Rowr14 Posted September 21, 2017 Posted September 21, 2017 Can anyone tell me if it is possible to point Rlaunchers Pause to Hyperspins media folders? The idea being that it halves disc space in the sense all my artwork and videos aren't doubled up and saves time in me not having to go through and copy everything into the rlauncher media file. I'm sure someone must of asked this before, I've done my best to search online and these forums. I found one old thread online which mentioned that this happened automatically in some older version? Or perhaps it should happen automatically and i've missed a setting somewhere. There is also a mention that this should happen with the plugin settings though i'm not seeing anything obvious in RLauncherUI settings. Any help is appreciated as I don't really want to proceed with setting up media in Rlauncher until I can work out if it's possible or not.
Rowr14 Posted September 22, 2017 Author Posted September 22, 2017 It clearly shows in the rocketlauncherui plugins menu that it will draw from those folders so I guess it's just not working for me for some reason. Edit- Ok it works if I launch the game through rocketlauncherui but not if selected through hyperspin, so I guess i'll keep googling. Sorry for the thread but I'm finding it difficult to find much regarding pause online so it makes it difficult to know if something should be working in the case that it isn't
Rowr14 Posted September 22, 2017 Author Posted September 22, 2017 Ok It was just a case of my "Default Frontend Path" in the rocketlauncherui general settings pointing to rocketlauncherui instead of hyperspin. Not sure if I missed that somehow or if something I have done changed it back at some point. For anyone else the common solution Is you need the default plugin set to hyperspin in Base settings in general settings and check your rocketlauncherui>frontends and ensure hyperspin is checked as default there also.
Lewist Posted September 22, 2017 Posted September 22, 2017 If using Windows, I would suggest using symbolic links in the appropriate rocket launcher folder and pointing to the the appropriate image files. Google "symbolic links"
