Hibernate instead of shutdown with hyperspin running!
nicco84
I can't test this as I'm at work, but I think if you create a batch file containing the hibernate command (shutdown /h) then you could use a keyboard shortcut to execute this while HyperSpin is running.
Thnx agrajag, I already try this way but not always the buttons combo work when hyperspin is active.
I think is better go inside the code of hyperHQ and change the shutdown method... But I don't know how! :(
This could be a great tweak in next release
I have set my Windows OS to hibernate after so many minutes of inactivity. It seems to work fine. I do plan to setup a button combo on my cab to force a hibernate, but haven't done so yet.
