Creezz67 Posted February 11, 2017 Posted February 11, 2017 Hi all, I am trying to load Citra on RocketLauncherUI/Hyperspin but keep getting this error I am using latest RocketLauncher and Hyperspin and also latest Citra emulator I have manually started Citra but it does not create the ini file Where exactly does it create the ini file as it was working fine before, but i had to re-install windows now its not working Citra loads and plays manually, just not through RocketLauncher Any ideas ? Thanks for any info
VoIPTeK Posted February 7, 2019 Posted February 7, 2019 On 2/11/2017 at 4:18 AM, cataclysm67 said: Hi all, I am trying to load Citra on RocketLauncherUI/Hyperspin but keep getting this error I am using latest RocketLauncher and Hyperspin and also latest Citra emulator I have manually started Citra but it does not create the ini file Where exactly does it create the ini file as it was working fine before, but i had to re-install windows now its not working Citra loads and plays manually, just not through RocketLauncher Any ideas ? Thanks for any info 5 5 Did you ever get it working? I have the same issue. I tried newer and older versions of Citra but no dice. Games run just fine in the emulator itself. 2/7/2019 Update: I should have looked elsewhere on the interwebs. I ended up having to get the qt-config.ini file from %appdata%\Citra\config folder then put the .ini file into the working directory Citra is installed.. I.e. C:\Emulators\Citra\nightly-mingw\user\config
