Chaos Breaker Speed Issue
dexllgamer
taito are normally straight forward as far as setup so I'm not sure what exactly is going on but being that these games were meant to be run on specific hardware.. that could be the issue? I have that game setup and it runs.. but I never play it because the resolution is bad. do you experience this with other TTX games? I know the TTX loaders have options for graphics so maybe try that. sorry for not being much help.
2 hours ago, dexllgamer said:
Hey, thanks for your responce.  Its the only game that does it.  How do you get into the options on the TTX loader?
Try searching google for the Game Loader ALL RH or Taito Type X loader.
I was trying to find info on games running fast... some people mentioned something about Vsync
When you initially setup your game through PC Arcade Loader it gives you t all the options you can set. Resolution, region, credits etc...
So you put it through that, which creates the exe with your settings. For example with Chaos Breaker if you pick Japanese region you get the blue knight looking main character, but if you pick US region you get the more badass looking barbarian dude.
No idea why yours is running fast. works fine for me.
34 minutes ago, dexllgamer said:
Oh do you mean the RocketLauncher PCLauncher.ahk module?  I'll check it out.
No. I meant the Arcade PC Loader program that you set TTX games up with (you can also use the All RH Loader, but I haven't messed with that one.
Although you do need to set your TTX games up using the PCLauncher module in RL, but that's a totally different thing.
