mightydimo Posted July 12, 2017 Share Posted July 12, 2017 In the available systems there are probably 100 or so. I dont need them all but i need ones like Atari 2600 etc which are not recognised or "not linked" to the program. How do i get this fixed? I understand i need to get .xml database files which i have done but i also need .ini files? Where i get them? Thanks in advance. Link to comment Share on other sites More sharing options...
esmith13 Posted July 28, 2017 Share Posted July 28, 2017 same issue here. I can only sync the systems that are pre-linked. I went to hyperlist and downloaded the databases for other systems (like atari 2600) and put the XMLs in properly named folders in the Databases folder. I closed and relaunched HyperSync Cloud and I still cannot link Atari 2600 (and others) as the pull down list of what to link to still does not show any of my newly added databases. What am I doing wrong??? Is it because hyperbase is down or am I just an idiot? Thanks in advance for any help. Link to comment Share on other sites More sharing options...
Dilated18 Posted July 28, 2017 Share Posted July 28, 2017 If you dont see in hypersync list then there prob is no art available throught it for that system. I do no there is box and cart available for 2600 but remember that people update sync on there own time so they cant always have it rdy with all the new stuff Link to comment Share on other sites More sharing options...
esmith13 Posted July 28, 2017 Share Posted July 28, 2017 Just now, Bain408 said: If you dont see in hypersync list then there prob is no art available throught it for that system. I do no there is box and cart available for 2600 but remember that people update sync on there own time so they cant always have it rdy with all the new stuff The system is already in the list on the left but it cannot be linked as the system is not in the pull down list on the top right. Link to comment Share on other sites More sharing options...
Dilated18 Posted July 28, 2017 Share Posted July 28, 2017 Ahh, then have you checked that u named the system exactly the same ? and aslo make sure sync have the rite paths to yur HS folders Link to comment Share on other sites More sharing options...
esmith13 Posted July 28, 2017 Share Posted July 28, 2017 2 minutes ago, Bain408 said: Ahh, then have you checked that u named the system exactly the same ? and aslo make sure sync have the rite paths to yur HS folders Both are correct. The folder I created in Databases is named exactly as the XML itself I got from HyperList (just the the ones included in the basic install) and the Sync path is correct. I double checked but also I can sync all the built-in systems correctly too. It is just not seeing my manually added database for some reason... Link to comment Share on other sites More sharing options...
Dilated18 Posted July 28, 2017 Share Posted July 28, 2017 1 minute ago, esmith13 said: The folder I created in Databases is named exactly as the XML itself I got from HyperList Ok did u manually creat this folder or did u add the system through hyperhq? Link to comment Share on other sites More sharing options...
esmith13 Posted July 28, 2017 Share Posted July 28, 2017 I manually created a folder with the proper name in the Databases folder. I put the official XML from hyperlist in there (which is also named the same). Then I relaunched HyperCloud Sync. EDIT: YOU ARE THE MAN!!! I forgot about HyperHQ!!!! I never created the wheel in the main menu wizard!!!!! It's working fine now, syncing Atari 2600 media files as I type this. Thank you so much!!! I've been out of the loop a bit too long. My last HyperSpin build from scratch was in 2014! Thanks again!!! Link to comment Share on other sites More sharing options...
Dilated18 Posted July 28, 2017 Share Posted July 28, 2017 delete the folders and items u added and add the system through hyperhq. U still need a system ini file for the system and HQ will do that for u. Prob y it doesnt see it Link to comment Share on other sites More sharing options...
Dilated18 Posted July 28, 2017 Share Posted July 28, 2017 or leave the folders, dont think it will hurt Link to comment Share on other sites More sharing options...
richie_jones Posted October 5, 2017 Share Posted October 5, 2017 you choose your system on the right hand side you want to associate it with...then press set Link to comment Share on other sites More sharing options...
