metroplex2k7 Posted May 28, 2017 Posted May 28, 2017 Ok, so there are only 3 systems left I want to get, but the main one I'm having the hardest time with, and that's Daphne. Has anyone gotten Daphne working on their HyperSpin? I tried researching, and the only option I could find was Daphne for Dummies, which downloads the files you need when you select the game (or something like that). So, does anyone have it setup nice on HS? Thanks for any help.
rastan Posted June 5, 2017 Posted June 5, 2017 I have Daphne and Daphne Singe setup... Daphne for the dragon's lair type games and Singe for the American Laser type games. I set it up a long time ago and can't really remember much except the tutorials were confusing and some of the information that they said was needed I probably skipped over and got it working anyways.. (most likely older tutorials). One quick question.. have you gotten it to work outside of HS? that's always a good step in the right direction.
gigapig Posted June 5, 2017 Posted June 5, 2017 No the rules do not allow, hence I had to edit your post. The non Digital Leisure games are easy to get via Daphne as it should download them via torrent for you. The DL games however will require you to have either the disc's or an iso of the game mounted in Daemon tools. Once mounted or disc inserted Daphne will need to verify the disc so you can then play it. Wallmachine posted the best guide by rfancella.
metroplex2k7 Posted June 6, 2017 Author Posted June 6, 2017 I appreciate the help. I did find an iso of DL, DL2, & SA. But I also found a site with all the .mpegs, so, I'm hoping to just get it running using the mpegs/framefiles method if possible. I'll keep you guys posted, it'll be a project for another day, Im still trying to get these last remaining systems working.
rastan Posted June 7, 2017 Posted June 7, 2017 I still can't get the controls to work for Dragon's Lair.. all my other games work fine.. Dragon's Lair no matter how many times I set the coin and start... I can't seem to get the game to work... gonna figure it out one day.
gigapig Posted June 7, 2017 Posted June 7, 2017 On 6/7/2017 at 4:25 AM, rastan said: I still can't get the controls to work for Dragon's Lair.. all my other games work fine.. Dragon's Lair no matter how many times I set the coin and start... I can't seem to get the game to work... gonna figure it out one day. Expand Did you read the module notes ? There is a method to set controls in there.
rastan Posted June 9, 2017 Posted June 9, 2017 On 6/7/2017 at 7:33 AM, gigapig said: Did you read the module notes ? There is a method to set controls in there. Expand Never bothered to read the module... but I will now. all the other games work fine..
