pcsx2 1.5 - Not Working yet?
pjbridger
Hi Guys,
Is Pcsx2 1.5 working in hyperspin yet?
Or does the module still need to be updated?
I am getting the - There was an error detecting when PCSX2 finished loading your game - Problem,
Best,
P
Ok, so I sorted the first problem (didnt apply the Rocket Launcher Update settings, Doh!)
But now i am still getting the error if i -
1 - dont run with a bezel
2 - dont enable full screen,
so at the moment it only runs with a bezel within a window (as in you can see the border of the emulator)
Would love to be able to run it in widescreen with no bezel, anyone else had these problems?
Best,
P
Did PS2 actually have any widescreen games? If not then it isn't a problem, but just that they are supposed to run in 4:3.
When you exit the PCSX2 emulator does it actually close properly and close the GUI box also?
Thanks for the  reply,
when you run the emulator standalone you can play games in 16:9 and they look good,
Would be nice to do this in hyperspin aswell,
and yes it does close the GUI
Weird. Not sure why then as I only use PCsX2 for 2 games and use bezels with both.
Good to know it actually closes. I'm using an older module and it doesn't close it properly.
Sent from my SM-G935V
Im now having a problem with configs re- setting,
for example I run with Hardware hacks enabled for games like Tekken 5, which require sprite alignment to be playable
But every time I launch the game the hardware hacks setting reverts to off,
all the other settings remain the same,
I checked in the module settings but t doesnt seem to be able to be set within there,
anyone have a clue what could be going on?
I've never figured out how you're supposed to launch games with different individual settings in the first place so I can't help.
There are settings for those things in the module though.
  • 3 weeks later...
Sorry for the late reply,
Im not trying to launch it with individual settings,
I have sprite alignment on for every game,
but it still resets itself the next time i play the game,
