hyperspin not responding to joystick
ace5112
hello everyone! I been trying to troubleshoot this issue for the last couple of days and it's driving me crazy. I was trying to update the hyperspin software and now hyperspin is not responding to my joystick input. everything else works; joytokey is registering my joystick input. what I do notice is that when I open a older hyperspin 1.33 in a separate folder on my desktop the joystick is able to control that hyperspin 1.33. when I open the main hyperspin 1.44 located on my D drive the joystick does not register with that version. I checked HyperHQ as well as HyperLaunch to see if somehow joytostick was pointing to 1.33 instead of 1.44 but didn't see anything. is there a script somewhere that I have to change tell joytostick to control Hyperspin 1.44 instead of 1..33. thanks!
Are you sure you have the Joysticks disabled in HyperHQ (enabled box un-checked). Joysticks, trackballs and spinners don't work right in HS so if you have them enabled it causes problems.
Yes I made sure the boxes are unchecked. the weird thing is the joystick is controlling the older hyperspin fine when I launch it but when I launch the newer hyperspin the joystick no longer works. if I had to guess it might be a script somewhere that points the joytostick to the older hyperspin version, I just can't find the script and change it to point to the newer hyperspin.
Thanks for the help!
FINALLY! after week of going through all the possible settings for hyperspin, hyperlaunch, hyperHQ, and joytostick I finally discovered for some reason under HyperSpin properties when you right click on the icon the "Full Control" was disabled under "security" section. after setting it back to "Allow" it works again. Posting in case others have this issues.
2 hours ago, ace5112 said:
FINALLY! after week of going through all the possible settings for hyperspin, hyperlaunch, hyperHQ, and joytostick I finally discovered for some reason under HyperSpin properties when you right click on the icon the "Full Control" was disabled under "security" section. after setting it back to "Allow" I works again. Posting in case others have this issues.
You're talking about if you right-click directly on the Hyperspin.exe?
