:05:57:433 | MD | DEBUG | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Publisher|Year|Genre|Rating 10:05:57:434 | MD | INFO | +0 | CheckFile - Checking if D:\Arcade\Databases\Taito Type X\Taito Type X.xml exists 10:05:57:434 | MD | DEBUG | +0 | CheckFile - Attributes: File Size: 6671 bytes Created: 12/27/2015 - 3:48:45 PM Modified: 11/29/2016 - 8:15:23 PM 10:05:57:434 | MD | DEBUG | +0 | BuildDatabaseTable - Searching for a "Game Name" in the database 10:05:57:457 | MD | DEBUG | +31 | BuildDatabaseTable - Found "Game Name" in the database! 10:05:57:457 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Name 10:05:57:457 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Name" with a value: "Battle Fantasia" 10:05:57:457 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Cloneof 10:05:57:458 | MD | DEBUG | +0 | BuildDatabaseTable - Could not find: Cloneof 10:05:57:458 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Publisher 10:05:57:458 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Publisher" with a value: "Arc System Works" 10:05:57:458 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Year 10:05:57:458 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Year" with a value: "2007" 10:05:57:458 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Genre 10:05:57:459 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Genre" with a value: "Fighter" 10:05:57:459 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Rating 10:05:57:459 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Rating" with a value: "AAMA - Yellow (Animated Violence Mild)" 10:05:57:459 | MD | TRACE | +0 | PluginInit - GameInfo: GameInfo Label: Genre | GameInfo Value: Fighter GameInfo Label: Name | GameInfo Value: Battle Fantasia GameInfo Label: Publisher | GameInfo Value: Arc System Works GameInfo Label: Rating | GameInfo Value: AAMA - Yellow (Animated Violence Mild) GameInfo Label: Year | GameInfo Value: 2007 10:05:57:459 | MD | DEBUG | +0 | BuildDatabaseTable - Ended 10:05:57:460 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 10:05:57:460 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Game Logo: D:\Arcade\Media\Taito Type X\Images\Wheel\Battle Fantasia.png 10:05:57:460 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a System Logo: D:\Arcade\Media\Main Menu\Images\Wheel\Taito Type X.png 10:05:57:461 | MD | DEBUG | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Logo | Asset Path1: D:\Arcade\Media\Taito Type X\Images\Wheel\Battle Fantasia.png | Asset Extension1: png | Asset Type1: game Asset Label: System Logo | Asset Path1: D:\Arcade\Media\Main Menu\Images\Wheel\Taito Type X.png | Asset Extension1: png | Asset Type1: system 10:05:57:461 | MD | INFO | +0 | BuildAssetsTable - Ended 10:05:57:461 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 10:05:57:461 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Artwork1: D:\Arcade\Media\Taito Type X\Images\Artwork1\Battle Fantasia.png 10:05:57:461 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Box Art: D:\Arcade\Media\Taito Type X\Images\Artwork2\Battle Fantasia.png 10:05:57:462 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Cartridge: D:\Arcade\Media\Taito Type X\Images\Artwork3\Battle Fantasia.png 10:05:57:462 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Flyers: D:\Arcade\Media\Taito Type X\Images\Artwork4\Battle Fantasia.png 10:05:57:462 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Letters: D:\Arcade\Media\Taito Type X\Images\Letters 10:05:57:496 | MD | DEBUG | +31 | BuildAssetsTable - Searching for a Other: D:\Arcade\Media\Taito Type X\Images\Other 10:05:57:519 | MD | DEBUG | +31 | BuildAssetsTable - Media assets found: Asset Label: Letters | Asset Path1: D:\Arcade\Media\Taito Type X\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system Asset Label: Letters | Asset Path2: D:\Arcade\Media\Taito Type X\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system Asset Label: Letters | Asset Path3: D:\Arcade\Media\Taito Type X\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system Asset Label: Letters | Asset Path4: D:\Arcade\Media\Taito Type X\Images\Letters\0.png | Asset Extension4: png | Asset Type4: system Asset Label: Letters | Asset Path5: D:\Arcade\Media\Taito Type X\Images\Letters\1.png | Asset Extension5: png | Asset Type5: system Asset Label: Letters | Asset Path6: D:\Arcade\Media\Taito Type X\Images\Letters\2.png | Asset Extension6: png | Asset Type6: system Asset Label: Letters | Asset Path7: D:\Arcade\Media\Taito Type X\Images\Letters\3.png | Asset Extension7: png | Asset Type7: system Asset Label: Letters | Asset Path8: D:\Arcade\Media\Taito Type X\Images\Letters\4.png | Asset Extension8: png | Asset Type8: system Asset Label: Letters | Asset Path9: D:\Arcade\Media\Taito Type X\Images\Letters\5.png | Asset Extension9: png | Asset Type9: system Asset Label: Letters | Asset Path10: D:\Arcade\Media\Taito Type X\Images\Letters\6.png | Asset Extension10: png | Asset Type10: system Asset Label: Letters | Asset Path11: D:\Arcade\Media\Taito Type X\Images\Letters\7.png | Asset Extension11: png | Asset Type11: system Asset Label: Letters | Asset Path12: D:\Arcade\Media\Taito Type X\Images\Letters\8.png | Asset Extension12: png | Asset Type12: system Asset Label: Letters | Asset Path13: D:\Arcade\Media\Taito Type X\Images\Letters\9.png | Asset Extension13: png | Asset Type13: system Asset Label: Letters | Asset Path14: D:\Arcade\Media\Taito Type X\Images\Letters\a.png | Asset Extension14: png | Asset Type14: system Asset Label: Letters | Asset Path15: D:\Arcade\Media\Taito Type X\Images\Letters\b.png | Asset Extension15: png | Asset Type15: system Asset Label: Letters | Asset Path16: D:\Arcade\Media\Taito Type X\Images\Letters\c.png | Asset Extension16: png | Asset Type16: system Asset Label: Letters | Asset Path17: D:\Arcade\Media\Taito Type X\Images\Letters\d.png | Asset Extension17: png | Asset Type17: system Asset Label: Letters | Asset Path18: D:\Arcade\Media\Taito Type X\Images\Letters\e.png | Asset Extension18: png | Asset Type18: system Asset Label: Letters | Asset Path19: D:\Arcade\Media\Taito Type X\Images\Letters\f.png | Asset Extension19: png | Asset Type19: system Asset Label: Letters | Asset Path20: D:\Arcade\Media\Taito Type X\Images\Letters\g.png | Asset Extension20: png | Asset Type20: system Asset Label: Letters | Asset Path21: D:\Arcade\Media\Taito Type X\Images\Letters\h.png | Asset Extension21: png | Asset Type21: system Asset Label: Letters | Asset Path22: D:\Arcade\Media\Taito Type X\Images\Letters\i.png | Asset Extension22: png | Asset Type22: system Asset Label: Letters | Asset Path23: D:\Arcade\Media\Taito Type X\Images\Letters\j.png | Asset Extension23: png | Asset Type23: system Asset Label: Letters | Asset Path24: D:\Arcade\Media\Taito Type X\Images\Letters\k.png | Asset Extension24: png | Asset Type24: system Asset Label: Letters | Asset Path25: D:\Arcade\Media\Taito Type X\Images\Letters\l.png | Asset Extension25: png | Asset Type25: system Asset Label: Letters | Asset Path26: D:\Arcade\Media\Taito Type X\Images\Letters\m.png | Asset Extension26: png | Asset Type26: system Asset Label: Letters | Asset Path27: D:\Arcade\Media\Taito Type X\Images\Letters\n.png | Asset Extension27: png | Asset Type27: system Asset Label: Letters | Asset Path28: D:\Arcade\Media\Taito Type X\Images\Letters\o.png | Asset Extension28: png | Asset Type28: system Asset Label: Letters | Asset Path29: D:\Arcade\Media\Taito Type X\Images\Letters\p.png | Asset Extension29: png | Asset Type29: system Asset Label: Letters | Asset Path30: D:\Arcade\Media\Taito Type X\Images\Letters\q.png | Asset Extension30: png | Asset Type30: system Asset Label: Letters | Asset Path31: D:\Arcade\Media\Taito Type X\Images\Letters\r.png | Asset Extension31: png | Asset Type31: system Asset Label: Letters | Asset Path32: D:\Arcade\Media\Taito Type X\Images\Letters\s.png | Asset Extension32: png | Asset Type32: system Asset Label: Letters | Asset Path33: D:\Arcade\Media\Taito Type X\Images\Letters\t.png | Asset Extension33: png | Asset Type33: system Asset Label: Letters | Asset Path34: D:\Arcade\Media\Taito Type X\Images\Letters\u.png | Asset Extension34: png | Asset Type34: system Asset Label: Letters | Asset Path35: D:\Arcade\Media\Taito