Case Fan's Wiring
dziactorx
 Purchased a case from Monster Arcades. They included 2 fans for the case for the top and bottom. These are just like for a computer with the same kind of connector. They have 4 pin connectors.  How do you wire these to power? Cant find anything that extends too far?
Thanks!
Thanks both of you. I only have the one in the PC. Other than the case fans what else do you power with a separate power supply? Sounds like ill need to make my own extension pieces.
Open up the PC and see if you have any extra 4-pin Molex connectors... It's easy to find splitters if you even have one free.
Also if you have a pc in the cabinet, there probably isn't a need for a second psu on the cabinet. I'm actually going through the the same thing. Just built the pc and going to add case fans to the cabinet via ac plug I think
