mothergoose729 Posted July 2, 2017 Posted July 2, 2017 A lot of cores in retroarch, in particular MESS, require special command line parameters in order to work right. I was wondering how you can configure all that in rocket launcher? Is it possible to pass in custom command line arguments when you load a particular core?
thatman84 Posted July 2, 2017 Posted July 2, 2017 I'm not sure on retroarch mess in RocketLauncher but unless your hell bent on it just use the standalone MAME emulator, it's a Lon easier beast to tame Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
steptoeUK Posted July 7, 2017 Posted July 7, 2017 I've had aggrevation getting MESS to work in RetroArch and also the latest MAME/MESS builds as HyperSpin thought it was trying to run MAME ROMs so failed I knew the MESS is still supported as a separate issue so hunted them down, installed from here3 and changed the pointers in the global emulators.ini and MESS worked first time. On every MESS system I've had problems with they now worked first time every time Plus its the latest 0.187 MESS release, bear in mind this is MESS only. MAME is also there but they are separate entitities http://messui.1emulation.com/