Type X\Images\Letters\v.png | Asset Extension35: png | Asset Type35: system Asset Label: Letters | Asset Path36: D:\Arcade\Media\Taito Type X\Images\Letters\w.png | Asset Extension36: png | Asset Type36: system Asset Label: Letters | Asset Path37: D:\Arcade\Media\Taito Type X\Images\Letters\x.png | Asset Extension37: png | Asset Type37: system Asset Label: Letters | Asset Path38: D:\Arcade\Media\Taito Type X\Images\Letters\y.png | Asset Extension38: png | Asset Type38: system Asset Label: Letters | Asset Path39: D:\Arcade\Media\Taito Type X\Images\Letters\z.png | Asset Extension39: png | Asset Type39: system Asset Label: Other | Asset Path1: D:\Arcade\Media\Taito Type X\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system 10:05:57:519 | MD | INFO | +0 | BuildAssetsTable - Ended 10:05:57:519 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 10:05:57:520 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Game Video: D:\Arcade\Media\Taito Type X\Video\Battle Fantasia.* 10:05:57:520 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a System Video: D:\Arcade\Media\Main Menu\Video\Taito Type X.* 10:05:57:520 | MD | DEBUG | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Video | Asset Path1: D:\Arcade\Media\Taito Type X\Video\Battle Fantasia.flv | Asset Extension1: flv | Asset Type1: game 10:05:57:520 | MD | INFO | +0 | BuildAssetsTable - Ended 10:05:57:521 | MD | INFO | +0 | PluginInit - Ended 10:05:57:521 | MD | DEBUG | +0 | StartModule - Setting romName to the dbName sent to RocketLauncher: Battle Fantasia 10:05:57:521 | MD | DEBUG | +0 | XHotkeyTableCreation - Started 10:05:57:521 | MD | DEBUG | +0 | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc, 10:05:57:522 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 1 check 10:05:57:522 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 2 check 10:05:57:522 | MD | DEBUG | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 10:05:57:522 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 10:05:57:522 | MD | TRACE | +0 | Process.__New - Creating new process object for: "D:\Arcade\HyperSpin.exe" 10:05:57:523 | MD | TRACE | +0 | File.__New - Creating new file object of: "D:\Arcade\HyperSpin.exe" 10:05:57:524 | MD | TRACE | +0 | File.__New - Creating new file object of: "D:\RocketLauncher\Modules\PCLauncher\Taito Type X\Battle Fantasia.ini" 10:05:57:524 | MD | TRACE | +0 | File.__New - Creating new file object of: "D:\RocketLauncher\Modules\PCLauncher\Taito Type X.ini" 10:05:57:525 | MD | TRACE | +0 | File.Exist - This file exists: D:\RocketLauncher\Modules\PCLauncher\Taito Type X.ini 10:05:57:548 | MD | DEBUG | +32 | RIniFile.__New - "Module" at index 1, adding "SystemModuleIni" from: "D:\RocketLauncher\Modules\PCLauncher\Taito Type X.ini" 10:05:57:548 | MD | TRACE | +0 | File.__New - Creating new file object of: "D:\RocketLauncher\Modules\PCLauncher\PCLauncher.ini" 10:05:57:549 | MD | TRACE | +0 | File.Exist - This file exists: D:\RocketLauncher\Modules\PCLauncher\PCLauncher.ini 10:05:57:552 | MD | DEBUG | +0 | RIniFile.__New - "Module" at index 2, adding "GlobalModuleIni" from: "D:\RocketLauncher\Modules\PCLauncher\PCLauncher.ini" 10:05:57:554 | MD | INFO | +0 | StartModule - Ended 10:05:57:554 | MD | INFO | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - Application: D:\Arcade\Taito Type X\Battle Fantasia\Battle Fantasia.bat 10:05:57:554 | MD | INFO | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - AppWaitExe: game.exe 10:05:57:555 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - DiscImage: No value for this key 10:05:57:555 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - DiscImage: No value for this key 10:05:57:555 | MD | INFO | +0 | RIniFile.Read - Module - DiscImage: (NO VALUE) 10:05:57:555 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - DXWndGame: No value for this key 10:05:57:556 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - DXWndGame: No value for this key 10:05:57:556 | MD | INFO | +0 | RIniFile.Read - Module - DXWndGame: (NO VALUE) 10:05:57:556 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - DXWndMaximizeWindow: No value for this