shitoken Posted January 8, 2017 Posted January 8, 2017 I have setup Nesicaxlive frontend to launch from Hyperspin similar to Fightcade setting which is fine but I want RL to handle and launch the games and exit back to HS as soon as I exit the Nesicaxlive frontend. Does any one know how to do it?
shitoken Posted January 11, 2017 Author Posted January 11, 2017 I mean to launch Nesica attract mode frontend via hyperspin wheel which I done it already , but how should I set up RL so that when I run the game from Nesica frontend RL will receive signal and launch the game?
rastan Posted January 11, 2017 Posted January 11, 2017 You're using the nesicaxlive front end that was originally attract mode but uses RL right? I have it but never set it up.. it looks amazing tho. I thought you just set everything in the nesicaxlive front end which uses it's own RL??
shitoken Posted January 12, 2017 Author Posted January 12, 2017 Rocketlauncher came with Attractmode does not look good. So I want to use my own RL with database of NesicaXlive and launch the NEsica games for me when I select from Nesica frontend. I am sure it can do but cant figure out. It launches the RL but game wont start. I just use one main wheel "NesicaXlive" in hyperspin and it launches Nesica frontend which is damm beautiful compare to choosing the wheels per game in Hyperspin. Hyperspin is A MUST because I use for all systems, NesicaXlive frontend and RL all 3 of them involved for this system . Now I just left to set up RL to launch Nesica games instead of bring up RL , if someone did already this way please give some light to me.
pjbridger Posted February 4, 2017 Posted February 4, 2017 If I understand the question, You can create a .BAT file which on exit would force quit the nesica frontend and you would be back to Hyperspin, In Rocket Launcher (for your Hyperspin) If you choose the global module settings tab in modules, Choose Pre/Post Launch and under Post exit put the .BAT file,
shitoken Posted February 7, 2017 Author Posted February 7, 2017 just finished setting up Nesica frontend with few problems left should not be a big deal but really look awesome and the feel of official nesica lauching via HS. Tested a.s.a exiting the Nesica it goes back to HS automatically. But I would still like to know more about the batch file. What code do I need add to this batch.exe?
pjbridger Posted February 10, 2017 Posted February 10, 2017 To Create a .BAT file you make a new notepad file, Then add this text, taskkill /f /im "attract.exe" Save the file and rename it - KillAttractMode.bat That works, I tested it
Disco77 Posted March 9, 2017 Posted March 9, 2017 Would love to see a step by step setup guide for nesicaxlive use with hyperspin and rocketlauncher, the only one i found so far is in french, and that one dont even cover hyperspin rl integration..
shitoken Posted March 9, 2017 Author Posted March 9, 2017 Chrome is ur friend to translateTapatalk を使用して私の A0001 から送信
Disco77 Posted March 9, 2017 Posted March 9, 2017 9 minutes ago, shitoken said: Chrome is ur friend to translate Tapatalk を使用して私の A0001 から送信 yes it def. is, unfortunately it is not working that good for some language combinations, it is just spitting out nonsense. or realy hard to figure out sentences.
shitoken Posted March 9, 2017 Author Posted March 9, 2017 Page 38 you will find eng guide to set RL with AM. Before setting you make sure the games are working with allloaderTapatalk を使用して私の A0001 から送信
Disco77 Posted March 9, 2017 Posted March 9, 2017 Page 38 ? + guide "request" was about nesicaxlive/rocketlauncher/hyperspin combo. no am.
shitoken Posted March 9, 2017 Author Posted March 9, 2017 That is am frontend buddyTapatalk を使用して私の A0001 から送信
shitoken Posted March 10, 2017 Author Posted March 10, 2017 This is how my nesica is with attract mode + hyperspin.Is this what you mean? Tapatalk を使用して私の A0001 から送信
Disco77 Posted March 11, 2017 Posted March 11, 2017 thanks for the video shitoken . but now you confused me *lol so you running attract mode inside hyperspin ? sorry for beeing so noobish, but i was under the impression that attract mode is just another frontend / same as hyperspin frontend , no ? + your machine is running realy fluid, great job mate.
shitoken Posted March 11, 2017 Author Posted March 11, 2017 You are right , I am using total 2 frontends, why I chose second frontend because I want to get the original feeling of nesica and that is done the theme is on available with attract mode.Tapatalk を使用して私の A0001 から送信
Disco77 Posted March 11, 2017 Posted March 11, 2017 ah, ok, so you start attract mode thru hyperspin ? interesting, would not have thought that this is possible. thanks for the insight.
