OnceLer Posted February 15, 2017 Posted February 15, 2017 Please either post links here or msg me with them, I received one but no manual! I have been looking everywhere but everything that I google comes up with reviews and other useless stuff. Thanks
wesfranks Posted February 15, 2017 Posted February 15, 2017 http://www.supremefactory.com/cgi-bin/supreme/ministore.pl?function=details&suche=cn-ps4-010086&cat=PLAYSTATION - PS 3 ACCESSORIES Firmware Updates for the MagCube to connect to PC on that site, but be careful updating due to possible issues with firmware. Also, Amazon reviews has additional info such as: The bad: - Although the calibration is one of the simplest I have ever seen, the GUN needs recalibration every 10 seconds. If you do not, you can still use it but you may end up shooting at the ceiling to be shooting your opponent on screen. What I mean is that you remain at all time in control of the cursor since your MAG II works as a mouse. The calibration works to let you point your MAG where the mouse cursor is supposed to be and align the movements with it. - You cannot remap the buttons. I would have loved to reassign the buttons on the MAG but I have not found any way to do so. and Cons: -After 30 or so seconds of play, or quick movements, the gun will drift, causing your crosshair to be in a position that isn't lined up with the gun. This however is fixed within 1-2 seconds of holding the orange calibration button and realigning the gun with the reticule. -At about 180 degrees, the tracking seems to bug and it will cause your view to jump. Can be avoided with semi-frequent taps of the calibration button -The 1:1 tracking mode, which i used for my HL2 experience, forced the gun into a "turbo" mode with no option to turn off, which was a mild inconvenience. and MAG II Button Remap mode: Hold the Yellow + START + SELECT buttons at the same time for 2 seconds. The MAG II GUN will enter Customized Button mode (Power ring flashing). Press together a pair of buttons you want to swap. (you can press another pair if you want to swap another pair) Press the START + SELECT buttons together again for 2 seconds. When the power indicator back to normal, MAG II GUN exited the Custom Button mode.
wesfranks Posted February 15, 2017 Posted February 15, 2017 Sorry about the code box formatting. Tried to adjust, but it wasn't playing nice.
wesfranks Posted February 15, 2017 Posted February 15, 2017 Also, this amazing human being with some uummmmmm............ info that probably won't help, but might.
OnceLer Posted February 15, 2017 Author Posted February 15, 2017 Thank you I've tried flashing them in Windows xp,7, 8.1 and none of them will flash it- I click on reconnect and it says device found but when I click on auto or write it says device not found. What I need is to know what positions the wheel should be in and what the default configuration for the buttons are. Does anyone have any information