key 10:05:57:556 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - DXWndMaximizeWindow: No value for this key 10:05:57:557 | MD | INFO | +0 | RIniFile.Read - Module - DXWndMaximizeWindow: (NO VALUE) 10:05:57:557 | MD | INFO | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - ExitMethod: Send Alt+F4 10:05:57:557 | MD | INFO | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - FadeTitle: BattleFantasia 10:05:57:557 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - FadeTitleWaitTillActive: No value for this key 10:05:57:558 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - FadeTitleWaitTillActive: No value for this key 10:05:57:558 | MD | INFO | +0 | RIniFile.Read - Module - FadeTitleWaitTillActive: true (DEFAULT) 10:05:57:558 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - FadeTitleTimeout: No value for this key 10:05:57:558 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - FadeTitleTimeout: No value for this key 10:05:57:559 | MD | INFO | +0 | RIniFile.Read - Module - FadeTitleTimeout: (NO VALUE) 10:05:57:559 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - FadeInExitSleep: No value for this key 10:05:57:559 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - FadeInExitSleep: No value for this key 10:05:57:559 | MD | INFO | +0 | RIniFile.Read - Module - FadeInExitSleep: (NO VALUE) 10:05:57:581 | MD | TRACE | +31 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - HideConsole: No value for this key 10:05:57:581 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - HideConsole: No value for this key 10:05:57:581 | MD | INFO | +0 | RIniFile.Read - Module - HideConsole: (NO VALUE) 10:05:57:581 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - OriginGame: No value for this key 10:05:57:581 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - OriginGame: No value for this key 10:05:57:582 | MD | INFO | +0 | RIniFile.Read - Module - OriginGame: (NO VALUE) 10:05:57:582 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - Parameters: No value for this key 10:05:57:582 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - Parameters: No value for this key 10:05:57:582 | MD | INFO | +0 | RIniFile.Read - Module - Parameters: (NO VALUE) 10:05:57:582 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - PostLaunch: No value for this key 10:05:57:583 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - PostLaunch: No value for this key 10:05:57:583 | MD | INFO | +0 | RIniFile.Read - Module - PostLaunch: (NO VALUE) 10:05:57:583 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - PostLaunchParameters: No value for this key 10:05:57:583 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - PostLaunchParameters: No value for this key 10:05:57:584 | MD | INFO | +0 | RIniFile.Read - Module - PostLaunchParameters: (NO VALUE) 10:05:57:584 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - PostLaunchSleep: No value for this key 10:05:57:584 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - PostLaunchSleep: No value for this key 10:05:57:584 | MD | INFO | +0 | RIniFile.Read - Module - PostLaunchSleep: (NO VALUE) 10:05:57:584 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - PostExit: No value for this key 10:05:57:585 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - PostExit: No value for this key 10:05:57:585 | MD | INFO | +0 | RIniFile.Read - Module - PostExit: (NO VALUE) 10:05:57:585 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - PostExitParameters: No value for this key 10:05:57:585 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - PostExitParameters: No value for this key 10:05:57:586 | MD | INFO | +0 | RIniFile.Read - Module - PostExitParameters: (NO VALUE) 10:05:57:586 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - PostExitSleep: No value for this key 10:05:57:586 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - PostExitSleep: No value for this key 10:05:57:586 | MD | INFO | +0 | RIniFile.Read - Module - PostExitSleep: (NO VALUE) 10:05:57:586 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - PreLaunch: No value for this key 10:05:57:587 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - PreLaunch: