hyperspin error cannot find d:\utilities\joytokey\joytokey.exe
kron
Hello,
I have HyperSpin v1.4 installed with RL running on Win7Pro 64bit. The problem I'm having is when I open HS, select Mame and choose any game a HS window comes up saying 'error cannot find d:\utilities\joytokey\joytokey.exe'. It stops me from getting into the game. I don't use any other consoles/emulators at this time.
Mame works fine on its own.
Not sure why this error is coming up. I don't want to configure JoyToKey or Xpadder stuff, although in RLUI it appears to be enabled with keymapper. In RLUI >> General Settings > Global > Third Party, I do see JoyToKey and Xpadder Paths listed to the error path, although those paths for some reason cannot be removed. Hitting the 'X' does nothing.
I'm using a tankstick for my controls in Mame and would like the emulator to have the settings rather then HS or RL. Does anyone know how I can fix this error I'm getting?
Thanks in advance.
From your post I can't tell if you are actually use Joy2key or not...
If not then make sure you don't have it enabled for your MAME system in RLauncher under the keymapper section.
  • 3 months later...
i keep getting this error message over and over as im playing thru hyperspin and idk why. could someone help me out with this. everything still runs its just this error message keeps popping up over and over as i go thru the wheels.
Expand
When did that start happening? / How long has it been happening for?
Ok. Did you make any changes to your system/cabinet? What version is your HyperSpin and your RocketLauncher? And what external devices and external programs do you run through HyperSpin?
ive done soo many changes its not even funny lol but i have hyperspin 1.4 with rocketlauncher 1.2.01. i think it started when i deleted a picture or file in while i was using hypert00ls
I believe this has something to do with HyperBrite. Maybe you have it set as a startup/exit program somewhere.
  On 5/16/2017 at 3:34 AM, Sasuke2006 said:
im not finding it
Expand
Try checking your startup programs in HyperHQ. If not there maybe search HyperBrite.exe in your HS directory. Tbh I'm not sure what exactly about it may cause that and I could very well be wrong.
Expand
ok yeah i restored all defaults in Hyperbrite.exe and that fixed it.^_^
Expand
  On 5/16/2017 at 4:06 AM, Sasuke2006 said:
Expand
Phew, glad that helped! Were you actually using HyperBrite in a cab or did it just randomly start being weird like that?
I believe there's a decent set of wheels now that's mostly complete. If not there will be by the time I'm done the HS media audit.
