JoeBlow42069 Posted April 9, 2014 Posted April 9, 2014 When I launch Mame .150 from HS, the game loads as normal for about a second, but then HS comes to the front and forces Mame behind. Mame is still running in the background unable to be seen. None of my other emulators do this. Any suggestions?
rfancella Posted April 9, 2014 Posted April 9, 2014 JoeBlow42069 said: When I launch Mame .150 from HS, the game loads as normal for about a second, but then HS comes to the front and forces Mame behind. Mame is still running in the background unable to be seen. None of my other emulators do this. Any suggestions? Try this method for search. Open a google search page and put this in the search: site:hyperspin-fe.com Mame launching behind hyperspin I don't remember the exact post, but i'm sure your answer is in there somewhere. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
KrillCaz Posted April 9, 2014 Posted April 9, 2014 I have this issue with "fushion" sometimes. I have no idea why this happens.
yashijoe Posted April 9, 2014 Posted April 9, 2014 JoeBlow42069 said: When I launch Mame .150 from HS, the game loads as normal for about a second, but then HS comes to the front and forces Mame behind. Mame is still running in the background unable to be seen. None of my other emulators do this. Any suggestions? Try following ghutch92 tip: http://www.hyperspin-fe.com/forum/showthread.php?30805-HyperLaunch-v3-0-1-1-Update&p=299513&viewfull=1#post299513
JoeBlow42069 Posted April 11, 2014 Author Posted April 11, 2014 In the log viewer what severity level should I choose? The HLHQ docs says set it to troubleshooting, but I don't see that option with HL v.3.0.1.1 HLHQ v.1.0.13.0. edit* Oops, i was looking in the wrong tab. Needed to select Global>General Settings>Hyperlaunch>Logger.
JoeBlow42069 Posted April 12, 2014 Author Posted April 12, 2014 After reading the HL troubleshooting guide again I tried setting all the Mame desktop hide options to false. Looks like it fixed the problem:)
