Loss of controls-Xbox 360 Gamepad
demonseed
Hey
So I have been playing a lot of emulators on HS lately and noticed a issue.  I will be in a game menu scrolling along then the controls suddenly stop working?  I try the keyboard and it too stops working.. only way to fix it is to Ctrl+alt+delete and close HS and re open it?  Is this a glitch? Can it be fixed?
I should have mentioned that I did try alt and tab but it did nothing.  Was just playing and it did it again. Went into Menu/Genesis all worked fine.. played for 30 mins, exited back to menu it worked for a second then all controls stopped. The xbox controller does nothing and the keyboard does nothing. CHecking Alt Tab and only two things are running, HS and joy2key.  Only way to fix it is to CTRL+ALT+Delete.>??
Ok I did some testing... I ran HS with just my Key board and it seems to work...... ???
Is it an official Xbox360 controller.. Cause iv had a similar issue using a ps3 controller set up as an xbox360 controller..
On February 22, 2017 at 8:18 AM, demonseed said:
If I turn on logging will that show the issue?
It is an official xbox wireless game pad.  Funny thing I restarted the computer and tried again it appears to work however I haven't tried playing a longer game, I noticed it stopped working if I was of the menu and in. The emulator for a longer period of time?? I will do some more testing to see see
