AYOOOB Posted April 1, 2014 Posted April 1, 2014 Guys i have problem with SuperModel When i load its give me this massage (I did whats written in notes of the module)
rfancella Posted April 1, 2014 Posted April 1, 2014 Guys i have problem with SuperModelWhen i load its give me this massage (I did whats written in notes of the module) [ATTACH=CONFIG]39850[/ATTACH] Please post your HyperLaunch log as described in this thread: http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
AYOOOB Posted April 1, 2014 Author Posted April 1, 2014 12:39:37:603 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 12:39:37:603 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 12:39:37:603 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 12:39:37:603 | HL | INFO | +0 | Main - Module is built 12:39:37:603 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin Install v1.3.2.0\AutoHotkey.dll exists 12:39:37:603 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 3/30/2014 - 1:44:42 AM Modified: 3/26/2014 - 10:05:22 PM 12:39:37:613 | HL | INFO | +15 | Main - Running module 12:39:37:613 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 12:39:37:743 | MD | INFO | +N/A | Module initialized 12:39:37:743 | MD | INFO | +0 | StartModule - Started 12:39:37:743 | MD | INFO | +0 | StartModule - MEmu: SuperModel MEmuV: r271 MURL: http://www.supermodel3.com/ MAuthor: djvj & chillin MVersion: 2.0.6 MCRC: DC765B83 iCRC: A8F43E35 MID: MSystem: "Sega Model 3" 12:39:37:743 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Sega Model 3" 12:39:37:743 | MD | DEBUG1 | +0 | StartModule - Leaving romName as is because Rom Mapping filled it with an Alternate_Rom_Name: vs2 12:39:37:743 | MD | INFO | +0 | StartModule - Ended 12:39:37:743 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 12:39:37:743 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - Fullscreen: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - Fullscreen: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - Widescreen: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - Widescreen: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - ConfigInputs: false 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - ConfigInputs: false 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - ScreenWidth: 1080 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - ScreenWidth: 1080 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - ScreenHeight: 1920 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - ScreenHeight: 1920 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - VertShader: 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - VertShader: 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - FragShader: 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - FragShader: 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - InputSystem: dinput 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - InputSystem: dinput 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - ForceFeedback: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - ForceFeedback: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - Frequency: 50 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - Frequency: 50 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - Throttle: false 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - Throttle: false 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - MultiThreading: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - MultiThreading: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - MusicVolume: 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - MusicVolume: 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - SoundVolume: 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - SoundVolume: 12:39:37:763 | MD | INFO | +16 | Run - Running: F:\HyperSpin1\Emulators\Sega Model 3\Supermodel.exe "F:\HyperSpin1\Emulators\Sega Model 3\Roms\vs2.zip" -fullscreen -wide-screen -res=1080,1920 -ppc-frequency=50 -no-throttle -input-system=dinput -force-feedback 12:39:37:883 | MD | DEBUG1 | +124 | Run - "Supermodel.exe "F:\HyperSpin1\Emulators\Sega Model 3\Roms\vs2.zip" -fullscreen -wide-screen -res=1080,1920 -ppc-frequency=50 -no-throttle -input-system=dinput -force-feedback " Process ID: 3612 12:39:37:893 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperSpin Install v1.3.2.0 | Class: CabinetWClass | State: 0 | X: 376 | Y: 260 | Width: 1198 | Height: 675 | Window HWND: 0x20284 | Process ID: 1780 | Process Path: C:\Windows\explorer.exe 12:39:37:893 | MD | INFO | +0 | WinWait - Waiting for "Supermodel" 12:39:37:993 | MD | DEBUG1 | +110 | GetActiveWindowStatus - Title: HyperSpin Install v1.3.2.0 | Class: CabinetWClass | State: 0 | X: 376 | Y: 260 | Width: 1198 | Height: 675 | Window HWND: 0x20284 | Process ID: 1780 | Process Path: C:\Windows\explorer.exe 12:39:37:993 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperSpin Install v1.3.2.0 | Class: CabinetWClass | State: 0 | X: 376 | Y: 260 | Width: 1198 | Height: 675 | Window HWND: 0x20284 | Process ID: 1780 | Process Path: C:\Windows\explorer.exe 12:39:37:993 | MD | INFO | +0 | WinWaitActive - Waiting for "Supermodel ahk_class SDL_app" 12:40:07:994 | MD | DEBUG1 | +29999 | GetActiveWindowStatus - Title: HyperSpin Install v1.3.2.0 | Class: CabinetWClass | State: 0 | X: 376 | Y: 260 | Width: 1198 | Height: 675 | Window HWND: 0x20284 | Process ID: 1780 | Process Path: C:\Windows\explorer.exe 12:40:08:494 | MD | DEBUG1 | +499 | ScriptError - Playing error sound: error12.mp3 12:40:12:839 | MD | ERROR | +4352 | There was an error waiting for the window "Supermodel ahk_class SDL_app" to become active. Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem. 12:40:12:839 | MD | INFO | +0 | ExitModule - Started 12:40:12:839 | MD | INFO | +0 | Starting Updating Statistics: 12:40:12:839 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 12:40:12:839 | MD | DEBUG2 | +0 | gameSectionStartTime:302501 12:40:12:839 | MD | DEBUG2 | +0 | ElapsedTime:35 12:40:12:849 | MD | INFO | +0 | CreateRomTable - Started 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Disc" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Disk" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Cart" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Tape" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Cassette" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Part" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Side" 12:40:12:849 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 12:40:12:849 | MD | DEBUG2 | +0 | Statistics cleared game name: vs2 12:40:12:939 | MD | DEBUG2 | +94 | Loaded game statistics from ini files: Number_of_Times_Played: 8 Last_Time_Played: Tuesday April 1, 2014 11:38:34 AM Average_Time_Played: 40 Total_Time_Played: 320 System_Total_Played_Time: 362 Total_Global_Played_Time: 2744 12:40:12:939 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 9 Last_Time_Played: Tuesday April 1, 2014 12:39:37 PM Average_Time_Played: 39 Total_Time_Played: 355 System_Total_Played_Time: 397 Total_Global_Played_Time: 2779 12:40:12:959 | MD | INFO | +15 | Game section statistics updated. 12:40:12:959 | MD | INFO | +0 | ExitModule - Ended 12:40:12:959 | MD | INFO | +0 | End of Module Logs 12:40:13:029 | HL | INFO | +35412 | Main - Module ended, exiting HyperLaunch normally 12:40:13:029 | HL | INFO | +0 | ExitScript - Started 12:40:13:049 | HL | INFO | +16 | SystemCursor - Restoring mouse cursor 12:40:13:069 | HL | INFO | +16 | ExitScript - Ended [/code] that's it right ? ?
rfancella Posted April 1, 2014 Posted April 1, 2014 is this ok ? Close, post your HyperLaunch.log not the HyperLaunchHQ.log. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
rfancella Posted April 1, 2014 Posted April 1, 2014 12:39:37:603 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 12:39:37:603 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 12:39:37:603 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 12:39:37:603 | HL | INFO | +0 | Main - Module is built 12:39:37:603 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin Install v1.3.2.0\AutoHotkey.dll exists 12:39:37:603 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 3/30/2014 - 1:44:42 AM Modified: 3/26/2014 - 10:05:22 PM 12:39:37:613 | HL | INFO | +15 | Main - Running module 12:39:37:613 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 12:39:37:743 | MD | INFO | +N/A | Module initialized 12:39:37:743 | MD | INFO | +0 | StartModule - Started 12:39:37:743 | MD | INFO | +0 | StartModule - MEmu: SuperModel MEmuV: r271 MURL: http://www.supermodel3.com/ MAuthor: djvj & chillin MVersion: 2.0.6 MCRC: DC765B83 iCRC: A8F43E35 MID: MSystem: "Sega Model 3" 12:39:37:743 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Sega Model 3" 12:39:37:743 | MD | DEBUG1 | +0 | StartModule - Leaving romName as is because Rom Mapping filled it with an Alternate_Rom_Name: vs2 12:39:37:743 | MD | INFO | +0 | StartModule - Ended 12:39:37:743 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 12:39:37:743 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - Fullscreen: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - Fullscreen: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - Widescreen: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - Widescreen: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - ConfigInputs: false 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - ConfigInputs: false 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - ScreenWidth: 1080 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - ScreenWidth: 1080 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - ScreenHeight: 1920 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - ScreenHeight: 1920 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - VertShader: 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - VertShader: 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - FragShader: 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - FragShader: 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - InputSystem: dinput 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - InputSystem: dinput 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - ForceFeedback: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - ForceFeedback: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - Frequency: 50 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - Frequency: 50 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - Throttle: false 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - Throttle: false 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - MultiThreading: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - MultiThreading: true 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - MusicVolume: 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - MusicVolume: 12:39:37:753 | MD | INFO | +0 | Module Setting - [settings] - SoundVolume: 12:39:37:753 | MD | INFO | +0 | Module Setting - [vs2] - SoundVolume: 12:39:37:763 | MD | INFO | +16 | Run - Running: F:\HyperSpin1\Emulators\Sega Model 3\Supermodel.exe "F:\HyperSpin1\Emulators\Sega Model 3\Roms\vs2.zip" -fullscreen -wide-screen -res=1080,1920 -ppc-frequency=50 -no-throttle -input-system=dinput -force-feedback 12:39:37:883 | MD | DEBUG1 | +124 | Run - "Supermodel.exe "F:\HyperSpin1\Emulators\Sega Model 3\Roms\vs2.zip" -fullscreen -wide-screen -res=1080,1920 -ppc-frequency=50 -no-throttle -input-system=dinput -force-feedback " Process ID: 3612 12:39:37:893 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperSpin Install v1.3.2.0 | Class: CabinetWClass | State: 0 | X: 376 | Y: 260 | Width: 1198 | Height: 675 | Window HWND: 0x20284 | Process ID: 1780 | Process Path: C:\Windows\explorer.exe 12:39:37:893 | MD | INFO | +0 | WinWait - Waiting for "Supermodel" 12:39:37:993 | MD | DEBUG1 | +110 | GetActiveWindowStatus - Title: HyperSpin Install v1.3.2.0 | Class: CabinetWClass | State: 0 | X: 376 | Y: 260 | Width: 1198 | Height: 675 | Window HWND: 0x20284 | Process ID: 1780 | Process Path: C:\Windows\explorer.exe 12:39:37:993 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperSpin Install v1.3.2.0 | Class: CabinetWClass | State: 0 | X: 376 | Y: 260 | Width: 1198 | Height: 675 | Window HWND: 0x20284 | Process ID: 1780 | Process Path: C:\Windows\explorer.exe 12:39:37:993 | MD | INFO | +0 | WinWaitActive - Waiting for "Supermodel ahk_class SDL_app" 12:40:07:994 | MD | DEBUG1 | +29999 | GetActiveWindowStatus - Title: HyperSpin Install v1.3.2.0 | Class: CabinetWClass | State: 0 | X: 376 | Y: 260 | Width: 1198 | Height: 675 | Window HWND: 0x20284 | Process ID: 1780 | Process Path: C:\Windows\explorer.exe 12:40:08:494 | MD | DEBUG1 | +499 | ScriptError - Playing error sound: error12.mp3 12:40:12:839 | MD | ERROR | +4352 | There was an error waiting for the window "Supermodel ahk_class SDL_app" to become active. Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem. 12:40:12:839 | MD | INFO | +0 | ExitModule - Started 12:40:12:839 | MD | INFO | +0 | Starting Updating Statistics: 12:40:12:839 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 12:40:12:839 | MD | DEBUG2 | +0 | gameSectionStartTime:302501 12:40:12:839 | MD | DEBUG2 | +0 | ElapsedTime:35 12:40:12:849 | MD | INFO | +0 | CreateRomTable - Started 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Disc" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Disk" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Cart" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Tape" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Cassette" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Part" 12:40:12:849 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "vs2" and "(Side" 12:40:12:849 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 12:40:12:849 | MD | DEBUG2 | +0 | Statistics cleared game name: vs2 12:40:12:939 | MD | DEBUG2 | +94 | Loaded game statistics from ini files: Number_of_Times_Played: 8 Last_Time_Played: Tuesday April 1, 2014 11:38:34 AM Average_Time_Played: 40 Total_Time_Played: 320 System_Total_Played_Time: 362 Total_Global_Played_Time: 2744 12:40:12:939 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 9 Last_Time_Played: Tuesday April 1, 2014 12:39:37 PM Average_Time_Played: 39 Total_Time_Played: 355 System_Total_Played_Time: 397 Total_Global_Played_Time: 2779 12:40:12:959 | MD | INFO | +15 | Game section statistics updated. 12:40:12:959 | MD | INFO | +0 | ExitModule - Ended 12:40:12:959 | MD | INFO | +0 | End of Module Logs 12:40:13:029 | HL | INFO | +35412 | Main - Module ended, exiting HyperLaunch normally 12:40:13:029 | HL | INFO | +0 | ExitScript - Started 12:40:13:049 | HL | INFO | +16 | SystemCursor - Restoring mouse cursor 12:40:13:069 | HL | INFO | +16 | ExitScript - Ended [/code] that's it right ? ? Ok, couple things look out of place to me. 1). Either this is not the complete log, or it's an old HyperLaunch setup. Change your Logging Level to Troubleshooting and post the entire log please. 2). The path does not look correct. 12:39:37:603 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin Install v1.3.2.0\AutoHotkey.dll exists What is your directory structure? When you installed, you should use the following directory structure: \HyperSpin\ \HyperSpin\HyperLaunch\ \HyperSpin\HyperLaunch\HyperLaunchHQ If this had been installed this way, the AutoHotkey.dll should show: C:\HyperSpin Install v1.3.2.0\HyperLaunch\AutoHotkey.dll Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
AYOOOB Posted April 2, 2014 Author Posted April 2, 2014 i did the next step (directory structure) and its working fine now Thanks Ron Sorry for any disturbance
rfancella Posted April 2, 2014 Posted April 2, 2014 i did the next step (directory structure)and its working fine now Thanks Ron Sorry for any disturbance Glad it works now! It may be easier to setup additional systems now also. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
AYOOOB Posted April 2, 2014 Author Posted April 2, 2014 everything is working but only supermodel had trouble with it Thanks again
