BostonD Posted February 12, 2017 Posted February 12, 2017 I just migrated drives and I've got this wonderful error again and I can't seem to figure out what the issue is. Rocket Launcher gives me the Cannot find GSDX.ini error. I've got pcsx2 running outside of RL, I have the .ini folder renamed to inis and theres a copy of gsdx.ini in the folder. I searched for the answer already and I can't seem to find anything that helps.
RLBradders26 Posted February 13, 2017 Posted February 13, 2017 Does the emulator work outside of hyperspin? If it does its a module setting, check the paths and make sure they are all right. Hope that helps
jfp Posted March 4, 2017 Posted March 4, 2017 Path error setup plugins and bios in pcsx2Sent from my Q718B using Tapatalk
jfp Posted March 4, 2017 Posted March 4, 2017 Path error setup plugins and bios in pcsx2Sent from my Q718B using TapatalkAnd in RL if plugin location is under module global settingSent from my Q718B using Tapatalk
jfp Posted March 4, 2017 Posted March 4, 2017 Pcsx2 throws this error if the wrong shader is selected in the drop down menu as well Sent from my Q718B using Tapatalk
