Sharp X68000 - Which set to use?
RyuHayabusa78
Hi, just wondering which set to use for Sharp X68000 to match the Hyperspin xml file. I have a set that has over 3,000 files and 99% of the names are different than the ones used in the Hyperspin xml file, meaning I can't get hardly any of the video snaps, logos, etc to work. Not asking for roms, just wondering which set I should be looking for, as in naming convention like Good Tools, Tosec, etc. Thanks
On ‎11‎/‎18‎/‎2017 at 12:25 AM, dragon57 said:
Why don't you just use Don's Renamer to rename your files per the xml data?
Thanks! I did that and now I've got the video snaps and game logos working, at least partially. Is there any easy way to get the video snaps and game logos to work for each disk in the wheel? For instance, a game like Daimakaimura has multiple discs. Is there a way to get the video snaps and logos to work for each disk on the wheel without having to create separate copies of them for each disk and rename them all for each disk?
  • 1 year later...
The problem with using that is that the HS XML is a mess and the game names are super weird. It's likely many of your games were renamed improperly.