No value for this key 10:05:57:587 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunch: (NO VALUE) 10:05:57:587 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - PreLaunchParameters: No value for this key 10:05:57:587 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - PreLaunchParameters: No value for this key 10:05:57:588 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunchParameters: (NO VALUE) 10:05:57:588 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - PreLaunchMode: No value for this key 10:05:57:588 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - PreLaunchMode: No value for this key 10:05:57:588 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunchMode: (NO VALUE) 10:05:57:588 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - PreLaunchSleep: No value for this key 10:05:57:589 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - PreLaunchSleep: No value for this key 10:05:57:589 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunchSleep: (NO VALUE) 10:05:57:589 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - SteamID: No value for this key 10:05:57:589 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - SteamID: No value for this key 10:05:57:590 | MD | INFO | +0 | RIniFile.Read - Module - SteamID: (NO VALUE) 10:05:57:590 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - WorkingFolder: No value for this key 10:05:57:590 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - WorkingFolder: No value for this key 10:05:57:590 | MD | INFO | +0 | RIniFile.Read - Module - WorkingFolder: (NO VALUE) 10:05:57:611 | MD | TRACE | +31 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - BezelTopOffset: No value for this key 10:05:57:611 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - BezelTopOffset: No value for this key 10:05:57:611 | MD | INFO | +0 | RIniFile.Read - Module - BezelTopOffset: 0 (DEFAULT) 10:05:57:611 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - BezelBottomOffset: No value for this key 10:05:57:611 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - BezelBottomOffset: No value for this key 10:05:57:612 | MD | INFO | +0 | RIniFile.Read - Module - BezelBottomOffset: 0 (DEFAULT) 10:05:57:612 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - BezelLeftOffset: No value for this key 10:05:57:612 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - BezelLeftOffset: No value for this key 10:05:57:612 | MD | INFO | +0 | RIniFile.Read - Module - BezelLeftOffset: 0 (DEFAULT) 10:05:57:613 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - BezelRightOffset: No value for this key 10:05:57:613 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - BezelRightOffset: No value for this key 10:05:57:613 | MD | INFO | +0 | RIniFile.Read - Module - BezelRightOffset: 0 (DEFAULT) 10:05:57:613 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - BezelFixedResMode: No value for this key 10:05:57:613 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - BezelFixedResMode: No value for this key 10:05:57:614 | MD | INFO | +0 | RIniFile.Read - Module - BezelFixedResMode: false (DEFAULT) 10:05:57:614 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - HideWindowTitleBar: No value for this key 10:05:57:614 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - HideWindowTitleBar: No value for this key 10:05:57:614 | MD | INFO | +0 | RIniFile.Read - Module - HideWindowTitleBar: true (DEFAULT) 10:05:57:615 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - HideWindowBorder: No value for this key 10:05:57:615 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - HideWindowBorder: No value for this key 10:05:57:615 | MD | INFO | +0 | RIniFile.Read - Module - HideWindowBorder: true (DEFAULT) 10:05:57:615 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - HideWindowMenuBar: No value for this key 10:05:57:615 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - HideWindowMenuBar: No value for this key 10:05:57:616 | MD | INFO | +0 | RIniFile.Read - Module - HideWindowMenuBar: true (DEFAULT) 10:05:57:616 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - HideDecoratorsAfterWindowMove: No value for this key 10:05:57:616 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - HideDecoratorsAfterWindowMove: No value for this key 10:05:57:616 | MD | INFO | +0 | RIniFile.Read - Module - HideDecoratorsAfterWindowMove: false (DEFAULT) 10:05:57:617 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - HideWindowBorderFirst: No value for this key 10:05:57:617 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - HideWindowBorderFirst: No value for this key 10:05:57:617 | MD | INFO | +0 | RIniFile.Read - Module - HideWindowBorderFirst: false (DEFAULT) 10:05:57:617 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Battle Fantasia] - Fullscreen: No value for this key 10:05:57:618 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Battle Fantasia] - Fullscreen: No value for this key 10:05:57:618 | MD | INFO | +0 | RIniFile.Read - Module - Fullscreen: (NO VALUE) 10:05:57:618 | MD | TRACE | +0 | CustomFunction.PreStart - Starting 10:05:57:618 | MD | TRACE | +0 | CustomFunction.PreStart - Ending 10:05:57:618 | MD | TRACE | +0 | Emulator.__New - Creating new emulator object for: "D:\Arcade\Taito Type X\Battle Fantasia\Battle Fantasia.bat" 10:05:57:619 | MD | TRACE | +0 | Process.__New - Creating new process object for: "D:\Arcade\Taito Type X\Battle Fantasia\Battle Fantasia.bat" 10:05:57:619 | MD | TRACE | +0 | File.__New - Creating new file object of: "D:\Arcade\Taito Type X\Battle Fantasia\Battle Fantasia.bat" 10:05:57:620 | MD | TRACE | +0 | Process.__New - Creating new process object for: "game.exe" 10:05:57:620 | MD | TRACE | +0 | File.__New - Creating new file object of: "game.exe" 10:05:57:620 | MD | TRACE | +0 | StringUtils.Contains - "BattleFantasia" does not contain "ahk_class" 10:05:57:621 | MD | TRACE | +0 | Window.__New - Created: "BattleFantasia" 10:05:57:621 | MD | INFO | +0 | CheckSettings - Started 10:05:57:621 | MD | TRACE | +0 | StringUtils.SubStr - Retrieved "D:\" from "D:\Arcade\Taito Type X\Battle Fantasia\Battle Fantasia.bat" 10:05:57:621 | MD | TRACE | +0 | StringUtils.SubStr - Retrieved "D:\A" from "D:\Arcade\Taito Type X\Battle Fantasia\Battle Fantasia.bat" 10:05:57:642 | MD | INFO | +31 | PCLauncher - Setting mode to: "standard" 10:05:57:642 | MD | INFO | +0 | File.CheckFile - Checking if "D:\Arcade\Taito Type X\Battle Fantasia\Battle Fantasia.bat" exists 10:05:57:642 | MD | TRACE | +0 | File.Exist - This file exists: D:\Arcade\Taito Type X\Battle Fantasia\Battle Fantasia.bat 10:05:57:643 | MD | DEBUG | +0 | File.CheckFile - Attributes: File Size: 34 bytes Created: 12/24/2015 - 11:47:29 AM Modified: 10/29/2014 - 9:05:42 PM 10:05:57:643 | MD | INFO | +0 | CheckSettings - Ended 10:05:57:643 | MD | TRACE | +0 | CustomFunction.SetFullscreenPreLaunch - Starting 10:05:57:643 | MD | TRACE | +0 | CustomFunction.SetFullscreenPreLaunch - Setting fullscreen to 10:05:57:643 | MD | TRACE | +0 | CustomFunction.SetFullscreenPreLaunch - Ending 10:05:57:644 | MD | TRACE | +0 | StringUtils.Contains - "standard" does not contain "steam|steambp" 10:05:57:644 | MD | INFO | +0 | PCLauncher - Launching a standard application. 10:05:57:644 | MD | TRACE | +0 | CustomFunction.PreLaunch - Starting 10:05:57:644 | MD | TRACE | +0 | CustomFunction.PreLaunch - Ending 10:05:57:644 | MD | INFO | +0 | Process.Run - Running: "D:\Arcade\Taito Type X\Battle Fantasia\Battle Fantasia.bat" 10:05:57:686 | MD | DEBUG | +47 | Process.Run - "Battle Fantasia.bat" Process ID: 6496 10:05:57:686 | MD | TRACE | +0 | CustomFunction.PostLaunch - Starting 10:05:57:686 | MD | TRACE | +0 | CustomFunction.PostLaunch - Ending 10:05:57:687 | MD | INFO | +0 | PCLauncher - FadeTitle set by user, waiting for "BattleFantasia" 10:05:57:687 | MD | TRACE | +0 | Window.__New - Created: "ahk_id 131666" 10:05:57:687 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 10:05:57:687 | MD | TRACE | +0 | Window.GetPos - Retrieved x:25 y:70 w: 1427 h: 712 from "ahk_id 131666" 10:05:57:687 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 10:05:57:688 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: RocketLauncherUI v1.0.1.9 [ FE = HyperSpin 1.4 | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;cff56e1e-8f6f-4ed4-a4c1-bd0c0b7e17ab] | State: 0 | X: 25 | Y: 70 | Width: 1427 | Height: 712 | Window HWND: 0x20252 | Process ID: 3864 | Process Path: D:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe 10:05:57:688 | MD | INFO | +0 | Window.Wait - Waiting for window "BattleFantasia" 10:06:27:684 | MD | TRACE | +29999 | Window.