amnshall Posted March 12, 2017 Posted March 12, 2017 Hi all, This might be a really dumb problem/question, but long story short, my hyperspin/rocket luancher was working until today and now I can't get anything to launch from hyperspin. It will launch from the Rocket Launcher UI and I've double checked my settings.ini on rocket launcher and settings in the UI. Nothing has changed but nothing will load. Has anyone ever come across this problem?
amnshall Posted March 12, 2017 Author Posted March 12, 2017 Both are set to run as admin and my antivirus exceptions are set up. I am probably going to attempt to start from scratch, but I'm hoping there might be something I missed.
jfp Posted March 12, 2017 Posted March 12, 2017 If you open the emulator directly does it throw a security warning?(uncheck always ask) That's very annoying but usually makes hyperspin hang tho
woosdom Posted March 15, 2017 Posted March 15, 2017 i had a similar issue and it had to do with the emulator not finding the correct ctrlr file. i was setting up a new controller config on a MAME build saved under a different drive. once i finished i changed the name but forgot to update the ini file. MAME was searching for the wrong file and it was giving me the same type of log date you are showing. everything looked to be setup correctly, but the games wouldn't start. just a thought. hope you get it working soon.
amnshall Posted March 17, 2017 Author Posted March 17, 2017 I just ended up re-downloading hyperspin/hyperlaunch and starting from scratch. Everything works fine now, maybe something in the old build was causing issues? I appreciate the help and troubleshooting from everyone.