Jon.Damico Posted August 19, 2014 Posted August 19, 2014 So, I am actually having the same issue. This is my first attempt at the Supermodel Emulator. I have the command prompt window pop-up with the same writing as if I was running it outside of Hyperspin. Outside of Hyperspin I can run everything fine. I go to command prompt change the directories to the Sega Model 3 folder, type supermodel.exe with the .zip, then it loads it into another window, which is supermodel.exe. HL doesn't seem to want to open that other window or something. Maybe I have a directory issue as well, but I am really confused. I somehow ended up with two HLHQ's one in a HLHQ folder and the other in my Hyperspin folder, so I am wondering if that is the issue. Both of the HLHQ load the same information regarding settings and emulators, paths, etc. Here is my error log, I set it to troubleshooting, let me know if I need something else. Thanks code] 20:47:39:562 | HL | INFO | +N/A | Main - HyperLaunch v3.0.1.1c 20:47:39:828 | HL | INFO | +265 | Main - System Specs: HyperLaunch Dir: H:\Hyperspin OS: Microsoft Windows XP Professional SKU: Total Memory: 3327.10 MB Free Memory: 2135.97 MB Used Memory: 1191.133 MB SystemType: X86-based PC Physical Processors: See Logical in XP Logical Processors: 4 GPU 1 Name: ATI Radeon HD 5450 GPU 1 RAM: 1024.00 MB GPU 1 Driver Version: 6.14.10.7279 Sound 1 Device: Envy24 Family Audio Controller WDM Sound 1 Status: Enabled Sound 2 Device: Realtek High Definition Audio Sound 2 Status: Unknown OS Language: English_United_States OS Admin Status: Yes Monitor #1 (\\.\DISPLAY1): 1024x768 (1024x738 work) AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 20:47:39:828 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1024 h768 20:47:39:828 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\HyperLaunch.exe exists 20:47:39:828 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! FileVersion 3.0.1.1 LegalCopyright ©2013 HL squad ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName djvj's one swell guy! File Size: 910336 bytes Created: 12/16/2013 - 9:10:15 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:828 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Module Extensions\itextsharp.dll exists 20:47:39:828 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright © 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 12/16/2013 - 9:10:29 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:828 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Module Extensions\SevenZipSharp.dll exists 20:47:39:828 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.4841.31212 InternalName SevenZipSharp.dll LegalCopyright Copyright © Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.4841.31212 CompanyName Markovtsev Vadim File Size: 165888 bytes Created: 12/16/2013 - 9:10:29 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:828 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Module Extensions\gsdll32.dll exists 20:47:39:828 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 8818688 bytes Created: 12/16/2013 - 9:10:28 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:828 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Module Extensions\BlockInput.exe exists 20:47:39:828 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 6/30/2014 - 5:57:11 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:828 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Module Extensions\gdip.ahk exists 20:47:39:843 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 20:47:39:843 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 12/16/2013 - 9:10:28 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:843 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Module Extensions\RIni.ahk exists 20:47:39:843 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:47:39:843 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 12/16/2013 - 9:10:29 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:843 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Module Extensions\CLR.ahk exists 20:47:39:859 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 20:47:39:859 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 12/16/2013 - 9:10:28 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:859 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Module Extensions\COM.ahk exists 20:47:39:859 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:47:39:859 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 12/16/2013 - 9:10:28 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:859 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Module Extensions\JSON.ahk exists 20:47:39:859 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:47:39:859 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 12/16/2013 - 9:10:29 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:859 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\Fade Init.ahk exists 20:47:39:859 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:859 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1145 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:859 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\HyperPause Init.ahk exists 20:47:39:859 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:859 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 691 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:859 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\Keymapper Init.ahk exists 20:47:39:875 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:875 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3435 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:875 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\MultiGame Init.ahk exists 20:47:39:875 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:875 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:875 