__New - Created: "ahk_id 131666" 10:06:27:684 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 10:06:27:684 | MD | TRACE | +0 | Window.GetPos - Retrieved x:25 y:70 w: 1427 h: 712 from "ahk_id 131666" 10:06:27:685 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 10:06:27:685 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: RocketLauncherUI v1.0.1.9 [ FE = HyperSpin 1.4 | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;cff56e1e-8f6f-4ed4-a4c1-bd0c0b7e17ab] | State: 0 | X: 25 | Y: 70 | Width: 1427 | Height: 712 | Window HWND: 0x20252 | Process ID: 3864 | Process Path: D:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe 10:06:27:685 | MD | DEBUG | +0 | XHotkeyTableCreation - Started 10:06:27:686 | MD | DEBUG | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~e&~t, 10:06:27:686 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 10 check 10:06:27:686 | MD | DEBUG | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 10:06:27:686 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 11 check 10:06:27:686 | MD | DEBUG | +0 | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc" 10:06:27:687 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 12 check 10:06:27:687 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 10:06:27:687 | MD | DEBUG | +0 | XHotkeyTableCreation - Started 10:06:27:687 | MD | DEBUG | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~e&~t, 10:06:27:688 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 10 check 10:06:27:688 | MD | DEBUG | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 10:06:27:688 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 11 check 10:06:27:688 | MD | DEBUG | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseError" 10:06:27:688 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 12 check 10:06:27:689 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 10:06:28:056 | MD | DEBUG | +359 | ScriptError - Playing error sound: error3.mp3 10:06:28:936 | MD | INFO | +889 | 7zCleanUp - Started 10:06:28:936 | MD | INFO | +0 | 7zCleanUp - Deleted 10:06:28:936 | MD | INFO | +0 | 7zCleanUp - Ended 10:06:39:255 | MD | DEBUG | +10312 | XHotkeyTableCreation - Started 10:06:39:255 | MD | DEBUG | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~e&~t, 10:06:39:255 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 10 check 10:06:39:255 | MD | DEBUG | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 10:06:39:256 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 11 check 10:06:39:256 | MD | DEBUG | +0 | XHotkeyTableCreation - Disabling "CloseError" standard Hotkey method for key(s): "~Esc" 10:06:39:256 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 12 check 10:06:39:256 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 10:06:39:257 | MD | DEBUG | +0 | XHotkeyTableCreation - Started 10:06:39:257 | MD | DEBUG | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~e&~t, 10:06:39:257 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 10 check 10:06:39:257 | MD | DEBUG | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 10:06:39:257 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 11 check 10:06:39:278 | MD | DEBUG | +31 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 10:06:39:278 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 12 check 10:06:39:278 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 10:06:39:279 | MD | ERROR | +0 | ScriptError - There was an error waiting for the window "BattleFantasia". