Vertical Mame in 32" LCD - Marquee help
solid187
I have a 32" lcd that is rotated for vertical orientation.  My goal is to move the MAME gameplay to the bottom of the screen (it currently centers itself), and then display the appropriate marquee above.  This would all be done on a single display.  Is this possible?
It's sounds like you just need a bezel or transparent bezel with the correct ini coordinates. I've created my own for my vertical games but it's centered as I have a cocktail table and the screen flips for P2.
Cool.  Thanks.  I think I'm on the right track now.  Hit the ` key to reposition the game.  For the marquee, I edited the default.lay in each artwork file to look for the marquee.png (I had to add that image to the zip file).  Then as you mentioned, edit the coordinates until the image fit properly.
thanks!