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\Statistics Init.ahk exists 20:47:39:875 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:875 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 167 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:875 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\Fade.ahk exists 20:47:39:875 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:875 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 25516 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:875 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\HyperPause.ahk exists 20:47:39:890 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:890 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 360180 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:890 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\Keymapper.ahk exists 20:47:39:890 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:890 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 30775 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:906 | HL | INFO | +15 | CheckFile - Checking if H:\Hyperspin\Lib\MultiGame.ahk exists 20:47:39:906 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:906 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 36816 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:906 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\Bezel.ahk exists 20:47:39:906 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:906 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 83008 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:906 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\Statistics.ahk exists 20:47:39:906 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:906 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26153 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:906 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\Rom Mapping Launch Menu.ahk exists 20:47:39:921 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:921 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 63798 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:921 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\Shared.ahk exists 20:47:39:921 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:921 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 81966 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:921 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\XHotkey.ahk exists 20:47:39:921 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:921 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28374 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:921 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Lib\Fade Animations.ahk exists 20:47:39:937 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 20:47:39:937 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 49050 bytes Created: 12/16/2013 - 9:17:45 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:937 | HL | INFO | +0 | Main - HyperLaunch received "Sega Model 3" and "lostwsga" 20:47:39:937 | HL | INFO | +0 | Main - lostwsga is using the default emulator: SuperModel 20:47:39:937 | HL | INFO | +0 | Main - Checking for a [superModel] section in H:\Hyperspin\Settings\Sega Model 3\Emulators.ini 20:47:39:937 | HL | INFO | +0 | Main - Checking for a [superModel] section in H:\Hyperspin\Settings\Global Emulators.ini 20:47:39:937 | HL | INFO | +0 | Main - Found [superModel] in H:\Hyperspin\Settings\Global Emulators.ini 20:47:39:937 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Modules\SuperModel\SuperModel.ahk exists 20:47:39:937 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5057 bytes Created: 12/16/2013 - 9:10:24 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:937 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 20:47:39:953 | HL | INFO | +15 | Main - lostwsga will use module: H:\Hyperspin\Modules\SuperModel\SuperModel.ahk 20:47:39:953 | HL | INFO | +0 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 20:47:39:968 | HL | INFO | +16 | Main - INI Keys read 20:47:39:968 | HL | INFO | +0 | CheckFile - Checking if H:\Program Files\7-Zip\7zFM.exe exists 20:47:39:968 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip File Manager FileVersion 9.20 InternalName 7zFM LegalCopyright Copyright © 1999-2010 Igor Pavlov OriginalFilename 7zFM.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 421888 bytes Created: 11/18/2010 - 9:09:00 AM Modified: 11/18/2010 - 9:09:00 AM 20:47:39:968 | HL | INFO | +0 | CheckFile - Checking if H:\Program Files\7-Zip\7z.dll exists 20:47:39:968 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright © 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 11/18/2010 - 9:27:30 AM Modified: 11/18/2010 - 9:27:30 AM 20:47:39:968 | HL | INFO | +0 | CheckPaths - Started 20:47:39:968 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: H:\Hyperspin\Emulators\Sega Model 3\lostwsga.zip 20:47:39:968 | HL | INFO | +0 | CheckPaths - Found rom: H:\Hyperspin\Emulators\Sega Model 3\lostwsga.zip 20:47:39:968 | HL | DEBUG1 | +0 | CheckPaths - Current romName: lostwsga 20:47:39:968 | HL | DEBUG1 | +0 | CheckPaths - Current romPath: H:\Hyperspin\Emulators\Sega Model 3 20:47:39:968 | HL | DEBUG1 | +0 | CheckPaths - Current romExtension: .zip 20:47:39:968 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\Emulators\Sega Model 3\Supermodel.exe exists 20:47:39:968 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1351168 bytes Created: 8/17/2014 - 10:14:23 PM Modified: 