RocketLauncher not detecting roms
SirWolf
Hello. Im currently trying configure nintendo 64 roms on rocket launcher but it isnt working.
It only detects 2 of 303 roms and i have 472.
I have all the extensions that i need. And the games that have been detected have same extensions as the other ones, idk why they are detected and the other aren't
Here is a screenshot:
Hope You can help me..
----^ what he said.
need to download the XML/DAT And clrmame or a likewise program to rename your set!
hit up YouTube for further info and search.  It's easy once you understand it!
Okay, i used don's hyperspin tools and it works, but now i have another problem.
When i use load the games on rocketlauncher with retroarch only a porcion of the game video shows.
Hope you can help me.
You've got bezels turned on.
in RL, select whatever system
you will see a tab called bezels
click it - make sure at the top i think it says "enabled" make sure it says "false"
you can also do the same under "global" tab, that will be every system wide.
i think there is a setting in global or system selected, called fullscree , make sure that's set to true.
i know In retroarch there's a full screen option.
Did you save your current "working" config in retroarch before you exit it?
get retroarch working the way you want it, save your configure in RA, quit it, then reopen it.  See if the setup is the same.
make sure RA is saving your config properly.then move to HS.  Always dial in your emulator first before adding to hS, makes troubleshooting way easier .
try that.
I did save the config with my settings. I just dont know how to replace the settings that i saved to hyperspin. When I did custom settings in retroarch folder it worked. But idk how to save the settings to "mupen64"
Ok.
what controller are you using? And are you using the same controller for all the emulators in RA?
i ask because I did a much easier setup for a lot of systems in RA without opening retroarch and I can tell you how.
I managed to figure it out. Just did retroarch config and renamed the new file to Nintendo 64 and deleted the old one. Thank for all the Help
