Martin0037 Posted June 12, 2017 Posted June 12, 2017 Solved I use led blinky, all works ok, apart from one small issue.. when people play on my cab, they tend to press the start game button (enter) to launch a game several times instead of just the once! This drives me mad, as then, LED Blinky does it's usual flashing sequence and speaks the primary controls as it does ok as the rom loads, but because they've pressed the start button loads of times LED Blinky does this over and over again, however many times they've pressed it! Has anyone had this? And if so, any idea how I stop it? Ice contaced the LED Blinky support and they said to look at posting something on the HS forum as they've got no idea. - I've now solved this. Anyone having this trouble do the following... in the LED blinky settings, change the "game start delay" to 10 and tick the "all LEDs off" box. Now, no matter how many times you hit the game launch button, the leds go out and led blinky speaks the controls - just the once! Not multiple times. Hope that hat helps someone else.