12/1/2013 - 3:39:49 AM 20:47:39:968 | HL | INFO | +0 | CheckPaths - Ended 20:47:39:968 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 hlMode = frontendPID = 1548 frontendPath = H:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = H: exitEmulatorKey = 3|4 exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = H:\Hyperspin\Emulators\Sega Model 3\Supermodel.exe emuPath = H:\Hyperspin\Emulators\Sega Model 3 emuName = SuperModel emuExt = exe romPath = H:\Hyperspin\Emulators\Sega Model 3 romPathFromIni = H:\Hyperspin\Emulators\Sega Model 3 romExtension = .zip romExtensionOrig = .zip romExtensions = zip executable = Supermodel.exe systemName = Sega Model 3 dbName = lostwsga romName = lostwsga romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = true blockInputTime = 0 blockInputFile = H:\Hyperspin\Module Extensions\BlockInput.exe errorLevelReporting = false logFile = H:\Hyperspin\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false sysLang = English_United_States navUpKey = 8 navDownKey = 2 navLeftKey = 4 navRightKey = 6 navSelectKey = 1 navP2UpKey = r navP2DownKey = f navP2LeftKey = d navP2RightKey = g navP2SelectKey = 2 originalWidth = 1024 originalHeight = 768 dtEnabled = false dtPath = H:\Program Files\DAEMON Tools Lite\DTLite.exe dtUseSCSI = false dtAddDrive = true emuIdleShutdown = 0 hideCursor = false hideEmu = true hideFE = true fadeIn = false fadeInDuration = 2000 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 1000 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = NoAnimation fadeLyr37zAnimation = NoAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = false fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = false fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = false fadeBarInfoText = false fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = disabled fadeRomInfoSystemName = disabled fadeRomInfoYear = disabled fadeRomInfoManufacturer = disabled fadeRomInfoGenre = disabled fadeRomInfoRating = disabled fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = disabled fadeStats_Last_Time_Played = disabled fadeStats_Average_Time_Played = disabled fadeStats_Total_Time_Played = disabled fadeStats_System_Total_Played_Time = disabled fadeStats_Total_Global_Played_Time = disabled fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = true fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = H:\Hyperspin\Media\Fade HLDataPath = H:\Hyperspin\Data HLMediaPath = H:\Hyperspin\Media HLErrSoundPath = H:\Hyperspin\Media\Sounds\Error modulesPath = H:\Hyperspin\Modules moduleFullName = H:\Hyperspin\Modules\SuperModel\SuperModel.ahk moduleName = SuperModel modulePath = H:\Hyperspin\Modules\SuperModel moduleExtension = ahk moduleExtensionsPath = H:\Hyperspin\Module Extensions libPath = H:\Hyperspin\Lib 7zEnabled = true 7zPath = H:\Program Files\7-Zip\7zFM.exe 7zDllPath = H:\Program Files\7-Zip\7z.dll 7zExtractPath = H:\Hyperspin\Temp 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 1 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = H:\Hyperspin\Module Extensions\HiToText.exe hpSaveStateKeyCodes = hpLoadStateKeyCodes = keymapperEnabled = false keymapperAHKMethod = Internal keymapper = xpadderFullPath = H:\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = H:\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = H:\Hyperspin\Profiles\ keymapperFrontEndProfileName = HyperSpin keymapperFrontEndProfile = false keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = H:\Hyperspin\Profiles\\HyperSpin defaultProfile = H:\Hyperspin\Profiles\\_Default systemProfile = H:\Hyperspin\Profiles\\Sega Model 3 xPadderSystemProfile = H:\Hyperspin\Profiles\\Sega Model 3\_Default emuProfile = H:\Hyperspin\Profiles\\Sega Model 3\SuperModel romProfile = H:\Hyperspin\Profiles\\Sega Model 3\lostwsga HyperLaunchProfile = H:\Hyperspin\Profiles\\HyperLaunch blankProfile = H:\Hyperspin\Profiles\\blank ahkFEProfile = H:\Hyperspin\Profiles\AHK\HyperSpin ahkDefaultProfile = H:\Hyperspin\Profiles\AHK\_Default ahkSystemProfile = H:\Hyperspin\Profiles\AHK\Sega Model 3 ahkEmuProfile = H:\Hyperspin\Profiles\AHK\Sega Model 3\SuperModel ahkRomProfile = H:\Hyperspin\Profiles\AHK\Sega Model 3\lostwsga ahkHyperLaunchProfile = H:\Hyperspin\Profiles\AHK\HyperLaunch bezelEnabled = false statisticsEnabled = true 20:47:39:968 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 20:47:39:968 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 20:47:39:968 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 20:47:39:968 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 2 20:47:39:968 | HL | INFO | +0 | BuildScript - Module: MEmu = SuperModel MEmuV = r271 MURL = http://www.supermodel3.com/ MAuthor = djvj & chillin MVersion = 2.0.6 MCRC = DC765B83 iCRC = A8F43E35 MID = 635038268926572770 MSystem = "Sega Model 3" ;---------------------------------------------------------------------------- ; Notes: ; You can find r271 on emucr: http://www.emucr.com/2013/12/supermodel-svn-r271.html ; Required module ini file found on git with this module (rename it to remove the Example part so it matches the ahk name). It contains a few settings to get some games to work. It goes in the folder with this module. ; Set ConfigInputs to true if you want to configure the controls for the emulator. Set to false when you want to play a game ;---------------------------------------------------------------------------- StartModule() BezelGui() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings|" . romName, "Fullscreen","true",,1) Widescreen := IniReadCheck(settingsFile, "Settings|" . romName, "Widescreen","true",,1) ConfigInputs := IniReadCheck(settingsFile, "Settings|" . romName, "ConfigInputs","false",,1) screenWidth := IniReadCheck(settingsFile, "Settings|" . romName, "ScreenWidth",A_ScreenWidth,,1) ; Width screenHeight := IniReadCheck(settingsFile, "Settings|" . romName, "ScreenHeight",A_ScreenHeight,,1) ; Height vertShader := IniReadCheck(settingsFile, "Settings|" . romName, "VertShader",A_Space,,1) ; Filename of the 3D vertex shader vertShader := GetFullName(vertShader) ; convert from relative to absolute fragShader := IniReadCheck(settingsFile, "Settings|" . romName, "FragShader",A_Space,,1) ; Filename of the 3D fragment shader fragShader := GetFullName(fragShader) ; convert from relative to absolute inputSystem := IniReadCheck(settingsFile, "Settings|" . romName, "InputSystem","dinput",,1) ; Choices are dinput (default), xinput, & rawinput. Use dinput for most setups. Use xinput if you use XBox 360 controllers. Use rawinput for multiple mice or keyboard support. forceFeedback := IniReadCheck(settingsFile, "Settings|" . romName, "ForceFeedback","true",,1) ; Turns on force feedback if you have a controller that supports it. Scud Race' (including 'Scud Race Plus'), 'Daytona USA 2' (both editions), and 'Sega Rally 2' are the only games that support it. frequency := IniReadCheck(SettingsFile, "Settings|" . romName, "Frequency","50",,1) throttle := IniReadCheck(SettingsFile, "Settings|" . romName, "Throttle","false",,1) multiThreading := IniReadCheck(SettingsFile, "Settings|" . romName, "MultiThreading","true",,1) musicVolume := IniReadCheck(SettingsFile, "Settings|" . romName, "MusicVolume",,,1) soundVolume := IniReadCheck(SettingsFile, "Settings|" . romName, "SoundVolume",,,1) BezelStart() If bezelEnabled = true ; If bezels are enabled, the emu's width and height need to be set to the width and height of the bezel. Otherwise the user defined width and height are used. { screenWidth := If bezelEnabled = "true" ? bezelScreenWidth : screenWidth screenHeight := If bezelEnabled = "true" ? bezelScreenHeight : screenHeight } freq := If frequency != "" ? "-ppc-frequency=" . frequency : "" throttle := If throttle = "true" ? "" : "-no-throttle" fullscreen := If Fullscreen = "true" ? "-fullscreen" : "-window" widescreen := If widescreen = "true" ? "-wide-screen" : "" resolution := If screenWidth != "" ? "-res=" . screenWidth . "`," . screenHeight : "" vertShader := If vertShader != "" ? "-vert-shader=""" . vertShader . """" : "" fragShader := If fragShader != "" ? "-frag-shader=""" . fragShader . """" : "" inputSystem := If inputSystem != "" ? "-input-system=" . inputSystem : "" forceFeedback := If forceFeedback = "true" ? "-force-feedback" : "" multiThreading := If multiThreading = "true" ? "" : "-no-threads" musicVolume := If musicVolume != "" ? "-music-volume=" . musicVolume : "" soundVolume := If soundVolume != "" ? "-sound-volume=" . soundVolume : "" If ConfigInputs = true Run(executable . " -config-inputs", emuPath) Else Run(executable . " """ . romPath . "\" . romName . romExtension . """ " . fullscreen . " " . widescreen . " " . resolution . " " . freq . " " . throttle . " " . vertShader . " " . fragShader . " " . inputSystem . " " . forceFeedback . " " . multiThreading, emuPath, "Min") WinWait("Supermodel") If ConfigInputs = true { WinWait("ahk_class ConsoleWindowClass") WinGetPos,,, width,, ahk_class ConsoleWindowClass x := ( A_ScreenWidth / 2 ) - ( width / 2 ) WinMove, ahk_class ConsoleWindowClass,, %x%, 0,, %A_ScreenHeight% WinHide, ahk_class SDL_app ; hides the small emu window that pops up as it is not needed when configuring controls WinActivate, ahk_class ConsoleWindowClass } Else { WinWaitActive("Supermodel ahk_class SDL_app") Sleep, 1000 BezelDraw() } FadeInExit() Process("WaitClose", executable) BezelExit() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() WinClose("Supermodel ahk_class SDL_app") Return 20:47:39:968 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 20:47:39:968 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 20:47:39:968 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 20:47:39:968 | HL | INFO | +0 | Main - Module is built 20:47:39:968 | HL | INFO | +0 | CheckFile - Checking if H:\Hyperspin\AutoHotkey.dll exists 20:47:39:968 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright © 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 12/16/2013 - 9:10:14 PM Modified: 6/28/2014 - 11:28:01 PM 20:47:39:984 | HL | INFO | +15 | Main - Hiding taskbar 20:47:40:093 | HL | INFO | +110 | Main - Hiding desktop 20:47:40:093 | HL | INFO | +0 | Main - Loading Internal AHK Keymapping 20:47:40:093 | HL | INFO | +0 | GetProfileAHK - Started 20:47:40:093 | HL | DEBUG2 | +0 | GetProfileAHK - Searching for: H:\Hyperspin\Profiles\AHK\Sega Model 3\lostwsga.ahk 20:47:40:093 | HL | DEBUG2 | +0 | GetProfileAHK - Searching for: H:\Hyperspin\Profiles\AHK\Sega Model 3\SuperModel.ahk 20:47:40:093 | HL | DEBUG2 | +0 | GetProfileAHK - Searching for: H:\Hyperspin\Profiles\AHK\Sega Model 3.ahk 20:47:40:093 | HL | DEBUG2 | +0 | GetProfileAHK - Searching for: H:\Hyperspin\Profiles\AHK\_Default.ahk 20:47:40:093 | HL | WARNING | +0 | GetProfileAHK - Keymapper support is enabled for AHK, but could not find a lostwsga, SuperModel, Sega Model 3, or a default profile in 20:47:40:093 | HL | INFO | +0 | GetProfileAHK - Ended 20:47:40:093 | HL | DEBUG2 | +0 | Main - Attaching AHK remaps