luc2010 Posted October 22, 2017 Posted October 22, 2017 I am new to Hyperspin. I currently have V1.3.2.0 setup with all systems and roms. I started testing to make sure everything is working. Well, it is not hence why I am posting in here. I got Rocketlauncher to successfully test super nes games and they load and play. The issue is with Hyperspin. I get to the point of the screen loading complete and then it transitions to a black screen and I can move the mouse and that's it. I have to press Escape key to get out of the black screen. It seems to be an issue between Hyperspin not directly communicating with RocketLaunch or something along those lines. The log is posted below. 03:01:07 PM | HyperSpin Started 03:01:07 PM | Going FullScreen 03:01:07 PM | Checking for updates 03:01:07 PM | Update Check Complete 03:01:07 PM | Startup program unavailable 03:01:07 PM | Error intializing joysticks 03:01:07 PM | Menu Mode is multi 03:01:07 PM | Loading Main Menu.xml 03:01:07 PM | Main Menu.xml successfully loaded 03:01:07 PM | Main Menu wheel loaded successfully 03:01:10 PM | Loading Super Nintendo Entertainment System.xml 03:01:10 PM | Main Menu.xml successfully loaded 03:01:11 PM | Super Nintendo Entertainment System wheel loaded successfully 03:01:15 PM | Launching Game 03:01:15 PM | Not using HyperLaunch 03:01:15 PM | Running in normal rom mode 03:01:15 PM | Excecutable is RocketLauncher.exe 03:01:15 PM | Command Line is: "G:\Hyperspin\RocketLauncher\RocketLauncher.exe" "G:\Hyperspin\Games\Nintendo - Super Nintendo Entertainment System\ActRaiser (USA).zip,7z,sfc" "Super Nintendo Entertainment System" -f "G:\HyperSpin\HyperSpin.exe" -p "HyperSpin" 03:01:41 PM | Loading Main Menu.xml 03:01:41 PM | Main Menu.xml successfully loaded 03:01:41 PM | Main Menu wheel loaded successfully 03:01:43 PM | Exit program unavailable 03:01:43 PM | Quiting Hyperspin 03:01:43 PM | Bye! Below is the Super Nes ini file settings: [exe info] path=G:\Hyperspin\RocketLauncher\ rompath=G:\Hyperspin\Games\Nintendo - Super Nintendo Entertainment System\ userompath=true exe=RocketLauncher.exe romextension=zip,7z,sfc parameters="Super Nintendo Entertainment System" -f "G:\HyperSpin\HyperSpin.exe" -p "HyperSpin" searchsubfolders=false pcgame=false winstate=NORMAL hyperlaunch=false
thatman84 Posted October 22, 2017 Posted October 22, 2017 Not sure about you setup but Hyperspin is on v1.4 now, Check these videos to get straightened out Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
luc2010 Posted October 27, 2017 Author Posted October 27, 2017 Quote OK, so I installed v1.4. I am testing it with Zsnes using the module Zsnes151. I can get Rocket Launcher to test the game and run it. When I test it with HyperLauncher I get error missing Super Nintendo Entertainment .AHK file. I renamed the Super Nes Znes module to just Super Nintendo Entertainment System.ahk. Then when I run it, I get a black screen. If I run Hyperspin it loads Znes, but I have to manually load the rom. I feel I am pretty close to resolving this, but now need to know how to get the roms to load when using the frontend. I am using Widnows 10 Pro 64 Bit version. Thanks
