RLBradders26 Posted March 16, 2017 Posted March 16, 2017 Hey Guys, So I have triforce setup and working perfectly, for triforce to work you need to set port-1 to AM-Baseboard. If i set this then dolphin 5.0 also changes its settings to the same thing meaning the gamecube controller 1 no longer works and I have to change this back each manually each time i change between the two. Does anybody know a way to automate this?
Dime333 Posted March 16, 2017 Posted March 16, 2017 Create an empty file called portable.txt and just put it in the triforce emu folder. That will fix your issue.
RLBradders26 Posted March 16, 2017 Author Posted March 16, 2017 4 hours ago, Dime333 said: Create an empty file called portable.txt and just put it in the triforce emu folder. That will fix your issue. Thanks dude that worked perfectly, for anybody who reads this now or in the future. Adding the portable.txt file in the same folder as the emulator changes the global directory to a local directory this means triforce now has a separate user profile within its own folder. You will need to copy and paste some settings across if you already had the games working before hand.
