Espgod Posted June 2, 2017 Posted June 2, 2017 Hey everyone, I'm trying to add the translated version of Mother 3 to my Gameboy Advance XML. I've opened the XML with Notepad++ and copied the format to a different game and renamed the name as what matches the rom file but it still won't show up in the library. Does the CRC have something to do with it? I am totally stumped and would love a bit of help.
Avar Posted June 2, 2017 Posted June 2, 2017 Negative. all that matters as long as the format is correct is that the game name matches the rom name. Do you maybe have "wheels only" toggled in HyperHQ? And are you putting the new entry in its proper place in alphabetical order?
Espgod Posted June 2, 2017 Author Posted June 2, 2017 I didn't have it in the right alphabetical order. Got it all straightened out. Thank you much!
Kondorito Posted June 2, 2017 Posted June 2, 2017 1 hour ago, Avar said: Negative. all that matters as long as the format is correct is that the game name matches the rom name. Do you maybe have "wheels only" toggled in HyperHQ? And are you putting the new entry in its proper place in alphabetical order? Ok, so this is new to me If I add an entry to the XML, let's say at the bottom of it, will it: A ) Show up in alphabetical order in HS B ) Show up in the XML order in HS C) Won't show up at all ?
Kondorito Posted June 2, 2017 Posted June 2, 2017 7 minutes ago, agent47 said: From what I recall, A. There is an option in HyperHQ for each system I believe is called "Use xml indices" which when enabled will display the games in the order they are in the xml. Cheers agent. That's what I thought. It threw me off Espgod response about the alphabetical order in XML that fixed his situation.