to module using: 20:47:40:093 | HL | DEBUG2 | +0 | Main - Finished building Internal AHK remaps 20:47:40:093 | HL | INFO | +0 | Main - Running module 20:47:40:093 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 20:47:40:203 | MD | INFO | +N/A | Module initialized 20:47:40:203 | MD | INFO | +0 | StartModule - Started 20:47:40:203 | MD | INFO | +0 | StartModule - MEmu: SuperModel MEmuV: r271 MURL: http://www.supermodel3.com/ MAuthor: djvj & chillin MVersion: 2.0.6 MCRC: DC765B83 iCRC: A8F43E35 MID: MSystem: "Sega Model 3" 20:47:40:203 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Sega Model 3" 20:47:40:203 | MD | DEBUG1 | +0 | StartModule - Leaving romName as is because Rom Mapping filled it with an Alternate_Rom_Name: lostwsga 20:47:40:203 | MD | INFO | +0 | StartModule - Ended 20:47:40:203 | MD | INFO | +0 | HideFE - Hiding Frontend by making it transparent 20:47:40:203 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 20:47:40:203 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 20:47:40:218 | MD | INFO | +16 | Module Setting - [settings] - Fullscreen: true 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - Fullscreen: true 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - Widescreen: true 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - Widescreen: true 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - ConfigInputs: false 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - ConfigInputs: false 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - ScreenWidth: 1024 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - ScreenWidth: 1024 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - ScreenHeight: 768 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - ScreenHeight: 768 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - VertShader: 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - VertShader: 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - FragShader: 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - FragShader: 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - InputSystem: dinput 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - InputSystem: dinput 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - ForceFeedback: true 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - ForceFeedback: true 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - Frequency: 50 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - Frequency: 25 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - Throttle: false 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - Throttle: 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - MultiThreading: true 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - MultiThreading: true 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - MusicVolume: 20:47:40:218 | MD | INFO | +0 | Module Setting - [lostwsga] - MusicVolume: 20:47:40:218 | MD | INFO | +0 | Module Setting - [settings] - SoundVolume: 20:47:40:234 | MD | INFO | +15 | Module Setting - [lostwsga] - SoundVolume: 20:47:40:234 | MD | INFO | +0 | Run - Running: H:\Hyperspin\Emulators\Sega Model 3\Supermodel.exe "H:\Hyperspin\Emulators\Sega Model 3\lostwsga.zip" -fullscreen -wide-screen -res=1024,768 -ppc-frequency=25 -no-throttle -input-system=dinput -force-feedback 20:47:40:343 | MD | DEBUG1 | +110 | Run - "Supermodel.exe "H:\Hyperspin\Emulators\Sega Model 3\lostwsga.zip" -fullscreen -wide-screen -res=1024,768 -ppc-frequency=25 -no-throttle -input-system=dinput -force-feedback " Process ID: 2312 20:47:40:343 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: BlackScreen | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1024 | Height: 768 | Window HWND: 0x100316 | Process ID: 2340 | Process Path: H:\Hyperspin\HyperLaunch.exe 20:47:40:343 | MD | INFO | +0 | WinWait - Waiting for "Supermodel" 20:47:40:453 | MD | DEBUG1 | +109 | GetActiveWindowStatus - Title: H:\Hyperspin\Emulators\Sega Model 3\Supermodel.exe | Class: ConsoleWindowClass | State: 0 | X: 132 | Y: 174 | Width: 669 | Height: 338 | Window HWND: 0x120372 | Process ID: 2312 | Process Path: H:\Hyperspin\Emulators\Sega Model 3\Supermodel.exe 20:47:40:453 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: H:\Hyperspin\Emulators\Sega Model 3\Supermodel.exe | Class: ConsoleWindowClass | State: 0 | X: 132 | Y: 174 | Width: 669 | Height: 338 | Window HWND: 0x120372 | Process ID: 2312 | Process Path: H:\Hyperspin\Emulators\Sega Model 3\Supermodel.exe 20:47:40:453 | MD | INFO | +0 | WinWaitActive - Waiting for "Supermodel ahk_class SDL_app" 20:47:56:859 | MD | DEBUG1 | +16406 | CloseProcess - Started, user requested to end launched application 20:47:56:859 | MD | INFO | +0 | HideFE - Showing Frontend and removing transparency 20:47:56:859 | MD | INFO | +0 | WinClose - Closing: Supermodel ahk_class SDL_app 20:47:56:968 | MD | DEBUG1 | +110 | CloseProcess - Ended 20:48:02:703 | HL | INFO | +22609 | GuiClose - User exited via GUI 20:48:02:703 | HL | INFO | +0 | ExitScript - Started 20:48:02:703 | HL | DEBUG1 | +0 | ExitScript - Unhiding taskbar 20:48:02:812 | HL | DEBUG1 | +110 | ExitScript - Checking what application is currently in focus. 20:48:02:812 | HL | DEBUG1 | +0 | ExitScript - is currently active. Putting focus back on HyperSpin.exe 20:48:02:937 | HL | DEBUG1 | +125 | ExitScript - Took 1 attempts to put HyperSpin.exe back in focus. 20:48:02:937 | HL | INFO | +0 | SystemCursor - Restoring mouse cursor 20:48:02:937 | HL | INFO | +0 | ExitScript - Ended [/code]
