Retrotechy Posted June 7, 2017 Posted June 7, 2017 Sorry to make 2 threads in such a short time. I'm trying to get my hyperspin working on my laptop, I've copied it over from my PC. The laptop is very low spec, so it's running like a dog. Is there a way to disable the themes? I tried deleting them, but hyperspin showed nothing at all afterwards.
Avar Posted June 7, 2017 Posted June 7, 2017 So you can open up any theme XML to check out its insides and it's pretty intuitive which things are which in there. Basically the theme is the code that tells HS what assets to look for, while also containing some of those assets. You always need some sort of theme there but you could run -only- the default themes, which are typically less graphic intensive. I suggest going into HyperHQ -> Main Settings -> Optimizer and adjusting the levels there instead though until your system runs fine.
Retrotechy Posted June 8, 2017 Author Posted June 8, 2017 Thanks for the reply. How do I get the default themes running again?
KlopjerO Posted June 8, 2017 Posted June 8, 2017 by downloading and placing them in their respective folders. Main menu themes go into the main menu themes folder, default systems themes should be placed in [system]\themes folder. | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