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem. 10:06:39:279 | MD | INFO | +0 | ExitModule - Started 10:06:39:279 | MD | INFO | +0 | UpdateStatistics - Starting Updating Statistics 10:06:39:280 | MD | DEBUG | +0 | UpdateStatistics - Total Elapsed Time in Pause in seconds: 0 10:06:39:280 | MD | DEBUG | +0 | UpdateStatistics - gameSectionStartTime:7197496 10:06:39:280 | MD | DEBUG | +0 | UpdateStatistics - ElapsedTime:41 10:06:39:280 | MD | TRACE | +0 | Statistics cleared game name: Battle Fantasia 10:06:39:319 | MD | DEBUG | +31 | UpdateStatistics - Loaded game statistics from ini files: Number_of_Times_Played: 53 Last_Time_Played: Wednesday November 30, 2016 10:03:25 AM Average_Time_Played: 45 Total_Time_Played: 2405 System_Total_Played_Time: 7215 Total_Global_Played_Time: 205266 10:06:39:320 | MD | DEBUG | +0 | UpdateStatistics - Updated Statistics: Number_of_Times_Played: 54 Last_Time_Played: Wednesday November 30, 2016 10:05:57 AM Average_Time_Played: 45 Total_Time_Played: 2446 System_Total_Played_Time: 7256 Total_Global_Played_Time: 205307 10:06:39:377 | MD | INFO | +62 | UpdateStatistics - Game section statistics updated. 10:06:39:378 | MD | TRACE | +0 | CustomFunction.PostExit - Starting 10:06:39:378 | MD | TRACE | +0 | CustomFunction.PostExit - Ending 10:06:39:378 | MD | INFO | +0 | ExitModule - Ended End of Module Logs 10:06:39:448 | RL | INFO | +42151 | Main - Module ended, exiting RocketLauncher normally 10:06:39:448 | RL | INFO | +0 | ExitScript - Started 10:06:39:451 | RL | DEBUG | +0 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 10:06:39:451 | RL | DEBUG | +0 | Registry.Read - Registry Read finished, returning 0 10:06:39:452 | RL | TRACE | +0 | StringUtils.Contains - "false" does not contain "true|kill" 10:06:39:452 | RL | INFO | +0 | ExitScript - Restoring taskbar 10:06:39:452 | RL | TRACE | +0 | Window.__New - Created: "ahk_class Shell_TrayWnd" 10:06:39:452 | RL | TRACE | +0 | Window.__New - Created: "Start ahk_class Button" 10:06:39:453 | RL | TRACE | +0 | Window.Show - Unhiding window "ahk_class Shell_TrayWnd" 10:06:39:560 | RL | TRACE | +110 | Window.Show - Unhiding window "Start ahk_class Button" 10:06:39:674 | RL | INFO | +109 | SystemCursor - Restoring mouse cursor 10:06:39:680 | RL | INFO | +15 | ExitScript - Restored cursor 10:06:39:680 | RL | INFO | +0 | ExitScript - Ended
Metalzoic Posted November 30, 2016 Posted November 30, 2016 Do you have your AppWaitExe seting set in the RL module for each game as needed? Many, if not most of them, need game.exe set as the AppWaitExe
m714w Posted November 30, 2016 Author Posted November 30, 2016 Yes, I rechecked all setting many times, but cannot find an issue. Below are some of the settings for the Taito Type X ini. For example my AppWaitExe is game.exe and fade title is BattleFantasia some of the module ini settings below: [Arcana Heart 3] Application=..\Taito Type X\Arcana Heart 3\xb_loader.exe AppWaitExe=game.exe FadeTitle=AH3 HideCursor=true ExitMethod=WinClose Application [Battle Fantasia] Application=D:\Arcade\Taito Type X\Battle Fantasia\Battle Fantasia.bat AppWaitExe=game.exe FadeTitle=BattleFantasia ExitMethod=Send Alt+F4 [BlazBlue Calamity Trigger] Application=D:\Arcade\Taito Type X\BlazBlue Calamity Trigger\BlazBlue Calamity Trigger.bat AppWaitExe=game.exe FadeTitle=Blaz Blue ExitMethod=WinClose Application
Metalzoic Posted December 1, 2016 Posted December 1, 2016 You set an AppWait and a FadeTitle? Try just going with the AppWaitExe and see what happens.
m714w Posted December 1, 2016 Author Posted December 1, 2016 I just tried this suggestion of removing the FadeTitle, Same, It did not launch, but I received a new line in the error. There was an error waiting for the window "ahk_pid 5008". Instead of the original error There was an error waiting for the window "BattleFantasia" . So maybe it has something to do with the fadetitle? I attached the origianal error and my current printscreen Application setup. Taito Type X Launch issue screen capture.docx
jedihermit Posted November 12, 2017 Posted November 12, 2017 My Taito Type X games stopped working after I moved my install folder because the shortcuts to the batch files had the wrong drive letter. The shortcuts are under attract//roms/ttx. You can manually update each one but I found a utility to update all of them with a find and replace. http://jacquelin.potier.free.fr/ShortcutsSearchAndReplace/
