TheMadHatter Posted March 13, 2017 Posted March 13, 2017 Ok. So I am familiar with where I can manually go into ePSXe and select the memory cards i want to use for a specific game im playing. Like if im about to play FF7 i can select the memory cards .MCR files though the config. But i wanted to know is there a way to have ePSXe do that manually so that i dont have to hop out of fullscreen mode and reload memory cards each time i change a game in my hyperspin set up.
BATTLEDONKEY Posted March 13, 2017 Posted March 13, 2017 I'm pretty sure there is a per game memory card setting either in epsxe directly or in rocketlauncher under the epsxe modules settings
TheMadHatter Posted March 13, 2017 Author Posted March 13, 2017 On 3/13/2017 at 10:48 AM, BATTLEDONKEY said: I'm pretty sure there is a per game memory card setting either in epsxe directly or in rocketlauncher under the epsxe modules settings Expand Sweet i think i got it ima test it out now thanks for the heads up. Yep it works now just had to change the modules. Thanks again! even found another fix for a different problem i had lol
