dibs Posted June 29, 2017 Posted June 29, 2017 I'm having a really annoying issue I just can't figure out. I have my trackball setup to spin through system wheels and then my buttons wired to my u360 joysticks to advance through the wheels and select games. I have 3 systems so far, MAME, SNES, AND NES. Everything works great for MAME and SNES when selecting and backing out of wheels using button 1 and 2, but for some strange reason it is really difficult getting the joystick buttons to advance only when trying to select the NES system. I have to button mash for a good 10 or 30 seconds until it finally advances to the games. Sometimes I need to back out with the keyboard and go back in to get it to work. After it finally does get to the games, selecting a game with the button works right away. It is also important to note that using "enter" on the keyboard works right away with no problem. Let me know what you think, thanks!
Metalzoic Posted June 30, 2017 Posted June 30, 2017 You're using a trackball in the HS front end? Do you have Trackball and Joysticks enabled in HyperHQ? If so you might try un-enabling them as joysticks and trackballs don't work properly with HS and maybe that's causing your issue. This could maybe also be caused not by the buttons, trackball or sticks, but maybe you have a mistake in your NES system. Having a letter in the wrong case ( such as the Mario wheel art upper case, but the rom mario lower case) won't work correctly, but sometimes it can work anyway and give sporadic results like yours. The spelling including upper/lower case must match 100% exactly for meida, themes, wheels, roms, database etc... Not saying that's it, just spitballing.
