NES Theme Bug?-Solved
demonseed
Hey  Guys
I am not sure if anyone else had a similar issue with the NES theme. But when it loads up it all appears to work, however the boxes to the lower right corner are off centered and half the box is off the screen>?  Is there a way to fix this?
Anyone? I thought last time this happened I had to go into a theme and reconfigure the box locations? I forget how as it's been a long long time.
Sounds like the boxes you are using are the wrong size and you will need to resize them with a program like photosizer.
You should be able to open the theme in hypertheme to figure out the correct dimemsions as far as I know.
Good luck.
Hey,
what theme and part do I edit? I can't remember is it in. Media/main menu?? I forget how to do that.   Seems every time I update my setup on hyper cloud it resets the theme so the boxes are not showing correctly, I have had the issue before and fixed it just can't remember where and what files I did edit.
Ok So I figured out how to fix it. I had to go into media/nintendo/default.zip.. extract it and play with the numbers for the artwork file #4.. all works now!
<Theme>
    <video w="380"
           h="264"
           x="357"
           y="424"
           r="-5"
           rx="0"
           ry="0"
           below="false"
           overlaybelow="false"
           overlayoffsetx="0"
           overlayoffsety="0"
           forceaspect="horizontal"
           time="0.2"
           delay="0"
           bsize="0"
           bsize2="0"
           bsize3="0"
           bcolor="0x000000"
           bcolor2=""
           bcolor3=""
           bshape="false"
           type="fade"
           start="none"
           rest="none"/>
    <artwork1 x="511" y="383" r="0" time="0.5" delay ="0" type="fade" start="none" rest="none"/>
    <artwork2 x="362" y="425" r="-5" time="1" delay ="0" type="fade" start="none" rest="none"/>
    <artwork3 x="734" y="503" r="0" time="0.5" delay ="0" type="none" start="right" rest="none"/>
    <artwork4 x="760" y="520" r="0" time="0.5" delay ="0.3" type="none" start="right" rest="none"/>
</Theme>
