Games wont launch
CAS0311
I can launch my games in RL and through the emulator itself. However, when I try and launch the game in hyperspin itself, nothing happens. I have watched the install, emulator and adding roms tutorials more times than I can count. I am sure I am missing something very simple. Advice?
Could be a few things, you may not have set the path to Rocketlauncher in the Hyperspin settings.ini found in the settings folder.
Could be this is caused by having wheel filters checked in HyperHQ or if Rocketlauncher is still running in the system tray.
I apologize for my ignorance, but where and what is the log.txt file located. Also gigapig I will go address those other issues right now should they exist.
figured it out. Here you go
03:12:38 PM |  HyperSpin Started
03:12:38 PM |  Going FullScreen
03:12:38 PM |  Checking for updates
03:12:38 PM |  Update Check Complete
03:12:38 PM |  Startup program unavailable
03:12:38 PM |  Playing intro video
03:12:43 PM |  Error intializing joysticks
03:12:43 PM |  Menu Mode is multi
03:12:43 PM |  Loading Main Menu.xml
03:12:43 PM |  Main Menu.xml successfully loaded
03:12:44 PM |  Main Menu wheel loaded successfully
03:12:45 PM |  Loading Nintendo Entertainment System.xml
03:12:45 PM |  Main Menu.xml successfully loaded
03:12:46 PM |  Nintendo Entertainment System wheel loaded successfully
03:12:48 PM |  Launching Game
03:12:48 PM |  Using HyperLaunch
03:12:48 PM |  Getting Launcher path
03:12:48 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
03:12:48 PM |  Launcher located at C:\HyperSpin\HyperLaunch.exe
03:12:48 PM |  Running Launcher
03:12:48 PM |  Launcher Command Line is: C:\HyperSpin\HyperLaunch.exe "Nintendo Entertainment System" "10-Yard Fight (USA, Europe)"
03:12:49 PM |  Launching Game
03:12:49 PM |  Using HyperLaunch
03:12:49 PM |  Getting Launcher path
03:12:49 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
03:12:49 PM |  Launcher located at C:\HyperSpin\HyperLaunch.exe
03:12:49 PM |  Running Launcher
03:12:49 PM |  Launcher Command Line is: C:\HyperSpin\HyperLaunch.exe "Nintendo Entertainment System" "10-Yard Fight (USA, Europe)"
03:12:51 PM |  Loading Main Menu.xml
03:12:51 PM |  Main Menu.xml successfully loaded
03:12:52 PM |  Main Menu wheel loaded successfully
03:12:53 PM |  Exit program unavailable
03:12:53 PM |  Quiting Hyperspin
03:12:53 PM |  Bye!
No worries. It's in the root of your HyperSpin folder. Same place as your HyperSpin.exe.
Like I mentiones you have not set the path the Rocketlauncher, yours is trying to use Hyperlaunch.
You need to open the settings.ini and change the path.
Is this the file you are referring to? Am I just supposed to delete Hyperlaunch and replace it with Rocketlauncher? or is it RocketLauncher?
[Hyperlaunch]
Hide_Cursor=false
Fade_In=false
Fade_Out=false
Fade_Color=0x000000
Fade_In_Duration=500
Fade_Out_Duration=500
Fade_In_Delay=0
Keymapper_Enabled=false
Keymapper=
Hide_Desktop=false
Hide_Taskbar=false
CPWizard_Enabled=false
CPWizard_Delay=8000
CPWizard_Params=minimized -timeout 9000
7z_Enabled=false
7z_Extract_Dir=C:\Users\Clayton\AppData\Local\Temp\Hyperspin\
7z_Delete_Temp=true
MultiGame_Enabled=false
MultiGame_Background_Color=FF000000
MultiGame_Side_Padding=0.2
MultiGame_Y_Offset=500
MultiGame_Image_Adjust=1
MultiGame_Font=Arial
MultiGame_Text_1_Options=x10p y30p w80p Centre cBBFFFFFF r4 s100 Bold Italic
MultiGame_Text_1_Text=Please select a game
MultiGame_Text_2_Options=w96p cFFFFFFFF r4 s50 Center Bold Italic
MultiGame_Text_2_Offset=70
MultiGame_Use_Sound=true
MultiGame_Sound_Frequency=300
MultiGame_Exit_Effect=none
MultiGame_Selected_Effect=rotate
MultiGame_Use_Game_Art=false
MultiGame_Art_Folder=Artwork1
[HyperLaunch]
Hide_Cursor=false
Hide_Desktop=false
Hide_Taskbar=false
CPWizard_Delay=8000
Fade_In=false
Fade_Out=false
Fade_Color=0x000000
Fade_In_Delay=0
7z_Enabled=false
7z_Delete_Temp=true
Keymapper=
  On 6/4/2017 at 8:28 PM, CAS0311 said:
I changed the text to RocketLauncher and tried Rocketlauncher as well. The games will not load in Hyperspin
Expand
[Hyperlaunch]
Hide_Cursor=false
Fade_In=false
Fade_Out=false
Fade_Color=0x000000
Fade_In_Delay=0
Keymapper=
Hide_Desktop=false
Hide_Taskbar=false
CPWizard_Delay=8000
7z_Enabled=false
7z_Delete_Temp=true
[HyperLaunch]
Hide_Cursor=false
Hide_Desktop=false
Hide_Taskbar=false
CPWizard_Delay=8000
Fade_In=false
Fade_Out=false
Fade_Color=0x000000
Fade_In_Delay=0
7z_Enabled=false
7z_Delete_Temp=true
Keymapper=
Expand
In your Hyperspin folder there is a "settings" folder, within that there is the settings.ini file, open that in notepad or notepad++ and look for the Hyperlaunch path which is in the first block of text.
You need to change it to where you have the Rocketlauncher exe installed. Only you know this.
Also, that log you posted is from RocketLauncher. To see what's going on we need you to post your :\HyperSpin\log.txt file and preferably your :\HyperSpin\Settings\Settings.ini file as well, as Gigapig said.
Again, thanks to you two so much. I really do appreciate the help. I cannot imagine how many times you have answered these same questions! Is it possible that I improperly merged the 2 systems? Could I even open Hyperspin if I did do that? I had to step away from my set up for a minute. I will post again shortly.
Iunno man but I kinda get the impression you may have skipped some important stuff from the videos and might have made some other random changes trying to fix it :P
If you did put RL and HS together, nothing will work. What I suggest is moving everything you've done to a backup folder then starting from scratch, following the official videos very carefully and pausing as needed as you go. There are a few details in the descriptions as well but the big one, which you already prolly fixed, is making sure your extensions aren't hidden in windows. Just follow along everything exactly as you see it and it will work, and if you ever see anything on your computer that doesn't match what you're seeing in the video at any given stage, it's probably a case of missing a step and if you can't tell what you did feel free to post.
my files do not look like yours on the video. I downloaded all the latest versions. Could that be the problem? Should I install the older versions you have listed in the video?
Everything in the video is the latest version or should be identical to the latest version so if things aren't matching up something's not in the right place. Only time anything'll look different is I think one step on NES setup where I have a few folders Nestopia makes after you run it for the first time. Other than that, everything you see should be essentially identical.
http://www.hyperspin-fe.com/forums/topic/15177-official-hyperspin-tutorials/
